Hi,
I recently installed Kernel 6.6.26-1 and I am facing a problem that after some time working with the system the system freezes and nothing can be done and I just have to press the power button to turn off the system.(I can only move the mouse but nothing can be done with it and the keyboard doesn’t work at all)
Logs:
journalctl -b -1 -p3
Apr 23 14:56:31 wave kernel: integrity: Problem loading X.509 certificate -65
Apr 23 14:56:31 wave systemd-udevd[302]: /etc/udev/rules.d/40-libsane.rules:26 GOTO="libsane_rules_end" has no matching label, ignoring.
Apr 23 14:56:31 wave systemd-udevd[302]: /etc/udev/rules.d/S99-2000S1.rules:26 GOTO="libsane_rules_end" has no matching label, ignoring.
Apr 23 14:56:32 wave kernel:
Apr 23 14:57:00 wave gdm-password][1699]: gkr-pam: unable to locate daemon control file
Apr 23 14:57:03 wave systemd[1715]: Failed to start Application launched by gnome-session-binary.
Apr 23 14:57:05 wave systemd[1715]: Failed to start Application launched by gnome-session-binary.
Apr 23 14:57:05 wave pulseaudio[2171]: GetManagedObjects() failed: org.freedesktop.DBus.Error.NameHasNoOwner: Could not activate remote peer: activation request failed: unknown unit.
Apr 24 01:31:03 wave kernel: BUG: kernel NULL pointer dereference, address: 000000000000001a
Apr 24 01:31:03 wave kernel: #PF: supervisor read access in kernel mode
Apr 24 01:31:03 wave kernel: #PF: error_code(0x0000) - not-present page
Apr 24 04:49:25 wave kernel: BUG: workqueue leaked lock or atomic: kworker/3:0/0x7fffffff/115479
last function: ata_scsi_dev_rescan
Apr 24 04:49:25 wave kernel: BUG: scheduling while atomic: kworker/3:0/115479/0x00000000
Apr 24 04:49:58 wave kernel: BUG: workqueue leaked lock or atomic: kworker/5:0/0x7fffffff/24274
Apr 24 04:49:58 wave kernel: BUG: scheduling while atomic: kworker/5:0/24274/0x00000000
Apr 24 04:50:49 wave kernel: BUG: workqueue leaked lock or atomic: kworker/7:0/0x7fffffff/114390
Apr 24 04:50:49 wave kernel: BUG: scheduling while atomic: kworker/7:0/114390/0x00000000
Apr 24 04:50:50 wave dbus-broker-launch[742]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
Apr 24 04:50:51 wave systemd[1]: Failed unmounting /home.
Apr 24 04:51:21 wave kernel: BUG: workqueue leaked lock or atomic: kworker/1:0/0x7fffffff/114019
Apr 24 04:51:21 wave kernel: BUG: scheduling while atomic: kworker/1:0/114019/0x00000000
Apr 24 04:51:53 wave kernel: BUG: workqueue leaked lock or atomic: kworker/5:3/0x7fffffff/115429
Apr 24 04:51:53 wave kernel: BUG: scheduling while atomic: kworker/5:3/115429/0x00000000
Apr 24 04:52:25 wave kernel: BUG: workqueue leaked lock or atomic: kworker/0:2/0x7fffffff/91805
Apr 24 04:52:25 wave kernel: BUG: scheduling while atomic: kworker/0:2/91805/0x00000000
Apr 24 04:52:57 wave kernel: BUG: workqueue leaked lock or atomic: kworker/1:0/0x7fffffff/114019
Apr 24 04:52:57 wave kernel: BUG: scheduling while atomic: kworker/1:0/114019/0x00000000
I had this problem almost every day in the last few days, and the first time I encountered this problem, I saved the log and placed it in the section below.
Apr 18 04:35:15 wave kernel: BUG: unable to handle page fault for address: 00000000000137d1
Apr 18 04:35:15 wave kernel: #PF: supervisor read access in kernel mode
Apr 18 04:35:15 wave kernel: #PF: error_code(0x0000) - not-present page
Apr 18 04:35:15 wave kernel: PGD 0 P4D 0
Apr 18 04:35:15 wave kernel: Oops: 0000 [#2] PREEMPT SMP PTI
Extra Info:
OS: Manjaro Linux x86_64
Kernel: 6.6.26-1-MANJARO
DE: GNOME 45.4
inxi -Fazy -c0
Kernel: 6.6.26-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=... rw quiet apparmor=1
security=apparmor resume=UUID=...
