Hello
I run stable with LTS kernel 6.12.21-4 (after some years with arch).
So far I cannot connect with my bluetooth JLB Tune 770. It is recognized as “miscellaneous” instead of headset. My other BT-devices work fine.
I remember with 6.13 or 6.14 (with arch) I ran into similar issues, though another device wasn’t working too. I had to wait for a kernel update to enjoy again my BT-headset.
Any chance to confirm it is a kernel issue and then maybe hope for a 6.12.21-5?
best regards
Brice
j8a
25 April 2025 15:34
2
Hi @bricem13 ,
I wonder whether you could post the output of the following terminal command below this post, in order to help you solve the issue:
inxi -zv8
Regards,
j8a:
inxi -zv8
sure, here it is:
[brice@TuxBox:~]$ sudo inxi -zv8
Kernel: 6.12.21-4-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: root=UUID=1154cdb2-0f0f-4823-8930-ce41f7dbea12 rw quiet
splash apparmor=1 security=apparmor udev.log_priority=3
initrd=boot\initramfs-6.12-x86_64.img
Desktop: Xfce v: 4.20.1 tk: Gtk v: 3.24.48 wm: xfwm4 v: 4.20.0
with: xfce4-panel tools: xfce4-screensaver dm: LightDM v: 1.32.0
Type: Laptop System: LENOVO product: 82NB v: Lenovo V15 G1 IML
serial: <filter> Chassis: type: 10 v: Lenovo V15 G1 IML serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40700 WIN serial: <filter>
part-nu: LENOVO_MT_82NB_BU_idea_FM_V15 G1 IML
uuid: a2bc3802-d066-48a8-a949-88a4c27a292d UEFI: LENOVO v: DXCN44WW
date: 11/17/2022
ID-1: BAT0 charge: 33.4 Wh (96.0%) condition: 34.8/35.3 Wh (98.6%)
volts: 8.4 min: 7.6 model: CPT-COS L16C2PB1 type: Li-poly serial: <filter>
status: not charging cycles: 32
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse PID:0081
serial: N/A charge: 70% (should be ignored) rechargeable: yes
status: discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Keyboard PID:0062
status: discharging
System RAM: total: 20 GiB available: 19.28 GiB used: 5.26 GiB (27.3%)
igpu: 32 MiB
Array-1: capacity: 32 GiB note: est. slots: 2 modules: 2 EC: None
Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 4 GiB
speed: 2667 MT/s volts: curr: 1.2 min: 1.5 max: 1.5 width (bits): data: 64
total: 64 manufacturer: Micron part-no: MT40A512M16TB-062E:R serial: N/A
Device-2: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 16 GiB
total: 64 manufacturer: Crucial part-no: CT16G4SFRA32A.. serial: <filter>
Slot: 1 type: PCIe status: available info: J6C1 length: other
bus-ID: 00:1c.0
Slot: 2 type: PCIe status: available info: J6D2 length: other
bus-ID: 00:1c.1
Slot: 3 type: PCIe status: available info: J7C1 length: other
bus-ID: 00:1c.2
Slot: 4 type: PCIe status: available info: J7D1 length: other
bus-ID: 00:1c.3
Slot: 5 type: PCIe status: available info: J8C1 length: other
bus-ID: 00:1c.4
Info: model: Intel Core i3-10110U socket: BGA1528 (U3E1) note: check
bits: 64 type: MT MCP arch: Comet/Whiskey Lake note: check gen: core 10
level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x8E (142) stepping: 0xC (12) microcode: 0xFC
Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
desc: 2x256 KiB L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2789 min/max: 400/4100 base/boost: 1980/4100 scaling:
driver: intel_pstate governor: powersave volts: 0.7 V ext-clock: 100 MHz
cores: 1: 2789 2: 2789 3: 2789 4: 2789 bogomips: 20810
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
ibrs_enhanced ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx
monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq
pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand rdseed rdtscp
rep_good sdbg sep sgx smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: retbleed mitigation: Enhanced IBRS
conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW
loop
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Lenovo driver: i915
v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
active: HDMI-A-1,eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9b41
class-ID: 0300
Device-2: Bison Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:3 chip-ID: 5986:1135
Display: x11 server: X.org v: 1.21.1.16 compositor: xfwm4 v: 4.20.0
driver: X: loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-size: <missing: xdpyinfo>
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary,right model: HP V27i
serial: <filter> built: 2022 res: mode: 1920x1080 hz: 60 scale: 100% (1)
dpi: 82 gamma: 1.2 chroma: red: x: 0.639 y: 0.341 green: x: 0.294 y: 0.624
blue: x: 0.153 y: 0.051 white: x: 0.314 y: 0.329
size: 598x336mm (23.54x13.23") diag: 686mm (27") ratio: 16:9
modes: 1920x1080, 1680x1050, 1600x900, 1280x1024, 1440x900, 1280x800,
1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480, 720x400
Monitor-2: eDP-1 pos: left model: BOE Display 0x0812 built: 2018 res:
mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 142 gamma: 1.2 chroma: red:
x: 0.584 y: 0.361 green: x: 0.353 y: 0.569 blue: x: 0.161 y: 0.129 white:
x: 0.314 y: 0.329 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.0.3-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (CML GT2)
device-ID: 8086:9b41 memory: 9.41 GiB unified: yes
x11: xprop,xrandr
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Lenovo driver: snd_hda_intel
v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
chip-ID: 8086:02c8 class-ID: 0403
