Hi everyone!
Last week i’m seeing this error in my journalctl log:
-- Journal begins at Sun 2021-01-17 12:01:53 -05, ends at Mon 2021-01-18 08:16:36 -05. --
ene 18 08:15:16 pc kernel: Generic FE-GE Realtek PHY r8169-700:00: r8169_apply_firmware failed: -110
ene 18 08:15:17 pc kernel: Generic FE-GE Realtek PHY r8169-700:00: phy_poll_reset failed: -110
Those are my specs:
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=7a9bcc6c-7a65-45fa-abee-ca484a8d664e rw quiet udev.log_priority=3
Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Portable System: Dell product: Inspiron 3437 v: N/A serial: <filter>
Chassis: type: 8 serial: <filter>
Mobo: Dell model: 04NV60 v: A11 serial: <filter> UEFI: Dell v: A11
date: 05/28/2018
ID-1: BAT0 charge: 23.0 Wh condition: 28.9/32.6 Wh (89%) volts: 15.5/14.8
model: LGC-LGC2.8 DELL T1G4M type: Li-ion serial: <filter>
status: Discharging
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: Discharging
Info: Dual Core model: Intel Core i5-4200U bits: 64 type: MT MCP
arch: Haswell family: 6 model-id: 45 (69) stepping: 1 microcode: 26
L2 cache: 3 MiB
bogomips: 12774
Speed: 798 MHz min/max: 800/2600 MHz Core speeds (MHz): 1: 798 2: 798 3: 800
4: 798
Type: l1tf
Device-1: Intel Haswell-ULT Integrated Graphics vendor: Dell driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:0a16
Device-2: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus ID: 1-1.5:3 chip ID: 0c45:64af
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: intel
unloaded: modesetting alternate: fbdev,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4400 (HSW GT2)
v: 4.5 Mesa 20.3.1 compat-v: 3.0 direct render: Yes
Device-1: Intel Haswell-ULT HD Audio vendor: Dell driver: snd_hda_intel
v: kernel bus ID: 00:03.0 chip ID: 8086:0a0c
Device-2: Intel 8 Series HD Audio vendor: Dell driver: snd_hda_intel
v: kernel bus ID: 00:1b.0 chip ID: 8086:9c20
Sound Server: ALSA v: k5.9.16-1-MANJARO
Device-1: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: Dell driver: ath9k v: kernel port: f040 bus ID: 06:00.0
chip ID: 168c:0036
IF: wlp6s0 state: up mac: <filter>
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel port: e000 bus ID: 07:00.0 chip ID: 10ec:8136
IF: enp7s0 state: down mac: <filter>
Device-3: Qualcomm Atheros AR9462 Bluetooth type: USB driver: btusb
bus ID: 1-1.6:5 chip ID: 0cf3:0036
Local Storage: total: 931.51 GiB used: 36.77 GiB (3.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10JPVX-75JC3T0
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 1A01
ID-1: / raw size: 238.38 GiB size: 233.64 GiB (98.01%)
used: 36.77 GiB (15.7%) fs: ext4 dev: /dev/sda3 maj-min: 8:3
ID-2: /boot/efi raw size: 340 MiB size: 339.3 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: partition size: 11.72 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda4 maj-min: 8:4
System Temperatures: cpu: 47.0 C mobo: 36.0 C
Fan Speeds (RPM): cpu: 0
Processes: 165 Uptime: 10m wakeups: 3 Memory: 11.61 GiB
used: 1.73 GiB (14.9%) Init: systemd v: 247 Compilers: gcc: 10.2.0
clang: 11.0.0 Packages: pacman: 1192 lib: 371 Shell: Bash v: 5.1.0
running in: yakuake inxi: 3.2.01
How i can fix it?
Thanks you by the way!
