Kernel 6.15 on stable 25.0.1 hibernation delay
I run Plasma on Wayland, in case that matters.
After the last updates everything runs fine. Hibernation changed, but did not break. There is no error. It going INTO hibernation:
With kernel 6.14 hibernation takes 20 seconds. With kernel 6.15 it takes 4 minutes and 42 seconds. These are times on a Dell Latitude E7470 Ultrabook.
Wondering if this is unique to my hardware, or if others have noticed that a quick search did not turn up.
I’m running Plasma on Wayland, no issues with Hibernation here.
basic set up details.
KDE Plasma Version: 6.3.4
KDE Frameworks Version: 6.13.0
Qt Version: 6.9.0
Kernel Version: 6.14.4-1-MANJARO (64-bit)
Graphics Platform: Wayland
Processors: 4 × Intel® Pentium® CPU  N3540  @ 2.16GHz
Memory: 7.6 GiB of RAM
Graphics Processor: Intel® HD Graphics
Manufacturer: Notebook
Product Name: W54_W94_W955TU,-T,-C
You’ll need to supply more details, including logs.
Some system details might help e.g.:
inxi -zv8
This will give us info on RAM availability and swap etc. … :wink:
Would you like reports for BOTH kernels, or only one?
Here is the report for the 6.14 kernel.
  Kernel: 6.14.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.14-x86_64
    root=UUID=c0742a37-0fbc-40a4-8f94-e208c0606e5c rw rootflags=subvol=@
    quiet apparmor=1 security=apparmor
    resume=UUID=809319f8-dca1-47de-9b9f-0942b6628eeb udev.log_priority=3
  Console: pty pts/1 wm: kwin_wayland DM: SDDM Distro: Manjaro
    base: Arch Linux
  Type: Laptop System: Dell product: Latitude E7470 v: N/A serial: <filter>
    Chassis: type: 9 serial: <filter>
  Mobo: Dell model: 0T6HHJ v: A00 serial: <filter> part-nu: 06DC
    uuid: 4c4c4544-0051-5610-8051-c6c04f4b4332 UEFI-[Legacy]: Dell v: 1.36.3
    date: 09/18/2022
  ID-1: BAT0 charge: 42.5 Wh (100.0%) condition: 42.5/55.0 Wh (77.3%)
    volts: 8.5 min: 7.6 model: SMP DELL MC34Y51 type: Li-poly serial: <filter>
    status: full
  System RAM: total: 16 GiB available: 15.43 GiB used: 3.2 GiB (20.8%)
    igpu: 32 MiB
  Device-1: DIMM A type: DDR4 detail: synchronous size: 8 GiB
    speed: 2133 MT/s volts: curr: 1.2 width (bits): data: 64 total: 64
    manufacturer: SK Hynix part-no: HMA41GS6AFR8N-TF serial: <filter>
  Device-2: DIMM B type: DDR4 detail: synchronous size: 8 GiB
  Slot: 0 type: PCIe status: in use info: J6B2 length: long volts: 3.3
    bus-ID: 00:01.0
  Slot: 1 type: PCIe status: in use info: J6B1 length: short volts: 3.3
    bus-ID: 00:1c.3
  Slot: 2 type: PCIe status: in use info: J6D1 length: short volts: 3.3
    bus-ID: 00:1c.4
  Slot: 3 type: PCIe status: in use info: J7B1 length: short volts: 3.3
    bus-ID: 00:1c.5
  Slot: 4 type: PCIe status: in use info: J8B4 length: short volts: 3.3
    bus-ID: 00:1c.6
  Info: model: Intel Core i5-6300U socket: U3E1 bits: 64 type: MT MCP
    arch: Skylake gen: core 6 level: v3 note: check built: 2015
    process: Intel 14nm family: 6 model-id: 0x4E (78) stepping: 3
    microcode: 0xF0
  Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
    smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
    desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 500 min/max: 400/3000 base/boost: 2400/2400 scaling:
    driver: intel_pstate governor: powersave volts: 0.8 V ext-clock: 100 MHz
    cores: 1: 500 2: 500 3: 500 4: 500 bogomips: 19999
    smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
  Type: gather_data_sampling status: Vulnerable: No microcode
    vulnerable
  Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Dell Latitude E7470
    driver: i915 v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports:
    active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
    chip-ID: 8086:1916 class-ID: 0300
  Device-2: Realtek Integrated_Webcam_FHD driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:2 chip-ID: 0bda:5765
  Display: unspecified server: X.Org v: 24.1.6 with: Xwayland v: 24.1.6
    alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :1 screens: 1
  Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 508x318mm (20.00x12.52")
    s-diag: 599mm (23.6")
  Monitor-1: eDP-1 model: LG Display 0x04a0 built: 2014 res: mode: 1920x1200
    hz: 60 scale: 100% (1) dpi: 157 gamma: 1.2 chroma: red: x: 0.647 y: 0.337
    green: x: 0.318 y: 0.612 blue: x: 0.153 y: 0.047 white: x: 0.314 y: 0.329
    size: 310x174mm (12.2x6.85") diag: 355mm (14") ratio: 16:9
    modes: 2560x1440
    device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
    inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.0.4-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 520 (SKL GT2)
    device-ID: 8086:1916 memory: 7.53 GiB unified: yes
  API: Vulkan v: 1.4.309 layers: N/A device: 0 type: integrated-gpu
    name: Intel HD Graphics 520 (SKL GT2) driver: mesa intel v: 25.0.4-arch1.1
    device-ID: 8086:1916 surfaces: xcb,xlib
    de: kscreen-console,kscreen-doctor wl: kanshi,wayland-info x11: xdriinfo,
    xdpyinfo, xprop, xrandr
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell Latitude E7470
