Kernel 7.2.0rc5-1 fails to reboot on my system - Minisforum UM-690
Restart using 7.2.0rc5-1 goes into an infinite wait or just beyond my patience. My system is
KDE Plasma Version: 6.7.3
KDE Frameworks Version: 6.28.0
Qt Version: 6.11.1
Kernel Version: 7.1.5-2-MANJARO (64-bit)
Graphics Platform: WaylandProcessors: 16 × AMD Ryzen 9 6900HX with Radeon Graphics
Memory: 32 GiB of RAM (30.6 GiB usable)
Graphics Processor: AMD Radeon 680M
Manufacturer: Micro Computer (HK) Tech LimitedProduct
Name: Venus seriesSystem
Version: Version 1.0
BTW 7.1.5 works fine - Uninstalled 7.2 rebooted - reinstalled 7.2 – same results.
Inxi –zv8 results follow
Kernel: 7.2.0-rc5-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.1.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-7.2-x86_64
    root=UUID=ea8f9b67-04f2-49c7-9d41-98f8382419e1 rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.7.3 tk: Qt v: N/A wm: kwin_wayland dm: N/A
  Type: Desktop System: Micro (HK) Tech product: Venus series v: Version 1.0
    serial: N/A
  Mobo: Shenzhen Meigao Equipment model: F7BFC v: Version 1.0 serial: N/A
    part-nu: Default SKU uuid: 6d92bd56-8bf3-11ed-ab78-9706745a3c00
    Firmware: UEFI vendor: American Megatrends LLC. v: 1.20 date: 03/06/2024
  System RAM: total: 32 GiB available: 30.58 GiB used: 2.95 GiB (9.6%)
  Device-1: Channel-A DIMM 0 type: DDR5 detail: synchronous unbuffered
    (unregistered) size: 16 GiB speed: 4800 MT/s volts: curr: 1.1 min: 1.1
    max: 1.1 width (bits): data: 64 total: 64 manufacturer: A-DATA Technology
    part-no: N/A serial: <filter>
  Device-2: Channel-B DIMM 0 type: DDR5 detail: synchronous unbuffered
  Slot: 1 type: PCIe status: available info: J3604 length: short volts: 3.3
    bus-ID: 0200:00:01.1
  Slot: 3 type: N/A status: in use info: M.2, J3711 length: short volts: 3.3
    bus-ID: 00:01.2 children: 1: 01:00.0 class-ID: 0c03 type: serialbus
  Slot: 5 type: N/A status: in use info: M.2, J3704 length: short volts: 3.3
    bus-ID: 00:02.4 children: 1: 04:00.0 class-ID: 0108 type: mass-storage
  Slot: 6 type: N/A status: in use info: M.2, J3709 length: short volts: 3.3
    bus-ID: 00:02.2 children: 1: 03:00.0 class-ID: 0280 type: network
  Info: model: AMD Ryzen 9 6900HX with Radeon Graphics socket: FP7r2 bits: 64
    type: MT MCP arch: Zen 3+ gen: 3 level: v3 note: check built: 2022
    process: TSMC n6 (7nm) family: 0x19 (25) model-id: 0x44 (68) stepping: 1
    microcode: 0xA404108
    desc: 8x512 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1100 min/max: 416/4937 boost: enabled
    base/boost: 3300/4925 scaling: driver: amd-pstate-epp governor: powersave
    volts: 1.2 V ext-clock: 100 MHz cores: 1: 1100 2: 1100 3: 1100 4: 1100
    5: 1100 6: 1100 7: 1100 8: 1100 9: 1100 10: 1100 11: 1100 12: 1100
    13: 1100 14: 1100 15: 1100 16: 1100 bogomips: 105407
    xsaves xtopology
  Type: spectre_v1 mitigation: usercopy/swapgs barriers and \__user pointer
    affected
  Device-1: Advanced Micro Devices \[AMD/ATI\] Rembrandt \[Radeon 680M\]
    driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
    built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
    active: HDMI-A-2 empty: DP-1, DP-2, DP-3, DP-4, DP-5, HDMI-A-1,
    Writeback-1 bus-ID: 35:00.0 chip-ID: 1002:1681 class-ID: 0300 temp: 48.0 C
  Device-2: Image+ NewEye 62 driver: snd-usb-audio,uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.2:5
    chip-ID: 2757:3032 class-ID: 0102 serial: <filter>
  Display: unspecified server: X.Org v: 24.1.13 with: Xwayland v: 24.1.13