API: ALSA v: k6.12.21-4-MANJARO status: kernel-api with: aoss
Server-1: JACK v: 1.9.22 status: off with: nsmd status: off tools: N/A
Server-2: PipeWire v: 1.4.1 status: n/a (root, process) with:
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:4
Local Storage: total: 535.92 GiB used: 278.8 GiB (52.0%)
model: MZALQ512HALU-000L2 size: 476.94 GiB block-size: physical: 512 B
fw-rev: BL2QFXV7 temp: 31.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Alcor Micro model: 6387
size: 58.98 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 2.0 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter>
fw-rev: 8.07
ID-1: / raw-size: 39 GiB size: 38.09 GiB (97.67%) used: 30.99 GiB (81.3%)
fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
uuid: 1154cdb2-0f0f-4823-8930-ce41f7dbea12
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 7.5 MiB (2.9%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: N/A uuid: C1CD-2B04
ID-3: /home raw-size: 100.02 GiB size: 97.89 GiB (97.87%)
used: 36.49 GiB (37.3%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p7
maj-min: 259:7 label: N/A uuid: 0e88efb7-d900-4523-be95-3418e9e8feae
ID-4: /mnt/SNAS_homes raw-size: N/A size: 3.48 TiB
used: 598.83 GiB (16.8%) fs: cifs dev: /dev/homes
ID-5: /mnt/SNAS_music raw-size: N/A size: 3.48 TiB
used: 598.83 GiB (16.8%) fs: cifs dev: /dev/music
ID-6: /mnt/SNAS_photo raw-size: N/A size: 3.48 TiB
used: 598.83 GiB (16.8%) fs: cifs dev: /dev/photo
ID-7: /mnt/SNAS_video raw-size: N/A size: 3.48 TiB
used: 598.83 GiB (16.8%) fs: cifs dev: /dev/video
ID-8: /mnt/exchange raw-size: 250 GiB size: 250 GiB (100.00%)
used: 180.83 GiB (72.3%) fs: ntfs block-size: 4096 B dev: /dev/nvme0n1p4
maj-min: 259:4 label: exchange uuid: 1E16CD9116CD69FB
ID-9: /run/media/brice/CAF2-C4CD raw-size: 58.98 GiB
size: 58.98 GiB (100.00%) used: 30.49 GiB (51.7%) fs: exfat
block-size: 512 B dev: /dev/sda maj-min: 8:0 label: N/A uuid: CAF2-C4CD
ID-1: swap-1 type: partition size: 12 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
uuid: d9e8ee94-d7ec-46bd-aa7b-8a2c1540edff
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: N/A label: N/A
uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 74.67 GiB fs: ntfs
label: Windows-SSD uuid: 70E6BC68E6BC3068
ID-3: /dev/nvme0n1p8 maj-min: 259:8 size: 1000 MiB fs: ntfs
label: WINRE_DRV uuid: C0EEBD3EEEBD2D92
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-1:6 info: Alcor Micro Flash Drive type: mass storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 200mA chip-ID: 058f:6387 class-ID: 0806
serial: <filter>
Device-2: 1-4:5 info: Logitech LX710 Cordless Desktop Laser
type: keyboard,mouse driver: logitech-djreceiver,usbhid interfaces: 2
rev: 1.1 speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 98mA
chip-ID: 046d:c517 class-ID: 0301
Device-3: 1-7:3 info: Bison Integrated Camera type: video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 5986:1135 class-ID: 0e02 serial: <filter>
Device-4: 1-10:4 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.1
System Temperatures: cpu: 57.0 C pch: 50.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1365 libs: 372 tools: pamac pm: flatpak pkgs: 0
1: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
2: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
3: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
4: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
5: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
6: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
7: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
8: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
9: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
10: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
11: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
12: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
13: https://mirror.init7.net/manjaro/stable/$repo/$arch
14: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
15: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
16: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
17: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
18: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
19: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
20: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
21: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
22: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
23: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
24: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
25: http://mirror.fcix.net/manjaro/stable/$repo/$arch
26: https://muug.ca/mirror/manjaro/stable/$repo/$arch
27: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
28: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
29: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
30: http://manjaro.grena.ge/stable/$repo/$arch
31: https://mirror.zetup.net/manjaro/stable/$repo/$arch
32: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
33: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
34: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
35: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
36: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
37: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
38: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
