Hi,
I’ve been using Manjaro for some time now on my Lenovo T14 AMD Gen1.
There is a USB-C Dock connected Gen2 from Lenovo with two external Display Port screens.
Yesterday I went to manjaro 22.0.0 and with it I upgraded to Kernel 6.1. Eversince the external screens won’t display anything, they say “No Signal”.
In the Gnome Settings though they are shown. Whatever I do, it won’t work.
When I boot Kernel 5.15.84 the displays go back to a working state.
This is what journalctl looks like, when I connect it with Kernel 6.1:
Dez 23 11:33:31 t14 kernel: usb 4-1: new high-speed USB device number 21 using xhci_hcd
Dez 23 11:33:31 t14 kernel: usb 4-1: New USB device found, idVendor=17ef, idProduct=a392, bcdDevice= d.24
Dez 23 11:33:31 t14 kernel: usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Dez 23 11:33:31 t14 kernel: usb 4-1: Product: USB2.0 Hub
Dez 23 11:33:31 t14 kernel: usb 4-1: Manufacturer: VIA Labs, Inc.
Dez 23 11:33:31 t14 kernel: hub 4-1:1.0: USB hub found
Dez 23 11:33:31 t14 kernel: hub 4-1:1.0: 4 ports detected
Dez 23 11:33:32 t14 kernel: usb 4-1.1: new high-speed USB device number 22 using xhci_hcd
Dez 23 11:33:32 t14 kernel: usb 4-1.1: New USB device found, idVendor=17ef, idProduct=a387, bcdDevice=31.03
Dez 23 11:33:32 t14 kernel: usb 4-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=6
Dez 23 11:33:32 t14 kernel: usb 4-1.1: Product: USB-C Dock Ethernet
Dez 23 11:33:32 t14 kernel: usb 4-1.1: Manufacturer: Realtek
Dez 23 11:33:32 t14 kernel: usb 4-1.1: SerialNumber: 301000001
Dez 23 11:33:32 t14 kernel: usb 4-1.3: new high-speed USB device number 23 using xhci_hcd
Dez 23 11:33:32 t14 kernel: usb 4-1.3: New USB device found, idVendor=17ef, idProduct=a394, bcdDevice= d.23
Dez 23 11:33:32 t14 kernel: usb 4-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Dez 23 11:33:32 t14 kernel: usb 4-1.3: Product: USB2.0 Hub
Dez 23 11:33:32 t14 kernel: usb 4-1.3: Manufacturer: VIA Labs, Inc.
Dez 23 11:33:32 t14 kernel: [drm] DP Alt mode state on HPD: 1
Dez 23 11:33:32 t14 kernel: hub 4-1.3:1.0: USB hub found
Dez 23 11:33:32 t14 kernel: hub 4-1.3:1.0: 4 ports detected
Dez 23 11:33:33 t14 kernel: [drm] DM_MST: starting TM on aconnector: 000000000d27f2d3 [id: 89]
Dez 23 11:33:33 t14 kernel: usb 4-1.1: reset high-speed USB device number 22 using xhci_hcd
Dez 23 11:33:33 t14 kernel: r8152 4-1.1:1.0 (unnamed net_device) (uninitialized): Invalid header when reading pass-thru MAC addr
Dez 23 11:33:33 t14 kernel: r8152 4-1.1:1.0: load rtl8153b-2 v1 10/23/19 successfully
Dez 23 11:33:33 t14 kernel: [drm] Downstream port present 1, type 0
Dez 23 11:33:33 t14 kernel: r8152 4-1.1:1.0 eth0: v1.12.13
Dez 23 11:33:33 t14 NetworkManager[1334]: <info> [1671791613.3396] manager: (eth0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/8)
Dez 23 11:33:33 t14 mtp-probe[4852]: checking bus 4, device 22: "/sys/devices/pci0000:00/0000:00:08.1/0000:07:00.3/usb4/4-1/4-1.1"
Dez 23 11:33:33 t14 mtp-probe[4852]: bus: 4, device: 22 was not an MTP device
Dez 23 11:33:33 t14 dbus-daemon[1281]: [system] Activating via systemd: service name='org.freedesktop.Avahi' unit='dbus-org.freedesktop.Avahi.service' requested by ':1.140' (uid=970 pid=4792
comm="/usr/lib/colord-sane")
Dez 23 11:33:33 t14 dbus-daemon[1281]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.Avahi.service': Unit dbus-org.freedesktop.Avahi.service not found.
