Kernel error. My system freezes when shutting down
I have a problem when I want to shut down my notebook; it just freezes. I discovered the following error with systemctl:
Mar 24 16:44:43 pascal-notebook-manjaro kernel: BUG: kernel NULL pointer dereference, address: 000000000000001a
Is this a known bug in the kernel at the moment? I’m using Kernel 6.6.19-1-MANJARO.
It would probably be helpful to include system info, ex;
inxi -Farzy
Also here is the guide for how to format code, etc;
Unless you need 6.6 for some reason, I would suggest running 6.1 or 5.15
inxi -Farzy                                                      ✔
  Kernel: 6.6.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=3fe1158e-8862-41e2-9542-867627548ada rw quiet splash apparmor=1
    security=apparmor udev.log_priority=3 nvidia_drm.modeset=1
  Desktop: GNOME v: 45.4 tk: GTK v: 3.24.41 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 45.0.1 Distro: Manjaro
    base: Arch Linux
  Type: Laptop System: TUXEDO product: TUXEDO InfinityBook Pro Gen8 (MK2)
    v: Standard serial: <superuser required>
  Mobo: NB02 model: PH6PG01_PH6PG71 v: Standard serial: <superuser required>
    part-nu: IBP1XI08MK2 uuid: <superuser required> UEFI: American Megatrends
    LLC. v: N.1.10A07 date: 11/16/2023
  ID-1: BAT0 charge: 82.1 Wh (100.0%) condition: 82.1/82.1 Wh (100.0%)
    volts: 17.3 min: 15.5 model: standard type: Li-ion serial: <filter>
    status: full
  Device-1: hidpp_battery_0 model: Logitech Marathon Mouse/Performance Plus
    M705 serial: <filter> charge: 55% (should be ignored) rechargeable: yes
    status: discharging
  Info: model: 13th Gen Intel Core i7-13700H bits: 64 type: MST AMCP
    arch: Raptor Lake gen: core 13 level: v3 note: check built: 2022+
    process: Intel 7 (10nm) family: 6 model-id: 0xBA (186) stepping: 2
    microcode: 0x411C
  Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
    cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
    L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
  Speed (MHz): avg: 2149 high: 4590 min/max: 400/4800:5000:3700 scaling:
    driver: intel_pstate governor: powersave cores: 1: 4590 2: 2688 3: 1132
    4: 400 5: 400 6: 400 7: 2590 8: 3825 9: 1565 10: 400 11: 400 12: 2800
    13: 2663 14: 3496 15: 3539 16: 2100 17: 2897 18: 3213 19: 3489 20: 400
    bogomips: 116780
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
    RSB filling, PBRSB-eIBRS: SW sequence
  Device-1: Intel Raptor Lake-P [Iris Xe Graphics] vendor: Tongfang Hongkong
    driver: i915 v: kernel arch: Gen-13 process: Intel 7 (10nm) built: 2022+
    ports: active: eDP-1 empty: DP-2,DP-3,HDMI-A-1 bus-ID: 00:02.0
    chip-ID: 8086:a7a0 class-ID: 0300
  Device-2: NVIDIA AD107M [GeForce RTX 4060 Max-Q / Mobile]
    vendor: Tongfang Hongkong driver: nvidia v: 550.54.14
    alternate: nouveau,nvidia_drm non-free: 545.xx+
    status: current (as of 2024-02) arch: Lovelace code: AD1xx
    process: TSMC n4 (5nm) built: 2022+ pcie: gen: 1 speed: 2.5 GT/s lanes: 8
    link-max: gen: 4 speed: 16 GT/s ports: active: none empty: DP-1
    bus-ID: 01:00.0 chip-ID: 10de:28a0 class-ID: 0300
  Device-3: SunplusIT FHD Webcam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:3 chip-ID: 2b7e:c757
  Display: wayland server: X.org v: 1.21.1.11 with: Xwayland v: 23.2.4
    compositor: gnome-shell driver: X: loaded: modesetting,nvidia
    alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915 display-ID: 0
  Monitor-1: eDP-1 model: BOE Display 0x0a3b built: 2021 res: 2560x1600
    dpi: 189 gamma: 1.2 size: 344x215mm (13.54x8.46") diag: 406mm (16")
    ratio: 16:10 modes: 2560x1600
    drv: nvidia device: 2 drv: iris device: 3 drv: swrast gbm: drv: nvidia
    surfaceless: drv: nvidia wayland: drv: iris x11: drv: iris
    inactive: device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.0.2-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (RPL-P)
    device-ID: 8086:a7a0 memory: 30.36 GiB unified: yes display-ID: :0.0
  API: Vulkan v: 1.3.279 layers: 11 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 4060 Laptop GPU driver: nvidia v: 550.54.14
    device-ID: 10de:28a0 surfaces: xcb,xlib,wayland
  Device-1: Intel Raptor Lake-P/U/H cAVS vendor: Tongfang Hongkong
    driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
    bus-ID: 00:1f.3 chip-ID: 8086:51ca class-ID: 0403
  Device-2: NVIDIA vendor: Tongfang Hongkong driver: snd_hda_intel v: kernel
    pcie: gen: 4 speed: 16 GT/s lanes: 8 bus-ID: 01:00.1 chip-ID: 10de:22be
    class-ID: 0403
  API: ALSA v: k6.6.19-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.3 status: off tools: pw-cli
  Server-3: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
  Device-1: Intel Raptor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:51f1 class-ID: 0280
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0026
    class-ID: e001
  Local Storage: total: 931.51 GiB used: 384.02 GiB (41.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 1TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 3B4QFXO7 temp: 23.9 C
    scheme: GPT
  ID-1: / raw-size: 585.94 GiB size: 575.67 GiB (98.25%) used: 384 GiB (66.7%)
    fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
    used: 26.6 MiB (27.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-1: swap-1 type: file size: 2 GiB used: 0 KiB (0.0%) priority: -2
    file: /swapfile
  System Temperatures: cpu: 39.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: 1879 pm: dpkg pkgs: 0 pm: pacman pkgs: 1862 libs: 533
    tools: gnome-software,pamac pm: flatpak pkgs: 17
    1: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    2: https://mirrors.xtom.de/manjaro/stable/$repo/$arch
    3: https://mirror.23m.com/manjaro/stable/$repo/$arch
    4: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    5: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    6: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    7: https://mirror.seahost.de/manjaro/stable/$repo/$arch
    8: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
  Memory: total: 32 GiB note: est. available: 31.09 GiB used: 4.14 GiB (13.3%)
  Processes: 434 Power: uptime: 2m states: freeze,mem,disk suspend: s2idle
    avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend,
    test_resume image: 12.38 GiB services: gsd-power, power-profiles-daemon,
    upowerd Init: systemd v: 255 default: graphical tool: systemctl
  Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9
    running-in: gnome-terminal inxi: 3.3.33
I apologize if I was too brief. I have a Tuxedo Infinity Book Pro Gen8. Since the 6.6 kernel was designated as an LTS kernel, I’ve been using it. Until now, I’ve never had any problems. I haven’t installed any new software or similar; I’ve only regularly installed updates. It’s difficult for me to pinpoint the error. If I start the notebook and shut it down directly afterward, everything seems to work without any issues. However, if it runs a bit longer and, for example, I’ve only been surfing the internet with Firefox, it suddenly freezes as soon as I try to shut down the notebook using the gnome interface in the top right corner.
Not enough context, that one line tells us nothing. Next time you restart after a freeze post output from journalctl -b1 | tail -50 which hopefully will show exactly what it was doing when it froze.
I hadn’t had the problem for some time. But just now, the notebook froze again while shutting down. However, in the output of journalctl -b1 | tail -50, I don’t find any entries from today.
journalctl -b1 | tail -50                                        ✔
Feb 28 20:11:44 pascal-notebook-manjaro systemd[1]: var-lib-snapd-snap-gtk\x2dcommon\x2dthemes-1535.mount: Deactivated successfully.
Feb 28 20:11:44 pascal-notebook-manjaro systemd[1]: Unmounted Mount unit for gtk-common-themes, revision 1535.
Feb 28 20:11:44 pascal-notebook-manjaro systemd[1]: var-lib-snapd-snap-retroarch-2448.mount: Deactivated successfully.
Feb 28 20:11:44 pascal-notebook-manjaro systemd[1]: Unmounted Mount unit for retroarch, revision 2448.
Feb 28 20:11:44 pascal-notebook-manjaro systemd[1]: var-lib-snapd-snap-retroarch-2648.mount: Deactivated successfully.
Feb 28 20:11:44 pascal-notebook-manjaro systemd[1]: Unmounted Mount unit for retroarch, revision 2648.
Feb 28 20:11:44 pascal-notebook-manjaro systemd[1]: var-lib-snapd-snap-snap\x2dstore-959.mount: Deactivated successfully.
Feb 28 20:11:44 pascal-notebook-manjaro systemd[1]: Unmounted Mount unit for snap-store, revision 959.
Feb 28 20:11:44 pascal-notebook-manjaro systemd[1]: var-lib-snapd-snap-snapd-20290.mount: Deactivated successfully.
Feb 28 20:11:44 pascal-notebook-manjaro systemd[1]: Unmounted Mount unit for snapd, revision 20290.
Feb 28 20:11:44 pascal-notebook-manjaro systemd[1]: var-lib-snapd-snap-snapd-20671.mount: Deactivated successfully.
Feb 28 20:11:44 pascal-notebook-manjaro systemd[1]: Unmounted Mount unit for snapd, revision 20671.
Feb 28 20:11:44 pascal-notebook-manjaro systemd[1]: var-lib-snapd-snap-spotify-73.mount: Deactivated successfully.
Feb 28 20:11:44 pascal-notebook-manjaro systemd[1]: Unmounted Mount unit for spotify, revision 73.
Feb 28 20:11:44 pascal-notebook-manjaro systemd[1]: var-lib-snapd-snap-spotify-74.mount: Deactivated successfully.
Feb 28 20:11:44 pascal-notebook-manjaro systemd[1]: Unmounted Mount unit for spotify, revision 74.
Feb 28 20:11:44 pascal-notebook-manjaro systemd[1]: Stopped target Swaps.
Feb 28 20:11:44 pascal-notebook-manjaro systemd[1]: Deactivating swap /swapfile...
Feb 28 20:11:44 pascal-notebook-manjaro systemd[1]: systemd-fsck@dev-disk-by\x2duuid-3E45\x2dFE83.service: Deactivated successfully.
Feb 28 20:11:44 pascal-notebook-manjaro systemd[1]: Stopped File System Check on /dev/disk/by-uuid/3E45-FE83.
