Has there been any reports on or a regression in the amd-pstate-epp driver, or something since 6.17 and 6.18?
Last November I upgraded to AM5 + 7800X3D a few weeks before the Ahn-Linh release, so was still running 6.16.8. Switched to amd-pstate-epp (active) driver instead of amd-pstate (passive) for the 7800X3D and this gave no issues worked very well.
Since updating to Kernel 6.18 lts released with Ahn-lynn preview, I have been having CPU performance issues when the system has resumed from sleep.
I noticed my CPU ‘all core boost’ would no longer boosts to it’s ‘all core frequency’ under all core load. Which for my part is ~4.9Ghz.
The following boost behavior occurs, after resume from sleep, on 6.17 and 6.18:
Only two cores boost to max freq of 5049Mhz and the rest are stuck at 4.0Ghz.
A reboot is needed to get normal CPU frequency boosting behavior back for all core work loads.
Temprorarily as workaround I switched back to the non-epp amd-pstate driver amd_pstate=passive amd_prefcore=enable, still running Kernel 6.18 and the boost behavior issue after resume does not occur using amd_pstate=passive.
More additional information in the spoilers below:
Test method
The Power-Profile was set to Performance and tested with stress -c 16 to load all cores.
Also tested setting the Power-Profile set to Power-Saver or Performance before putting the system to sleep. This had no effect.
journalctl
Journalctl did not show anything out of the ordinary after a resume from sleep state, except for these cores:
jan 02 15:05:57 Infinity kernel: smpboot: Booting Node 0 Processor 9 APIC 0x3
jan 02 15:05:57 Infinity kernel: Spurious APIC interrupt (vector 0xFF) on CPU#9, should never happen.
jan 02 15:05:57 Infinity kernel: smpboot: Booting Node 0 Processor 10 APIC 0x5
jan 02 15:05:57 Infinity kernel: Spurious APIC interrupt (vector 0xFF) on CPU#10, should never happen.
jan 02 15:05:57 Infinity kernel: smpboot: Booting Node 0 Processor 11 APIC 0x7
jan 02 15:05:57 Infinity kernel: Spurious APIC interrupt (vector 0xFF) on CPU#11, should never happen.
jan 02 15:05:57 Infinity kernel: smpboot: Booting Node 0 Processor 12 APIC 0x9
jan 02 15:05:57 Infinity kernel: Spurious APIC interrupt (vector 0xFF) on CPU#12, should never happen.
jan 02 15:05:57 Infinity kernel: smpboot: Booting Node 0 Processor 13 APIC 0xb
jan 02 15:05:57 Infinity kernel: Spurious APIC interrupt (vector 0xFF) on CPU#13, should never happen.
jan 02 15:05:57 Infinity kernel: smpboot: Booting Node 0 Processor 14 APIC 0xd
jan 02 15:05:57 Infinity kernel: Spurious APIC interrupt (vector 0xFF) on CPU#14, should never happen.
jan 02 15:05:57 Infinity kernel: smpboot: Booting Node 0 Processor 15 APIC 0xf
jan 02 15:05:57 Infinity kernel: Spurious APIC interrupt (vector 0xFF) on CPU#15, should never happen.
cpupower frequency-info output, using amd-pstate=active set to Performance profile:
analyzing CPU 10:
driver: amd-pstate-epp
CPUs which run at the same hardware frequency: 10
CPUs which need to have their frequency coordinated by software: 10
energy performance preference: power
hardware limits: 426 MHz - 5.05 GHz
available cpufreq governors: performance powersave
current policy: frequency should be within 2.98 GHz and 5.05 GHz.
The governor "powersave" may decide which speed to use
within this range.
current CPU frequency: 3.80 GHz (asserted by call to kernel)
boost state support:
Supported: yes
Active: yes
amd-pstate limits:
Highest Performance: 166. Maximum Frequency: 5.05 GHz.
Nominal Performance: 138. Nominal Frequency: 4.20 GHz.