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3
    chip-ID: 8086:9d70 class-ID: 0403
  API: ALSA v: k6.14.4-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.4.2 status: n/a (root, process)
    with: pipewire-media-session status: active tools: pw-cli
  Server-4: PulseAudio v: 17.0-43-g3e2bb status: active (root, process)
    with: pulseaudio-alsa type: plugin tools: pacat,pactl
  Device-1: Intel Ethernet I219-LM vendor: Dell Latitude E7470 driver: e1000e
    v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:156f class-ID: 0200
  IF: enp0s31f6 state: down mac: <filter>
  Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:24f3 class-ID: 0280
  IF-ID-1: incusbr0 state: down mac: <filter>
  IP v4: <filter> scope: global
  IP v6: <filter> scope: global
  IF-ID-2: virbr0 state: down mac: <filter>
  Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:4 chip-ID: 8087:0a2b
    class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 4 state: up address: <filter> bt-v: 4.2
    lmp-v: 8 status: discoverable: no pairing: no class-ID: 6c010c
  Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
    v: 3.0 port: f060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
  Local Storage: total: 476.94 GiB used: 286.48 GiB (60.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Silicon Power
    model: SPCC M.2 PCIe SSD size: 476.94 GiB block-size: physical: 512 B
    fw-rev: U0708A3 temp: 35.9 C scheme: MBR
  SMART: yes health: PASSED on: 256d 23h cycles: 8,525
    read-units: 127,786,765 [65.4 TB] written-units: 68,727,945 [35.1 TB]
  ID-1: / raw-size: 459.96 GiB size: 459.96 GiB (100.00%)
    used: 286.48 GiB (62.3%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p1
    maj-min: 259:1 label: N/A uuid: c0742a37-0fbc-40a4-8f94-e208c0606e5c
  ID-2: /home raw-size: 459.96 GiB size: 459.96 GiB (100.00%)
  ID-3: /var/cache raw-size: 459.96 GiB size: 459.96 GiB (100.00%)
  ID-4: /var/lib/incus/storage-pools/default raw-size: 459.96 GiB
    size: 459.96 GiB (100.00%) used: 286.48 GiB (62.3%) fs: btrfs
    block-size: 4096 B dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
  ID-5: /var/lib/incus/storage-pools/newstorage raw-size: 459.96 GiB
  ID-6: /var/lib/incus/storage-pools/pool raw-size: 459.96 GiB
  ID-7: /var/log raw-size: 459.96 GiB size: 459.96 GiB (100.00%)
  ID-1: swap-1 type: partition size: 16.98 GiB used: 6.6 MiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:2 label: swap
    uuid: 809319f8-dca1-47de-9b9f-0942b6628eeb
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-2:2 info: Realtek Integrated_Webcam_FHD type: video
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 0bda:5765 class-ID: 0e02
    serial: <filter>
  Hub-2: 1-4:3 info: Genesys Logic USB 2.0 Hub / D-Link DUB-H4 ports: 4
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
    chip-ID: 05e3:0606 class-ID: 0900
  Device-1: 1-4.3:5 info: Logitech Keyboard K120 type: keyboard,HID
    speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 90mA
    chip-ID: 046d:c31c class-ID: 0300
  Device-2: 1-4.4:7 info: Logitech Mouse type: mouse
    chip-ID: 046d:c077 class-ID: 0301
  Device-3: 1-8:4 info: Intel Bluetooth wireless interface type: bluetooth
    mode: 1.1 power: 100mA chip-ID: 8087:0a2b class-ID: e001
  Device-4: 1-9:6 info: Elan Micro Touchscreen type: HID
    driver: hid-multitouch,usbhid interfaces: 1 rev: 2.0
    chip-ID: 04f3:21e3 class-ID: 0300
  Hub-3: 2-0:1 info: super-speed hub ports: 6 rev: 3.0
  System Temperatures: cpu: 47.0 C pch: 41.5 C mobo: 40.0 C
  Fan Speeds (rpm): cpu: 0
  Packages: pm: pacman pkgs: 2259 libs: 554 tools: pamac,yay
    1: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    3: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    4: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    5: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    7: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    8: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 223
  1: cpu: 22.8% command: floorp pid: 4637 mem: 652.1 MiB (4.1%)
  2: cpu: 10.7% command: floorp pid: 9431 mem: 327.7 MiB (2.0%)
  3: cpu: 9.8% command: kwin_wayland pid: 1571 mem: 243.5 MiB (1.5%)
  4: cpu: 5.6% command: doas pid: 9644 mem: 4.60 MiB (0.0%)
  5: cpu: 4.5% command: pulseaudio pid: 1688 mem: 37.4 MiB (0.2%)
  Memory top: 5 of 223
  1: mem: 652.1 MiB (4.1%) command: floorp pid: 4637 cpu: 22.8%
  2: mem: 370.6 MiB (2.3%) command: plasmashell pid: 1789 cpu: 1.2%
  3: mem: 362.5 MiB (2.2%) command: floorp pid: 4792 cpu: 2.6%
  4: mem: 327.7 MiB (2.0%) command: floorp pid: 9431 cpu: 10.7%
  5: mem: 243.5 MiB (1.5%) command: kwin_wayland pid: 1571 cpu: 9.8%
  Processes: 223 Power: uptime: 3h 55m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.16 GiB services: org_kde_powerdevil,upowerd
  Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Bash (doas) v: 5.2.37
    running-in: yakuake inxi: 3.3.38
Mod edit:- Converted quote box to preformatted text box so that readers can avoid scrolling to Antarctica and back.
6.15 is still in development. So issues might still occur with it …