Feb 28 20:11:44 pascal-notebook-manjaro systemd[1]: Removed slice Slice /system/systemd-fsck.
Feb 28 20:11:44 pascal-notebook-manjaro systemd[1]: Stopped target Preparation for Local File Systems.
Feb 28 20:11:44 pascal-notebook-manjaro systemd[1]: Stopping Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
Feb 28 20:11:44 pascal-notebook-manjaro systemd[1]: systemd-tmpfiles-setup-dev.service: Deactivated successfully.
Feb 28 20:11:44 pascal-notebook-manjaro systemd[1]: Stopped Create Static Device Nodes in /dev.
Feb 28 20:11:44 pascal-notebook-manjaro systemd[1]: systemd-sysusers.service: Deactivated successfully.
Feb 28 20:11:44 pascal-notebook-manjaro systemd[1]: Stopped Create System Users.
Feb 28 20:11:44 pascal-notebook-manjaro systemd[1]: systemd-tmpfiles-setup-dev-early.service: Deactivated successfully.
Feb 28 20:11:44 pascal-notebook-manjaro systemd[1]: Stopped Create Static Device Nodes in /dev gracefully.
Feb 28 20:11:44 pascal-notebook-manjaro systemd[1]: swapfile.swap: Deactivated successfully.
Feb 28 20:11:44 pascal-notebook-manjaro systemd[1]: Deactivated swap /swapfile.
Feb 28 20:11:44 pascal-notebook-manjaro systemd[1]: lvm2-monitor.service: Deactivated successfully.
Feb 28 20:11:44 pascal-notebook-manjaro systemd[1]: Stopped Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
Feb 28 20:11:44 pascal-notebook-manjaro systemd[1]: Reached target Unmount All Filesystems.
Feb 28 20:11:44 pascal-notebook-manjaro systemd[1]: systemd-remount-fs.service: Deactivated successfully.
Feb 28 20:11:44 pascal-notebook-manjaro systemd[1]: Stopped Remount Root and Kernel File Systems.
Feb 28 20:11:44 pascal-notebook-manjaro systemd[1]: Reached target System Shutdown.
Feb 28 20:11:44 pascal-notebook-manjaro systemd[1]: Reached target Late Shutdown Services.
Feb 28 20:11:44 pascal-notebook-manjaro systemd[1]: systemd-reboot.service: Deactivated successfully.
Feb 28 20:11:44 pascal-notebook-manjaro systemd[1]: Finished System Reboot.
Feb 28 20:11:44 pascal-notebook-manjaro systemd[1]: Reached target System Reboot.
Feb 28 20:11:44 pascal-notebook-manjaro systemd[1]: Shutting down.
Feb 28 20:11:44 pascal-notebook-manjaro systemd[1]: Using hardware watchdog 'iTCO_wdt', version 6, device /dev/watchdog0
Feb 28 20:11:44 pascal-notebook-manjaro systemd[1]: Watchdog running with a timeout of 10min.
Feb 28 20:11:44 pascal-notebook-manjaro kernel: watchdog: watchdog0: watchdog did not stop!
Feb 28 20:11:44 pascal-notebook-manjaro systemd-shutdown[1]: Using hardware watchdog 'iTCO_wdt', version 6, device /dev/watchdog0
Feb 28 20:11:45 pascal-notebook-manjaro systemd-shutdown[1]: Watchdog running with a timeout of 10min.
Feb 28 20:11:45 pascal-notebook-manjaro systemd-shutdown[1]: Syncing filesystems and block devices.
Feb 28 20:11:45 pascal-notebook-manjaro systemd-shutdown[1]: Sending SIGTERM to remaining processes...
Feb 28 20:11:45 pascal-notebook-manjaro systemd-journald[542]: Journal stopped
I’ve got the journalctl log from the shutdown here again. Maybe you can read something from it.
journalctl --since "12:56" --until "13:00"         INT ✘  2m 23s 
Apr 02 12:56:01 pascal-notebook-manjaro gnome-shell[5267]: endSessionDialog: No XDG_SESSION_ID, fetched from logind: 1
Apr 02 12:56:02 pascal-notebook-manjaro systemd-logind[872]: The system will power off now!
Apr 02 12:56:02 pascal-notebook-manjaro gnome-shell[5267]: Shutting down GNOME Shell
Apr 02 12:56:02 pascal-notebook-manjaro systemd-logind[872]: System is powering down.
Apr 02 12:56:02 pascal-notebook-manjaro dbus-broker[5344]: Dispatched 228 messages @ 3(±6)μs / message.
Apr 02 12:56:02 pascal-notebook-manjaro kernel: rfkill: input handler enabled
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Stopping Session 1 of User pascal...
Apr 02 12:56:02 pascal-notebook-manjaro gdm-autologin][4512]: pam_unix(gdm-autologin:session): session closed for user pascal
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopped GNOME USB protection service.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopped GNOME accessibility service.
Apr 02 12:56:02 pascal-notebook-manjaro gdm[1883]: Gdm: Freeing conversation 'gdm-autologin' with active job
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopped GNOME date & time service.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopped GNOME maintenance of expirable data service.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopped GNOME printer notifications service.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopped GNOME RFKill support service.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopped GNOME FreeDesktop screensaver service.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopped GNOME file sharing service.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopped GNOME smartcard service.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopped GNOME sound sample caching service.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopped Monitor Session leader for GNOME Session.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopped target GNOME Wayland Session (session: gnome).
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopping Virtual filesystem service - Apple File Conduit monitor...
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopping Virtual filesystem service...
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopping Virtual filesystem service - GNOME Online Accounts monitor...
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopping Virtual filesystem service - digital camera monitor...
Apr 02 12:56:02 pascal-notebook-manjaro tracker-miner-f[6170]: Owner of volume monitor org.gtk.vfs.AfcVolumeMonitor disconnected from the bus; removing drives/volumes/mounts
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopping Virtual filesystem metadata service...
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopping Virtual filesystem service - Media Transfer Protocol monitor...
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopping Virtual filesystem service - disk device monitor...
Apr 02 12:56:02 pascal-notebook-manjaro tracker-miner-f[6170]: Owner of volume monitor org.gtk.vfs.GoaVolumeMonitor disconnected from the bus; removing drives/volumes/mounts
Apr 02 12:56:02 pascal-notebook-manjaro tracker-miner-f[6170]: Owner of volume monitor org.gtk.vfs.GPhoto2VolumeMonitor disconnected from the bus; removing drives/volumes/mounts
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopping Portal service (GNOME implementation)...
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopping Portal service...
Apr 02 12:56:02 pascal-notebook-manjaro tracker-miner-f[6170]: Owner of volume monitor org.gtk.vfs.MTPVolumeMonitor disconnected from the bus; removing drives/volumes/mounts
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopping flatpak document portal service...
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopping sandboxed app permission store...
Apr 02 12:56:02 pascal-notebook-manjaro tracker-miner-f[6170]: Owner of volume monitor org.gtk.vfs.UDisks2VolumeMonitor disconnected from the bus; removing drives/volumes/mounts
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopped sandboxed app permission store.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopped Virtual filesystem service - disk device monitor.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopped Virtual filesystem service - GNOME Online Accounts monitor.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopped Virtual filesystem service - Media Transfer Protocol monitor.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopped Virtual filesystem service - Apple File Conduit monitor.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopped Virtual filesystem service - digital camera monitor.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopped Portal service.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopped Portal service (GNOME implementation).
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopped Virtual filesystem metadata service.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopped target Current graphical user session.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopped target GNOME Session.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopped target GNOME Wayland Session.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopped target GNOME session X11 services.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopped target GNOME Session (session: gnome).
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopped target GNOME accessibility target.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopped target GNOME color management target.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopped target GNOME date & time target.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopped target GNOME maintenance of expirable data target.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopped target GNOME keyboard configuration target.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopped target GNOME keyboard shortcuts target.
Apr 02 12:56:02 pascal-notebook-manjaro gnome-shell[5267]: Attempting to call back into JSAPI during the sweeping phase of GC. This is most likely caused by not destroying a Clutter acto>
                                                           The offending signal was kill-window-effects on ShellWM 0x5561f20523b0.
                                                           == Stack trace for context 0x5561f17e77b0 ==
                                                           The offending signal was destroy on ShellWM 0x5561f20523b0.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopped target GNOME power management target.
                                                           The offending signal was notify on MetaDisplay 0x5561f20788b0.
                                                           The offending signal was window-left-monitor on MetaDisplay 0x5561f20788b0.
                                                           The offending signal was unmanaged on MetaWindowWayland 0x5561f90ca390.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopped target GNOME printer notifications target.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopped target GNOME RFKill support target.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopped target GNOME FreeDesktop screensaver target.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Removed slice Slice /system/getty.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopped target GNOME file sharing target.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopped target GNOME smartcard target.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopped target GNOME sound sample caching target.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopped target GNOME USB protection target.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopped target GNOME Wacom tablet support target.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopped target GNOME XSettings target.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopping IBus Daemon for GNOME...
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopping GNOME color management service...
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopping GNOME keyboard configuration service...
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopping GNOME keyboard shortcuts service...
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopping GNOME power management service...
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopping GNOME Wacom tablet support service...
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopped GNOME Session Manager (session: gnome).
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopped GNOME XSettings service.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopped IBus Daemon for GNOME.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: org.freedesktop.IBus.session.GNOME.service: Consumed 1.316s CPU time.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Removed slice Slice /system/modprobe.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopped Virtual filesystem service.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Removed slice Slice /system/systemd-coredump.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Stopped target Bluetooth Support.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Stopped target Graphical Interface.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Stopped target Multi-User System.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Stopped target Login Prompts.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Stopped target Sound Card.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Stopped target Timer Units.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: archlinux-keyring-wkd-sync.timer: Deactivated successfully.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Stopped Refresh existing PGP keys of archlinux-keyring regularly.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: btrfs-balance.timer: Deactivated successfully.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Stopped Balance block groups on a btrfs filesystem.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: btrfs-scrub.timer: Deactivated successfully.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Stopped Scrub btrfs filesystem, verify block checksums.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: btrfs-trim.timer: Deactivated successfully.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Stopped Discard unused blocks on a mounted filesystem.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: fstrim.timer: Deactivated successfully.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Stopped Discard unused filesystem blocks once a week.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: logrotate.timer: Deactivated successfully.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Stopped Daily rotation of log files.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: man-db.timer: Deactivated successfully.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Stopped Daily man-db regeneration.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: pamac-cleancache.timer: Deactivated successfully.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Stopped Monthly clean packages cache.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: pamac-mirrorlist.timer: Deactivated successfully.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Stopped Generate mirrorlist weekly.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: pkgfile-update.timer: Deactivated successfully.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Stopped pkgfile database update timer.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: shadow.timer: Deactivated successfully.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Stopped Daily verification of password and group files.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: systemd-tmpfiles-clean.timer: Deactivated successfully.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Stopped Daily Cleanup of Temporary Directories.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Stopped target System Time Set.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: lvm2-lvmpolld.socket: Deactivated successfully.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Closed LVM2 poll daemon socket.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: systemd-rfkill.socket: Deactivated successfully.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Stopping Modem Manager...
