Just wondering if there is a schedule or calendar for Manjaro ISO coming with Kernel 5.16 or higher?
My hardware requires 5.16, so it’s just useful to know for a fresh re-install.
But also generally it would be good to know if future version news exists.
On the same machine or a new one?
Fresh install is only necessary when the system is totally broken and unrecoverable, and because there is a new ISO doesn’t mean you have to fresh install from it.
I have seen no plans to default to Kernel 5.16 for new ISO, and the newer one is Kernel 5.17-rc7 (on unstable branch) so it will take some time to become stable and then considered to be default.
Thanks. Yes, I have 2 partitions & 2nd is manjaro, I was thinking of repartitioning for manjaro only as I use it exclusively. My personal files are on another internal drive.
Maybe I could merge, but safer to assume a fresh-install may be necessary.
Normally I would just upgrade.
Also, Id like to keep a USB drive handy with an ISO, just in case of disaster!
