Hello,
I run Manjaro XFCE on my Thinkpad. It seems that the last update on 2025-12-15 introduced some potential bugs.
I am talking about the following lines from the logs (see further down for full log):
Dez 22 12:09:54 mjf-laptop kernel: BUG: kernel NULL pointer dereference, address: 0000000000000000
Dez 22 12:09:54 mjf-laptop kernel: #PF: supervisor instruction fetch in kernel mode
Dez 22 12:09:54 mjf-laptop kernel: #PF: error_code(0x0010) - not-present page
Symptoms:
Whenever I start with kernels 6.17.12 or 6.18.1 the screen stays black. It seems that it reaches the login screen but fails to show anything except the mouse pointer.
Switching to a tty works with 6.18 but the tty is unusable. I.e. it is only a black screen with a blinking cursor (tty2) or only shows the boot messages (tty1). In the end, I tried to restart using REISUB, but it did not work and I had to force shut down by a long press on the power button.
With 6.17 switching to tty does not work at all. I just end up with a black screen and a mouse pointer. Same as above: REISUB did not work fully and I had to force shutdown.
With 6.12 I am able to start and it seems to work normally. When I check the log files, the logs for kernel 6.17 and 6.18 contain messages that indicate a kernel bug (see below).
Can anyone confirm if it is a bug or has an idea how to fix the problem?
Disclaimer
I didn’t see anything related in the announcements. There are no packnew-files (I switched to the new mkinitcpio defaults) and I installed the updated grub.
System information
>>sudo inxi -zv8
Kernel: 6.12.62-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=ad323d0f-7b78-4b73-882d-0e75f3dfd6a1 rw udev.log_priority=3
systemd.unified_cgroup_hierarchy=true radeon.runpm=0 nowatchdog
Desktop: Xfce v: 4.20.1 tk: Gtk v: 3.24.51 wm: xfwm4 v: 4.20.0
with: xfce4-panel tools: light-locker dm: LightDM v: 1.32.0 Distro: Manjaro
base: Arch Linux
Type: Laptop System: LENOVO product: 20EV000WGE v: ThinkPad E560
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 20EV000WGE v: 0B98417 WIN serial: <filter>
part-nu: LENOVO_MT_20EV_BU_Think_FM_ThinkPad E560
uuid: a45f11cc-3486-11b2-a85c-8f09095ef911 Firmware: UEFI vendor: LENOVO
v: R00ET69W (1.44 ) date: 06/13/2022
ID-1: BAT0 charge: 44.1 Wh (99.2%) condition: 44.4/47.5 Wh (93.5%)
volts: 10.86 min: 10.8 model: LGC LNV-45N1 type: Li-ion serial: <filter>
charging: status: not charging control: start: 70% end: 85% cycles: N/A
System RAM: total: 8 GiB available: 7.53 GiB used: 3.34 GiB (44.3%)
igpu: 32 MiB
Array-1: capacity: 16 GiB slots: 2 modules: 1 EC: None
Device-1: ChannelA-DIMM0 type: DDR3 detail: synchronous size: 8 GiB
speed: 1600 MT/s volts: curr: 1.35 width (bits): data: 64 total: 64
manufacturer: Micron part-no: 16KTF1G64HZ-1G6E1 serial: <filter>
Device-2: ChannelA-DIMM1 type: no module installed
Device-3: ChannelB-DIMM0 type: no module installed
Device-4: ChannelB-DIMM1 type: no module installed
Slot: N/A type: MediaCard status: available length: other bus-ID: 00:00.0
Slot: N/A type: N/A status: available length: other bus-ID: 00:00.0
Info: model: Intel Core i7-6500U socket: U3E1 bits: 64 type: MT MCP
arch: Skylake gen: core 6 level: v3 note: check built: 2015
process: Intel 14nm family: 6 model-id: 0x4E (78) stepping: 3
microcode: 0xF0
Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
desc: 2x256 KiB L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 541 min/max: 400/3100 base/boost: 3100/3100 scaling:
driver: intel_pstate governor: powersave volts: 1.0 V ext-clock: 100 MHz
cores: 1: 541 2: 541 3: 541 4: 541 bogomips: 20810
Flags: 3dnowprefetch abm acpi adx aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht
hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc
nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt
pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep sgx smap smep ss
ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Type: gather_data_sampling status: Vulnerable: No microcode
vulnerable
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Lenovo driver: i915
v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: eDP-1
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:1916
class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Mars [Radeon HD
8670A/8670M/8750M / R7 M370] vendor: Lenovo driver: amdgpu v: kernel
alternate: radeon arch: GCN-1 code: Southern Islands process: TSMC 28nm
built: 2011-20 pcie: gen: 2 speed: 5 GT/s lanes: 4 link-max: lanes: 8
bus-ID: 03:00.0 chip-ID: 1002:6600 class-ID: 0380 temp: 43.0 C
Device-3: Intel RealSense 3D Camera (Front F200) driver: uvcvideo
type: USB rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-5:2
chip-ID: 8086:0a66 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.21 compositor: xfwm4 v: 4.20.0 driver:
X: loaded: amdgpu,modesetting alternate: fbdev,vesa dri: iris,radeonsi
gpu: i915 display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 509x286mm (20.04x11.26")
s-diag: 584mm (22.99")
Monitor-1: eDP-1 model-id: HKC 0x3cfb built: 2021 res: mode: 1920x1080
hz: 60 scale: 100% (1) dpi: 142 gamma: 1.2 chroma: red: x: 0.576 y: 0.345
green: x: 0.337 y: 0.576 blue: x: 0.153 y: 0.106 white: x: 0.314 y: 0.329
size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9
modes: 1920x1080
API: EGL v: 1.5 hw: drv: intel iris drv: amd radeonsi platforms: device: 0
drv: radeonsi device: 1 drv: iris device: 2 drv: swrast gbm: drv: radeonsi
surfaceless: drv: radeonsi x11: drv: iris inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.3.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 520 (SKL GT2)
device-ID: 8086:1916 memory: 7.36 GiB unified: yes
API: Vulkan v: 1.4.328 layers: 4 device: 0 type: integrated-gpu name: Intel
HD Graphics 520 (SKL GT2) driver: mesa intel v: 25.3.1-arch1.2
device-ID: 8086:1916 surfaces: N/A device: 1 type: discrete-gpu name: AMD
Radeon R7 M370 (RADV OLAND) driver: mesa radv v: 25.3.1-arch1.2
device-ID: 1002:6600 surfaces: N/A
Info: Tools: api: eglinfo, glxinfo, vulkaninfo de: xfce4-display-settings
x11: xdpyinfo, xprop, xrandr
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3
chip-ID: 8086:9d70 class-ID: 0403
API: ALSA v: k6.12.62-1-MANJARO status: kernel-api
Server-2: PipeWire v: 1.4.9 status: n/a (root, process) with:
Device-1: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:1570 class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
Device-2: Intel Dual Band Wireless-AC 3165 Plus Bluetooth driver: iwlwifi
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0
chip-ID: 8086:3166 class-ID: 0280
Info: services: NetworkManager, smbd, systemd-timesyncd, wpa_supplicant
Local Storage: total: 465.76 GiB used: 189.29 GiB (40.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
family: based SSDs size: 465.76 GiB block-size: physical: 512 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 2B6Q temp: 38 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 261d 20h cycles: 2755
written: 7.44 TiB
Optical-1: /dev/sr0 vendor: PLDS model: DVD-RW DA8A6SH rev: GU63
dev-links: cdrom
ID-1: / raw-size: 146.48 GiB size: 143.13 GiB (97.71%) used: 56 GiB (39.1%)
fs: ext4 block-size: 4096 B dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: ad323d0f-7b78-4b73-882d-0e75f3dfd6a1
used: 26 MiB (5.1%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
label: N/A uuid: 21BB-2742
ID-3: /home raw-size: 272.11 GiB size: 266.78 GiB (98.04%)
used: 133.26 GiB (49.9%) fs: ext4 block-size: 4096 B dev: /dev/sda3
maj-min: 8:3 label: N/A uuid: f6596531-db40-494e-923d-3964ae172673
ID-1: swap-1 type: file size: 7.66 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/sda4 maj-min: 8:4 size: 46.09 GiB fs: ntfs label: N/A
uuid: 5C7C32BB7C328FAE
ID-2: /dev/sda5 maj-min: 8:5 size: 594 MiB fs: ntfs label: N/A
uuid: E0C681E7C681BDF2
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-8:3 info: Validity Sensors VFS5011 Fingerprint Reader
type: <vendor specific> driver: N/A interfaces: 1 rev: 1.1
chip-ID: 138a:0011 class-ID: ff00 serial: <filter>
Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.0
Device-1: 2-5:2 info: Intel RealSense 3D Camera (Front F200) type: video
driver: uvcvideo interfaces: 5 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s) lanes: 1
mode: 3.2 gen-1x1 power: 440mA chip-ID: 8086:0a66 class-ID: 0e02
serial: <filter>
System Temperatures: cpu: 45.0 C pch: 40.5 C mobo: 0.0 C gpu: amdgpu
temp: 43.0 C
Fan Speeds (rpm): cpu: 2484 fan-2: 2484
Packages: pm: pacman pkgs: 1612 libs: 428 tools: pamac,yay
1: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
2: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 230
1: cpu: 100% command: ps pid: 5424 mem: 4.01 MiB (0.0%)
2: cpu: 11.6% command: firefox pid: 2440 mem: 628.3 MiB (8.1%)
3: cpu: 7.1% command: firefox pid: 2810 mem: 359.7 MiB (4.6%)
4: cpu: 5.5% command: Xorg pid: 720 mem: 108.7 MiB (1.4%)
5: cpu: 5.0% command: sudo pid: 5389 mem: 9.38 MiB (0.1%)
Memory top: 5 of 230
1: mem: 628.3 MiB (8.1%) command: firefox pid: 2440 cpu: 11.6%
2: mem: 457.9 MiB (5.9%) command: firefox pid: 2636 cpu: 0.7%
3: mem: 359.7 MiB (4.6%) command: firefox pid: 2810 cpu: 7.1%
4: mem: 354.4 MiB (4.5%) command: firefox pid: 4307 cpu: 1.5%
5: mem: 339.4 MiB (4.3%) command: firefox pid: 3051 cpu: 2.1%
Processes: 230 Power: uptime: 28m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 2.99 GiB services: upowerd,xfce4-power-manager
Init: systemd v: 258 default: graphical tool: systemctl
Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Sudo (sudo) v: 1.9.17p2
default: Bash v: 5.3.8 running-in: xfce4-terminal inxi: 3.3.40
Log for 6.18 (level warning):
>>journalctl -b -2 -p warning
Dez 22 12:09:44 manjaro kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
Dez 22 12:09:44 manjaro kernel: MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
Dez 22 12:09:44 manjaro kernel: VMSCAPE: SMT on, STIBP is required for full protection. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/vmscape.html for more details.