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1016x571mm (40.00x22.48")
    s-diag: 1165mm (45.88") monitors: <missing: xrandr>
  Monitor-1: HDMI-A-2 model: LG (GoldStar) HDR 4K serial: <filter>
    built: 2022 res: 3840x2160 dpi: 163 gamma: 1.2 chroma: red: x: 0.682
    y: 0.314 green: x: 0.278 y: 0.675 blue: x: 0.153 y: 0.047 white: x: 0.314
    y: 0.329 size: 600x340mm (23.62x13.39") diag: 690mm (27.2") ratio: 16:9
    modes: 3840x2160, 2560x1440, 1920x1080, 1600x900, 1280x1024, 1280x800,
    1152x864, 1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 97 2: parse_edid:
    unhandled CEA mode 96 3: parse_edid: unhandled CEA mode 93 4: parse_edid:
    unhandled CEA mode 94 5: parse_edid: unhandled CEA mode 95
    device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 vendor: amd mesa v: 26.1.5-arch1.1 glx-v: 1.4
    direct-render: yes renderer: AMD Radeon 680M (radeonsi rembrandt ACO DRM
    3.64 7.2.0-rc5-1-MANJARO) device-ID: 1002:1681 memory: 500 MiB
    unified: yes
  API: Vulkan v: 1.4.350 layers: 2 device: 0 type: integrated-gpu name: AMD
    Radeon 680M (RADV REMBRANDT) driver: mesa radv v: 26.1.5-arch1.1
    device-ID: 1002:1681 surfaces: N/A
  Device-1: Advanced Micro Devices \[AMD/ATI\] Radeon High Definition Audio
    bus-ID: 35:00.1 chip-ID: 1002:1640 class-ID: 0403
  Device-2: Advanced Micro Devices \[AMD\] Audio Coprocessor
    driver: snd_pci_acp6x v: kernel alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
    snd_pci_acp5x, snd_acp_pci, snd_pci_ps, snd_sof_amd_renoir,
    snd_sof_amd_rembrandt, snd_sof_amd_vangogh, snd_sof_amd_acp63,
    snd_sof_amd_acp70 pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 35:00.5
    chip-ID: 1022:15e2 class-ID: 0480
  Device-3: Advanced Micro Devices \[AMD\] Ryzen HD Audio vendor: Realtek
    bus-ID: 35:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Device-4: Image+ NewEye 62 driver: snd-usb-audio,uvcvideo type: USB
  API: ALSA v: k7.2.0-rc5-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.8 status: n/a (root, process) with:
  Device-1: Intel Ethernet I225-V driver: igc v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 port: N/A bus-ID: 02:00.0 chip-ID: 8086:15f3
    class-ID: 0200
  Device-2: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel pcie:
    gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 14c3:0608
    class-ID: 0280
  Device-1: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-3:3 chip-ID: 0e8d:0608
  Local Storage: total: 10.03 TiB used: 34.87 GiB (0.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8PGP41024Q-A0
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: ELFK0S.6 temp: 39.9 C
    scheme: GPT
  SMART: yes health: PASSED on: 190d 4h cycles: 7,063
    read-units: 106,425,197 \[54.4 TB\] written-units: 106,361,480 \[54.4 TB\]
  ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT2000MX500SSD1
    family: Micron Client SSDs size: 1.82 TiB block-size: physical: 4096 B
    logical: 512 B sata: 3.3 speed: 6.0 Gb/s tech: SSD serial: <filter>
    fw-rev: 046 temp: 40 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 1y 168d 2h cycles: 10030
    written: 6.6 TiB
  ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: Backup+ Hub BK
    size: 7.28 TiB block-size: physical: 4096 B logical: 512 B type: USB
    rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
    fw-rev: D781 scheme: GPT
  SMART Message: A mandatory SMART command failed. Various possible causes.
