LTS Kernel 6.6.19-1 will not wake from sleep.
Dmesg and journalctl are empty, only show the system enter suspension, system comes back to a black screen, the mouse cursor is visible but immovable and the system is unresponsive. Hard reset is the only option. Same behavior in X11 or Wayland, and with an external monitor attached or not. Haven’t tried with a different discreet GPU. But I currently run a FirePro M6100 with the AMDGPU driver.
For now I just run the 6.1.80-1 LTS kernel. It works fine.
Olli
20 March 2024 16:19
2
@Imightbebatman
keep it simple, a lot of users have issues with kernel 6.6.xxx. if you have to stay on lts kernel 6.1.xxx will suit very good while long-term-distros as debian,fedora,redhat will use 6.1 as long-term-kernel. if you wann stay up-to-date then use kernel 6.7
Teo
20 March 2024 16:20
3
It is not exactly a kernel bug, because i resume from sleep just fine (6.6.19). It is probably some driver or something to do with the video.
Yea, maybe it should be titled “potential kernel bug”.
I’m just posting here for awareness. I’m running on 6.1 just fine and intend to stay there. 6.6 came pre-installed and broken for me. Figured someone here might care.
FYSA for everyone else.
Teo
20 March 2024 16:25
5
An inxi with your hardware will be nice here, because it is obviously hardware dependend. As said, (s2idle !) works fine on
inxi -v7azy
Kernel: 6.6.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=cf8b53ae-432d-4976-a363-214a6ecc9d84 rw apparmor=1
security=apparmor udev.log_priority=3 mem_sleep_default=s2idle
resume=UUID=600cb33a-5cd6-4a40-85cd-75ad77b2d095 sysrq_always_enabled=1
plymouth.enable=0 disablehooks=plymouth
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 wm: xfwm4 v: 4.18.0
with: xfce4-panel tools: light-locker vt: 7 dm: LightDM v: 1.32.0
Type: Laptop System: LENOVO product: 82QY v: Lenovo V15 G2 IJL
serial: <superuser required> Chassis: type: 10 v: Lenovo V15 G2 IJL
Mobo: LENOVO model: LNVNB161216 v: SDK0T76465 WIN
serial: <superuser required> part-nu: LENOVO_MT_82QY_BU_idea_FM_V15 G2 IJL
uuid: <superuser required> UEFI: LENOVO v: HTCN39WW date: 01/10/2024
Device-1: Intel JasperLake [UHD Graphics] vendor: Lenovo driver: i915
v: kernel arch: Gen-11 process: Intel 10nm built: 2019-21 ports:
active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:4e71
class-ID: 0300
Olli
20 March 2024 16:27
6
it’s already known that the 6.6 kernel has some bugs/malfunctions with filesystems and networking and got updated to 6.7. i expect that kernel 6.6 will be soon eol and replaced with a newer one as lts. but that’s my speculation, who knows what linus-kernel-brewery is doing. i already wonder that the frequency of new kernel version became so fast and rapid while the last one year. we are already at 6.8-rc and it won’t last long that the major release number is getting kernel 7.xxx.
Tried varios inxi outputs and I keep being told I’m trying to insert a link, and the post fails.
I’m new here, we’ll blame me.
I’m going to mark @Olli ’s answer as solving this.
Thanks everybody.
It’s because I had a typo in my markup.