Dez 23 11:33:33 t14 kernel: usb 4-1.3.3: new high-speed USB device number 24 using xhci_hcd
Dez 23 11:33:33 t14 kernel: usb 4-1.3.3: New USB device found, idVendor=17ef, idProduct=a395, bcdDevice=60.70
Dez 23 11:33:33 t14 kernel: usb 4-1.3.3: New USB device strings: Mfr=10, Product=11, SerialNumber=0
Dez 23 11:33:33 t14 kernel: usb 4-1.3.3: Product: USB2.0 Hub
Dez 23 11:33:33 t14 kernel: usb 4-1.3.3: Manufacturer: Lenovo
Dez 23 11:33:33 t14 kernel: [drm:dc_link_allocate_mst_payload [amdgpu]] *ERROR* Failure: pbn_per_slot==0 not allowed. Cannot continue, returning DC_UNSUPPORTED_VALUE.
Dez 23 11:33:33 t14 kernel: hub 4-1.3.3:1.0: USB hub found
Dez 23 11:33:33 t14 kernel: hub 4-1.3.3:1.0: 4 ports detected
Dez 23 11:33:34 t14 kernel: [drm:dc_link_allocate_mst_payload [amdgpu]] *ERROR* Failure: pbn_per_slot==0 not allowed. Cannot continue, returning DC_UNSUPPORTED_VALUE.
Dez 23 11:33:34 t14 mtp-probe[5108]: checking bus 4, device 22: "/sys/devices/pci0000:00/0000:00:08.1/0000:07:00.3/usb4/4-1/4-1.1"
Dez 23 11:33:34 t14 kernel: usb 4-1.3.3.1: new full-speed USB device number 25 using xhci_hcd
Dez 23 11:33:34 t14 systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Dez 23 11:33:34 t14 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dez 23 11:33:34 t14 kernel: audit: type=1131 audit(1671791614.342:206): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dez 23 11:33:34 t14 kernel: usb 4-1.3.3.1: New USB device found, idVendor=17ef, idProduct=a38f, bcdDevice= 0.00
Dez 23 11:33:34 t14 kernel: usb 4-1.3.3.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Dez 23 11:33:34 t14 kernel: usb 4-1.3.3.1: Product: 40AS
Dez 23 11:33:34 t14 kernel: usb 4-1.3.3.1: Manufacturer: Cypress Semiconductor
Dez 23 11:33:34 t14 kernel: usb 4-1.3.3.1: SerialNumber: 1S40ASZKW19JXT
Dez 23 11:33:34 t14 kernel: hid-generic 0003:17EF:A38F.000D: hiddev96,hidraw0: USB HID v1.11 Device [Cypress Semiconductor 40AS] on usb-0000:07:00.3-1.3.3.1/input1
Dez 23 11:33:34 t14 kernel: usb 4-1.3.4: new full-speed USB device number 26 using xhci_hcd
Dez 23 11:33:34 t14 kernel: usb 4-1.3.3.2: new full-speed USB device number 27 using xhci_hcd
Dez 23 11:33:34 t14 kernel: usb 4-1.3.3.2: New USB device found, idVendor=17ef, idProduct=30d1, bcdDevice= 0.42
Dez 23 11:33:34 t14 kernel: usb 4-1.3.3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Dez 23 11:33:34 t14 kernel: usb 4-1.3.3.2: Product: ThinkPad USB-C Dock Gen2 USB Audio
Dez 23 11:33:34 t14 kernel: usb 4-1.3.3.2: Manufacturer: Lenovo
Dez 23 11:33:34 t14 kernel: usb 4-1.3.3.2: SerialNumber: 000000000000