Apr 02 12:56:02 pascal-notebook-manjaro ModemManager[923]: <msg> caught signal, shutting down...
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Stopping Accounts Service...
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Stopping Save/Restore Sound Card State...
Apr 02 12:56:02 pascal-notebook-manjaro bluetoothd[870]: Terminating
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Stopping Bluetooth service...
Apr 02 12:56:02 pascal-notebook-manjaro ModemManager[923]: <msg> ModemManager is shut down
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Stopping Thunderbolt system service...
Apr 02 12:56:02 pascal-notebook-manjaro NetworkManager[868]: <info>  [1712055362.6647] modem-manager: ModemManager no longer available
Apr 02 12:56:02 pascal-notebook-manjaro systemd[4836]: Stopped flatpak document portal service.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Stopping Manage, Install and Generate Color Profiles...
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Stopping CUPS Scheduler...
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Stopping GNOME Display Manager...
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Starting Generate shutdown-ramfs...
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: plymouth-quit-wait.service: Deactivated successfully.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Stopped Hold until boot process finishes up.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Stopping Power Profiles daemon...
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Stopping RealtimeKit Scheduling Policy Service...
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Stopping Load/Save OS Random Seed...
Apr 02 12:56:02 pascal-notebook-manjaro mkinitcpio[308237]: ==> Starting build: 'none'
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Stopping TUXEDO Control Center Service...
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Stopping TeamViewer remote control daemon...
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Stopping Touchégg Daemon...
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Stopping Disk Manager...
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Stopping Daemon for power management...
Apr 02 12:56:02 pascal-notebook-manjaro touchegg.desktop[5574]: Connection with Touchégg daemon lost Underlying GIOStream returned 0 bytes on an async read
Apr 02 12:56:02 pascal-notebook-manjaro touchegg.desktop[5574]: Connecting to Touchégg daemon...
Apr 02 12:56:02 pascal-notebook-manjaro udisksd[5573]: udisks daemon version 2.10.1 exiting
Apr 02 12:56:02 pascal-notebook-manjaro mkinitcpio[308237]:   -> Running build hook: [sd-shutdown]
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: run-user-1000-doc.mount: Deactivated successfully.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Unmounted /run/user/1000/doc.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: run-user-1000-gvfs.mount: Deactivated successfully.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Unmounted /run/user/1000/gvfs.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: ModemManager.service: Deactivated successfully.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Stopped Modem Manager.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: bolt.service: Deactivated successfully.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Stopped Thunderbolt system service.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: cups.service: Deactivated successfully.
Apr 02 12:56:02 pascal-notebook-manjaro bluetoothd[870]: Endpoint unregistered: sender=:1.84 path=/MediaEndpoint/A2DPSource/ldac_hq
Apr 02 12:56:02 pascal-notebook-manjaro bluetoothd[870]: Endpoint unregistered: sender=:1.84 path=/MediaEndpoint/A2DPSource/ldac_sq
Apr 02 12:56:02 pascal-notebook-manjaro bluetoothd[870]: Endpoint unregistered: sender=:1.84 path=/MediaEndpoint/A2DPSource/ldac_mq
Apr 02 12:56:02 pascal-notebook-manjaro bluetoothd[870]: Endpoint unregistered: sender=:1.84 path=/MediaEndpoint/A2DPSink/aptx_hd
Apr 02 12:56:02 pascal-notebook-manjaro bluetoothd[870]: Endpoint unregistered: sender=:1.84 path=/MediaEndpoint/A2DPSource/aptx_hd
Apr 02 12:56:02 pascal-notebook-manjaro bluetoothd[870]: Endpoint unregistered: sender=:1.84 path=/MediaEndpoint/A2DPSink/sbc
Apr 02 12:56:02 pascal-notebook-manjaro bluetoothd[870]: Endpoint unregistered: sender=:1.84 path=/MediaEndpoint/A2DPSource/sbc
Apr 02 12:56:02 pascal-notebook-manjaro bluetoothd[870]: Endpoint unregistered: sender=:1.84 path=/MediaEndpoint/A2DPSink/sbc_xq_453
Apr 02 12:56:02 pascal-notebook-manjaro bluetoothd[870]: Endpoint unregistered: sender=:1.84 path=/MediaEndpoint/A2DPSource/sbc_xq_453
Apr 02 12:56:02 pascal-notebook-manjaro bluetoothd[870]: Endpoint unregistered: sender=:1.84 path=/MediaEndpoint/A2DPSink/sbc_xq_512
Apr 02 12:56:02 pascal-notebook-manjaro bluetoothd[870]: Endpoint unregistered: sender=:1.84 path=/MediaEndpoint/A2DPSource/sbc_xq_512
Apr 02 12:56:02 pascal-notebook-manjaro bluetoothd[870]: Endpoint unregistered: sender=:1.84 path=/MediaEndpoint/A2DPSink/sbc_xq_552
Apr 02 12:56:02 pascal-notebook-manjaro bluetoothd[870]: Endpoint unregistered: sender=:1.84 path=/MediaEndpoint/A2DPSource/sbc_xq_552
Apr 02 12:56:02 pascal-notebook-manjaro bluetoothd[870]: Endpoint unregistered: sender=:1.84 path=/MediaEndpoint/A2DPSink/faststream
Apr 02 12:56:02 pascal-notebook-manjaro bluetoothd[870]: Endpoint unregistered: sender=:1.84 path=/MediaEndpoint/A2DPSource/faststream
Apr 02 12:56:02 pascal-notebook-manjaro bluetoothd[870]: Battery Provider Manager destroyed
Apr 02 12:56:02 pascal-notebook-manjaro bluetoothd[870]: Stopping SDP server
Apr 02 12:56:02 pascal-notebook-manjaro bluetoothd[870]: Exit
Apr 02 12:56:02 pascal-notebook-manjaro pulseaudio[5796]: org.bluez.BatteryProviderManager1.UnregisterBatteryProvider() Failed: org.freedesktop.DBus.Error.NoReply:Remote peer disconnected
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Stopped CUPS Scheduler.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: bluetooth.service: Deactivated successfully.
Apr 02 12:56:02 pascal-notebook-manjaro tccd[308256]: Stopping daemon..
Apr 02 12:56:02 pascal-notebook-manjaro tccd[873]: SIGINT - Exiting
Apr 02 12:56:02 pascal-notebook-manjaro tccd[873]: DisplayBacklightWorker: Save display brightness 90% (86017) on exit
Apr 02 12:56:02 pascal-notebook-manjaro mkinitcpio[308237]: ==> Build complete.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Stopped Bluetooth service.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: colord.service: Deactivated successfully.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Stopped Manage, Install and Generate Color Profiles.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: accounts-daemon.service: Deactivated successfully.
Apr 02 12:56:02 pascal-notebook-manjaro tccd[308256]: Daemon is stopped
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: Stopped Accounts Service.
Apr 02 12:56:02 pascal-notebook-manjaro systemd[1]: upower.service: Deactivated successfully.
Apr 02 12:56:03 pascal-notebook-manjaro systemd[1]: Stopped Daemon for power management.
Apr 02 12:56:03 pascal-notebook-manjaro systemd[1]: udisks2.service: Deactivated successfully.
Apr 02 12:56:03 pascal-notebook-manjaro systemd[1]: Stopped Disk Manager.
Apr 02 12:56:03 pascal-notebook-manjaro systemd[1]: power-profiles-daemon.service: Deactivated successfully.
Apr 02 12:56:03 pascal-notebook-manjaro systemd[1]: Stopped Power Profiles daemon.
Apr 02 12:56:03 pascal-notebook-manjaro systemd[1]: rtkit-daemon.service: Deactivated successfully.
Apr 02 12:56:03 pascal-notebook-manjaro touchegg.desktop[5574]: Error connecting to Touchégg daemon: Error receiving data: Connection reset by peer
Apr 02 12:56:03 pascal-notebook-manjaro touchegg.desktop[5574]: Reconnecting in 5 seconds...
Apr 02 12:56:03 pascal-notebook-manjaro systemd[1]: Stopped RealtimeKit Scheduling Policy Service.
Apr 02 12:56:03 pascal-notebook-manjaro systemd[1]: touchegg.service: Deactivated successfully.
Apr 02 12:56:03 pascal-notebook-manjaro systemd[1]: Stopped Touchégg Daemon.
Apr 02 12:56:03 pascal-notebook-manjaro systemd[1]: alsa-restore.service: Deactivated successfully.
Apr 02 12:56:03 pascal-notebook-manjaro systemd[1]: Stopped Save/Restore Sound Card State.
Apr 02 12:56:03 pascal-notebook-manjaro systemd[1]: mkinitcpio-generate-shutdown-ramfs.service: Deactivated successfully.
Apr 02 12:56:03 pascal-notebook-manjaro systemd[1]: Finished Generate shutdown-ramfs.
Apr 02 12:56:03 pascal-notebook-manjaro systemd[1]: systemd-random-seed.service: Deactivated successfully.
Apr 02 12:56:03 pascal-notebook-manjaro systemd[1]: Stopped Load/Save OS Random Seed.
Apr 02 12:56:03 pascal-notebook-manjaro systemd[1]: tccd.service: Deactivated successfully.
Apr 02 12:56:03 pascal-notebook-manjaro systemd[1]: Stopped TUXEDO Control Center Service.
Apr 02 12:56:03 pascal-notebook-manjaro systemd[1]: tccd.service: Consumed 4min 45.439s CPU time.
Apr 02 12:56:03 pascal-notebook-manjaro systemd[1]: session-1.scope: Deactivated successfully.
Apr 02 12:56:03 pascal-notebook-manjaro systemd[1]: Stopped Session 1 of User pascal.
Apr 02 12:56:03 pascal-notebook-manjaro systemd[1]: Stopping Authorization Manager...
Apr 02 12:56:03 pascal-notebook-manjaro systemd[1]: Stopping User Manager for UID 1000...
Apr 02 12:56:03 pascal-notebook-manjaro systemd[1]: polkit.service: Deactivated successfully.
Apr 02 12:56:03 pascal-notebook-manjaro systemd[4836]: Activating special unit Exit the Session...
Apr 02 12:56:03 pascal-notebook-manjaro systemd[4836]: Stopping Application launched by gnome-session-binary...
