I used to run paccache to trim older versions of installed packages. But then after the most recent updates, I found out that paccache is no longer installed, and I had to install pacman-contrib to make it available again in my system. Did the update remove pacman-contrib? If so, should I have not reinstalled it?
Please read the update announcements … or any related thread.
pacman-contrib
was split from pacman