  ID-1: / raw-size: 47.51 GiB size: 46.59 GiB (98.06%) used: 33.92 GiB (72.8%)
    fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
    uuid: ea8f9b67-04f2-49c7-9d41-98f8382419e1
  ID-2: /boot/efi raw-size: 3.95 GiB size: 3.92 GiB (99.22%)
    used: 974.2 MiB (24.3%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1 label: SYSTEM uuid: CA37-6A09
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 852.55 GiB fs: ntfs label: N/A
    uuid: 98DA81EBDA81C5CA
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 47.7 GiB fs: btrfs
    label: KDELinux uuid: 79ad71c0-4c00-493f-af9e-b4c2c97a8d38
  ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 1.8 GiB fs: ntfs label: Recovery
    uuid: 6A20821B2081EE7F
  ID-4: /dev/sda1 maj-min: 8:1 size: 1.82 TiB fs: ntfs label: MINI-Data
    uuid: 787BDE381E0A0803
  ID-5: /dev/sdb1 maj-min: 8:17 size: 6.06 TiB fs: ntfs label: Backup-26
    uuid: F492DFD792DF9D04
  ID-6: /dev/sdb2 maj-min: 8:18 size: 1.21 TiB fs: exfat label: extra
    uuid: 2A6A-7857
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-2: 1-1:2 info: Super Top 4-Port hub ports: 4 rev: 2.0
    chip-ID: 14cd:8601 class-ID: 0900
  Device-1: 1-1.1:4 info: Primax HP 710 Wireless KB MS Combo
    type: keyboard,HID,mouse driver: hid-generic,usbhid interfaces: 3 rev: 2.0
    chip-ID: 0461:4ef1 class-ID: 0301
  Device-2: 1-1.2:5 info: Image+ NewEye 62 type: video,audio
  Hub-3: 1-2:3 info: Seagate RSS LLC Backup Plus Hub ports: 3 rev: 2.1
    chip-ID: 0bc2:ab44 class-ID: 0900
  Hub-4: 2-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-5: 2-2:2 info: Seagate RSS LLC Backup+ Hub ports: 3 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bc2:ab45
  Device-1: 2-2.1:3 info: Seagate RSS LLC Backup Plus Hub (Mass Storage)
    type: mass storage driver: uas interfaces: 1 rev: 3.1
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bc2:ab38
    class-ID: 0806 serial: <filter>
  Hub-6: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-7: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-8: 5-0:1 info: hi-speed hub with single TT ports: 3 rev: 2.0
  Hub-9: 5-1:2 info: VIA Labs Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2811
  Device-1: 5-3:3 info: MediaTek Wireless_Device type: bluetooth
    mode: 2.0 power: 100mA chip-ID: 0e8d:0608 class-ID: e001 serial: <filter>
  Hub-10: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-11: 6-1:2 info: VIA Labs Hub ports: 4 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:8110
  Hub-12: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-13: 8-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-14: 9-0:1 info: super-speed hub ports: 1 rev: 3.1
  Hub-15: 10-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-16: 11-0:1 info: super-speed hub ports: 1 rev: 3.1
  System Temperatures: cpu: 48.6 C mobo: 48.0 C gpu: amdgpu temp: 48.0 C
  Fan Speeds (rpm): N/A
  Packages: 1453 pm: pacman pkgs: 1443 libs: 399 tools: pamac pm: flatpak
    pkgs: 10
    1: https://ziply.mm.fcix.net/manjaro/testing/$repo/$arch
    2: https://opencolo.mm.fcix.net/manjaro/testing/$repo/$arch
    3: https://codingflyboy.mm.fcix.net/manjaro/testing/$repo/$arch
    4: https://mirror.fcix.net/manjaro/testing/$repo/$arch
    5: https://irltoolkit.mm.fcix.net/manjaro/testing/$repo/$arch
    6: https://mirrors.ocf.berkeley.edu/manjaro/testing/$repo/$arch
    7: https://nocix.mm.fcix.net/manjaro/testing/$repo/$arch
    8: https://forksystems.mm.fcix.net/manjaro/testing/$repo/$arch
    9: https://ohioix.mm.fcix.net/manjaro/testing/$repo/$arch
    10: https://coresite.mm.fcix.net/manjaro/testing/$repo/$arch
    11: https://cofractal-ewr.mm.fcix.net/manjaro/testing/$repo/$arch
    12: https://volico.mm.fcix.net/manjaro/testing/$repo/$arch
    13: https://nnenix.mm.fcix.net/manjaro/testing/$repo/$arch
    14: https://southfront.mm.fcix.net/manjaro/testing/$repo/$arch
    15: https://mirror.math.princeton.edu/pub/manjaro/testing/$repo/$arch
    16: https://repo.ialab.dsu.edu/manjaro/testing/$repo/$arch
Processes:
  CPU top: 5 of 362
  1: cpu: 100% command: ps pid: 2469 mem: 3.91 MiB (0.0%)
  2: cpu: 6.2% command: plasmashell pid: 1179 mem: 379.3 MiB (1.2%)
  3: cpu: 5.2% command: manjaro-hello started-by: python3 pid: 1433
    mem: 522.9 MiB (1.6%)
  4: cpu: 3.9% command: kwin_wayland pid: 1019 mem: 216.1 MiB (0.6%)
  5: cpu: 2.8% command: systemsettings pid: 2295 mem: 225.4 MiB (0.7%)
  Memory top: 5 of 362
  1: mem: 522.9 MiB (1.6%) command: manjaro-hello started-by: python3
    pid: 1433 cpu: 5.2%
  2: mem: 379.3 MiB (1.2%) command: plasmashell pid: 1179 cpu: 6.2%
  3: mem: 225.4 MiB (0.7%) command: systemsettings pid: 2295 cpu: 2.8%
  4: mem: 216.1 MiB (0.6%) command: kwin_wayland pid: 1019 cpu: 3.9%
  5: mem: 99.5 MiB (0.3%) command: konsole pid: 2347 cpu: 1.0%
  Processes: 362 Power: uptime: 0m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.15 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 261 default: graphical
    tool: systemctl
  Compilers: gcc: 16.1.1 Shell: Sudo (sudo) v: 1.9.17p2 default: Bash
    v: 5.3.15 running-in: konsole inxi: 3.3.41
Mod Edit: Fixed formatting
I’d use that then.