Apr 02 12:56:03 pascal-notebook-manjaro systemd[4836]: Removed slice Slice /app/dbus-:1.21-org.a11y.atspi.Registry.
Apr 02 12:56:03 pascal-notebook-manjaro systemd[4836]: Removed slice Slice /app/dbus-:1.2-org.freedesktop.portal.IBus.
Apr 02 12:56:03 pascal-notebook-manjaro systemd[4836]: Removed slice Slice /app/dbus-:1.2-org.gnome.ArchiveManager1.
Apr 02 12:56:03 pascal-notebook-manjaro systemd[4836]: Removed slice Slice /app/dbus-:1.2-org.gnome.DejaDup.
Apr 02 12:56:03 pascal-notebook-manjaro kernel: BUG: kernel NULL pointer dereference, address: 000000000000001a
Apr 02 12:56:03 pascal-notebook-manjaro kernel: #PF: supervisor read access in kernel mode
Apr 02 12:56:03 pascal-notebook-manjaro kernel: #PF: error_code(0x0000) - not-present page
Apr 02 12:56:03 pascal-notebook-manjaro kernel: PGD 0 P4D 0
Apr 02 12:56:03 pascal-notebook-manjaro kernel: Oops: 0000 [#1] PREEMPT SMP NOPTI
Apr 02 12:56:03 pascal-notebook-manjaro kernel: CPU: 18 PID: 4836 Comm: systemd Tainted: P           OE      6.6.19-1-MANJARO #1 76c482e512047110118a77981ac42e42c9746e1c
Apr 02 12:56:03 pascal-notebook-manjaro kernel: Hardware name: TUXEDO TUXEDO InfinityBook Pro Gen8 (MK2)/PH6PG01_PH6PG71, BIOS N.1.10A07 11/16/2023
Apr 02 12:56:03 pascal-notebook-manjaro kernel: RIP: 0010:rb_first+0xf/0x30
Apr 02 12:56:03 pascal-notebook-manjaro kernel: Code: 10 c3 cc cc cc cc 0f 1f 44 00 00 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 f3 0f 1e fa 48 8b 07 48 85 c0 74 14 48 89 c2 <48> 8>
Apr 02 12:56:03 pascal-notebook-manjaro kernel: RSP: 0018:ffffb0eacdb2bc90 EFLAGS: 00010206
Apr 02 12:56:03 pascal-notebook-manjaro kernel: RAX: 000000000000000a RBX: ffffa0c7cdff4100 RCX: 0000000080800043
Apr 02 12:56:03 pascal-notebook-manjaro kernel: RDX: 000000000000000a RSI: 0000000000000000 RDI: ffffa0c7cdff5d58
Apr 02 12:56:03 pascal-notebook-manjaro kernel: RBP: ffffa0c7cdfdda80 R08: 0000000000000000 R09: 0000000080800043
Apr 02 12:56:03 pascal-notebook-manjaro kernel: R10: ffffa0c7a783f0e0 R11: ffffb0eacdb2bc90 R12: 0000000000000000
Apr 02 12:56:03 pascal-notebook-manjaro kernel: R13: ffffa0c7cdff5d58 R14: ffffffff9b70baa0 R15: ffffa0c799a5b800
Apr 02 12:56:03 pascal-notebook-manjaro kernel: FS:  00007f4b15e4a400(0000) GS:ffffa0ceaba80000(0000) knlGS:0000000000000000
Apr 02 12:56:03 pascal-notebook-manjaro kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Apr 02 12:56:03 pascal-notebook-manjaro kernel: CR2: 000000000000001a CR3: 0000000106b1e000 CR4: 0000000000f50ee0
Apr 02 12:56:03 pascal-notebook-manjaro kernel: PKRU: 55555554
Apr 02 12:56:03 pascal-notebook-manjaro kernel: Call Trace:
Apr 02 12:56:03 pascal-notebook-manjaro kernel:  <TASK>
Apr 02 12:56:03 pascal-notebook-manjaro kernel:  ? __die+0x23/0x70
Apr 02 12:56:03 pascal-notebook-manjaro kernel:  ? page_fault_oops+0x171/0x4e0
Apr 02 12:56:03 pascal-notebook-manjaro kernel:  ? __kmem_cache_alloc_node+0x1a6/0x340
Apr 02 12:56:03 pascal-notebook-manjaro kernel:  ? exc_page_fault+0x7f/0x180
Apr 02 12:56:03 pascal-notebook-manjaro kernel:  ? asm_exc_page_fault+0x26/0x30
Apr 02 12:56:03 pascal-notebook-manjaro kernel:  ? rb_first+0xf/0x30
Apr 02 12:56:03 pascal-notebook-manjaro kernel:  simple_xattrs_free+0x29/0x90
Apr 02 12:56:03 pascal-notebook-manjaro kernel:  kernfs_put.part.0+0x60/0x150
Apr 02 12:56:03 pascal-notebook-manjaro kernel:  kernfs_remove_by_name_ns+0x81/0xd0
Apr 02 12:56:03 pascal-notebook-manjaro kernel:  cgroup_addrm_files+0x2c6/0x350
Apr 02 12:56:03 pascal-notebook-manjaro kernel:  css_clear_dir+0x4b/0xc0
Apr 02 12:56:03 pascal-notebook-manjaro kernel:  cgroup_destroy_locked+0xcd/0x1b0
Apr 02 12:56:03 pascal-notebook-manjaro kernel:  cgroup_rmdir+0x2b/0xd0
Apr 02 12:56:03 pascal-notebook-manjaro kernel:  kernfs_iop_rmdir+0x50/0x80
Apr 02 12:56:03 pascal-notebook-manjaro kernel:  vfs_rmdir+0x97/0x200
Apr 02 12:56:03 pascal-notebook-manjaro kernel:  do_rmdir+0x175/0x1b0
Apr 02 12:56:03 pascal-notebook-manjaro kernel:  __x64_sys_rmdir+0x42/0x70
Apr 02 12:56:03 pascal-notebook-manjaro kernel:  do_syscall_64+0x5d/0x90
Apr 02 12:56:03 pascal-notebook-manjaro kernel:  ? do_syscall_64+0x6c/0x90
Apr 02 12:56:03 pascal-notebook-manjaro kernel:  ? syscall_exit_to_user_mode+0x2b/0x40
Apr 02 12:56:03 pascal-notebook-manjaro kernel:  entry_SYSCALL_64_after_hwframe+0x6e/0xd8
Apr 02 12:56:03 pascal-notebook-manjaro kernel: RIP: 0033:0x7f4b1551977b
Apr 02 12:56:03 pascal-notebook-manjaro kernel: Code: f0 ff ff 73 01 c3 48 8b 0d a2 c5 0d 00 f7 d8 64 89 01 48 83 c8 ff c3 0f 1f 84 00 00 00 00 00 f3 0f 1e fa b8 54 00 00 00 0f 05 <48> 3>
Apr 02 12:56:03 pascal-notebook-manjaro kernel: RSP: 002b:00007ffd9dad4308 EFLAGS: 00000246 ORIG_RAX: 0000000000000054
Apr 02 12:56:03 pascal-notebook-manjaro kernel: RAX: ffffffffffffffda RBX: 000055ab151d3bc0 RCX: 00007f4b1551977b
Apr 02 12:56:03 pascal-notebook-manjaro kernel: RDX: 0000000000000000 RSI: 0000000000000001 RDI: 000055ab150b6310
Apr 02 12:56:03 pascal-notebook-manjaro kernel: RBP: 00007ffd9dad4360 R08: 00007f4b156c490a R09: 0000000000000000
Apr 02 12:56:03 pascal-notebook-manjaro kernel: R10: 000055ab150b2f50 R11: 0000000000000246 R12: 0000000000000001
Apr 02 12:56:03 pascal-notebook-manjaro kernel: R13: 0000000000000000 R14: 000055ab150b6310 R15: 0000000000000000
Apr 02 12:56:03 pascal-notebook-manjaro kernel:  </TASK>
Apr 02 12:56:03 pascal-notebook-manjaro kernel: Modules linked in: ccm rfcomm nls_utf8 cifs cifs_arc4 nls_ucs2_utils cifs_md4 dns_resolver fscache netfs cmac algif_hash algif_skcipher af>
Apr 02 12:56:03 pascal-notebook-manjaro kernel:  snd_hda_codec libarc4 uvcvideo cryptd snd_hda_core videobuf2_vmalloc bluetooth uvc drm_buddy snd_hwdep processor_thermal_device_pci iwlwi>
Apr 02 12:56:03 pascal-notebook-manjaro kernel:  nf_log_syslog xt_limit xt_addrtype xt_tcpudp xt_conntrack nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 libcrc32c ip6table_filter ip6_tables>
Apr 02 12:56:03 pascal-notebook-manjaro kernel: ---[ end trace 0000000000000000 ]---
Apr 02 12:56:03 pascal-notebook-manjaro kernel: note: systemd[4836] exited with irqs disabled
-- Boot e16c80479a624a8eb441e21b41e7148b --
Apr 02 12:57:39 pascal-notebook-manjaro kernel: microcode: updated early: 0x4106 -> 0x411c, date = 2023-08-30
Apr 02 12:57:39 pascal-notebook-manjaro kernel: Linux version 6.6.19-1-MANJARO (builduser@fv-az1021-257) (gcc (GCC) 13.2.1 20230801, GNU ld (GNU Binutils) 2.42.0) #1 SMP PREEMPT_DYNAMIC >
Apr 02 12:57:39 pascal-notebook-manjaro kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-6.6-x86_64 root=UUID=3fe1158e-8862-41e2-9542-867627548ada rw quiet splash apparmor=1 security=appar>
Apr 02 12:57:39 pascal-notebook-manjaro kernel: x86/split lock detection: #AC: crashing the kernel on kernel split_locks and warning on user-space split_locks
Apr 02 12:57:39 pascal-notebook-manjaro kernel: BIOS-provided physical RAM map:
a Better way to get the logs would be:
journalctl --priority=warning..err --no-pager --boot=-1
Where:
  • The --priority=warning..err argument limits the output to warnings and errors only;
  • and the --no-pager formats the output nicely for use here, on the forum;
  • the --boot=-1 argument limits the output to log messages from the previous boot. This can be adjusted to -2 for the boot before that, -3 to the boot before that, and so on and so forth.