Dez 22 12:09:44 manjaro kernel: pnp 00:00: disabling [mem 0x000c0000-0x000c3fff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
Dez 22 12:09:44 manjaro kernel: pnp 00:00: disabling [mem 0x000c4000-0x000c7fff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
Dez 22 12:09:44 manjaro kernel: pnp 00:00: disabling [mem 0x000c8000-0x000cbfff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
Dez 22 12:09:44 manjaro kernel: pnp 00:00: disabling [mem 0x000cc000-0x000cffff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
Dez 22 12:09:44 manjaro kernel: pnp 00:00: disabling [mem 0x000d0000-0x000d3fff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
Dez 22 12:09:44 manjaro kernel: pnp 00:00: disabling [mem 0x000d4000-0x000d7fff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
Dez 22 12:09:44 manjaro kernel: pnp 00:00: disabling [mem 0x000d8000-0x000dbfff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
Dez 22 12:09:44 manjaro kernel: pnp 00:00: disabling [mem 0x000dc000-0x000dffff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
Dez 22 12:09:44 manjaro kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Dez 22 12:09:44 manjaro kernel: ata1.00: Model 'Samsung SSD 860 EVO 500GB', rev 'RVT02B6Q', applying quirks: noncqtrim zeroaftertrim noncqonati nolpmonati
Dez 22 12:09:44 manjaro kernel: ata1.00: supports DRM functions and may not be fully accessible
Dez 22 12:09:49 manjaro kernel: ACPI BIOS Error (bug): AE_AML_BUFFER_LIMIT, Field [TBF3] at bit offset/length 262144/32768 exceeds size of target Buffer (262144 bits) (20250807/dsopcode-198)
Dez 22 12:09:49 manjaro kernel: ACPI Error: Aborting method \_SB.PCI0.GFX0.GETB due to previous error (AE_AML_BUFFER_LIMIT) (20250807/psparse-529)
Dez 22 12:09:49 manjaro kernel: ACPI Error: Aborting method \_SB.PCI0.GFX0.ATRM due to previous error (AE_AML_BUFFER_LIMIT) (20250807/psparse-529)
Dez 22 12:09:49 manjaro kernel: [drm:amdgpu_get_bios [amdgpu]] *ERROR* failed to evaluate ATRM got AE_AML_BUFFER_LIMIT
Dez 22 12:09:51 mjf-laptop systemd-udevd[303]: /etc/udev/rules.d/51-android.rules:1 Group 'androiddev' is not a system group, ignoring.
Dez 22 12:09:52 mjf-laptop kernel: FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Dez 22 12:09:52 mjf-laptop systemd[1]: sys-devices-virtual-misc-rfkill.device: Failed to enqueue SYSTEMD_WANTS job, ignoring: Unit systemd-rfkill.socket is masked.
Dez 22 12:09:52 mjf-laptop kernel: at24 14-0050: supply vcc not found, using dummy regulator
Dez 22 12:09:53 mjf-laptop kernel: ACPI BIOS Error (bug): AE_AML_PACKAGE_LIMIT, Index (0x00000005A) is beyond end of object (length 0x5A) (20250807/exoparg2-393)
Dez 22 12:09:53 mjf-laptop kernel: ACPI Error: Aborting method \_SB.WMI1.WQA0 due to previous error (AE_AML_PACKAGE_LIMIT) (20250807/psparse-529)
Dez 22 12:09:53 mjf-laptop (uetoothd)[689]: bluetooth.service: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Dez 22 12:09:53 mjf-laptop NetworkManager[611]: <warn> [1766401793.9429] device (p2p-dev-wlp1s0): error setting IPv4 forwarding to '0': Die Ressource ist zur Zeit nicht verfügbar
Dez 22 12:09:54 mjf-laptop nmbd[713]: [2025/12/22 12:09:54.088827, 0] ../../source3/nmbd/nmbd_subnetdb.c:252(create_subnets)
Dez 22 12:09:54 mjf-laptop kernel: Oops: Oops: 0010 [#1] SMP PTI
Dez 22 12:09:54 mjf-laptop nmbd[713]: NOTE: NetBIOS name resolution is not supported for Internet Protocol Version 6 (IPv6).
Dez 22 12:09:54 mjf-laptop kernel: CPU: 0 UID: 0 PID: 9 Comm: kworker/0:0 Tainted: G U 6.18.1-1-MANJARO #1 PREEMPT(full) ac9f7f9cbf06bb1b3589e32b70c6de414b325132
Dez 22 12:09:54 mjf-laptop kernel: Tainted: [U]=USER
Dez 22 12:09:54 mjf-laptop kernel: Hardware name: LENOVO 20EV000WGE/20EV000WGE, BIOS R00ET69W (1.44 ) 06/13/2022
Dez 22 12:09:54 mjf-laptop kernel: Workqueue: events amdgpu_tlb_fence_work [amdgpu]
Dez 22 12:09:54 mjf-laptop kernel: RIP: 0010:0x0
Dez 22 12:09:54 mjf-laptop kernel: Code: Unable to access opcode bytes at 0xffffffffffffffd6.