Is there a reason you want to use 7.2.0rc5-1?
If you want help figuring it out, then you’ll probably need to provide more information about the symptoms than:
There may be some clues in the journal.
journalctl
For 7.2 release candidate kernels it may be better to switch to unstable branch
that has 7.2.0rc5-2 at the moment, but should have 7.2-rc5-4 soon
@byron4120
Please devote some time to learning how this forum works.
The forum software used is Discourse, which is a popular base for many online forums, which may be useful to know. However, more useful will be taking the time to examine Support categories available to post in, and searching for other information such as Forum Rules.
Your post has been moved to a dedicated topic.
Make the most of this by providing a more informative description of your issue which might help others gain a better understanding of the the problem.
Please also provide your system information in accordance with forum guidelines. :point_down:
inxi -zv8 (short-form)
Your privacy is respected
What is a Quark?
I should also point out that that kernel 7.2.0rc5-1 is a release candidate – that’s what the “rc” stands for – as such, it is expected that there might be issues with it.
Generally, only users with an interest in experimenting with a new kernel and/or participating in either the Unstable or Testing branches will install a pre-release kernel.
If your issue is a result of using a release candidate kernel, it might be prudent to install the well supported kernel 6.18 (LTS) instead.
This would involve booting from a live USB, entering a chroot environment, and installing the kernel as described in the following Wiki article:
https://wiki.manjaro.org/index.php?title=Manjaro_Kernels
Note: At the time of writing, the Manjaro Wiki is experiencing some difficulty with an ongoing botnet attack. Please be patient.
It appears that The Wayback Machine (web.archive.org) is also offline currently, so I am unable to offer an alternative link.
It might be useful to see where does it exactly hang. When rebooting hit the esc key to show the grub menu and edit the boot entry removing quiet splash
Further Clarification
It hangs on the shutdown process not the grub process. It never gets to the restart of the CPU. I tried unstable branch and rc-2 has the same issue. The reason I brought the topic up was to report issues on testing branch. I run stable kernels most of the time. My Dell laptop (intel I7) performs properly with the newer Kernels.
I encountered a regression bug during shutdown on: Framework Laptop 13 (AMD Ryzen 5 7640U with Radeon 760M graphics card)
The Fix will land into 7.3 but may not be backported to 7.2:
as a POI 7.2.0RC6-1 has same issue. Back on 7.1 - Will test or rebuild & test on next update
I can’t replicate it (on a desktop), 7.2.0rc6-1 reboots quickly for me, so it might be something with your hardware or your setup.
If this thread is to be anything but a waste of time, you need to provide information about the issue.
Do you see messages on shutdown?
If no, then do this :down_arrow: and answer the other questions
What’s the last message you see during shutdown?
Are there any other messages that might indicate the issue, eg a stop job with infinite timeout?
Is there anything in the journal that might shed light on the issue?
Keep in mind, if it’s actually an issue with the kernel - we’re not kernel devs. Also as it’s an RC, the issue may be resolved by the time it’s released.
7.2-rc6 is also a bad one for my fw laptop
I rebuilt my system and tried again. Also ran diagnostics etc. Wayland hang is present. Changed config by dropping external drives. No changes – will wait until later update. I hope this gets bumped up to Kernel developers.
7.2.0 Release went back on AMD stuff to previous stable. Reboot / shutdown etc. works properly. I suspect 7.3 will implement the new AMD codes properly, but only after more extensive testing - now that they have identified the failures.
Yep, known bug. Should be fixed in the final 7.2 even (at least 1 user reported so). If you want it now, switch to testing branch.
