As of updating to the lts 6.12.11-1-MANJARO kernel my 8BitDo Pro 2 Wired controller is no longer being automaticity detected and mounted to the system. I now need to reconnect the controller manually each time.
I’m not experience this on the 6.6.74-1 kernel :/. On that kernel the controller is automatically detected and mounted.
inxi -Fazy ✔
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = "en_GB",
LC_ALL = (unset),
LC_CTYPE = (unset),
LC_NUMERIC = "sv_SE.UTF-8",
LC_COLLATE = (unset),
LC_TIME = "sv_SE.UTF-8",
LC_MESSAGES = (unset),
LC_MONETARY = "en_SE.UTF-8",
LC_ADDRESS = "sv_SE.UTF-8",
LC_IDENTIFICATION = "sv_SE.UTF-8",
LC_MEASUREMENT = "C",
LC_PAPER = "sv_SE.UTF-8",
LC_TELEPHONE = "sv_SE.UTF-8",
LC_NAME = "sv_SE.UTF-8",
LANG = "en_GB.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to a fallback locale ("en_GB.UTF-8").
Kernel: 6.12.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=650fe6ed-2034-479f-9ce2-081f608ce8fc rw quiet
cryptdevice=UUID=e92b8294-fad6-4d8f-bc1b-9b7b507b8a07:luks-e92b8294-fad6-4d8f-bc1b-9b7b507b8a07
root=/dev/mapper/luks-e92b8294-fad6-4d8f-bc1b-9b7b507b8a07 splash
udev.log_priority=3 amdgpu.ppfeaturemask=0xffffffff
Desktop: KDE Plasma v: 6.2.5 tk: Qt v: N/A info: frameworks v: 6.10.0
Mobo: ASUSTeK model: ROG STRIX B650E-F GAMING WIFI v: Rev 1.xx
UEFI: American Megatrends v: 1616 date: 05/16/2023
Info: model: AMD Ryzen 7 7700X bits: 64 type: MT MCP arch: Zen 4 gen: 4
level: v4 note: check built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25)
model-id: 0x61 (97) stepping: 2 microcode: 0xA601209
smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB
desc: 8x1024 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 4391 min/max: 400/5573 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 4391 2: 4391 3: 4391
4: 4391 5: 4391 6: 4391 7: 4391 8: 4391 9: 4391 10: 4391 11: 4391 12: 4391
13: 4391 14: 4391 15: 4391 16: 4391 bogomips: 144049
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
affected
Device-1: Advanced Micro Devices [AMD/ATI] Navi 21 [Radeon RX 6800/6800 XT /
6900 XT] driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: DP-3 empty: DP-1, DP-2, HDMI-A-1, Writeback-1
bus-ID: 03:00.0 chip-ID: 1002:73bf class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Raphael vendor: ASUSTeK
driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
empty: DP-4,HDMI-A-2,Writeback-2 bus-ID: 0e:00.0 chip-ID: 1002:164e
class-ID: 0300 temp: 35.0 C
Device-3: Lenovo Performance Camera driver: snd-usb-audio,uvcvideo
type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-2.2.1:13
chip-ID: 17ef:4839 class-ID: 0102 serial: <filter>
Display: wayland server: X.org v: 1.21.1.15 with: Xwayland v: 24.1.4
compositor: kwin_wayland driver: X: loaded: amdgpu
gpu: amdgpu display-ID: 0
Monitor-1: DP-3 model: Samsung LS49A950U serial: <filter> built: 2021 res:
mode: 5120x1440 hz: 60 scale: 100% (1) dpi: 82 gamma: 1.2
size: 1192x336mm (46.93x13.23") diag: 1238mm (48.8") modes: max: 5120x1440
min: 720x400
device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: radeonsi wayland: drv: radeonsi x11: drv: radeonsi
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6900 XT (radeonsi
navi21 LLVM 19.1.7 DRM 3.59 6.12.11-1-MANJARO) device-ID: 1002:73bf
memory: 15.62 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.303 layers: 4 device: 0 type: discrete-gpu name: AMD
Radeon RX 6900 XT (RADV NAVI21) driver: N/A device-ID: 1002:73bf
surfaces: xcb,xlib,wayland device: 1 type: integrated-gpu name: AMD Radeon
Graphics (RADV RAPHAEL_MENDOCINO) driver: N/A device-ID: 1002:164e
de: kscreen-console,kscreen-doctor gpu: corectrl wl: wayland-info
x11: xdpyinfo, xprop, xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio
bus-ID: 03:00.1 chip-ID: 1002:ab28 class-ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High
Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0e:00.1 chip-ID: 1002:1640
class-ID: 0403
Device-3: ASUSTek USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:6
chip-ID: 0b05:1a52 class-ID: 0300
Device-4: Lenovo Performance Camera driver: snd-usb-audio,uvcvideo
Device-5: Texas Instruments PCM2902 Audio Codec
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 5-2.2.3.4.4:19 chip-ID: 08bb:2902 class-ID: 0300
API: ALSA v: k6.12.11-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Server-3: PulseAudio v: 17.0-43-g3e2bb status: active with: pulseaudio-alsa
Device-1: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 09:00.0 chip-ID: 8086:15f3
class-ID: 0200
Device-2: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 0a:00.0 chip-ID: 14c3:0608
class-ID: 0280
IF: wlp10s0 state: up mac: <filter>
Device-1: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:9 chip-ID: 0e8d:0608
Local Storage: total: 5.46 TiB used: 732.68 GiB (13.1%)
model: WDS100T3X0C-00SJG0 size: 931.51 GiB block-size: physical: 512 B
fw-rev: 111130WD temp: 29.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM001-1CH164
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC27 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: HGST (Hitachi) model: HTS541010A9E680
tech: HDD rpm: 5400 serial: <filter> fw-rev: A560 scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD20EZRX-00DC0B0 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s lanes: 1 mode: 2.0
tech: N/A serial: <filter> fw-rev: 2021 scheme: MBR
ID-1: / raw-size: 931.21 GiB size: 915.52 GiB (98.32%)
used: 348.22 GiB (38.0%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-e92b8294-fad6-4d8f-bc1b-9b7b507b8a07
used: 448 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 52.4 C mobo: 34.0 C
Fan Speeds (rpm): N/A
GPU: device: amdgpu temp: 33.0 C mem: 36.0 C fan: 1100 watts: 33.00
device: amdgpu temp: 35.0 C
Memory: total: 32 GiB note: est. available: 30.5 GiB used: 8.86 GiB (29.1%)
Processes: 466 Power: uptime: 44m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.18 GiB services: org_kde_powerdevil,
tool: systemctl
Packages: 1584 pm: pacman pkgs: 1559 libs: 463 tools: pamac pm: appimage
pkgs: 0 pm: flatpak pkgs: 25 Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Zsh
v: 5.9 default: Bash v: 5.2.37 running-in: konsole inxi: 3.3.37
Mod edit: removed screenshot.