Dez 22 12:09:54 mjf-laptop kernel: RSP: 0018:ffffd3f2800a7dd0 EFLAGS: 00010246
Dez 22 12:09:54 mjf-laptop kernel: RAX: 0000000000000000 RBX: ffff8e000da00000 RCX: 0000000000000001
Dez 22 12:09:54 mjf-laptop kernel: RDX: 0000000000000002 RSI: 0000000000008000 RDI: ffff8e000da00000
Dez 22 12:09:54 mjf-laptop kernel: RBP: 0000000000008000 R08: 0000000000000000 R09: 0000000000000001
Dez 22 12:09:54 mjf-laptop kernel: R10: ffff8e0005341b80 R11: 0000000000000000 R12: 0000000000000001
Dez 22 12:09:54 mjf-laptop kernel: R13: 0000000000000002 R14: 0000000000000000 R15: ffff8e00183c0650
Dez 22 12:09:54 mjf-laptop kernel: FS: 0000000000000000(0000) GS:ffff8e019daf1000(0000) knlGS:0000000000000000
Dez 22 12:09:54 mjf-laptop kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Dez 22 12:09:54 mjf-laptop kernel: CR2: ffffffffffffffd6 CR3: 0000000106374002 CR4: 00000000003726f0
Dez 22 12:09:54 mjf-laptop kernel: Call Trace:
Dez 22 12:09:54 mjf-laptop kernel: <TASK>
Dez 22 12:09:54 mjf-laptop kernel: amdgpu_gmc_flush_gpu_tlb_pasid+0xc2/0x350 [amdgpu b6f7ffbc76b44044464c70c7af303860278decf5]
Dez 22 12:09:54 mjf-laptop kernel: amdgpu_tlb_fence_work+0x6e/0xe0 [amdgpu b6f7ffbc76b44044464c70c7af303860278decf5]
Dez 22 12:09:54 mjf-laptop kernel: process_one_work+0x193/0x350
Dez 22 12:09:54 mjf-laptop kernel: worker_thread+0x2d7/0x410
Dez 22 12:09:54 mjf-laptop kernel: ? __pfx_worker_thread+0x10/0x10
Dez 22 12:09:54 mjf-laptop kernel: kthread+0xfc/0x240
Dez 22 12:09:54 mjf-laptop kernel: ? __pfx_kthread+0x10/0x10
Dez 22 12:09:54 mjf-laptop kernel: ret_from_fork+0x1c2/0x1f0
Dez 22 12:09:54 mjf-laptop kernel: ret_from_fork_asm+0x1a/0x30
Dez 22 12:09:54 mjf-laptop kernel: </TASK>
Dez 22 12:09:54 mjf-laptop kernel: Modules linked in: cmac algif_hash algif_skcipher uvcvideo af_alg videobuf2_vmalloc uvc bnep videobuf2_memops videobuf2_v4l2 videobuf2_common videodev mc btusb btmtk btrtl btbcm btintel bluetooth joydev mousedev snd_hda_codec_intelhdmi snd_hda_codec_hdmi snd_ctl_led snd_hda_codec_conexant snd_hda_codec_generic intel_rapl_msr intel_rapl_common intel_pmc_core_pltdrv snd_hda_intel intel_pmc_core pmt_telemetry snd_soc_avs pmt_discovery pmt_class snd_soc_hda_codec snd_hda_ext_core intel_pmc_ssram_telemetry intel_vsec intel_tcc_cooling snd_hda_codec x86_pkg_temp_thermal intel_powerclamp coretemp snd_hda_core kvm_intel snd_intel_dspcfg snd_intel_sdw_acpi snd_hwdep at24 iwlmvm kvm snd_soc_core mac80211 snd_compress mei_pxp mei_hdcp libarc4 ac97_bus irqbypass polyval_clmulni ghash_clmulni_intel snd_pcm_dmaengine iwlwifi rapl i2c_i801 think_lmi snd_pcm nls_iso8859_1 e1000e vfat i2c_smbus intel_cstate ptp intel_uncore firmware_attributes_class fat psmouse pps_core wmi_bmof snd_timer i2c_mux cfg80211
Dez 22 12:09:54 mjf-laptop kernel: intel_xhci_usb_role_switch roles intel_pch_thermal mei_me mei intel_oc_wdt mac_hid ip6t_REJECT nf_reject_ipv6 xt_hl ip6t_rt ipt_REJECT nf_reject_ipv4 xt_LOG nf_log_syslog xt_multiport xt_limit xt_addrtype xt_tcpudp xt_conntrack nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 ip6table_filter ip6_tables iptable_filter usbip_host usbip_core uinput i2c_dev crypto_user ntsync loop dm_mod nfnetlink ip_tables x_tables amdgpu amdxcp drm_panel_backlight_quirks gpu_sched i915 radeon intel_gtt rtsx_pci_sdmmc drm_buddy drm_ttm_helper mmc_core thinkpad_acpi ttm sparse_keymap drm_exec platform_profile drm_suballoc_helper sr_mod i2c_algo_bit cdrom snd rtsx_pci drm_display_helper soundcore rfkill cec video wmi serio_raw
Dez 22 12:09:54 mjf-laptop kernel: CR2: 0000000000000000
Dez 22 12:09:54 mjf-laptop kernel: ---[ end trace 0000000000000000 ]---
Dez 22 12:09:54 mjf-laptop kernel: Oops: Oops: 0010 [#2] SMP PTI
Dez 22 12:09:54 mjf-laptop kernel: CPU: 2 UID: 0 PID: 59 Comm: kworker/2:1 Tainted: G UD 6.18.1-1-MANJARO #1 PREEMPT(full) ac9f7f9cbf06bb1b3589e32b70c6de414b325132
Dez 22 12:09:54 mjf-laptop kernel: Tainted: [U]=USER, [D]=DIE
Dez 22 12:09:54 mjf-laptop kernel: RSP: 0018:ffffd3f28025fdd0 EFLAGS: 00010246
Dez 22 12:09:54 mjf-laptop kernel: RDX: 0000000000000002 RSI: 0000000000008001 RDI: ffff8e000da00000
Dez 22 12:09:54 mjf-laptop kernel: RBP: 0000000000008001 R08: 0000000000000000 R09: 0000000000000001
Dez 22 12:09:54 mjf-laptop kernel: R13: 0000000000000002 R14: 0000000000000000 R15: ffff8e00062dd7d0
Dez 22 12:09:54 mjf-laptop kernel: FS: 0000000000000000(0000) GS:ffff8e019dbf1000(0000) knlGS:0000000000000000
Dez 22 12:09:54 mjf-laptop kernel: CR2: ffffffffffffffd6 CR3: 000000010b0b8005 CR4: 00000000003726f0
Dez 22 12:09:54 mjf-laptop kernel: Oops: Oops: 0010 [#3] SMP PTI
Dez 22 12:09:54 mjf-laptop kernel: CPU: 0 UID: 0 PID: 111 Comm: kworker/0:2 Tainted: G UD 6.18.1-1-MANJARO #1 PREEMPT(full) ac9f7f9cbf06bb1b3589e32b70c6de414b325132
Dez 22 12:09:54 mjf-laptop kernel: RSP: 0000:ffffd3f28057fdd0 EFLAGS: 00010246
Dez 22 12:09:54 mjf-laptop kernel: RDX: 0000000000000002 RSI: 0000000000008002 RDI: ffff8e000da00000
Dez 22 12:09:54 mjf-laptop kernel: RBP: 0000000000008002 R08: 0000000000000000 R09: 0000000000000001
Dez 22 12:09:54 mjf-laptop kernel: R13: 0000000000000002 R14: 0000000000000000 R15: ffff8e00183c0d50
Dez 22 12:09:54 mjf-laptop kernel: CR2: ffffffffffffffd6 CR3: 000000010b0b8006 CR4: 00000000003726f0
Dez 22 12:09:54 mjf-laptop kernel: Oops: Oops: 0010 [#4] SMP PTI
Dez 22 12:09:54 mjf-laptop kernel: CPU: 1 UID: 0 PID: 68 Comm: kworker/1:1 Tainted: G UD 6.18.1-1-MANJARO #1 PREEMPT(full) ac9f7f9cbf06bb1b3589e32b70c6de414b325132
Dez 22 12:09:54 mjf-laptop kernel: RSP: 0018:ffffd3f280483dd0 EFLAGS: 00010246
Dez 22 12:09:54 mjf-laptop kernel: RDX: 0000000000000002 RSI: 0000000000008003 RDI: ffff8e000da00000
Dez 22 12:09:54 mjf-laptop kernel: RBP: 0000000000008003 R08: 0000000000000000 R09: 0000000000000001
Dez 22 12:09:54 mjf-laptop kernel: R13: 0000000000000002 R14: 0000000000000000 R15: ffff8e000c8835d0
Dez 22 12:09:54 mjf-laptop kernel: FS: 0000000000000000(0000) GS:ffff8e019db71000(0000) knlGS:0000000000000000
Dez 22 12:09:54 mjf-laptop kernel: CR2: ffffffffffffffd6 CR3: 000000010b0b8001 CR4: 00000000003726f0
Dez 22 12:09:55 mjf-laptop systemd[1]: sys-devices-virtual-misc-rfkill.device: Failed to enqueue SYSTEMD_WANTS job, ignoring: Unit systemd-rfkill.socket is masked.
Dez 22 12:09:55 mjf-laptop dbus-broker-launch[601]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
Dez 22 12:09:56 mjf-laptop dbus-broker-launch[815]: Service file '/usr/share/dbus-1/services/org.xfce.Thunar.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Dez 22 12:09:56 mjf-laptop dbus-broker-launch[815]: Service file '/usr/share/dbus-1/services/org.xfce.Tumbler.Cache1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Cache1'.
Dez 22 12:09:56 mjf-laptop dbus-broker-launch[815]: Service file '/usr/share/dbus-1/services/org.xfce.Tumbler.Manager1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Manager1'.
Dez 22 12:09:56 mjf-laptop dbus-broker-launch[815]: Service file '/usr/share/dbus-1/services/org.xfce.Tumbler.Thumbnailer1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Thumbnailer1'.
Dez 22 12:09:56 mjf-laptop dbus-broker-launch[815]: Service file '/usr/share/dbus-1/services/org.xfce.xfce4-notifyd.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Dez 22 12:09:56 mjf-laptop dbus-broker-launch[815]: Service file '/usr/share/dbus-1/services/org.xfce.xfce4-notifyd.Notifyd.service' is not named after the D-Bus name 'org.xfce.Notifyd'.
Dez 22 12:10:17 mjf-laptop kernel: amdgpu 0000:03:00.0: amdgpu: evicting device resources failed
Dez 22 12:10:18 mjf-laptop systemd[1]: sys-devices-virtual-misc-rfkill.device: Failed to enqueue SYSTEMD_WANTS job, ignoring: Unit systemd-rfkill.socket is masked.