Lowest Non-linear Performance: 98. Lowest Non-linear Frequency: 2.98 GHz.
Lowest Performance: 14. Lowest Frequency: 545 MHz.
Preferred Core Support: 1. Preferred Core Ranking: 176.
cpupower frequency-info using amd-pstate=passive
analyzing CPU 3:
driver: amd-pstate
CPUs which run at the same hardware frequency: 3
CPUs which need to have their frequency coordinated by software: 3
maximum transition latency: 20.0 us
available cpufreq governors: conservative ondemand userspace powersave performance schedutil
current policy: frequency should be within 545 MHz and 5.05 GHz.
The governor "schedutil" may decide which speed to use
within this range.
current CPU frequency: 548 MHz (asserted by call to kernel)
Supported: yes
Active: yes
amd-pstate limits:
Preferred Core Support: 1. Preferred Core Ranking: 191.
inxi -v7azy
Kernel: 6.18.2-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=c2c92475-3f6d-43c2-9ed5-ce58e4c5b93f rw plymouth.enable=0
disablehooks=plymouth quiet splash udev.log_priority=3
video=DP-1:3440x1440MR@160 amd_pstate=active amd_prefcore=enable
amdgpu.ppfeaturemask=0xffffffff
Desktop: KDE Plasma v: 6.5.4 tk: Qt v: N/A info: frameworks v: 6.21.0
Type: Desktop Mobo: Micro-Star model: MAG B850M MORTAR WIFI (MS-7E61) v: 1.0
serial: <superuser required> uuid: <superuser required> Firmware: UEFI
vendor: American Megatrends LLC. v: 1.A45 date: 09/10/2025
System RAM: total: 32 GiB available: 30.4 GiB used: 5.25 GiB (17.3%)
Device-1: DIMMA1 type: no module installed
Device-2: DIMMA2 type: DDR5 detail: synchronous unbuffered (unregistered)
size: 16 GiB speed: 6000 MT/s volts: note: check curr: 1 min: 1 max: 1
width (bits): data: 64 total: 64 manufacturer: N/A
part-no: IR-6400D564L32S/16G serial: <filter>
Device-3: DIMMB1 type: no module installed
Device-4: DIMMB2 type: DDR5 detail: synchronous unbuffered (unregistered)
Info: model: AMD Ryzen 7 7800X3D bits: 64 type: MT MCP arch: Zen 4 gen: 4
level: v4 note: check built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25)
model-id: 0x61 (97) stepping: 2 microcode: 0xA60120C
smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB
desc: 8x1024 KiB L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 3798 min/max: 426/4201 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 3798 2: 3798 3: 3798
4: 3798 5: 3798 6: 3798 7: 3798 8: 3798 9: 3798 10: 3798 11: 3798 12: 3798
13: 3798 14: 3798 15: 3798 16: 3798 bogomips: 134400
apic arat avic avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2 avx512_vnni
avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi
avx512vl bmi1 bmi2 bpext cat_l3 cdp_l3 clflush clflushopt clwb clzero cmov
cmp_legacy constant_tsc cpb cppc cpuid cpuid_fault cqm cqm_llc
cqm_mbm_local cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de
decodeassists erms extapic extd_apicid f16c flush_l1d flushbyasid fma fpu
fsgsbase fsrm fxsr fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs
invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw
overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb perfmon_v2 pfthreshold pge pku pni popcnt pse pse36
rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit
smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm
svm_lock syscall tce topoext tsc tsc_scale umip user_shstk v_spec_ctrl
vaes vgif vmcb_clean vme vmmcall vnmi vpclmulqdq wbnoinvd wdt x2avic
xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
STIBP: always-on; PBRSB-eIBRS: Not affected; BHI: Not affected
Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 [Radeon RX 9070/9070
XT/9070 GRE] vendor: Sapphire driver: amdgpu v: kernel arch: RDNA-4
code: Navi-4x process: TSMC n4 (4nm) built: 2025+ pcie: gen: 5
speed: 32 GT/s lanes: 16 ports: active: DP-1 empty: DP-2, HDMI-A-1,