Dez 23 11:33:34 t14 kernel: usb 4-1.3.4: New USB device found, idVendor=0951, idProduct=16a4, bcdDevice= 0.30
Dez 23 11:33:34 t14 kernel: usb 4-1.3.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Dez 23 11:33:34 t14 kernel: usb 4-1.3.4: Product: HyperX Virtual Surround Sound
Dez 23 11:33:34 t14 kernel: usb 4-1.3.4: Manufacturer: Kingston
Dez 23 11:33:34 t14 kernel: usb 4-1.3.4: SerialNumber: 00000000
Dez 23 11:33:35 t14 kernel: hid-generic 0003:17EF:30D1.000E: hiddev97,hidraw1: USB HID v1.11 Device [Lenovo ThinkPad USB-C Dock Gen2 USB Audio] on usb-0000:07:00.3-1.3.3.2/input3
Dez 23 11:33:35 t14 kernel: usb 4-1.3.3.3: new low-speed USB device number 28 using xhci_hcd
Dez 23 11:33:35 t14 kernel: usb 4-1.3.3.3: New USB device found, idVendor=046a, idProduct=c098, bcdDevice= 3.03
Dez 23 11:33:35 t14 kernel: usb 4-1.3.3.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Dez 23 11:33:35 t14 kernel: usb 4-1.3.3.3: Product: CHERRY Corded Device
Dez 23 11:33:35 t14 kernel: usb 4-1.3.3.3: Manufacturer: Cherry GmbH
Dez 23 11:33:35 t14 kernel: input: Kingston HyperX Virtual Surround Sound Consumer Control as /devices/pci0000:00/0000:00:08.1/0000:07:00.3/usb4/4-1/4-1.3/4-1.3.4/4-1.3.4:1.3/0003:0951:16A4.000F/input/input31
Dez 23 11:33:35 t14 kernel: input: Cherry GmbH CHERRY Corded Device as /devices/pci0000:00/0000:00:08.1/0000:07:00.3/usb4/4-1/4-1.3/4-1.3.3/4-1.3.3.3/4-1.3.3.3:1.0/0003:046A:C098.0010/input/input33
Dez 23 11:33:35 t14 kernel: input: Kingston HyperX Virtual Surround Sound as /devices/pci0000:00/0000:00:08.1/0000:07:00.3/usb4/4-1/4-1.3/4-1.3.4/4-1.3.4:1.3/0003:0951:16A4.000F/input/input32
Dez 23 11:33:35 t14 kernel: hid-generic 0003:046A:C098.0010: input,hidraw2: USB HID v1.11 Keyboard [Cherry GmbH CHERRY Corded Device] on usb-0000:07:00.3-1.3.3.3/input0
Dez 23 11:33:35 t14 kernel: hid-generic 0003:0951:16A4.000F: input,hiddev98,hidraw3: USB HID v1.11 Device [Kingston HyperX Virtual Surround Sound] on usb-0000:07:00.3-1.3.4/input3
Dez 23 11:33:35 t14 mtp-probe[5121]: checking bus 4, device 26: "/sys/devices/pci0000:00/0000:00:08.1/0000:07:00.3/usb4/4-1/4-1.3/4-1.3.4"
Dez 23 11:33:35 t14 mtp-probe[5121]: bus: 4, device: 26 was not an MTP device
Dez 23 11:33:35 t14 kernel: input: Cherry GmbH CHERRY Corded Device as /devices/pci0000:00/0000:00:08.1/0000:07:00.3/usb4/4-1/4-1.3/4-1.3.3/4-1.3.3.3/4-1.3.3.3:1.1/0003:046A:C098.0011/input/input34
Dez 23 11:33:35 t14 kernel: hid-generic 0003:046A:C098.0011: input,hidraw4: USB HID v1.11 Device [Cherry GmbH CHERRY Corded Device] on usb-0000:07:00.3-1.3.3.3/input1