Dez 22 12:10:39 mjf-laptop kernel: amdgpu 0000:03:00.0: amdgpu: evicting device resources failed
Dez 22 12:11:00 mjf-laptop systemd[1]: sys-devices-virtual-misc-rfkill.device: Failed to enqueue SYSTEMD_WANTS job, ignoring: Unit systemd-rfkill.socket is masked.
Dez 22 12:11:22 mjf-laptop kernel: amdgpu 0000:03:00.0: amdgpu: evicting device resources failed
Dez 22 12:11:22 mjf-laptop systemd[1]: sys-devices-virtual-misc-rfkill.device: Failed to enqueue SYSTEMD_WANTS job, ignoring: Unit systemd-rfkill.socket is masked.
Dez 22 12:11:24 mjf-laptop systemd[1]: nmb.service: start operation timed out. Terminating.
Dez 22 12:11:24 mjf-laptop systemd[1]: nmb.service: Failed with result 'timeout'.
Dez 22 12:11:24 mjf-laptop systemd[1]: Failed to start Samba NMB Daemon.
Log for 6.17 (level warning):
>> journalctl -b -1 -p warning
Dez 22 13:21:27 manjaro kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
Dez 22 13:21:27 manjaro kernel: MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
Dez 22 13:21:27 manjaro kernel: VMSCAPE: SMT on, STIBP is required for full protection. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/vmscape.html for more details.
Dez 22 13:21:27 manjaro kernel: pnp 00:00: disabling [mem 0x000c0000-0x000c3fff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
Dez 22 13:21:27 manjaro kernel: pnp 00:00: disabling [mem 0x000c4000-0x000c7fff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
Dez 22 13:21:27 manjaro kernel: pnp 00:00: disabling [mem 0x000c8000-0x000cbfff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
Dez 22 13:21:27 manjaro kernel: pnp 00:00: disabling [mem 0x000cc000-0x000cffff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
Dez 22 13:21:27 manjaro kernel: pnp 00:00: disabling [mem 0x000d0000-0x000d3fff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
Dez 22 13:21:27 manjaro kernel: pnp 00:00: disabling [mem 0x000d4000-0x000d7fff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
Dez 22 13:21:27 manjaro kernel: pnp 00:00: disabling [mem 0x000d8000-0x000dbfff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
Dez 22 13:21:27 manjaro kernel: pnp 00:00: disabling [mem 0x000dc000-0x000dffff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
Dez 22 13:21:27 manjaro kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Dez 22 13:21:27 manjaro kernel: ata1.00: Model 'Samsung SSD 860 EVO 500GB', rev 'RVT02B6Q', applying quirks: noncqtrim zeroaftertrim noncqonati nolpmonati
Dez 22 13:21:27 manjaro kernel: ata1.00: supports DRM functions and may not be fully accessible
Dez 22 13:21:32 manjaro kernel: ACPI BIOS Error (bug): AE_AML_BUFFER_LIMIT, Field [TBF3] at bit offset/length 262144/32768 exceeds size of target Buffer (262144 bits) (20250404/dsopcode-198)
Dez 22 13:21:32 manjaro kernel: ACPI Error: Aborting method \_SB.PCI0.GFX0.GETB due to previous error (AE_AML_BUFFER_LIMIT) (20250404/psparse-529)
Dez 22 13:21:32 manjaro kernel: ACPI Error: Aborting method \_SB.PCI0.GFX0.ATRM due to previous error (AE_AML_BUFFER_LIMIT) (20250404/psparse-529)
Dez 22 13:21:32 manjaro kernel: [drm:amdgpu_get_bios [amdgpu]] *ERROR* failed to evaluate ATRM got AE_AML_BUFFER_LIMIT
Dez 22 13:21:34 mjf-laptop systemd-udevd[288]: /etc/udev/rules.d/51-android.rules:1 Group 'androiddev' is not a system group, ignoring.
Dez 22 13:21:35 mjf-laptop systemd[1]: sys-devices-virtual-misc-rfkill.device: Failed to enqueue SYSTEMD_WANTS job, ignoring: Unit systemd-rfkill.socket is masked.
Dez 22 13:21:35 mjf-laptop kernel: FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Dez 22 13:21:35 mjf-laptop kernel: at24 14-0050: supply vcc not found, using dummy regulator
Dez 22 13:21:36 mjf-laptop kernel: ACPI BIOS Error (bug): AE_AML_PACKAGE_LIMIT, Index (0x00000005A) is beyond end of object (length 0x5A) (20250404/exoparg2-393)
Dez 22 13:21:36 mjf-laptop kernel: ACPI Error: Aborting method \_SB.WMI1.WQA0 due to previous error (AE_AML_PACKAGE_LIMIT) (20250404/psparse-529)
Dez 22 13:21:36 mjf-laptop (uetoothd)[656]: bluetooth.service: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Dez 22 13:21:36 mjf-laptop NetworkManager[593]: <warn> [1766406096.7053] device (p2p-dev-wlp1s0): error setting IPv4 forwarding to '0': Die Ressource ist zur Zeit nicht verfügbar
Dez 22 13:21:36 mjf-laptop kernel: BUG: kernel NULL pointer dereference, address: 0000000000000000
Dez 22 13:21:36 mjf-laptop kernel: #PF: supervisor instruction fetch in kernel mode
Dez 22 13:21:36 mjf-laptop kernel: #PF: error_code(0x0010) - not-present page
Dez 22 13:21:36 mjf-laptop kernel: Oops: Oops: 0010 [#1] SMP PTI
Dez 22 13:21:36 mjf-laptop kernel: CPU: 2 UID: 0 PID: 119 Comm: kworker/2:2 Tainted: G U 6.17.12-1-MANJARO #1 PREEMPT(full) 201fa0c91753e6583ca8ac4a1c2c3fe98cee1d85
Dez 22 13:21:36 mjf-laptop kernel: Tainted: [U]=USER
Dez 22 13:21:36 mjf-laptop kernel: Hardware name: LENOVO 20EV000WGE/20EV000WGE, BIOS R00ET69W (1.44 ) 06/13/2022
Dez 22 13:21:36 mjf-laptop kernel: Workqueue: events amdgpu_tlb_fence_work [amdgpu]
Dez 22 13:21:36 mjf-laptop kernel: RIP: 0010:0x0
Dez 22 13:21:36 mjf-laptop kernel: Code: Unable to access opcode bytes at 0xffffffffffffffd6.
Dez 22 13:21:36 mjf-laptop kernel: RSP: 0018:ffffd0f5c0463dd0 EFLAGS: 00010246
Dez 22 13:21:36 mjf-laptop kernel: RAX: 0000000000000000 RBX: ffff8d2c4fa00000 RCX: 0000000000000001
Dez 22 13:21:36 mjf-laptop kernel: RDX: 0000000000000002 RSI: 0000000000008000 RDI: ffff8d2c4fa00000
Dez 22 13:21:36 mjf-laptop kernel: RBP: 0000000000008000 R08: 0000000000000000 R09: 0000000000000001
Dez 22 13:21:36 mjf-laptop kernel: R10: ffff8d2c42d49b40 R11: 0000000000000000 R12: 0000000000000001
Dez 22 13:21:36 mjf-laptop kernel: R13: 0000000000000002 R14: 0000000000000000 R15: ffff8d2c44b38750
Dez 22 13:21:36 mjf-laptop kernel: FS: 0000000000000000(0000) GS:ffff8d2dd6409000(0000) knlGS:0000000000000000
Dez 22 13:21:36 mjf-laptop kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Dez 22 13:21:36 mjf-laptop kernel: CR2: ffffffffffffffd6 CR3: 0000000107720001 CR4: 00000000003726f0
Dez 22 13:21:36 mjf-laptop kernel: Call Trace:
Dez 22 13:21:36 mjf-laptop kernel: <TASK>
Dez 22 13:21:36 mjf-laptop kernel: amdgpu_gmc_flush_gpu_tlb_pasid+0xbf/0x350 [amdgpu 60caaa41a68a3b2400628944d6be66c266880f13]
Dez 22 13:21:36 mjf-laptop kernel: amdgpu_tlb_fence_work+0x6e/0xe0 [amdgpu 60caaa41a68a3b2400628944d6be66c266880f13]