39: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
40: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
41: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
42: https://mirror.easyname.at/manjaro/stable/$repo/$arch
43: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
44: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
45: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
46: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
47: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
48: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
49: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
50: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
51: https://mirrors2.manjaro.org/stable/$repo/$arch
52: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
53: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
54: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
55: https://mirror.koddos.net/manjaro/stable/$repo/$arch
56: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
57: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
58: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
59: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
60: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
61: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
62: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
63: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
64: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
65: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
66: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
67: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
68: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
69: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
70: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
71: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
72: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
73: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
74: https://mirrors.manjaro.org/repo/stable/$repo/$arch
75: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
76: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
77: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
78: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
79: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
80: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
81: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
82: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
83: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
84: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
85: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
86: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
87: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
88: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
89: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
90: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
91: https://distrohub.kyiv.ua/manjaro/stable/$repo/$arch
92: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
93: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
94: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
95: http://manjaro.mirror.ac.za/stable/$repo/$arch
96: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
97: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
98: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
99: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
100: https://mirror.komelt.dev/manjaro/stable/$repo/$arch
101: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
102: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
103: https://mirror.23m.com/manjaro/stable/$repo/$arch
104: https://manjaro.kurdy.org/stable/$repo/$arch
105: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
106: https://manjaro.ynh.ovh/stable/$repo/$arch
Processes:
CPU top: 5 of 271
1: cpu: 29.1% command: firefox pid: 1233 mem: 672.6 MiB (3.4%)
2: cpu: 17.8% command: firefox pid: 12846 mem: 274.3 MiB (1.3%)
3: cpu: 10.4% command: tumblerd pid: 10331 mem: 61.7 MiB (0.3%)
4: cpu: 5.7% command: firefox pid: 2367 mem: 158.4 MiB (0.8%)
5: cpu: 5.6% command: firefox pid: 8958 mem: 389.6 MiB (1.9%)
Memory top: 5 of 271
1: mem: 780.4 MiB (3.9%) command: firefox pid: 1655 cpu: 1.1%
2: mem: 672.6 MiB (3.4%) command: firefox pid: 1233 cpu: 29.1%
3: mem: 544.3 MiB (2.7%) command: firefox pid: 5160 cpu: 0.6%
4: mem: 389.6 MiB (1.9%) command: firefox pid: 8958 cpu: 5.6%
5: mem: 293.2 MiB (1.4%) command: firefox pid: 2317 cpu: 0.4%
Processes: 271 Power: uptime: 5h 57m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 7.7 GiB services: upowerd,xfce4-power-manager
Compilers: clang: 19.1.7 gcc: 14.2.1 alt: 13 Shell: Sudo (sudo)
v: 1.9.16p2 default: Bash v: 5.2.37 running-in: xfce4-terminal inxi: 3.3.38
[brice@TuxBox:~]$
j8a
25 April 2025 17:22
4
bricem13:
As far as I understand the model is bluethoot JBL Tune 770.
I suggest you to read the following arch wiki links.
‘[SOLVED] how to connect bluetooth headphones / Applications & Desktop Environments / Arch Linux Forums ’
‘How to Set up Bluetooth in Arch Linux ’
They are a bit old but understandable enough for me.
Hope it helps,
well strange but now I could connect after a bit of struggling.
thanks all for the support