Dez 23 11:33:35 t14 kernel: usb 4-1.3.3.4: new full-speed USB device number 29 using xhci_hcd
Dez 23 11:33:35 t14 kernel: usb 4-1.3.3.4: New USB device found, idVendor=046a, idProduct=c094, bcdDevice= 1.03
Dez 23 11:33:35 t14 kernel: usb 4-1.3.3.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Dez 23 11:33:35 t14 kernel: usb 4-1.3.3.4: Product: CHERRY Mouse
Dez 23 11:33:35 t14 kernel: usb 4-1.3.3.4: Manufacturer: Cherry GmbH
Dez 23 11:33:35 t14 kernel: input: Cherry GmbH CHERRY Mouse as /devices/pci0000:00/0000:00:08.1/0000:07:00.3/usb4/4-1/4-1.3/4-1.3.3/4-1.3.3.4/4-1.3.3.4:1.0/0003:046A:C094.0012/input/input35
Dez 23 11:33:35 t14 kernel: hid-generic 0003:046A:C094.0012: input,hidraw5: USB HID v1.11 Mouse [Cherry GmbH CHERRY Mouse] on usb-0000:07:00.3-1.3.3.4/input0
Dez 23 11:33:35 t14 mtp-probe[5150]: checking bus 4, device 25: "/sys/devices/pci0000:00/0000:00:08.1/0000:07:00.3/usb4/4-1/4-1.3/4-1.3.3/4-1.3.3.1"
Dez 23 11:33:35 t14 mtp-probe[5151]: checking bus 4, device 27: "/sys/devices/pci0000:00/0000:00:08.1/0000:07:00.3/usb4/4-1/4-1.3/4-1.3.3/4-1.3.3.2"
Dez 23 11:33:35 t14 mtp-probe[5150]: bus: 4, device: 25 was not an MTP device
Dez 23 11:33:35 t14 mtp-probe[5151]: bus: 4, device: 27 was not an MTP device
Dez 23 11:33:35 t14 mtp-probe[5153]: checking bus 4, device 29: "/sys/devices/pci0000:00/0000:00:08.1/0000:07:00.3/usb4/4-1/4-1.3/4-1.3.3/4-1.3.3.4"
Dez 23 11:33:35 t14 mtp-probe[5152]: checking bus 4, device 28: "/sys/devices/pci0000:00/0000:00:08.1/0000:07:00.3/usb4/4-1/4-1.3/4-1.3.3/4-1.3.3.3"
Dez 23 11:33:35 t14 mtp-probe[5153]: bus: 4, device: 29 was not an MTP device
Dez 23 11:33:35 t14 mtp-probe[5152]: bus: 4, device: 28 was not an MTP device
Dez 23 11:33:36 t14 mtp-probe[5108]: bus: 4, device: 22 was not an MTP device
Dez 23 11:33:36 t14 mtp-probe[5280]: checking bus 4, device 26: "/sys/devices/pci0000:00/0000:00:08.1/0000:07:00.3/usb4/4-1/4-1.3/4-1.3.4"
Dez 23 11:33:36 t14 mtp-probe[5280]: bus: 4, device: 26 was not an MTP device
Dez 23 11:33:36 t14 kernel: r8152 4-1.1:1.0 enp7s0f3u1u1: renamed from eth0
Dez 23 11:33:36 t14 NetworkManager[1334]: <info> [1671791616.2337] device (eth0): interface index 7 renamed iface from 'eth0' to 'enp7s0f3u1u1'
Dez 23 11:33:36 t14 dbus-daemon[1281]: [system] Activating via systemd: service name='org.freedesktop.Avahi' unit='dbus-org.freedesktop.Avahi.service' requested by ':1.143' (uid=970 pid=5107 comm="/usr/lib/colord-sane")
Dez 23 11:33:36 t14 dbus-daemon[1281]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.Avahi.service': Unit dbus-org.freedesktop.Avahi.service not found.