Here:
Kernel: 6.1.80-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=90827936-b30d-4bb6-8e27-e2e58b197b2b rw quiet
cryptdevice=UUID=0fb9b96b-b130-4b07-b462-a056ec6c3a1b:luks-0fb9b96b-b130-4b07-b462-a056ec6c3a1b
root=/dev/mapper/luks-0fb9b96b-b130-4b07-b462-a056ec6c3a1b splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.11 tk: Qt v: 5.15.12 info: frameworks
v: 5.115.0 wm: kwin_x11 vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
Type: Laptop System: Dell product: Precision M6600 v: 01
serial: <superuser required> Chassis: type: 9 serial: <superuser required>
Mobo: Dell model: 04YY4M v: A00 serial: <superuser required>
uuid: <superuser required> BIOS: Dell v: A18 date: 09/14/2018
ID-1: BAT0 charge: 88.2 Wh (100.0%) condition: 88.2/98.2 Wh (89.8%)
volts: 12.9 min: 11.1 model: Samsung SDI DELL 7DWMT24 type: Li-ion
serial: <filter> status: full
Device-1: hidpp_battery_0 model: Logitech Wireless Mobile Mouse MX
Anywhere 2S serial: <filter> charge: 100% (should be ignored)
rechargeable: yes status: discharging
Device-2: hidpp_battery_1 model: Logitech K370s/K375s Multi-Device
Wireless Keyboard serial: <filter> charge: 100% (should be ignored)
System RAM: total: 32 GiB available: 31.3 GiB used: 3.48 GiB (11.1%)
Array-1: capacity: 64 GiB slots: 4 modules: 4 EC: None
Device-1: ChannelA-DIMM0 type: DDR3 detail: synchronous size: 8 GiB
speed: 1333 MT/s volts: N/A width (bits): data: 64 total: 64
manufacturer: Crucial part-no: CT102464BF1339.C16 serial: <filter>
Device-2: ChannelA-DIMM1 type: DDR3 detail: synchronous size: 8 GiB
Device-3: ChannelB-DIMM0 type: DDR3 detail: synchronous size: 8 GiB
Device-4: ChannelB-DIMM1 type: DDR3 detail: synchronous size: 8 GiB
Info: model: Intel Core i7-2760QM bits: 64 type: MT MCP arch: Sandy Bridge
gen: core 2 level: v2 built: 2010-12 process: Intel 32nm family: 6
model-id: 0x2A (42) stepping: 7 microcode: 0x2F
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1040 high: 1571 min/max: 800/3500 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1571 2: 959 3: 1243
4: 800 5: 950 6: 1199 7: 800 8: 800 bogomips: 38333
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept est
flexpriority flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce
md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdtscp rep_good
sep smx ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology
xtpr
vulnerable
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Saturn XT [FirePro M6100] vendor: Dell driver: amdgpu v: kernel
alternate: radeon arch: GCN-2 code: Sea Islands process: GF/TSMC 16-28nm
built: 2013-17 pcie: gen: 2 speed: 5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s ports: active: DP-1 off: LVDS-1 empty: DP-2,DP-3,VGA-1
bus-ID: 01:00.0 chip-ID: 1002:6640 class-ID: 0300 temp: 51.0 C
Device-2: Sunplus Innovation Laptop_Integrated_Webcam_FHD driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.5:3
chip-ID: 1bcf:280b class-ID: 0e02
Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.4
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 506x285mm (19.92x11.22")
s-diag: 581mm (22.86")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary model: Acer EZ321Q
serial: <filter> built: 2020 res: 1920x1080 hz: 60 dpi: 70 gamma: 1.2
size: 698x393mm (27.48x15.47") diag: 801mm (31.5") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
Monitor-2: LVDS-1 mapped: LVDS note: disabled model: LG Display 0x02d4
built: 2010 res: 1920x1080 dpi: 106 gamma: 1.2 size: 382x215mm (15.04x8.46")
diag: 438mm (17.3") ratio: 16:9 modes: max: 1600x900 min: 640x480
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.2-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon HD 8950 (radeonsi bonaire
LLVM 16.0.6 DRM 3.49 6.1.80-1-MANJARO) device-ID: 1002:6640
memory: 1.95 GiB unified: no
API: Vulkan v: 1.3.279 layers: 4 device: 0 type: discrete-gpu name: AMD