HDMI-A-2, Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:7550 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Raphael vendor: Micro-Star MSI
driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
empty: HDMI-A-3,Writeback-2 bus-ID: 11:00.0 chip-ID: 1002:164e
class-ID: 0300 temp: 34.0 C
compositor: kwin_wayland driver: X: loaded: amdgpu
gpu: amdgpu display-ID: 0
Monitor-1: DP-1 model: AOC CU34G2XP serial: <filter> built: 2024 res:
mode: 3440x1440 hz: 160 scale: 100% (1) dpi: 110 gamma: 1.2
size: 797x334mm (31.38x13.15") diag: 864mm (34") modes: max: 3440x1440
min: 720x400
device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: radeonsi surfaceless:
drv: radeonsi wayland: drv: radeonsi x11: drv: radeonsi
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.3.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 9070 XT (radeonsi
gfx1201 LLVM 21.1.6 DRM 3.64 6.18.2-1-MANJARO) device-ID: 1002:7550
memory: 15.62 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.335 layers: 11 device: 0 type: discrete-gpu name: AMD
Radeon RX 9070 XT (RADV GFX1201) driver: mesa radv v: 25.3.1-arch1.2
device-ID: 1002:7550 surfaces: N/A device: 1 type: integrated-gpu name: AMD
Ryzen 7 7800X3D 8-Core Processor (RADV RAPHAEL_MENDOCINO) driver: mesa radv
v: 25.3.1-arch1.2 device-ID: 1002:164e surfaces: N/A
de: kscreen-console,kscreen-doctor gpu: amdgpu_top,corectrl wl: wayland-info
x11: xdpyinfo, xprop, xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 HDMI/DP Audio
driver: snd_hda_intel v: kernel pcie: gen: 5 speed: 32 GT/s lanes: 16
bus-ID: 03:00.1 chip-ID: 1002:ab40 class-ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] Radeon High Definition Audio
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 11:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-3: Advanced Micro Devices [AMD] Ryzen HD Audio driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 11:00.6
chip-ID: 1022:15e3 class-ID: 0403
Device-4: Micro Star USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-12:7
chip-ID: 0db0:cc78 class-ID: 0300
Device-5: Texas Instruments PCM2902 Audio Codec
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-5.1:4 chip-ID: 08bb:2902 class-ID: 0300
API: ALSA v: k6.18.2-1-MANJARO status: kernel-api with: aoss
Server-1: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse
status: active 2: pipewire-media-session status: active 3: pipewire-alsa
type: plugin 4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli
Device-1: Realtek RTL8126 5GbE vendor: Micro-Star MSI driver: r8169 v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 1 port: e000 bus-ID: 0c:00.0
chip-ID: 10ec:8126 class-ID: 0200
IF: enp12s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Qualcomm WCN785x Wi-Fi 7 320MHz 2x2 [FastConnect 7800]
vendor: Foxconn Band Simultaneous Wireless driver: ath12k_pci v: N/A
modules: ath12k pcie: gen: 3 speed: 8 GT/s lanes: 1 link-max: lanes: 2
bus-ID: 0d:00.0 chip-ID: 17cb:1107 class-ID: 0280
IF: wlp13s0 state: down mac: <filter>
Info: services: NetworkManager, smbd, systemd-timesyncd
Device-1: Foxconn / Hon Hai driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-11:5 chip-ID: 0489:e10a
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 4 state: down bt-service: enabled,running
Local Storage: total: 6.41 TiB used: 2.1 TiB (32.7%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Lexar model: SSD NM620 1TB
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: V1.23 temp: 35.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Reletech model: M.2 SSD 1024GB
lanes: 4 tech: SSD serial: <filter> fw-rev: ECFM32.1 temp: 30.9 C
scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 2TB
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 3B6Q scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 2TB