Sure, here’s the output.
journalctl --priority=warning..err --no-pager --boot=-1         INT ✘  7m 42s 
Apr 02 12:31:26 pascal-notebook-manjaro kernel:   #1  #3  #5  #7  #9 #11
Apr 02 12:31:26 pascal-notebook-manjaro kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Apr 02 12:31:26 pascal-notebook-manjaro kernel: pci 0000:00:07.0: DPC: RP PIO log size 0 is invalid
Apr 02 12:31:26 pascal-notebook-manjaro kernel: pnp 00:03: disabling [mem 0xc0000000-0xcfffffff] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
Apr 02 12:31:26 pascal-notebook-manjaro kernel: hpet_acpi_add: no address or irqs in _CRS
Apr 02 12:31:26 pascal-notebook-manjaro kernel: nvidia: loading out-of-tree module taints kernel.
Apr 02 12:31:26 pascal-notebook-manjaro kernel: nvidia: module license 'NVIDIA' taints kernel.
Apr 02 12:31:26 pascal-notebook-manjaro kernel: Disabling lock debugging due to kernel taint
Apr 02 12:31:26 pascal-notebook-manjaro kernel: nvidia: module license taints kernel.
Apr 02 12:31:26 pascal-notebook-manjaro kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module  550.54.14  Thu Feb 22 01:44:30 UTC 2024
Apr 02 12:31:26 pascal-notebook-manjaro kernel: nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
Apr 02 12:31:26 pascal-notebook-manjaro kernel: ACPI Warning: \_SB.NPCF._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20230628/nsarguments-61)
Apr 02 12:31:26 pascal-notebook-manjaro kernel: ACPI Warning: \_SB.PC00.PEG1.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20230628/nsarguments-61)
Apr 02 12:31:26 pascal-notebook-manjaro kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
Apr 02 12:31:26 pascal-notebook-manjaro kernel: VBoxNetAdp: Successfully started.
Apr 02 12:31:26 pascal-notebook-manjaro kernel: VBoxNetFlt: Successfully started.
Apr 02 12:31:26 pascal-notebook-manjaro kernel: kauditd_printk_skb: 49 callbacks suppressed
Apr 02 12:31:25 pascal-notebook-manjaro systemd-modules-load[348]: Failed to find module '/etc/modules-load.d/my-modules.conf'
Apr 02 12:31:26 pascal-notebook-manjaro kernel: intel-hid INTC1078:00: failed to enable HID power button
Apr 02 12:31:27 pascal-notebook-manjaro kernel: proc_thermal_pci 0000:00:04.0: error: proc_thermal_add, will continue
Apr 02 12:31:27 pascal-notebook-manjaro kernel: asus_wmi: ASUS Management GUID not found
Apr 02 12:31:27 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
Apr 02 12:31:27 pascal-notebook-manjaro kernel: ACPI Warning: \_SB.PC00.XHCI.RHUB.HS10._DSM: Argument #4 type mismatch - Found [Integer], ACPI requires [Package] (20230628/nsarguments-61)
Apr 02 12:31:27 pascal-notebook-manjaro kernel: thermal thermal_zone3: failed to read out thermal zone (-61)
Apr 02 12:31:27 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
Apr 02 12:31:28 pascal-notebook-manjaro bluetoothd[870]: src/plugin.c:plugin_init() System does not support csip plugin
Apr 02 12:31:28 pascal-notebook-manjaro bluetoothd[870]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
Apr 02 12:31:28 pascal-notebook-manjaro bluetoothd[870]: src/plugin.c:plugin_init() System does not support micp plugin
Apr 02 12:31:28 pascal-notebook-manjaro bluetoothd[870]: src/plugin.c:plugin_init() System does not support vcp plugin
Apr 02 12:31:28 pascal-notebook-manjaro bluetoothd[870]: src/plugin.c:plugin_init() System does not support mcp plugin
Apr 02 12:31:28 pascal-notebook-manjaro bluetoothd[870]: src/plugin.c:plugin_init() System does not support bass plugin
Apr 02 12:31:28 pascal-notebook-manjaro bluetoothd[870]: src/plugin.c:plugin_init() System does not support bap plugin
Apr 02 12:31:28 pascal-notebook-manjaro boltd[924]: [92818780-c001-domain0                    ] udev: failed to determine if uid is stable: unknown NHI PCI id '0xa73e'
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
Apr 02 12:31:28 pascal-notebook-manjaro dbus-broker-launch[864]: Activation request for 'org.freedesktop.Avahi' failed: The systemd unit 'dbus-org.freedesktop.Avahi.service' could not be found.
Apr 02 12:31:28 pascal-notebook-manjaro kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: Microcode SW error detected. Restarting 0x0.
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: Transport status: 0x0000004A, valid: 6
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: Loaded firmware version: 83.e8f84e98.0 so-a0-hr-b0-83.ucode
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x00000071 | NMI_INTERRUPT_UMAC_FATAL
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x000002F0 | trm_hw_status0
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x004D9024 | branchlink2
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x004CF2F2 | interruptlink1
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x004CF2F2 | interruptlink2
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x0001308E | data1
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x00000010 | data2
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x00000000 | data3
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x0039D53F | beacon time
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x00079E5A | tsf low
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x00000000 | tsf hi
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x00000000 | time gp1
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x00085752 | time gp2
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x00000001 | uCode revision type
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x00000053 | uCode version major
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0xE8F84E98 | uCode version minor
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x00000370 | hw version
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x00C80002 | board version
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x80B8F500 | hcmd
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x00020000 | isr0
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x00000000 | isr1
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x48F00002 | isr2
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x00C3000C | isr3
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x00000000 | isr4
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x001D0103 | last cmd Id
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x0001308E | wait_event
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x00005E6F | l2p_control
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x00000020 | l2p_duration
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x00000003 | l2p_mhvalid
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x00000000 | l2p_addr_match
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x00000009 | lmpm_pmg_sel
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x00000000 | timestamp
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x0000284C | flow_handler
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: Transport status: 0x0000004A, valid: 7
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x2010190E | ADVANCED_SYSASSERT
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x804703E0 | umac branchlink2
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0xC0081500 | umac interruptlink1
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac interruptlink2
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x0101971C | umac data1
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0xDEADBEEF | umac data2
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0xDEADBEEF | umac data3
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x00000053 | umac major
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0xE8F84E98 | umac minor
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x0008574C | frame pointer
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0xC0886BE0 | stack pointer
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x0025010D | last host cmd
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x00000000 | isr status reg
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: IML/ROM dump:
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x00000B03 | IML/ROM error/state
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x00005113 | IML/ROM data1
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x00000090 | IML/ROM WFPM_AUTH_KEY_0
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: Fseq Registers:
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x60000000 | FSEQ_ERROR_CODE
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x00350002 | FSEQ_TOP_INIT_VERSION
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x00150001 | FSEQ_CNVIO_INIT_VERSION
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x0000A482 | FSEQ_OTP_VERSION
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x00000003 | FSEQ_TOP_CONTENT_VERSION
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x4552414E | FSEQ_ALIVE_TOKEN
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x00080400 | FSEQ_CNVI_ID
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x01300504 | FSEQ_CNVR_ID
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x00080400 | CNVI_AUX_MISC_CHIP
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x01300504 | CNVR_AUX_MISC_CHIP
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x05B0905B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x0000025B | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x00150001 | FSEQ_PREV_CNVIO_INIT_VERSION
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x00350002 | FSEQ_WIFI_FSEQ_VERSION
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x00350002 | FSEQ_BT_FSEQ_VERSION
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: 0x000000EB | FSEQ_CLASS_TP_VERSION
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: UMAC CURRENT PC: 0x8048f214
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: LMAC1 CURRENT PC: 0xd0
Apr 02 12:31:28 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 4 fired (delay=0ms).
Apr 02 12:31:29 pascal-notebook-manjaro kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
Apr 02 12:31:29 pascal-notebook-manjaro kernel: uniwill_wmi: uw ec read timeout, addr: 0x074e
Apr 02 12:31:29 pascal-notebook-manjaro systemd[1]: mnt-Homearchiv.mount: Failed with result 'exit-code'.
Apr 02 12:31:29 pascal-notebook-manjaro kernel: CIFS: No dialect specified on mount. Default has changed to a more secure dialect, SMB2.1 or later (e.g. SMB3.1.1), from CIFS (SMB1). To use the less secure SMB1 dialect to access old servers which do not support SMB3.1.1 (or even SMB3 or SMB2.1) specify vers=1.0 on mount.
Apr 02 12:31:29 pascal-notebook-manjaro kernel: CIFS: VFS: Error connecting to socket. Aborting operation.
Apr 02 12:31:29 pascal-notebook-manjaro kernel: CIFS: VFS: cifs_mount failed w/return code = -101
Apr 02 12:31:29 pascal-notebook-manjaro systemd[1]: Failed to mount Mount CIFS at /mnt/Homearchiv.
Apr 02 12:31:32 pascal-notebook-manjaro dbus-broker-launch[864]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
Apr 02 12:31:33 pascal-notebook-manjaro gdm-autologin][4512]: gkr-pam: couldn't unlock the login keyring.
Apr 02 12:31:33 pascal-notebook-manjaro gnome-session-binary[5243]: WARNING: Desktop file /home/pascal/.config/autostart/manjaro-starter.desktop for application manjaro-starter.desktop could not be parsed or references a missing TryExec binary
Apr 02 12:31:33 pascal-notebook-manjaro gnome-session-binary[5243]: WARNING: Desktop file /home/pascal/.config/autostart/ignore-lid-switch-tweak.desktop for application ignore-lid-switch-tweak.desktop could not be parsed or references a missing TryExec binary
Apr 02 12:31:33 pascal-notebook-manjaro gnome-session-binary[5243]: WARNING: Desktop file /home/pascal/.config/autostart/morgen.desktop for application morgen.desktop could not be parsed or references a missing TryExec binary
Apr 02 12:31:33 pascal-notebook-manjaro gnome-session-binary[5243]: WARNING: Desktop file /home/pascal/.config/autostart/manjaro-app-folder-settings.desktop for application manjaro-app-folder-settings.desktop could not be parsed or references a missing TryExec binary
Apr 02 12:31:33 pascal-notebook-manjaro gnome-keyring-daemon[5259]: discover_other_daemon: 1
Apr 02 12:31:33 pascal-notebook-manjaro gnome-keyring-daemon[5262]: discover_other_daemon: 1
Apr 02 12:31:33 pascal-notebook-manjaro systemd[4836]: app-gnome-gnome\x2dkeyring\x2dpkcs11-5250.scope: No PIDs left to attach to the scope's control group, refusing.
Apr 02 12:31:33 pascal-notebook-manjaro systemd[4836]: app-gnome-gnome\x2dkeyring\x2dpkcs11-5250.scope: Failed with result 'resources'.
Apr 02 12:31:33 pascal-notebook-manjaro systemd[4836]: Failed to start Application launched by gnome-session-binary.