Dez 22 13:21:36 mjf-laptop kernel: process_one_work+0x190/0x350
Dez 22 13:21:36 mjf-laptop kernel: worker_thread+0x2d7/0x410
Dez 22 13:21:36 mjf-laptop kernel: ? __pfx_worker_thread+0x10/0x10
Dez 22 13:21:36 mjf-laptop kernel: kthread+0xf9/0x240
Dez 22 13:21:36 mjf-laptop kernel: ? __pfx_kthread+0x10/0x10
Dez 22 13:21:36 mjf-laptop kernel: ret_from_fork+0x1c1/0x1f0
Dez 22 13:21:36 mjf-laptop kernel: ret_from_fork_asm+0x1a/0x30
Dez 22 13:21:36 mjf-laptop kernel: </TASK>
Dez 22 13:21:36 mjf-laptop kernel: Modules linked in: cmac algif_hash algif_skcipher af_alg uvcvideo videobuf2_vmalloc uvc videobuf2_memops videobuf2_v4l2 videobuf2_common videodev mc bnep btusb btrtl btintel btbcm btmtk bluetooth joydev mousedev intel_rapl_msr intel_rapl_common intel_pmc_core_pltdrv snd_hda_codec_intelhdmi snd_hda_codec_hdmi intel_pmc_core pmt_telemetry pmt_discovery snd_ctl_led pmt_class snd_hda_codec_conexant intel_pmc_ssram_telemetry snd_hda_codec_generic intel_vsec intel_tcc_cooling snd_hda_intel x86_pkg_temp_thermal intel_powerclamp snd_soc_avs coretemp snd_soc_hda_codec snd_hda_ext_core kvm_intel snd_hda_codec snd_hda_core kvm snd_intel_dspcfg snd_intel_sdw_acpi iwlmvm irqbypass mei_hdcp mei_pxp at24 polyval_clmulni ghash_clmulni_intel mac80211 snd_hwdep libarc4 snd_soc_core snd_compress nls_iso8859_1 rapl vfat fat iwlwifi intel_cstate ac97_bus e1000e think_lmi snd_pcm_dmaengine intel_uncore psmouse ptp cfg80211 snd_pcm i2c_i801 firmware_attributes_class wmi_bmof pps_core i2c_smbus mei_me snd_timer
Dez 22 13:21:36 mjf-laptop kernel: intel_xhci_usb_role_switch i2c_mux mei roles intel_pch_thermal intel_oc_wdt mac_hid ip6t_REJECT nf_reject_ipv6 xt_hl ip6t_rt ipt_REJECT nf_reject_ipv4 xt_LOG nf_log_syslog xt_multiport xt_limit xt_addrtype xt_tcpudp xt_conntrack nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 ip6table_filter ip6_tables iptable_filter usbip_host usbip_core uinput i2c_dev crypto_user ntsync loop dm_mod nfnetlink ip_tables x_tables amdgpu amdxcp drm_panel_backlight_quirks gpu_sched i915 rtsx_pci_sdmmc radeon thinkpad_acpi mmc_core sparse_keymap intel_gtt drm_ttm_helper drm_buddy platform_profile sr_mod ttm drm_exec snd cdrom soundcore i2c_algo_bit drm_suballoc_helper rtsx_pci rfkill drm_display_helper video cec wmi serio_raw
Dez 22 13:21:36 mjf-laptop kernel: CR2: 0000000000000000
Dez 22 13:21:36 mjf-laptop kernel: ---[ end trace 0000000000000000 ]---
Dez 22 13:21:36 mjf-laptop nmbd[694]: [2025/12/22 13:21:36.825134, 0] ../../source3/nmbd/nmbd_subnetdb.c:252(create_subnets)
Dez 22 13:21:36 mjf-laptop nmbd[694]: NOTE: NetBIOS name resolution is not supported for Internet Protocol Version 6 (IPv6).
Dez 22 13:21:36 mjf-laptop kernel: Oops: Oops: 0010 [#2] SMP PTI
Dez 22 13:21:36 mjf-laptop kernel: CPU: 0 UID: 0 PID: 11 Comm: kworker/0:1 Tainted: G UD 6.17.12-1-MANJARO #1 PREEMPT(full) 201fa0c91753e6583ca8ac4a1c2c3fe98cee1d85
Dez 22 13:21:36 mjf-laptop kernel: Tainted: [U]=USER, [D]=DIE
Dez 22 13:21:36 mjf-laptop kernel: RSP: 0018:ffffd0f5c00b7dd0 EFLAGS: 00010246
Dez 22 13:21:36 mjf-laptop kernel: RDX: 0000000000000002 RSI: 0000000000008001 RDI: ffff8d2c4fa00000
Dez 22 13:21:36 mjf-laptop kernel: RBP: 0000000000008001 R08: 0000000000000000 R09: 0000000000000001
Dez 22 13:21:36 mjf-laptop kernel: R10: ffff8d2c40c19b40 R11: 0000000000000000 R12: 0000000000000001
Dez 22 13:21:36 mjf-laptop kernel: R13: 0000000000000002 R14: 0000000000000000 R15: ffff8d2c4a0d4f50
Dez 22 13:21:36 mjf-laptop kernel: FS: 0000000000000000(0000) GS:ffff8d2dd6309000(0000) knlGS:0000000000000000
Dez 22 13:21:36 mjf-laptop kernel: CR2: ffffffffffffffd6 CR3: 000000021f424006 CR4: 00000000003726f0
Dez 22 13:21:36 mjf-laptop kernel: Oops: Oops: 0010 [#3] SMP PTI
Dez 22 13:21:36 mjf-laptop kernel: CPU: 2 UID: 0 PID: 33 Comm: kworker/2:0 Tainted: G UD 6.17.12-1-MANJARO #1 PREEMPT(full) 201fa0c91753e6583ca8ac4a1c2c3fe98cee1d85
Dez 22 13:21:36 mjf-laptop kernel: RSP: 0018:ffffd0f5c0183dd0 EFLAGS: 00010246
Dez 22 13:21:36 mjf-laptop kernel: RDX: 0000000000000002 RSI: 0000000000008002 RDI: ffff8d2c4fa00000
Dez 22 13:21:36 mjf-laptop kernel: RBP: 0000000000008002 R08: 0000000000000000 R09: 0000000000000001
Dez 22 13:21:36 mjf-laptop kernel: R10: 00000000fffffffb R11: 0000000000000000 R12: 0000000000000001
Dez 22 13:21:36 mjf-laptop kernel: R13: 0000000000000002 R14: 0000000000000000 R15: ffff8d2c4a65cd50
Dez 22 13:21:36 mjf-laptop kernel: CR2: ffffffffffffffd6 CR3: 000000021f424002 CR4: 00000000003726f0
Dez 22 13:21:36 mjf-laptop kernel: Oops: Oops: 0010 [#4] SMP PTI
Dez 22 13:21:36 mjf-laptop kernel: CPU: 1 UID: 0 PID: 162 Comm: kworker/1:3 Tainted: G UD 6.17.12-1-MANJARO #1 PREEMPT(full) 201fa0c91753e6583ca8ac4a1c2c3fe98cee1d85
Dez 22 13:21:36 mjf-laptop kernel: RSP: 0018:ffffd0f5c0567dd0 EFLAGS: 00010246
Dez 22 13:21:36 mjf-laptop kernel: RDX: 0000000000000002 RSI: 0000000000008003 RDI: ffff8d2c4fa00000
Dez 22 13:21:36 mjf-laptop kernel: RBP: 0000000000008003 R08: 0000000000000000 R09: 0000000000000001
Dez 22 13:21:36 mjf-laptop kernel: R10: ffff8d2c4ca33680 R11: 0000000000000000 R12: 0000000000000001
Dez 22 13:21:36 mjf-laptop kernel: R13: 0000000000000002 R14: 0000000000000000 R15: ffff8d2c46b17150
Dez 22 13:21:36 mjf-laptop kernel: FS: 0000000000000000(0000) GS:ffff8d2dd6389000(0000) knlGS:0000000000000000
Dez 22 13:21:36 mjf-laptop kernel: CR2: ffffffffffffffd6 CR3: 000000021f424003 CR4: 00000000003726f0
Dez 22 13:21:37 mjf-laptop kernel: BUG: kernel NULL pointer dereference, address: 0000000000000000
Dez 22 13:21:37 mjf-laptop kernel: #PF: supervisor instruction fetch in kernel mode
Dez 22 13:21:37 mjf-laptop kernel: #PF: error_code(0x0010) - not-present page
Dez 22 13:21:37 mjf-laptop kernel: Oops: Oops: 0010 [#5] SMP PTI
Dez 22 13:21:37 mjf-laptop kernel: CPU: 2 UID: 0 PID: 59 Comm: kworker/2:1 Tainted: G UD 6.17.12-1-MANJARO #1 PREEMPT(full) 201fa0c91753e6583ca8ac4a1c2c3fe98cee1d85
Dez 22 13:21:37 mjf-laptop kernel: Tainted: [U]=USER, [D]=DIE
Dez 22 13:21:37 mjf-laptop kernel: Hardware name: LENOVO 20EV000WGE/20EV000WGE, BIOS R00ET69W (1.44 ) 06/13/2022
Dez 22 13:21:37 mjf-laptop kernel: Workqueue: events amdgpu_tlb_fence_work [amdgpu]
Dez 22 13:21:37 mjf-laptop kernel: RIP: 0010:0x0
Dez 22 13:21:37 mjf-laptop kernel: Code: Unable to access opcode bytes at 0xffffffffffffffd6.