Dez 23 11:33:36 t14 NetworkManager[1334]: <info> [1671791616.2419] device (enp7s0f3u1u1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Dez 23 11:33:36 t14 NetworkManager[1334]: <info> [1671791616.2666] settings: (enp7s0f3u1u1): created default wired connection 'Kabelgebundene Verbindung 3'
Dez 23 11:33:36 t14 NetworkManager[1334]: <info> [1671791616.3070] device (enp7s0f3u1u1): carrier: link connected
Dez 23 11:33:36 t14 kernel: IPv6: ADDRCONF(NETDEV_CHANGE): enp7s0f3u1u1: link becomes ready
Dez 23 11:33:36 t14 kernel: r8152 4-1.1:1.0 enp7s0f3u1u1: carrier on
Dez 23 11:33:36 t14 NetworkManager[1334]: <info> [1671791616.3101] device (enp7s0f3u1u1): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
Dez 23 11:33:36 t14 NetworkManager[1334]: <info> [1671791616.3106] policy: auto-activating connection 'Kabelgebundene Verbindung 3' (623cd6b4-e845-3e1e-a231-05224e00569e)
Dez 23 11:33:36 t14 NetworkManager[1334]: <info> [1671791616.3109] device (enp7s0f3u1u1): Activation: starting connection 'Kabelgebundene Verbindung 3' (623cd6b4-e845-3e1e-a231-05224e00569e)
Dez 23 11:33:36 t14 NetworkManager[1334]: <info> [1671791616.3110] device (enp7s0f3u1u1): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Dez 23 11:33:36 t14 NetworkManager[1334]: <info> [1671791616.3111] manager: NetworkManager state is now CONNECTING
Dez 23 11:33:36 t14 NetworkManager[1334]: <info> [1671791616.3112] device (enp7s0f3u1u1): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Dez 23 11:33:36 t14 NetworkManager[1334]: <info> [1671791616.3115] device (enp7s0f3u1u1): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Dez 23 11:33:36 t14 NetworkManager[1334]: <info> [1671791616.3118] dhcp4 (enp7s0f3u1u1): activation: beginning transaction (timeout in 45 seconds)
Dez 23 11:33:36 t14 mtp-probe[5336]: checking bus 4, device 27: "/sys/devices/pci0000:00/0000:00:08.1/0000:07:00.3/usb4/4-1/4-1.3/4-1.3.3/4-1.3.3.2"
Dez 23 11:33:36 t14 mtp-probe[5336]: bus: 4, device: 27 was not an MTP device
Dez 23 11:33:36 t14 mtp-probe[5337]: checking bus 4, device 25: "/sys/devices/pci0000:00/0000:00:08.1/0000:07:00.3/usb4/4-1/4-1.3/4-1.3.3/4-1.3.3.1"
Dez 23 11:33:36 t14 mtp-probe[5337]: bus: 4, device: 25 was not an MTP device
Dez 23 11:33:36 t14 dbus-daemon[1281]: [system] Activating via systemd: service name='org.freedesktop.Avahi' unit='dbus-org.freedesktop.Avahi.service' requested by ':1.146' (uid=970 pid=5314 comm="/usr/lib/colord-sane")
Dez 23 11:33:36 t14 systemd-logind[1291]: Watching system buttons on /dev/input/event6 (Cherry GmbH CHERRY Corded Device)
Dez 23 11:33:36 t14 mtp-probe[5344]: checking bus 4, device 28: "/sys/devices/pci0000:00/0000:00:08.1/0000:07:00.3/usb4/4-1/4-1.3/4-1.3.3/4-1.3.3.3"
Dez 23 11:33:36 t14 mtp-probe[5344]: bus: 4, device: 28 was not an MTP device
Dez 23 11:33:36 t14 mtp-probe[5348]: checking bus 4, device 29: "/sys/devices/pci0000:00/0000:00:08.1/0000:07:00.3/usb4/4-1/4-1.3/4-1.3.3/4-1.3.3.4"
Dez 23 11:33:36 t14 mtp-probe[5348]: bus: 4, device: 29 was not an MTP device
Dez 23 11:33:37 t14 gsd-media-keys[2771]: gvc_mixer_card_get_index: assertion 'GVC_IS_MIXER_CARD (card)' failed