Apr 02 12:31:33 pascal-notebook-manjaro systemd[4836]: app-gnome-gnome\x2dkeyring\x2dsecrets-5253.scope: No PIDs left to attach to the scope's control group, refusing.
Apr 02 12:31:33 pascal-notebook-manjaro systemd[4836]: app-gnome-gnome\x2dkeyring\x2dsecrets-5253.scope: Failed with result 'resources'.
Apr 02 12:31:33 pascal-notebook-manjaro gnome-keyring-daemon[5264]: discover_other_daemon: 1
Apr 02 12:31:33 pascal-notebook-manjaro systemd[4836]: app-gnome-gnome\x2dkeyring\x2dssh-5257.scope: Failed to add PIDs to scope's control group: No such process
Apr 02 12:31:33 pascal-notebook-manjaro systemd[4836]: app-gnome-gnome\x2dkeyring\x2dssh-5257.scope: Failed with result 'resources'.
Apr 02 12:31:33 pascal-notebook-manjaro gnome-shell[5267]: Failed to make thread 'KMS thread' realtime scheduled: GDBus.Error:org.freedesktop.DBus.Error.NameHasNoOwner: Destination does not exist
Apr 02 12:31:34 pascal-notebook-manjaro kernel: gnome-shell[5267]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
Apr 02 12:31:34 pascal-notebook-manjaro systemd[4836]: Dependency failed for GNOME XSettings service.
Apr 02 12:31:34 pascal-notebook-manjaro gnome-shell[5267]: Failed to get METAR data: Fehler beim Auflösen von »aviationweather.gov«: Der Name oder der Dienst ist nicht bekannt
Apr 02 12:31:34 pascal-notebook-manjaro systemd[4836]: app-gnome-create\x2dtemplate-5532.scope: No PIDs left to attach to the scope's control group, refusing.
Apr 02 12:31:34 pascal-notebook-manjaro systemd[4836]: app-gnome-create\x2dtemplate-5532.scope: Failed with result 'resources'.
Apr 02 12:31:34 pascal-notebook-manjaro systemd[4836]: Failed to start Application launched by gnome-session-binary.
Apr 02 12:31:34 pascal-notebook-manjaro systemd[4836]: app-gnome-user\x2ddirs\x2dupdate\x2dgtk-5570.scope: No PIDs left to attach to the scope's control group, refusing.
Apr 02 12:31:34 pascal-notebook-manjaro systemd[4836]: app-gnome-user\x2ddirs\x2dupdate\x2dgtk-5570.scope: Failed with result 'resources'.
Apr 02 12:31:34 pascal-notebook-manjaro gsd-usb-protect[5435]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name is not activatable
Apr 02 12:31:34 pascal-notebook-manjaro gnome-shell[5267]: st_widget_get_theme_node called on the widget [0x5561f42f3280 StBoxLayout ("…")] which is not in the stage.
Apr 02 12:31:34 pascal-notebook-manjaro gnome-shell[5267]: st_widget_get_theme_node called on the widget [0x5561f42f58b0 StLabel.vitals-panel-label:insensitive ("…")] which is not in the stage.
Apr 02 12:31:34 pascal-notebook-manjaro gnome-shell[5267]: st_widget_get_theme_node called on the widget [0x5561f43a99c0 StLabel.vitals-panel-label:insensitive ("…")] which is not in the stage.
Apr 02 12:31:34 pascal-notebook-manjaro gnome-shell[5267]: st_widget_get_theme_node called on the widget [0x5561f432c250 StLabel.vitals-panel-label:insensitive ("…")] which is not in the stage.
Apr 02 12:31:34 pascal-notebook-manjaro gnome-shell[5267]: st_widget_get_theme_node called on the widget [0x5561f43ae4c0 StLabel.vitals-panel-label:insensitive ("…")] which is not in the stage.
Apr 02 12:31:34 pascal-notebook-manjaro gnome-shell[5267]: st_widget_get_theme_node called on the widget [0x5561f43aab90 StLabel.vitals-panel-label:insensitive ("…")] which is not in the stage.
Apr 02 12:31:34 pascal-notebook-manjaro kernel: warning: `pool-gnome-shel' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
Apr 02 12:31:34 pascal-notebook-manjaro gnome-shell[5267]: Failed to open sliced image: Vorgang wurde abgebrochen
Apr 02 12:31:34 pascal-notebook-manjaro geoclue[5795]: Failed to connect to avahi service: Daemon not running
Apr 02 12:31:35 pascal-notebook-manjaro gsd-media-keys[5414]: Failed to grab accelerator for keybinding settings:playback-repeat
Apr 02 12:31:35 pascal-notebook-manjaro gsd-media-keys[5414]: Failed to grab accelerator for keybinding settings:hibernate
Apr 02 12:31:35 pascal-notebook-manjaro pasystray[5528]: Error initializing Avahi: Daemon not running
Apr 02 12:31:35 pascal-notebook-manjaro kernel: show_signal_msg: 8 callbacks suppressed
Apr 02 12:31:35 pascal-notebook-manjaro gnome-shell[5267]: JS ERROR: TypeError: this._prepareStartupAnimation() is undefined
                                                           _loadBackground/signalId</id<@resource:///org/gnome/shell/ui/layout.js:693:26
                                                           @resource:///org/gnome/shell/ui/init.js:21:20
Apr 02 12:31:36 pascal-notebook-manjaro dbus-broker-launch[864]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
Apr 02 12:31:42 pascal-notebook-manjaro kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:b0:f2:08:4d:42:8f:08:00 SRC=192.168.150.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=34516 DF PROTO=2
Apr 02 12:31:47 pascal-notebook-manjaro nautilus[6056]: Could not delete '.meta.isrunning': Datei oder Verzeichnis nicht gefunden
Apr 02 12:31:50 pascal-notebook-manjaro gnome-shell[5267]: meta_window_set_stack_position_no_sync: assertion 'window->stack_position >= 0' failed
Apr 02 12:32:12 pascal-notebook-manjaro kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:b0:f2:08:4d:42:8f:08:00 SRC=192.168.150.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=49434 DF PROTO=2
Apr 02 12:32:42 pascal-notebook-manjaro kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:b0:f2:08:4d:42:8f:08:00 SRC=192.168.150.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=56173 DF PROTO=2
Apr 02 12:33:12 pascal-notebook-manjaro kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:b0:f2:08:4d:42:8f:08:00 SRC=192.168.150.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=1221 DF PROTO=2
Apr 02 12:33:42 pascal-notebook-manjaro kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:b0:f2:08:4d:42:8f:08:00 SRC=192.168.150.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=9275 DF PROTO=2
Apr 02 12:34:12 pascal-notebook-manjaro kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:b0:f2:08:4d:42:8f:08:00 SRC=192.168.150.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=30828 DF PROTO=2
Apr 02 12:34:42 pascal-notebook-manjaro kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:b0:f2:08:4d:42:8f:08:00 SRC=192.168.150.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=38802 DF PROTO=2
Apr 02 12:35:12 pascal-notebook-manjaro kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:b0:f2:08:4d:42:8f:08:00 SRC=192.168.150.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=57451 DF PROTO=2
Apr 02 12:35:42 pascal-notebook-manjaro kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:b0:f2:08:4d:42:8f:08:00 SRC=192.168.150.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=60871 DF PROTO=2
Apr 02 12:36:12 pascal-notebook-manjaro kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:b0:f2:08:4d:42:8f:08:00 SRC=192.168.150.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=18873 DF PROTO=2
Apr 02 12:36:42 pascal-notebook-manjaro kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:b0:f2:08:4d:42:8f:08:00 SRC=192.168.150.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=19630 DF PROTO=2
Apr 02 12:37:12 pascal-notebook-manjaro kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:b0:f2:08:4d:42:8f:08:00 SRC=192.168.150.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=39907 DF PROTO=2
Apr 02 12:37:42 pascal-notebook-manjaro kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:b0:f2:08:4d:42:8f:08:00 SRC=192.168.150.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=39953 DF PROTO=2
Apr 02 12:38:12 pascal-notebook-manjaro kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:b0:f2:08:4d:42:8f:08:00 SRC=192.168.150.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=51708 DF PROTO=2
Apr 02 12:38:42 pascal-notebook-manjaro kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:b0:f2:08:4d:42:8f:08:00 SRC=192.168.150.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=13205 DF PROTO=2
Apr 02 12:39:12 pascal-notebook-manjaro kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:b0:f2:08:4d:42:8f:08:00 SRC=192.168.150.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=26133 DF PROTO=2
Apr 02 12:39:42 pascal-notebook-manjaro kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:b0:f2:08:4d:42:8f:08:00 SRC=192.168.150.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=28389 DF PROTO=2
Apr 02 12:40:12 pascal-notebook-manjaro kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:b0:f2:08:4d:42:8f:08:00 SRC=192.168.150.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=33950 DF PROTO=2
Apr 02 12:40:42 pascal-notebook-manjaro kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:b0:f2:08:4d:42:8f:08:00 SRC=192.168.150.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=44055 DF PROTO=2
Apr 02 12:41:12 pascal-notebook-manjaro kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:b0:f2:08:4d:42:8f:08:00 SRC=192.168.150.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=50747 DF PROTO=2
Apr 02 12:41:36 pascal-notebook-manjaro kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=33:33:00:00:00:01:b0:f2:08:4d:42:8f:86:dd SRC=fe80:0000:0000:0000:b2f2:08ff:fe4d:428f DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=64 TC=0 HOPLIMIT=255 FLOWLBL=0 PROTO=UDP SPT=53805 DPT=53805 LEN=24
Apr 02 12:42:12 pascal-notebook-manjaro kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:b0:f2:08:4d:42:8f:08:00 SRC=192.168.150.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=18886 DF PROTO=2
Apr 02 12:42:42 pascal-notebook-manjaro kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:b0:f2:08:4d:42:8f:08:00 SRC=192.168.150.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=47493 DF PROTO=2
Apr 02 12:43:12 pascal-notebook-manjaro kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:b0:f2:08:4d:42:8f:08:00 SRC=192.168.150.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=61304 DF PROTO=2
Apr 02 12:43:42 pascal-notebook-manjaro kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:b0:f2:08:4d:42:8f:08:00 SRC=192.168.150.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=20604 DF PROTO=2
Apr 02 12:44:12 pascal-notebook-manjaro kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:b0:f2:08:4d:42:8f:08:00 SRC=192.168.150.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=28045 DF PROTO=2