Dez 22 13:21:37 mjf-laptop kernel: RSP: 0000:ffffd0f5c025fdd0 EFLAGS: 00010246
Dez 22 13:21:37 mjf-laptop kernel: RAX: 0000000000000000 RBX: ffff8d2c4fa00000 RCX: 0000000000000001
Dez 22 13:21:37 mjf-laptop kernel: RDX: 0000000000000002 RSI: 0000000000008003 RDI: ffff8d2c4fa00000
Dez 22 13:21:37 mjf-laptop kernel: RBP: 0000000000008003 R08: 0000000000000000 R09: 0000000000000001
Dez 22 13:21:37 mjf-laptop kernel: R10: ffff8d2c4004c8c0 R11: fefefefefefefeff R12: 0000000000000001
Dez 22 13:21:37 mjf-laptop kernel: R13: 0000000000000002 R14: 0000000000000000 R15: ffff8d2c4a65c4d0
Dez 22 13:21:37 mjf-laptop kernel: FS: 0000000000000000(0000) GS:ffff8d2dd6409000(0000) knlGS:0000000000000000
Dez 22 13:21:37 mjf-laptop kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Dez 22 13:21:37 mjf-laptop kernel: CR2: ffffffffffffffd6 CR3: 000000010ee10004 CR4: 00000000003726f0
Dez 22 13:21:37 mjf-laptop kernel: Call Trace:
Dez 22 13:21:37 mjf-laptop kernel: <TASK>
Dez 22 13:21:37 mjf-laptop kernel: amdgpu_gmc_flush_gpu_tlb_pasid+0xbf/0x350 [amdgpu 60caaa41a68a3b2400628944d6be66c266880f13]
Dez 22 13:21:37 mjf-laptop kernel: amdgpu_tlb_fence_work+0x6e/0xe0 [amdgpu 60caaa41a68a3b2400628944d6be66c266880f13]
Dez 22 13:21:37 mjf-laptop kernel: process_one_work+0x190/0x350
Dez 22 13:21:37 mjf-laptop kernel: worker_thread+0x2d7/0x410
Dez 22 13:21:37 mjf-laptop kernel: ? __pfx_worker_thread+0x10/0x10
Dez 22 13:21:37 mjf-laptop kernel: kthread+0xf9/0x240
Dez 22 13:21:37 mjf-laptop kernel: ? __pfx_kthread+0x10/0x10
Dez 22 13:21:37 mjf-laptop kernel: ret_from_fork+0x1c1/0x1f0
Dez 22 13:21:37 mjf-laptop kernel: ret_from_fork_asm+0x1a/0x30
Dez 22 13:21:37 mjf-laptop kernel: </TASK>
Dez 22 13:21:37 mjf-laptop kernel: Modules linked in: cmac algif_hash algif_skcipher af_alg uvcvideo videobuf2_vmalloc uvc videobuf2_memops videobuf2_v4l2 videobuf2_common videodev mc bnep btusb btrtl btintel btbcm btmtk bluetooth joydev mousedev intel_rapl_msr intel_rapl_common intel_pmc_core_pltdrv snd_hda_codec_intelhdmi snd_hda_codec_hdmi intel_pmc_core pmt_telemetry pmt_discovery snd_ctl_led pmt_class snd_hda_codec_conexant intel_pmc_ssram_telemetry snd_hda_codec_generic intel_vsec intel_tcc_cooling snd_hda_intel x86_pkg_temp_thermal intel_powerclamp snd_soc_avs coretemp snd_soc_hda_codec snd_hda_ext_core kvm_intel snd_hda_codec snd_hda_core kvm snd_intel_dspcfg snd_intel_sdw_acpi iwlmvm irqbypass mei_hdcp mei_pxp at24 polyval_clmulni ghash_clmulni_intel mac80211 snd_hwdep libarc4 snd_soc_core snd_compress nls_iso8859_1 rapl vfat fat iwlwifi intel_cstate ac97_bus e1000e think_lmi snd_pcm_dmaengine intel_uncore psmouse ptp cfg80211 snd_pcm i2c_i801 firmware_attributes_class wmi_bmof pps_core i2c_smbus mei_me snd_timer
Dez 22 13:21:37 mjf-laptop kernel: intel_xhci_usb_role_switch i2c_mux mei roles intel_pch_thermal intel_oc_wdt mac_hid ip6t_REJECT nf_reject_ipv6 xt_hl ip6t_rt ipt_REJECT nf_reject_ipv4 xt_LOG nf_log_syslog xt_multiport xt_limit xt_addrtype xt_tcpudp xt_conntrack nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 ip6table_filter ip6_tables iptable_filter usbip_host usbip_core uinput i2c_dev crypto_user ntsync loop dm_mod nfnetlink ip_tables x_tables amdgpu amdxcp drm_panel_backlight_quirks gpu_sched i915 rtsx_pci_sdmmc radeon thinkpad_acpi mmc_core sparse_keymap intel_gtt drm_ttm_helper drm_buddy platform_profile sr_mod ttm drm_exec snd cdrom soundcore i2c_algo_bit drm_suballoc_helper rtsx_pci rfkill drm_display_helper video cec wmi serio_raw
Dez 22 13:21:37 mjf-laptop kernel: CR2: 0000000000000000
Dez 22 13:21:37 mjf-laptop kernel: ---[ end trace 0000000000000000 ]---
Dez 22 13:21:37 mjf-laptop kernel: RSP: 0018:ffffd0f5c0463dd0 EFLAGS: 00010246
Dez 22 13:21:37 mjf-laptop kernel: RDX: 0000000000000002 RSI: 0000000000008000 RDI: ffff8d2c4fa00000
Dez 22 13:21:37 mjf-laptop kernel: RBP: 0000000000008000 R08: 0000000000000000 R09: 0000000000000001
Dez 22 13:21:37 mjf-laptop kernel: R10: ffff8d2c42d49b40 R11: 0000000000000000 R12: 0000000000000001
Dez 22 13:21:37 mjf-laptop kernel: R13: 0000000000000002 R14: 0000000000000000 R15: ffff8d2c44b38750
Dez 22 13:21:38 mjf-laptop systemd[1]: sys-devices-virtual-misc-rfkill.device: Failed to enqueue SYSTEMD_WANTS job, ignoring: Unit systemd-rfkill.socket is masked.
Dez 22 13:21:38 mjf-laptop dbus-broker-launch[577]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
Dez 22 13:21:39 mjf-laptop dbus-broker-launch[805]: Service file '/usr/share/dbus-1/services/org.xfce.Thunar.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Dez 22 13:21:39 mjf-laptop dbus-broker-launch[805]: Service file '/usr/share/dbus-1/services/org.xfce.Tumbler.Cache1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Cache1'.
Dez 22 13:21:39 mjf-laptop dbus-broker-launch[805]: Service file '/usr/share/dbus-1/services/org.xfce.Tumbler.Manager1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Manager1'.
Dez 22 13:21:39 mjf-laptop dbus-broker-launch[805]: Service file '/usr/share/dbus-1/services/org.xfce.Tumbler.Thumbnailer1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Thumbnailer1'.
Dez 22 13:21:39 mjf-laptop dbus-broker-launch[805]: Service file '/usr/share/dbus-1/services/org.xfce.xfce4-notifyd.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Dez 22 13:21:39 mjf-laptop dbus-broker-launch[805]: Service file '/usr/share/dbus-1/services/org.xfce.xfce4-notifyd.Notifyd.service' is not named after the D-Bus name 'org.xfce.Notifyd'.
Dez 22 13:23:06 mjf-laptop systemd[1]: nmb.service: start operation timed out. Terminating.
Dez 22 13:23:06 mjf-laptop systemd[1]: nmb.service: Failed with result 'timeout'.
Dez 22 13:23:06 mjf-laptop systemd[1]: Failed to start Samba NMB Daemon.
Log for 6.12 (level warning):
>>journalctl -b -p warning
Dez 22 13:32:45 manjaro kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
Dez 22 13:32:45 manjaro kernel: MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
Dez 22 13:32:45 manjaro kernel: VMSCAPE: SMT on, STIBP is required for full protection. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/vmscape.html for more details.
Dez 22 13:32:45 manjaro kernel: pnp 00:00: disabling [mem 0x000c0000-0x000c3fff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
Dez 22 13:32:45 manjaro kernel: pnp 00:00: disabling [mem 0x000c4000-0x000c7fff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
Dez 22 13:32:45 manjaro kernel: pnp 00:00: disabling [mem 0x000c8000-0x000cbfff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
Dez 22 13:32:45 manjaro kernel: pnp 00:00: disabling [mem 0x000cc000-0x000cffff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
Dez 22 13:32:45 manjaro kernel: pnp 00:00: disabling [mem 0x000d0000-0x000d3fff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
Dez 22 13:32:45 manjaro kernel: pnp 00:00: disabling [mem 0x000d4000-0x000d7fff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
Dez 22 13:32:45 manjaro kernel: pnp 00:00: disabling [mem 0x000d8000-0x000dbfff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
Dez 22 13:32:45 manjaro kernel: pnp 00:00: disabling [mem 0x000dc000-0x000dffff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
Dez 22 13:32:45 manjaro kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Dez 22 13:32:45 manjaro kernel: ata1.00: Model 'Samsung SSD 860 EVO 500GB', rev 'RVT02B6Q', applying quirks: noncqtrim zeroaftertrim noncqonati nolpmonati
Dez 22 13:32:45 manjaro kernel: ata1.00: supports DRM functions and may not be fully accessible
Dez 22 13:32:49 manjaro kernel: ACPI BIOS Error (bug): AE_AML_BUFFER_LIMIT, Field [TBF3] at bit offset/length 262144/32768 exceeds size of target Buffer (262144 bits) (20240827/dsopcode-198)
Dez 22 13:32:49 manjaro kernel: ACPI Error: Aborting method \_SB.PCI0.GFX0.GETB due to previous error (AE_AML_BUFFER_LIMIT) (20240827/psparse-529)
Dez 22 13:32:49 manjaro kernel: ACPI Error: Aborting method \_SB.PCI0.GFX0.ATRM due to previous error (AE_AML_BUFFER_LIMIT) (20240827/psparse-529)
Dez 22 13:32:49 manjaro kernel: [drm:amdgpu_get_bios [amdgpu]] *ERROR* failed to evaluate ATRM got AE_AML_BUFFER_LIMIT
Dez 22 13:32:51 mjf-laptop systemd-modules-load[246]: Failed to find module 'ntsync'
Dez 22 13:32:52 mjf-laptop systemd-udevd[292]: /etc/udev/rules.d/51-android.rules:1 Group 'androiddev' is not a system group, ignoring.