ID-5: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST1000DM010-2EP102
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: HDD rpm: 7200
serial: <filter> fw-rev: 0104 scheme: MBR
ID-1: / raw-size: 857.7 GiB size: 843.16 GiB (98.31%)
used: 413.98 GiB (49.1%) fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:2
label: N/A uuid: c2c92475-3f6d-43c2-9ed5-ce58e4c5b93f
used: 328 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1 label: N/A
uuid: 4A19-EA19
ID-3: /mnt/data raw-size: 858.48 GiB size: 843.93 GiB (98.31%)
used: 402.77 GiB (47.7%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:4
label: DATA uuid: 74423f52-a944-4f61-9500-f4bc683c2cef
ID-4: /mnt/data2 raw-size: 1.64 TiB size: 1.61 TiB (98.37%)
used: 480.26 GiB (29.1%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: DATA2
uuid: 4de3dfe5-98c9-438d-9fef-7bd41d5bf67f
ID-5: /mnt/data3 raw-size: 1.64 TiB size: 1.61 TiB (98.37%)
used: 262.43 GiB (15.9%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: DATA3
uuid: e14912f2-9e23-418f-9a32-6eca47b43d8f
ID-6: /mnt/storage raw-size: 755.73 GiB size: 755.73 GiB (100.00%)
used: 586.38 GiB (77.6%) fs: ntfs dev: /dev/sdc1 maj-min: 8:33 label: STORAGE
uuid: B0A0696BA069394C
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default) zswap: yes
ID-1: swap-1 type: file size: 8 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/sdc2 maj-min: 8:34 size: 175.78 GiB fs: ext4 label: STORAGE_BACKUP
uuid: b2548556-eb55-44c4-bc73-91b7499dee60
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Hub-2: 1-5:2 info: Genesys Logic Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 05e3:0610
Device-1: 1-5.1:4 info: Texas Instruments PCM2902 Audio Codec
type: audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
Device-2: 1-5.3:6 info: Sharkoon SHARK Force 3 type: mouse,keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 30fa:1440 class-ID: 0300
Device-3: 1-5.4:8 info: SONiX USB DEVICE type: keyboard,mouse
lanes: 1 mode: 1.1 power: 100mA chip-ID: 320f:500c class-ID: 0301
Device-4: 1-10:3 info: Micro Star MYSTIC LIGHT type: HID
lanes: 1 mode: 1.1 power: 100mA chip-ID: 0db0:0076 class-ID: 0300
serial: <filter>
Device-5: 1-11:5 info: Foxconn / Hon Hai type: bluetooth driver: btusb
interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 100mA chip-ID: 0489:e10a class-ID: e001
Device-6: 1-12:7 info: Micro Star USB Audio type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 8 rev: 2.0
Hub-3: 2-0:1 info: super-speed hub ports: 5 rev: 3.1
Hub-4: 2-5:2 info: Genesys Logic GL3523 Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0620
Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-6: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
Device-1: 4-2:2 info: JMS578 based SATA bridge type: mass storage
driver: uas interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s) lanes: 1
mode: 3.2 gen-1x1 power: 8mA chip-ID: 0080:a001 class-ID: 0806
serial: <filter>
Hub-7: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-8: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-9: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
System Temperatures: cpu: 39.6 C mobo: N/A
Fan Speeds (rpm): fan-1: 511 fan-2: 0 fan-3: 0 fan-4: 0 fan-13: 709
fan-14: 0 fan-15: 0 fan-16: 635
GPU: device: amdgpu temp: 32.0 C mem: 56.0 C fan: 0 watts: 22.00
device: amdgpu temp: 35.0 C
Power: 12v: 11.90 5v: 4.96 3.3v: 3.30 vbat: 1.84
Processes: 410 Power: uptime: 39m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 3 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 12.14 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 258 default: graphical
tool: systemctl
Packages: pm: pacman pkgs: 1561 libs: 436 tools: pamac pm: flatpak pkgs: 0
Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Bash v: 5.3.9 running-in: konsole
inxi: 3.3.40