Apr 02 12:44:42 pascal-notebook-manjaro kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:b0:f2:08:4d:42:8f:08:00 SRC=192.168.150.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=32705 DF PROTO=2
Apr 02 12:45:12 pascal-notebook-manjaro kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:b0:f2:08:4d:42:8f:08:00 SRC=192.168.150.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=34258 DF PROTO=2
Apr 02 12:45:42 pascal-notebook-manjaro kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:b0:f2:08:4d:42:8f:08:00 SRC=192.168.150.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=42935 DF PROTO=2
Apr 02 12:46:12 pascal-notebook-manjaro kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:b0:f2:08:4d:42:8f:08:00 SRC=192.168.150.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=45912 DF PROTO=2
Apr 02 12:46:42 pascal-notebook-manjaro kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:b0:f2:08:4d:42:8f:08:00 SRC=192.168.150.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=54438 DF PROTO=2
Apr 02 12:47:12 pascal-notebook-manjaro kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:b0:f2:08:4d:42:8f:08:00 SRC=192.168.150.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=5347 DF PROTO=2
Apr 02 12:47:42 pascal-notebook-manjaro kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:b0:f2:08:4d:42:8f:08:00 SRC=192.168.150.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=27922 DF PROTO=2
Apr 02 12:48:12 pascal-notebook-manjaro kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:b0:f2:08:4d:42:8f:08:00 SRC=192.168.150.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=32183 DF PROTO=2
Apr 02 12:48:42 pascal-notebook-manjaro kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:b0:f2:08:4d:42:8f:08:00 SRC=192.168.150.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=34374 DF PROTO=2
Apr 02 12:49:12 pascal-notebook-manjaro kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:b0:f2:08:4d:42:8f:08:00 SRC=192.168.150.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=35008 DF PROTO=2
Apr 02 12:49:42 pascal-notebook-manjaro kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:b0:f2:08:4d:42:8f:08:00 SRC=192.168.150.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=37935 DF PROTO=2
Apr 02 12:50:12 pascal-notebook-manjaro kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:b0:f2:08:4d:42:8f:08:00 SRC=192.168.150.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=2064 DF PROTO=2
Apr 02 12:50:42 pascal-notebook-manjaro kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:b0:f2:08:4d:42:8f:08:00 SRC=192.168.150.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=21735 DF PROTO=2
Apr 02 12:51:12 pascal-notebook-manjaro kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:b0:f2:08:4d:42:8f:08:00 SRC=192.168.150.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=49274 DF PROTO=2
Apr 02 12:51:36 pascal-notebook-manjaro kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=33:33:00:00:00:01:b0:f2:08:4d:42:8f:86:dd SRC=fe80:0000:0000:0000:b2f2:08ff:fe4d:428f DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=64 TC=0 HOPLIMIT=255 FLOWLBL=0 PROTO=UDP SPT=53805 DPT=53805 LEN=24
Apr 02 12:51:42 pascal-notebook-manjaro kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:b0:f2:08:4d:42:8f:08:00 SRC=192.168.150.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=49422 DF PROTO=2
Apr 02 12:52:12 pascal-notebook-manjaro kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:b0:f2:08:4d:42:8f:08:00 SRC=192.168.150.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=13338 DF PROTO=2
Apr 02 12:52:42 pascal-notebook-manjaro kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:b0:f2:08:4d:42:8f:08:00 SRC=192.168.150.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=24445 DF PROTO=2
Apr 02 12:53:12 pascal-notebook-manjaro kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:b0:f2:08:4d:42:8f:08:00 SRC=192.168.150.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=44075 DF PROTO=2
Apr 02 12:53:42 pascal-notebook-manjaro kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:b0:f2:08:4d:42:8f:08:00 SRC=192.168.150.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=61651 DF PROTO=2
Apr 02 12:54:12 pascal-notebook-manjaro kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:b0:f2:08:4d:42:8f:08:00 SRC=192.168.150.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=64250 DF PROTO=2
Apr 02 12:54:42 pascal-notebook-manjaro kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:b0:f2:08:4d:42:8f:08:00 SRC=192.168.150.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=14666 DF PROTO=2
Apr 02 12:55:12 pascal-notebook-manjaro kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:b0:f2:08:4d:42:8f:08:00 SRC=192.168.150.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=23492 DF PROTO=2
Apr 02 12:55:42 pascal-notebook-manjaro kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:b0:f2:08:4d:42:8f:08:00 SRC=192.168.150.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=46646 DF PROTO=2
Apr 02 12:56:02 pascal-notebook-manjaro gnome-shell[5267]: Attempting to call back into JSAPI during the sweeping phase of GC. This is most likely caused by not destroying a Clutter actor or Gtk+ widget with ::destroy signals connected, but can also be caused by using the destroy(), dispose(), or remove() vfuncs. Because it would crash the application, it has been blocked and the JS callback not invoked.
Apr 02 12:56:03 pascal-notebook-manjaro kernel: Code: 10 c3 cc cc cc cc 0f 1f 44 00 00 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 f3 0f 1e fa 48 8b 07 48 85 c0 74 14 48 89 c2 <48> 8b 40 10 48 85 c0 75 f4 48 89 d0 c3 cc cc cc cc 31 d2 eb f4 66
Apr 02 12:56:03 pascal-notebook-manjaro kernel: Code: f0 ff ff 73 01 c3 48 8b 0d a2 c5 0d 00 f7 d8 64 89 01 48 83 c8 ff c3 0f 1f 84 00 00 00 00 00 f3 0f 1e fa b8 54 00 00 00 0f 05 <48> 3d 00 f0 ff ff 77 05 c3 0f 1f 40 00 48 8b 15 71 c5 0d 00 f7 d8
Apr 02 12:56:03 pascal-notebook-manjaro kernel: Modules linked in: ccm rfcomm nls_utf8 cifs cifs_arc4 nls_ucs2_utils cifs_md4 dns_resolver fscache netfs cmac algif_hash algif_skcipher af_alg snd_hda_codec_realtek snd_hda_codec_generic qrtr bnep hid_logitech_hidpp joydev intel_uncore_frequency intel_uncore_frequency_common intel_tcc_cooling snd_sof_pci_intel_tgl x86_pkg_temp_thermal intel_powerclamp snd_sof_intel_hda_common coretemp soundwire_intel snd_sof_intel_hda_mlink soundwire_cadence kvm_intel snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp snd_sof kvm snd_sof_utils snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match irqbypass snd_soc_acpi crct10dif_pclmul soundwire_generic_allocation crc32_pclmul soundwire_bus polyval_clmulni polyval_generic iwlmvm snd_soc_core gf128mul btusb snd_compress ghash_clmulni_intel mousedev hid_logitech_dj snd_hda_codec_hdmi ac97_bus sha512_ssse3 vfat btrtl snd_pcm_dmaengine sha256_ssse3 fat btintel snd_hda_intel sha1_ssse3 mac80211 btbcm snd_intel_dspcfg aesni_intel snd_intel_sdw_acpi btmtk i915 crypto_simd
Apr 02 12:56:03 pascal-notebook-manjaro kernel:  snd_hda_codec libarc4 uvcvideo cryptd snd_hda_core videobuf2_vmalloc bluetooth uvc drm_buddy snd_hwdep processor_thermal_device_pci iwlwifi i2c_algo_bit rapl hid_multitouch iTCO_wdt asus_wmi videobuf2_memops processor_thermal_device snd_pcm mei_pxp mei_hdcp ttm intel_cstate processor_thermal_rfim intel_pmc_bxt ledtrig_audio videobuf2_v4l2 pmt_telemetry cfg80211 usbhid videobuf2_common intel_uncore ecdh_generic intel_rapl_msr tuxedo_nb02_nvidia_power_ctrl(OE) spi_nor iTCO_vendor_support pmt_class platform_profile processor_thermal_mbox uniwill_wmi(OE) ov13858 drm_display_helper clevo_wmi(OE) snd_timer mei_me intel_lpss_pci processor_thermal_rapl v4l2_fwnode wmi_bmof pcspkr mtd snd cec intel_lpss v4l2_async ucsi_acpi i2c_hid_acpi intel_rapl_common thunderbolt mei i2c_i801 soundcore idma64 intel_gtt rfkill int340x_thermal_zone i2c_smbus intel_vsec typec_ucsi i2c_hid videodev typec mc roles intel_hid acpi_pad acpi_tad mac_hid squashfs ip6t_REJECT nf_reject_ipv6 xt_hl ip6t_rt ipt_REJECT nf_reject_ipv4 xt_LOG
Apr 02 12:56:03 pascal-notebook-manjaro kernel:  nf_log_syslog xt_limit xt_addrtype xt_tcpudp xt_conntrack nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 libcrc32c ip6table_filter ip6_tables iptable_filter uinput tuxedo_io(OE) tuxedo_keyboard(OE) tuxedo_compatibility_check(OE) sparse_keymap led_class_multicolor vboxnetflt(OE) vboxnetadp(OE) vboxdrv(OE) sg crypto_user fuse dm_mod loop nfnetlink bpf_preload ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 serio_raw atkbd libps2 vivaldi_fmap nvme spi_intel_pci crc32c_intel nvme_core xhci_pci spi_intel xhci_pci_renesas nvme_common i8042 serio nvidia_drm(POE) nvidia_uvm(POE) nvidia_modeset(POE) video wmi nvidia(POE)
OK, I’m no expert and might be completely wrong here. The only way to test this would be to do it and try.
I see a lot of ufw errors. So try disabling that and see. (Don’t worry 'bout a firewall on Linux, at least for now, so you can test if it works. )
systemctl disaable --now ufw.service
  • you are using Nvidia and Wayland - a known bad combo
  • you have at least one extension which is not working
  • you have at least one mount unit for a samba share failing due to incorrect configuration
  • you have installed something related to ASUS on a Tuxedo InfinitiBookPro
    • Hardware name: TUXEDO TUXEDO InfinityBook Pro Gen8 (MK2)
kernel watchdog can be disabled - it can cause hangs - see Improving performance - ArchWiki
My screen resolution is 2560*1600. With X11, the display just isn’t nice with such a display. I’ve never had problems with Wayland and Nvidia before. Even gaming was no problem.
I’ve set up an automount with Samba for my NAS. It actually works without any problems. A bit surprising. Just now, when restarting, the following screen appeared. I took a photo of it. Again, something with my Wi-Fi card. Possibly also the mount configuration?
As far as I know, I haven’t installed anything from Asus. The only thing connected at the moment is a Logitech mouse. Occasionally, I’ve connected an Asus monitor via USB-C to DP. I’ve now disabled the watchdog. I’ll keep an eye on it to see if the problem persists.
That is great :raised_hand: and the Tuxedo InfinityBookPro usually just work.
As yours is labelled MK2 I assume it is the 16" version.
Mine is 14" without Nvidia - no issues with it.