Dez 22 13:32:53 mjf-laptop kernel: FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Dez 22 13:32:53 mjf-laptop systemd[1]: sys-devices-virtual-misc-rfkill.device: Failed to enqueue SYSTEMD_WANTS job, ignoring: Unit systemd-rfkill.socket is masked.
Dez 22 13:32:53 mjf-laptop kernel: at24 14-0050: supply vcc not found, using dummy regulator
Dez 22 13:32:54 mjf-laptop kernel: ACPI BIOS Error (bug): AE_AML_PACKAGE_LIMIT, Index (0x00000005A) is beyond end of object (length 0x5A) (20240827/exoparg2-393)
Dez 22 13:32:54 mjf-laptop kernel: ACPI Error: Aborting method \_SB.WMI1.WQA0 due to previous error (AE_AML_PACKAGE_LIMIT) (20240827/psparse-529)
Dez 22 13:32:54 mjf-laptop (uetoothd)[693]: bluetooth.service: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Dez 22 13:32:55 mjf-laptop NetworkManager[611]: <warn> [1766406775.0109] device (p2p-dev-wlp1s0): error setting IPv4 forwarding to '0': Die Ressource ist zur Zeit nicht verfügbar
Dez 22 13:32:55 mjf-laptop nmbd[702]: [2025/12/22 13:32:55.131881, 0] ../../source3/nmbd/nmbd_subnetdb.c:252(create_subnets)
Dez 22 13:32:55 mjf-laptop nmbd[702]: NOTE: NetBIOS name resolution is not supported for Internet Protocol Version 6 (IPv6).
Dez 22 13:32:56 mjf-laptop systemd[1]: sys-devices-virtual-misc-rfkill.device: Failed to enqueue SYSTEMD_WANTS job, ignoring: Unit systemd-rfkill.socket is masked.
Dez 22 13:32:57 mjf-laptop dbus-broker-launch[604]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
Dez 22 13:32:58 mjf-laptop dbus-broker-launch[803]: Service file '/usr/share/dbus-1/services/org.xfce.Thunar.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Dez 22 13:32:58 mjf-laptop dbus-broker-launch[803]: Service file '/usr/share/dbus-1/services/org.xfce.Tumbler.Cache1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Cache1'.
Dez 22 13:32:58 mjf-laptop dbus-broker-launch[803]: Service file '/usr/share/dbus-1/services/org.xfce.Tumbler.Manager1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Manager1'.
Dez 22 13:32:58 mjf-laptop dbus-broker-launch[803]: Service file '/usr/share/dbus-1/services/org.xfce.Tumbler.Thumbnailer1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Thumbnailer1'.
Dez 22 13:32:58 mjf-laptop dbus-broker-launch[803]: Service file '/usr/share/dbus-1/services/org.xfce.xfce4-notifyd.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Dez 22 13:32:58 mjf-laptop dbus-broker-launch[803]: Service file '/usr/share/dbus-1/services/org.xfce.xfce4-notifyd.Notifyd.service' is not named after the D-Bus name 'org.xfce.Notifyd'.
Dez 22 13:33:06 mjf-laptop systemd[1]: sys-devices-virtual-misc-rfkill.device: Failed to enqueue SYSTEMD_WANTS job, ignoring: Unit systemd-rfkill.socket is masked.
Dez 22 13:33:06 mjf-laptop systemd-xdg-autostart-generator[991]: /home/matthias/.config/autostart/io.github.slgobinath.SafeEyes.desktop: stat() failed, ignoring: No such file or directory
Dez 22 13:33:06 mjf-laptop dbus-broker-launch[1021]: Service file '/usr/share/dbus-1/services/org.xfce.Thunar.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Dez 22 13:33:06 mjf-laptop dbus-broker-launch[1021]: Service file '/usr/share/dbus-1/services/org.xfce.Tumbler.Cache1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Cache1'.
Dez 22 13:33:06 mjf-laptop dbus-broker-launch[1021]: Service file '/usr/share/dbus-1/services/org.xfce.Tumbler.Manager1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Manager1'.
Dez 22 13:33:06 mjf-laptop dbus-broker-launch[1021]: Service file '/usr/share/dbus-1/services/org.xfce.Tumbler.Thumbnailer1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Thumbnailer1'.
Dez 22 13:33:06 mjf-laptop dbus-broker-launch[1021]: Service file '/usr/share/dbus-1/services/org.xfce.xfce4-notifyd.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Dez 22 13:33:06 mjf-laptop dbus-broker-launch[1021]: Service file '/usr/share/dbus-1/services/org.xfce.xfce4-notifyd.Notifyd.service' is not named after the D-Bus name 'org.xfce.Notifyd'.
Dez 22 13:33:06 mjf-laptop lightdm[911]: gkr-pam: couldn't unlock the login keyring.
Dez 22 13:33:06 mjf-laptop syncthing[1009]: Service failed (error="Get \"https://relays.syncthing.net/endpoint\": dial tcp: lookup relays.syncthing.net: Temporary failure in name resolution" supervisor=listenerSupervisor@dynamic+https://relays.syncthing.net/endpoint service=dynamic+https://relays.syncthing.net/endpoint log.pkg=connections)
Dez 22 13:33:08 mjf-laptop dbus-broker-launch[604]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
Dez 22 13:33:09 mjf-laptop wireplumber[1249]: wp-event-dispatcher: wp_event_dispatcher_unregister_hook: assertion 'already_registered_dispatcher == self' failed
Dez 22 13:33:09 mjf-laptop wireplumber[1249]: default: Failed to get percentage from UPower: org.freedesktop.DBus.Error.NameHasNoOwner
Dez 22 13:33:12 mjf-laptop tumblerd[1822]: Failed to load plugin "tumbler-gepub-thumbnailer.so": libgepub-0.7.so.0: Kann die Shared-Object-Datei nicht öffnen: Datei oder Verzeichnis nicht gefunden
Dez 22 13:33:14 mjf-laptop dbus-broker-launch[604]: Activation request for 'org.freedesktop.ModemManager1' failed: The systemd unit 'dbus-org.freedesktop.ModemManager1.service' could not be found.
Dez 22 13:33:16 mjf-laptop dbus-broker[610]: A security policy denied :1.8 to send method call /midi/profile:org.bluez.GattProfile1.Release to :1.37.