Dez 23 11:33:38 t14 NetworkManager[1334]: <info> [1671791618.2478] policy: set 'Kabelgebundene Verbindung 3' (enp7s0f3u1u1) as default for IPv6 routing and DNS
Dez 23 11:33:38 t14 NetworkManager[1334]: <info> [1671791618.3129] dhcp4 (enp7s0f3u1u1): state changed new lease, address=192.168.20.147
Dez 23 11:33:38 t14 NetworkManager[1334]: <info> [1671791618.3133] policy: set 'Kabelgebundene Verbindung 3' (enp7s0f3u1u1) as default for IPv4 routing and DNS
Dez 23 11:33:38 t14 dbus-daemon[1281]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=1334 comm="/usr/bin/NetworkManager --no-daemon")
Dez 23 11:33:38 t14 NetworkManager[1334]: <info> [1671791618.3192] device (enp7s0f3u1u1): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Dez 23 11:33:38 t14 systemd[1]: Starting Network Manager Script Dispatcher Service...
Dez 23 11:33:38 t14 dbus-daemon[1281]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Dez 23 11:33:38 t14 systemd[1]: Started Network Manager Script Dispatcher Service.
Dez 23 11:33:38 t14 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dez 23 11:33:38 t14 NetworkManager[1334]: <info> [1671791618.3645] device (enp7s0f3u1u1): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Dez 23 11:33:38 t14 NetworkManager[1334]: <info> [1671791618.3648] device (enp7s0f3u1u1): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Dez 23 11:33:38 t14 NetworkManager[1334]: <info> [1671791618.3652] manager: NetworkManager state is now CONNECTED_SITE
Dez 23 11:33:38 t14 NetworkManager[1334]: <info> [1671791618.3656] device (enp7s0f3u1u1): Activation: successful, device activated.
Dez 23 11:33:38 t14 kernel: audit: type=1130 audit(1671791618.362:207): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dez 23 11:33:38 t14 NetworkManager[1334]: <info> [1671791618.3895] manager: NetworkManager state is now CONNECTED_GLOBAL
Dez 23 11:33:38 t14 ModemManager[1382]: <info> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:08.1/0000:07:00.3/usb4/4-1/4-1.1': not supported by any plugin
Dez 23 11:33:41 t14 gnome-shell[2436]: meta_display_get_monitor_in_fullscreen: assertion 'monitor >= 0 && monitor < n_logical_monitors' failed
Dez 23 11:33:41 t14 gnome-shell[2436]: meta_monitor_manager_get_logical_monitor_from_number: assertion '(unsigned int) number < g_list_length (manager->logical_monitors)' failed
Dez 23 11:33:41 t14 gnome-shell[2436]: meta_workspace_get_work_area_for_monitor: assertion 'logical_monitor != NULL' failed
Dez 23 11:33:48 t14 systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Dez 23 11:33:48 t14 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dez 23 11:33:48 t14 kernel: audit: type=1131 audit(1671791628.408:208): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dez 23 11:33:49 t14 gnome-shell[2436]: meta_display_get_monitor_in_fullscreen: assertion 'monitor >= 0 && monitor < n_logical_monitors' failed
Dez 23 11:33:49 t14 gnome-shell[2436]: meta_monitor_manager_get_logical_monitor_from_number: assertion '(unsigned int) number < g_list_length (manager->logical_monitors)' failed
Dez 23 11:33:49 t14 gnome-shell[2436]: meta_workspace_get_work_area_for_monitor: assertion 'logical_monitor != NULL' failed
Those seem relevant:
and
