pezlu
6 October 2023 12:59
1
Hello everyone,
since upgrading to kernel 6.5.x (any version including 6.5.5) my desktop PC boots very slowly and does not shut down.
When booting, after the BIOS I get a black screen for a very long time (about 30 minutes) before the Manjaro login screen shows up. Everything seems to work correctly afterwards, until I try to shutdown or reboot.
When shutting down, the following error is shown:
Timed out for waiting the udev queue being empty.
I’ve tried leaving the PC on but to no avail, I’ve always had to force shutdown by pressing the power button. It’s possible that waiting for a longer period of time would result in the PC shutting down by itself; I don’t know.
Reverting to kernel 6.4 solves the problem. I’ve tried reinstalling kernel 6.5 after every kernel update but nothing changed.
I’ve tried searching this forum and online for the error message but I couldn’t find anything related. Does anyone have any suggestion on how to solve this issue?
Thanks in advance for the help.
Hi
Perhaps you can show the community some info about you’re system. There’s plenty information how you should do that on the forum.
Then there’s this thread, hope it might solve you’re problem.
Hello,
since the last update my system does not boot anymore.
Only the following error message appears:
Timed out waiting for device disk/by-uuid/*hash_of_disk*
Dependency failed for /mnt/*same_hash_as_above*
I’m able to open a new session, but I have no clue what I can type in to fix my problem, because I’m new to Linux. I’ve tried to find a solution via search function tho.
Greetings
pezlu
9 October 2023 15:09
3
Hello and thanks for the quick reply.
Here is my inxi output:
Kernel: 6.4.16-5-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/vmlinuz-6.4-x86_64
root=UUID=921d454d-82dd-40c4-8cff-9cc99ed99802 rw quiet
resume=UUID=3a7e77b7-84db-4c9e-9189-7edfe0c7bd0d
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.10 info: latte-dock
wm: kwin_x11 vt: 2 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: MEDIONPC model: MS-7707 v: 1.1
serial: <superuser required> BIOS: American Megatrends v: E7707MLN.10E
date: 04/01/2011
System RAM: total: 8 GiB available: 7.74 GiB used: 4.69 GiB (60.5%)
Info: model: Intel Core i7-2600 bits: 64 type: MT MCP arch: Sandy Bridge
gen: core 2 level: v2 built: 2010-12 process: Intel 32nm family: 6
model-id: 0x2A (42) stepping: 7 microcode: 0x2F
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 2170 high: 3119 min/max: 1600/3800 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 2435 2: 2632 3: 1782
4: 2357 5: 3119 6: 1851 7: 1594 8: 1596 bogomips: 54296
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept est
flexpriority flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce
md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdtscp rep_good
sep smx ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology
xtpr
vulnerable
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GK106 [GeForce GTX 660] vendor: ASUSTeK driver: nvidia
v: 470.199.02 alternate: nouveau,nvidia_drm non-free: series: 470.xx+
status: legacy-active (EOL~2023/24) arch: Kepler code: GKxxx
process: TSMC 28nm built: 2012-18 pcie: gen: 2 speed: 5 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:11c0 class-ID: 0300
Device-2: Trust Webcam driver: snd-usb-audio,uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-1.1:3 chip-ID: 145f:016f
class-ID: 0102
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.2.1
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 101 s-size: 483x272mm (19.02x10.71")
s-diag: 554mm (21.82")
Monitor-1: DVI-D-0 res: 1920x1080 hz: 60 dpi: 102
size: 477x268mm (18.78x10.55") diag: 547mm (21.54") modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: kms_swrast surfaceless: drv: swrast x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 470.199.02
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 660/PCIe/SSE2
memory: 1.95 GiB
API: Vulkan v: 1.3.264 layers: 5 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 660 driver: nvidia v: 470.199.02
device-ID: 10de:11c0 surfaces: xcb,xlib
vendor: Micro-Star MSI 6 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1c20 class-ID: 0403
Device-2: NVIDIA GK106 HDMI Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:0e0b class-ID: 0403
Device-3: Trust Webcam driver: snd-usb-audio,uvcvideo type: USB rev: 2.0
class-ID: 0102
API: ALSA v: k6.4.16-5-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.80 status: active with: 1: pipewire-pulse
status: active 2: pipewire-media-session status: active 3: pipewire-alsa
type: plugin 4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli
Device-1: Intel 82579V Gigabit Network vendor: Micro-Star MSI driver: e1000e
v: kernel port: f040 bus-ID: 00:19.0 chip-ID: 8086:1503 class-ID: 0200
Device-2: Realtek RTL88x2bu [AC1200 Techkey] driver: rtl88x2bu type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-1.6:7
chip-ID: 0bda:b812 class-ID: 0000 serial: <filter>
IF: wlp0s29u1u6 state: up mac: <filter>
Device-3: D-Link System AirPlus G DWL-G122 Wireless Adapter(rev.E1)
[Ralink RT2070] driver: rt2800usb type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 07d1:3c0f class-ID: 0000
serial: <filter>
IF: wlp3s0u1 state: up mac: <filter>
Device-1: Broadcom BCM2045 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-1.7:6 chip-ID: 0a5c:2101
class-ID: fe01
Local Storage: total: 931.51 GiB used: 492.94 GiB (52.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST31000528AS
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC46 scheme: GPT
Optical-1: /dev/sr0 vendor: TSSTcorp model: CDDVDW SH-S223C rev: me01
dev-links: cdrom
Features: speed: 52 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 100 GiB size: 98.12 GiB (98.12%) used: 58.71 GiB (59.8%)
fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 921d454d-82dd-40c4-8cff-9cc99ed99802
ID-2: /boot raw-size: 512 MiB size: 511 MiB (99.80%)
used: 123.9 MiB (24.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 783C-FDE4
ID-3: /home raw-size: 821.01 GiB size: 807.05 GiB (98.30%)
used: 434.1 GiB (53.8%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: 0608d4a3-fa49-4a60-b377-09c141769042
ID-1: swap-1 type: partition size: 10 GiB used: 12 KiB (0.0%) priority: -2
dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 3a7e77b7-84db-4c9e-9189-7edfe0c7bd0d
Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:0024
Hub-3: 1-1.5:3 info: Alcor Micro USB Hub ports: 4 rev: 2.0
chip-ID: 058f:6254 class-ID: 0900
Device-1: 1-1.5.1:4 info: Alcor Micro USB Card Reader type: mass storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 250mA chip-ID: 058f:6365 class-ID: 0806
serial: <filter>
Hub-4: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-5: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Device-1: 2-1.1:3 info: Trust Webcam type: video,audio
chip-ID: 145f:016f class-ID: 0102
Device-2: 2-1.5:4 info: Holtek USB Gaming Mouse type: keyboard,mouse,HID
driver: holtek_mouse,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 04d9:a070 class-ID: 0300
Device-3: 2-1.6:7 info: Realtek RTL88x2bu [AC1200 Techkey] type: Network
driver: rtl88x2bu interfaces: 1 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 0bda:b812 class-ID: 0000
serial: <filter>
Device-4: 2-1.7:6 info: Broadcom BCM2045 Bluetooth type: bluetooth
driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 100mA chip-ID: 0a5c:2101 class-ID: fe01
Hub-6: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 3-1:2 info: D-Link System AirPlus G DWL-G122 Wireless
Adapter(rev.E1) [Ralink RT2070] type: Network driver: rt2800usb
power: 450mA chip-ID: 07d1:3c0f class-ID: 0000 serial: <filter>
Hub-7: 4-0:1 info: super-speed hub ports: 2 rev: 3.0
System Temperatures: cpu: 51.0 C mobo: 39.0 C
Fan Speeds (rpm): cpu: 0 fan-1: 1355 fan-3: 0
Power: 12v: N/A 5v: N/A 3.3v: 3.38 vbat: 3.39
Processes: 270 Uptime: 46m wakeups: 0 Init: systemd v: 254 default: graphical
tool: systemctl Compilers: gcc: 13.2.1 alt: 10/9 clang: 16.0.6 Packages:
pm: pacman pkgs: 2555 libs: 590 tools: pacaur,pamac,yay pm: flatpak pkgs: 0
Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.30
This being a production machine in currently running kennel 6.4, which works, but if needed I can reinstall kennel 6.5 for testing.
I’ve checked the thread you suggested, I had noticed it while searching the forum but the issue seems quite different. In my case the system boots, albeit very slowly.
Any suggestions?
Thanks again for the help
pezlu:
Any suggestions?
I had a similar experience which was attributable to the same GTX 660 model some years ago (in a Debian derivitive). I’m afraid I don’t recall how I overcame that, but it may help to narrow the search.
Wollie
13 October 2023 15:29
5
You could try to restore the boot loader .
You have a /boot partition but no /boot/efi partition. How did you mount your ESP ?
What is your use case for requiring the latest kernel on a system where both cpu + gpu (and motherboard BIOS) are more than 10 years old? You’d probably be better off with 6.1 LTS.
pezlu
26 October 2023 15:44
7
After some thinking I decided to just go that way. I reverted to 6.1; maybe I’ll upgrade to the next LTS ignoring other kernels.
Thanks to everyone for the suggestions
system
Closed
29 October 2023 05:44
8