udev.log_priority=3
Desktop: GNOME v: 45.4 tk: GTK v: 3.24.41 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 45.0.1 Distro: Manjaro
base: Arch Linux
Type: Laptop System: LENOVO product: 81BF v: Lenovo ideapad 520-15IKB
serial: <superuser required> Chassis: type: 10 v: Lenovo ideapad 520-15IKB
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
part-nu: LENOVO_MT_81BF_BU_idea_FM_ideapad 520-15IKB
uuid: <superuser required> UEFI: LENOVO v: 6JCN21WW date: 12/04/2017
ID-1: BAT0 charge: 14.8 Wh (57.8%) condition: 25.6/35.0 Wh (73.1%)
power: 2.0 W volts: 7.9 min: 7.5 model: SMP L16M2PB2 type: Li-poly
serial: <filter> status: not charging
Info: model: Intel Core i7-8550U bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 level: v3 note: check built: 2017 process: Intel 14nm family: 6
model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xF4
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 443 high: 744 min/max: 400/4000 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 744 4: 400
5: 400 6: 400 7: 400 8: 400 bogomips: 32012
vulnerable
Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1
empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:5917
class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX150] vendor: Lenovo driver: nvidia
v: 550.67 alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current
(as of 2024-04; EOL~2026-12-xx) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-2019 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1d10
class-ID: 0302
Device-3: Syntek EasyCamera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:5 chip-ID: 174f:241a
class-ID: 0e02
Display: x11 server: X.org v: 1.21.1.12 with: Xwayland v: 23.2.6
compositor: gnome-shell driver: X: loaded: intel,nvidia dri: i965 gpu: i915
display-ID: :1 screens: 1
Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
Monitor-1: eDP-1 mapped: eDP1 model: BOE Display 0x06c6 built: 2016
res: 1920x1080 hz: 60 dpi: 143 gamma: 1.2 size: 340x190mm (13.39x7.48")
diag: 395mm (15.5") ratio: 16:9 modes: 1920x1080
API: OpenGL Message: Unable to show GL data. glxinfo is missing.
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_soc_avs
bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
API: ALSA v: k6.6.26-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-3: PulseAudio v: 17.0 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl,pavucontrol
vendor: Lenovo RTL8111/8168/8411 driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168
class-ID: 0200
Device-2: Intel Dual Band Wireless-AC 3165 Plus Bluetooth driver: iwlwifi
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0
chip-ID: 8086:3166 class-ID: 0280
Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:4 chip-ID: 8087:0a2a
class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 3 state: down bt-service: disabled
rfk-block: hardware: no software: no address: N/A
Local Storage: total: 1.14 TiB used: 950.82 GiB (81.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: SK Hynix model: HFS256G3BTND-N210A
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 1P10 scheme: GPT
SMART Message: Unknown smartctl error. Unable to generate data.
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000LM035-1RK172
tech: HDD rpm: 5400 serial: <filter> fw-rev: LCM2 scheme: GPT
ID-1: / raw-size: 112.97 GiB size: 110.64 GiB (97.94%)
used: 39.83 GiB (36.0%) fs: ext4 block-size: 4096 B dev: /dev/sda2
maj-min: 8:2
used: 280 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 116.21 GiB size: 113.83 GiB (97.95%)
used: 63.22 GiB (55.5%) fs: ext4 block-size: 4096 B dev: /dev/sda3
maj-min: 8:3
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default) zswap: yes
ID-1: swap-1 type: partition size: 8.79 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda4 maj-min: 8:4
System Temperatures: cpu: 45.0 C pch: 42.5 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 16 GiB note: est. available: 15.41 GiB used: 10.43 GiB (67.7%)
Processes: 372 Power: uptime: 1h 25m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.15 GiB services: gsd-power,
tool: systemctl
Packages: pm: pacman pkgs: 2095 libs: 474 tools: pamac,yay pm: flatpak
pkgs: 0 Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.34
Meanwhile, a solution came to my mind is to go back to the previous kernel (6.1.85-1).
Although in it (Kernel 6.1.85-1) I was facing another problem in the way that when I wanted to suspend the system, sometimes it worked, but sometimes after pressing the Suspend button, the screen went black, but the cpu was still working, and the keyboard and the mouse didn’t work either. It seems that it was not completely suspended and the system could not be used and I had to turn off the system with the power button.
If anyone has got any idea what is happening, please don’t hesitate to tell
Thank you