Just for the sake of clarity - did you order it with Tuxedo OS - thus later installing Manjaro?
One idea is that the logging on the mount is caused by the network failing.
Perhaps you should boot it using a live ISO - chroot and do a complete sync with latest repo.
I only mentioned it because in the log you posted above was a reference to ASUS - perhaps the monitor was connected when log was created?
gnome-shell is bailing - usually this is caused by an incompatible extension
The Asus monitor was not connected when the log was created. Indeed, I have a Tuxedo InfinityBook Pro 16 Gen8 MK2. Originally, however, I had the TUXEDO InfinityBook Pro 16 Mk2 - Gen7. Due to a warranty case, I received a free upgrade to the Gen8. I swapped the hard drive from the Gen7 into the Gen8. Could this possibly cause the problem? But it has actually worked well for about 3 months. Otherwise, I would try to perform a complete synchronization with the latest repository.
I reinstalled the kernel after switching notebooks.
These are my active extensions
gnome-extensions list --enabled                                  ✔
Vitals@CoreCoding.com
appindicatorsupport@rgcjonas.gmail.com
apps-menu@gnome-shell-extensions.gcampax.github.com
custom-accent-colors@demiskp
dash-to-dock@micxgx.gmail.com
gnome-ui-tune@itstime.tech
gtk4-ding@smedius.gitlab.com
legacyschemeautoswitcher@joshimukul29.gmail.com
pamac-updates@manjaro.org
user-theme@gnome-shell-extensions.gcampax.github.com
x11gestures@joseexposito.github.io
Oh, and I ordered the notebook without an OS and then directly installed Manjaro myself.
We only support fully synced systems - so if you haven’t done that lately - now is the time :slight_smile:
I have not been gnome user for a very, very long time - searching the repo for indications - I came up with these which stands out as some I couldn’t locate - making them a candidate for disable
Okay, I’ll fully synchronize Manjaro and get back to you. I actually want to move away from Gnome and go back to KDE. I just haven’t looked into how feasible the switch is or whether a fresh installation would be better.
My personal opinion - very personal - it is often easier to reinstall - of course important files shouild exist elsewhere before execute :smile:
While learning is incredibly valuable - with todays fast systems and ample external media - sometimes reinstalling is simply the better solution.
Reflecting on the fresh installation might be a good idea. So, I believe I’ve fully synchronized now, but there was nothing to do. I followed these steps, hoping that was correct?
lsblk         ✔
NAME        MAJ:MIN RM   SIZE RO TYPE MOUNTPOINTS
loop0         7:0    0   153M  1 loop /run/miso/sfs/livefs
loop1         7:1    0   1,2G  1 loop /run/miso/sfs/mhwdfs
loop2         7:2    0   1,7G  1 loop /run/miso/sfs/desktopfs
loop3         7:3    0 767,4M  1 loop /run/miso/sfs/rootfs
sda           8:0    1  28,7G  0 disk
├─sda1        8:1    1  28,6G  0 part
│ └─ventoy  254:0    0   3,9G  1 dm   /run/miso/bootmnt
└─sda2        8:2    1    32M  0 part /run/media/manjaro/VTOYEFI
nvme0n1     259:0    0 931,5G  0 disk
├─nvme0n1p1 259:1    0   100M  0 part
├─nvme0n1p2 259:2    0    16M  0 part
├─nvme0n1p3 259:3    0 344,8G  0 part
├─nvme0n1p4 259:4    0   641M  0 part
└─nvme0n1p5 259:5    0 585,9G  0 part
    ~  sudo mount nvme0n1p5 /mnt         ✔
mount: /mnt: Spezialgerät nvme0n1p5 ist nicht vorhanden.
       dmesg(1) könnte nach einem fehlgeschlagenen mount-Systemaufruf
       weitere Informationen liefern.
    ~  sudo mount dev/nvme0n1p5 /mnt         32 ✘
mount: /mnt: Spezialgerät dev/nvme0n1p5 ist nicht vorhanden.
    ~  sudo mount /dev/nvme0n1p5 /mnt         32 ✘
    ~  sudo mount --bind /dev /mnt/dev         ✔
sudo mount --bind /dev/pts /mnt/dev/pts
sudo mount --bind /proc /mnt/proc
sudo mount --bind /sys /mnt/sys
    ~  sudo chroot /mnt         ✔
[manjaro-gnome /]# pacman-mirrors --fasttrack && pacman -Syyu
::WARNUNG https://repo.manjaro.org 'Connection: HTTPSConnectionPool(host='repo.manjaro.org', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7fe8687d6f90>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution'))'
::WARNUNG https://wikipedia.org 'Connection: HTTPSConnectionPool(host='wikipedia.org', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7fe867a70490>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution'))'
::WARNUNG https://bitbucket.org 'Connection: HTTPSConnectionPool(host='bitbucket.org', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7fe867a70610>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution'))'
::INFO Internetverbindung scheint inaktiv zu sein
::INFO Mirror-Ranking ist nicht verfügbar
::INFO Mirrorliste wird durch Zufallsmethode erzeugt
::INFO Schreibe Mirrorliste
::Germany         : https://mirror.netcologne.de/manjaro/stable/$repo/$arch
::Germany         : https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
::Germany         : https://mirror.alpix.eu/manjaro/stable/$repo/$arch
::Germany         : http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
::Germany         : https://mirror.seahost.de/manjaro/stable/$repo/$arch
::Germany         : https://mirrors.xtom.de/manjaro/stable/$repo/$arch
::Germany         : https://mirror.23m.com/manjaro/stable/$repo/$arch
::Germany         : http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
::Germany         : https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
::INFO Mirrorliste erzeugt und gespeichert nach: /etc/pacman.d/mirrorlist
::INFO To reset custom mirrorlist 'sudo pacman-mirrors -id'
::INFO Um benutzerspezifische Einstellungen zu entfernen starte 'sudo pacman-mirrors -c all'
:: Paketdatenbanken werden synchronisiert …
 core.db konnte nicht heruntergeladen werden
Fehler: Konnte Datei 'core.db' nicht von mirror.netcologne.de übertragen : Could not resolve host: mirror.netcologne.de
Warnung: zu viele Fehlermeldungen von mirror.netcologne.de, überspringe den Rest des Vorgangs
Fehler: Konnte Datei 'core.db' nicht von ftp.gwdg.de übertragen : Could not resolve host: ftp.gwdg.de
Warnung: zu viele Fehlermeldungen von ftp.gwdg.de, überspringe den Rest des Vorgangs
Fehler: Konnte Datei 'core.db' nicht von mirror.alpix.eu übertragen : Could not resolve host: mirror.alpix.eu
Warnung: zu viele Fehlermeldungen von mirror.alpix.eu, überspringe den Rest des Vorgangs
Fehler: Konnte Datei 'core.db' nicht von ftp.tu-chemnitz.de übertragen : Could not resolve host: ftp.tu-chemnitz.de
Warnung: zu viele Fehlermeldungen von ftp.tu-chemnitz.de, überspringe den Rest des Vorgangs
Fehler: Konnte Datei 'core.db' nicht von mirror.seahost.de übertragen : Could not resolve host: mirror.seahost.de
Warnung: zu viele Fehlermeldungen von mirror.seahost.de, überspringe den Rest des Vorgangs
Fehler: Konnte Datei 'core.db' nicht von mirrors.xtom.de übertragen : Could not resolve host: mirrors.xtom.de
Warnung: zu viele Fehlermeldungen von mirrors.xtom.de, überspringe den Rest des Vorgangs
Fehler: Konnte Datei 'core.db' nicht von mirror.23m.com übertragen : Could not resolve host: mirror.23m.com
Warnung: zu viele Fehlermeldungen von mirror.23m.com, überspringe den Rest des Vorgangs
Fehler: Konnte Datei 'core.db' nicht von ftp.rz.tu-bs.de übertragen : Could not resolve host: ftp.rz.tu-bs.de
Warnung: zu viele Fehlermeldungen von ftp.rz.tu-bs.de, überspringe den Rest des Vorgangs
Fehler: Konnte Datei 'core.db' nicht von ftp.halifax.rwth-aachen.de übertragen : Could not resolve host: ftp.halifax.rwth-aachen.de
Warnung: zu viele Fehlermeldungen von ftp.halifax.rwth-aachen.de, überspringe den Rest des Vorgangs
Fehler: Keine Datenbank konnte synchronisiert werden (Ungültige URL für den Server)
[manjaro-gnome /]# ping -c 4 google.com
ping: google.com: Temporärer Fehler bei der Namensauflösung
[manjaro-gnome /]# ping -c 4 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) Bytes an Daten.
64 Bytes von 8.8.8.8: icmp_seq=1 ttl=117 Zeit=32.3 ms
64 Bytes von 8.8.8.8: icmp_seq=2 ttl=117 Zeit=24.8 ms
64 Bytes von 8.8.8.8: icmp_seq=3 ttl=117 Zeit=29.1 ms
64 Bytes von 8.8.8.8: icmp_seq=4 ttl=117 Zeit=31.1 ms
--- 8.8.8.8 ping-Statistik ---
4 Pakete übertragen, 4 empfangen, 0% packet loss, time 3005ms
rtt min/avg/max/mdev = 24.788/29.320/32.349/2.867 ms
[manjaro-gnome /]# nano /etc/resolv.conf
PING google.com (2a00:1450:4005:800::200e) 56 Datenbytes
64 Bytes von ham11s01-in-x0e.1e100.net (2a00:1450:4005:800::200e): icmp_seq=1 ttl=118 Zeit=26.8 ms
64 Bytes von ham11s01-in-x0e.1e100.net (2a00:1450:4005:800::200e): icmp_seq=2 ttl=118 Zeit=30.2 ms
64 Bytes von ham11s01-in-x0e.1e100.net (2a00:1450:4005:800::200e): icmp_seq=3 ttl=118 Zeit=30.5 ms
64 Bytes von ham11s01-in-x0e.1e100.net (2a00:1450:4005:800::200e): icmp_seq=4 ttl=118 Zeit=27.4 ms
--- google.com ping-Statistik ---
rtt min/avg/max/mdev = 26.768/28.729/30.519/1.651 ms
[manjaro-gnome /]# pacman -Syyu
 core                                     150,4 KiB   410 KiB/s 00:00 [######################################] 100%
 extra                                      8,7 MiB  20,5 MiB/s 00:00 [######################################] 100%
 community                                 29,0   B   725   B/s 00:00 [######################################] 100%
 multilib                                 143,9 KiB  3,51 MiB/s 00:00 [######################################] 100%
:: Vollständige Systemaktualisierung wird gestartet …
 Es gibt nichts zu tun