Dez 22 13:33:16 mjf-laptop kernel: [UFW BLOCK] IN=wlp1s0 OUT= MAC=84:ef:18:58:54:8f:1c:7f:2c:ee:61:d2:08:00 SRC=10.0.0.138 DST=10.0.0.10 LEN=365 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=1900 DPT=49010 LEN=345
Dez 22 13:33:36 mjf-laptop kernel: [UFW BLOCK] IN=wlp1s0 OUT= MAC= SRC=fe80:0000:0000:0000:8586:8ea6:6d93:499b DST=ff12:0000:0000:0000:0000:0000:0000:8384 LEN=186 TC=0 HOPLIMIT=1 FLOWLBL=670730 PROTO=UDP SPT=41796 DPT=21027 LEN=146
Dez 22 13:33:36 mjf-laptop kernel: [UFW BLOCK] IN=wlp1s0 OUT= MAC=84:ef:18:58:54:8f:1c:7f:2c:ee:61:d2:08:00 SRC=10.0.0.138 DST=10.0.0.10 LEN=365 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=1900 DPT=46619 LEN=345
Dez 22 13:33:56 mjf-laptop kernel: [UFW BLOCK] IN=wlp1s0 OUT= MAC=84:ef:18:58:54:8f:66:7f:cd:70:4e:6f:08:00 SRC=10.0.0.8 DST=10.0.0.10 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=49414 DF PROTO=TCP SPT=22000 DPT=22000 WINDOW=65535 RES=0x00 SYN URGP=0
Dez 22 13:34:01 mjf-laptop kernel: [UFW BLOCK] IN=wlp1s0 OUT= MAC=84:ef:18:58:54:8f:66:7f:cd:70:4e:6f:08:00 SRC=10.0.0.8 DST=10.0.0.10 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=49415 DF PROTO=TCP SPT=22000 DPT=22000 WINDOW=65535 RES=0x00 SYN URGP=0
Dez 22 13:34:04 mjf-laptop kernel: [UFW BLOCK] IN=wlp1s0 OUT= MAC=84:ef:18:58:54:8f:66:7f:cd:70:4e:6f:08:00 SRC=10.0.0.8 DST=10.0.0.10 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=49416 DF PROTO=TCP SPT=22000 DPT=22000 WINDOW=65535 RES=0x00 SYN URGP=0
Dez 22 13:34:04 mjf-laptop kernel: [UFW BLOCK] IN=wlp1s0 OUT= MAC=84:ef:18:58:54:8f:66:7f:cd:70:4e:6f:08:00 SRC=10.0.0.8 DST=10.0.0.10 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=6828 DF PROTO=TCP SPT=42194 DPT=22000 WINDOW=65535 RES=0x00 SYN URGP=0
Dez 22 13:34:06 mjf-laptop kernel: [UFW BLOCK] IN=wlp1s0 OUT= MAC= SRC=fe80:0000:0000:0000:8586:8ea6:6d93:499b DST=ff12:0000:0000:0000:0000:0000:0000:8384 LEN=186 TC=0 HOPLIMIT=1 FLOWLBL=670730 PROTO=UDP SPT=41796 DPT=21027 LEN=146
Dez 22 13:34:11 mjf-laptop kernel: [UFW BLOCK] IN=wlp1s0 OUT= MAC=84:ef:18:58:54:8f:66:7f:cd:70:4e:6f:08:00 SRC=10.0.0.8 DST=10.0.0.10 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=6829 DF PROTO=TCP SPT=42194 DPT=22000 WINDOW=65535 RES=0x00 SYN URGP=0
Dez 22 13:34:13 mjf-laptop kernel: [UFW BLOCK] IN=wlp1s0 OUT= MAC=84:ef:18:58:54:8f:66:7f:cd:70:4e:6f:08:00 SRC=10.0.0.8 DST=10.0.0.10 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=6830 DF PROTO=TCP SPT=42194 DPT=22000 WINDOW=65535 RES=0x00 SYN URGP=0
Dez 22 13:34:14 mjf-laptop kernel: [UFW BLOCK] IN=wlp1s0 OUT= MAC=84:ef:18:58:54:8f:66:7f:cd:70:4e:6f:08:00 SRC=10.0.0.8 DST=10.0.0.10 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=49417 DF PROTO=TCP SPT=22000 DPT=22000 WINDOW=65535 RES=0x00 SYN URGP=0
Dez 22 13:34:16 mjf-laptop kernel: [UFW BLOCK] IN=wlp1s0 OUT= MAC=84:ef:18:58:54:8f:66:7f:cd:70:4e:6f:08:00 SRC=10.0.0.8 DST=10.0.0.10 LEN=1308 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=22000 DPT=22000 LEN=1288
Dez 22 13:34:17 mjf-laptop kernel: [UFW BLOCK] IN=wlp1s0 OUT= MAC=84:ef:18:58:54:8f:66:7f:cd:70:4e:6f:08:00 SRC=10.0.0.8 DST=10.0.0.10 LEN=1308 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=22000 DPT=22000 LEN=1288
Dez 22 13:34:36 mjf-laptop kernel: [UFW BLOCK] IN=wlp1s0 OUT= MAC= SRC=fe80:0000:0000:0000:8586:8ea6:6d93:499b DST=ff12:0000:0000:0000:0000:0000:0000:8384 LEN=283 TC=0 HOPLIMIT=1 FLOWLBL=670730 PROTO=UDP SPT=41796 DPT=21027 LEN=243
Dez 22 13:34:49 mjf-laptop kernel: [UFW BLOCK] IN=wlp1s0 OUT= MAC=33:33:00:00:83:84:a4:6c:f1:0b:c9:a0:86:dd SRC=fe80:0000:0000:0000:8d48:3253:b66f:1765 DST=ff12:0000:0000:0000:0000:0000:0000:8384 LEN=302 TC=0 HOPLIMIT=1 FLOWLBL=877826 PROTO=UDP SPT=35047 DPT=21027 LEN=262
Dez 22 13:35:06 mjf-laptop kernel: [UFW BLOCK] IN=wlp1s0 OUT= MAC= SRC=fe80:0000:0000:0000:8586:8ea6:6d93:499b DST=ff12:0000:0000:0000:0000:0000:0000:8384 LEN=283 TC=0 HOPLIMIT=1 FLOWLBL=670730 PROTO=UDP SPT=41796 DPT=21027 LEN=243
Dez 22 13:35:36 mjf-laptop kernel: [UFW BLOCK] IN=wlp1s0 OUT= MAC= SRC=fe80:0000:0000:0000:8586:8ea6:6d93:499b DST=ff12:0000:0000:0000:0000:0000:0000:8384 LEN=283 TC=0 HOPLIMIT=1 FLOWLBL=670730 PROTO=UDP SPT=41796 DPT=21027 LEN=243
Dez 22 13:35:52 mjf-laptop kernel: [UFW BLOCK] IN=wlp1s0 OUT= MAC=84:ef:18:58:54:8f:66:7f:cd:70:4e:6f:08:00 SRC=10.0.0.8 DST=10.0.0.10 LEN=1308 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=22000 DPT=22000 LEN=1288
Dez 22 13:35:57 mjf-laptop kernel: [UFW BLOCK] IN=wlp1s0 OUT= MAC=84:ef:18:58:54:8f:66:7f:cd:70:4e:6f:08:00 SRC=10.0.0.8 DST=10.0.0.10 LEN=1308 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=22000 DPT=22000 LEN=1288
Dez 22 13:36:06 mjf-laptop kernel: [UFW BLOCK] IN=wlp1s0 OUT= MAC= SRC=fe80:0000:0000:0000:8586:8ea6:6d93:499b DST=ff12:0000:0000:0000:0000:0000:0000:8384 LEN=283 TC=0 HOPLIMIT=1 FLOWLBL=670730 PROTO=UDP SPT=41796 DPT=21027 LEN=243
Dez 22 13:36:34 mjf-laptop kernel: [UFW BLOCK] IN=wlp1s0 OUT= MAC=84:ef:18:58:54:8f:66:7f:cd:70:4e:6f:08:00 SRC=10.0.0.8 DST=10.0.0.10 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=30755 DF PROTO=TCP SPT=22000 DPT=22000 WINDOW=65535 RES=0x00 SYN URGP=0
Dez 22 13:36:36 mjf-laptop kernel: [UFW BLOCK] IN=wlp1s0 OUT= MAC= SRC=fe80:0000:0000:0000:8586:8ea6:6d93:499b DST=ff12:0000:0000:0000:0000:0000:0000:8384 LEN=283 TC=0 HOPLIMIT=1 FLOWLBL=670730 PROTO=UDP SPT=41796 DPT=21027 LEN=243
Dez 22 13:36:39 mjf-laptop kernel: [UFW BLOCK] IN=wlp1s0 OUT= MAC=84:ef:18:58:54:8f:66:7f:cd:70:4e:6f:08:00 SRC=10.0.0.8 DST=10.0.0.10 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=30757 DF PROTO=TCP SPT=22000 DPT=22000 WINDOW=65535 RES=0x00 SYN URGP=0
Dez 22 13:37:06 mjf-laptop kernel: [UFW BLOCK] IN=wlp1s0 OUT= MAC= SRC=fe80:0000:0000:0000:8586:8ea6:6d93:499b DST=ff12:0000:0000:0000:0000:0000:0000:8384 LEN=283 TC=0 HOPLIMIT=1 FLOWLBL=670730 PROTO=UDP SPT=41796 DPT=21027 LEN=243
Dez 22 13:37:14 mjf-laptop kernel: [UFW BLOCK] IN=wlp1s0 OUT= MAC=84:ef:18:58:54:8f:66:7f:cd:70:4e:6f:08:00 SRC=10.0.0.8 DST=10.0.0.10 LEN=1308 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=22000 DPT=22000 LEN=1288
Dez 22 13:37:17 mjf-laptop kernel: [UFW BLOCK] IN=wlp1s0 OUT= MAC=84:ef:18:58:54:8f:66:7f:cd:70:4e:6f:08:00 SRC=10.0.0.8 DST=10.0.0.10 LEN=1308 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=22000 DPT=22000 LEN=1288
Dez 22 13:37:36 mjf-laptop kernel: [UFW BLOCK] IN=wlp1s0 OUT= MAC= SRC=fe80:0000:0000:0000:8586:8ea6:6d93:499b DST=ff12:0000:0000:0000:0000:0000:0000:8384 LEN=283 TC=0 HOPLIMIT=1 FLOWLBL=670730 PROTO=UDP SPT=41796 DPT=21027 LEN=243