Radeon HD 8950 (RADV BONAIRE) driver: mesa radv v: 24.0.2-manjaro1.1
device-ID: 1002:6640 surfaces: xcb,xlib
vendor: Dell 6 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1c20 class-ID: 0403
Device-2: AMD Tobago HDMI Audio [Radeon R7 360 / R9 OEM] vendor: Dell
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 1002:aac0
class-ID: 0403
API: ALSA v: k6.1.80-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
Device-1: Intel 82579LM Gigabit Network vendor: Dell driver: e1000e v: kernel
port: 8040 bus-ID: 00:19.0 chip-ID: 8086:1502 class-ID: 0200
Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:08b1 class-ID: 0280
Info: services: NetworkManager,wpa_supplicant
Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-1.5:5 chip-ID: 8087:07dc
class-ID: e001
Device-1: luks-0fb9b96b-b130-4b07-b462-a056ec6c3a1b maj-min: 254:0
type: LUKS dm: dm-0 size: 223.57 GiB
Components:
p-1: sda1 maj-min: 8:1 size: 223.57 GiB
Local Storage: total: 700.51 GiB used: 89.3 GiB (12.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37240G
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 1103 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: MZ7LN512HMJP-000L7
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 2L6Q scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVD+-RW GS30N rev: A102
dev-links: cdrom
ID-1: / raw-size: 223.57 GiB size: 219 GiB (97.96%) used: 19.15 GiB (8.7%)
fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-0fb9b96b-b130-4b07-b462-a056ec6c3a1b label: N/A
uuid: 90827936-b30d-4bb6-8e27-e2e58b197b2b
ID-2: /media/user/Backup raw-size: N/A size: 8.72 TiB
used: 5.04 TiB (57.8%) fs: cifs dev: /dev/Backup
ID-3: /media/user/Games_Extra raw-size: 476.94 GiB
size: 468.38 GiB (98.21%) used: 70.15 GiB (15.0%) fs: ext4 dev: /dev/sdb1
maj-min: 8:17 label: Games&Extra uuid: c1af194b-4077-4d95-8186-68c8f7649e8d
ID-4: /media/user/SNAS_USB raw-size: N/A size: 931.51 GiB
used: 131 GiB (14.1%) fs: cifs dev: /dev/usbshare1
Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:0024
Device-1: 1-1.5:3 info: Sunplus Innovation Laptop_Integrated_Webcam_FHD
type: video driver: uvcvideo interfaces: 2 rev: 2.0
Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Device-1: 2-1.1:3 info: Logitech Unifying Receiver type: keyboard,mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
chip-ID: 046d:c52b class-ID: 0300
Device-2: 2-1.2:4 info: Microsoft Xbox360 Controller
type: <vendor specific> driver: xpad interfaces: 4 rev: 2.0
chip-ID: 045e:028e class-ID: ff00 serial: <filter>
Device-3: 2-1.5:5 info: Intel Bluetooth wireless interface type: bluetooth
mode: 1.1 power: 100mA chip-ID: 8087:07dc class-ID: e001
Device-4: 2-1.8:6 info: Broadcom BCM5880 Secure Applications Processor
type: smart card driver: N/A interfaces: 2 rev: 1.1
chip-ID: 0a5c:5800 class-ID: 0b00 serial: <filter>
Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-6: 4-0:1 info: super-speed hub ports: 2 rev: 3.0
System Temperatures: cpu: 48.0 C mobo: 43.0 C sodimm: SODIMM C gpu: amdgpu
temp: 51.0 C
Fan Speeds (rpm): cpu: 0
Processes: 294 Power: uptime: 59m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.51 GiB services: org_kde_powerdevil,
tool: systemctl
Packages: 1318 pm: pacman pkgs: 1301 libs: 455 tools: pamac pm: flatpak
pkgs: 17 Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Bash v: 5.2.26
running-in: yakuake inxi: 3.3.33
ben75
20 March 2024 19:08
9
Kernel 6.6 will be EOL after December 2026.
Huh?
6.6 is an LTS kernel and it’s current projected EOL is Dec, 2026, see
https://kernel.org/category/releases.html
Olli
20 March 2024 19:56
11
@freggel.doe
@ben75
and the cip-consortium (let’s name it so) guarantee the support of kernel-6.1 till end of 2033 by it’s 10-year support decission. kernel 6.6 will be compost in 2033 while 6.1 is still active.
While that is true, december 2026 is not “soon” but rather 1 3/4 years ahead.
system
Closed
22 March 2024 08:00
13
