I have a small problem with kernel 5.14.10:
The connection to the WLAN router fails.
inxi -Fza:
parameters: BOOT_IMAGE=/vmlinuz-5.13-x86_64 root=UUID=21baa059-b0a2-4d63-9220-6a1f533a11a2 rw quiet
apparmor=1 security=apparmor resume=UUID=e4be566c-9f09-4f73-b427-9c88a7dd29ba udev.log_priority=3
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux
base: Arch Linux
Machine: Type: Laptop System: HP product: HP Laptop 15s-eq2xxx v: N/A serial: <filter> Chassis: type: 10
serial: <filter>
Mobo: HP model: 887A v: 59.11 serial: <filter> UEFI: AMI v: F.16 date: 09/24/2021
Battery: ID-1: BAT0 charge: 41.7 Wh (99.8%) condition: 41.8/41.8 Wh (100.0%) volts: 12.9 min: 11.3
model: HP Primary type: Li-ion serial: <filter> status: Unknown
CPU: Info: 6-Core model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 68 (104) stepping: 1 microcode: 8608103 cache: L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 50328
Speed: 1397 MHz min/max: 1400/2100 MHz boost: enabled Core speeds (MHz): 1: 1397 2: 1397 3: 1397 4: 1397
5: 1569 6: 1397 7: 1397 8: 1493 9: 1397 10: 1397 11: 1397 12: 1397
Type: spectre_v2
mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Lucienne vendor: Hewlett-Packard driver: amdgpu v: kernel
bus-ID: 03:00.0 chip-ID: 1002:164c class-ID: 0300
Device-2: Luxvisions Innotech Limited HP TrueVision HD Camera type: USB driver: uvcvideo bus-ID: 1-3:3
chip-ID: 30c9:0035 class-ID: fe01 serial: <filter>
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: amdgpu,ati unloaded: modesetting
alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 142 size: 344x194mm (13.5x7.6") diag: 395mm (15.5")
OpenGL: renderer: AMD RENOIR (DRM 3.41.0 5.13.19-2-MANJARO LLVM 12.0.1) v: 4.6 Mesa 21.2.3
direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD/ATI] vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus-ID: 03:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: Hewlett-Packard driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x bus-ID: 03:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Hewlett-Packard driver: snd_hda_intel
v: kernel bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Network: Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter vendor: Hewlett-Packard
driver: rtw_8821ce v: N/A modules: rtw88_8821ce port: f000 bus-ID: 01:00.0 chip-ID: 10ec:c821
class-ID: 0280
Bluetooth: Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8 bus-ID: 1-4:4 chip-ID: 0bda:b00e
Drives: Local Storage: total: 953.87 GiB used: 49.54 GiB (5.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: KBG40ZNV1T02 KIOXIA size: 953.87 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: HP00AE00
temp: 44.9 C scheme: GPT
Partition: ID-1: / raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 8.21 GiB (8.4%) fs: ext4 dev: /dev/nvme0n1p7
maj-min: 259:7
ID-2: /boot raw-size: 1024 MiB size: 973.4 MiB (95.06%) used: 113 MiB (11.6%) fs: ext4 dev: /dev/nvme0n1p5
maj-min: 259:5
ID-3: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 292 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p10 maj-min: 259:10
ID-4: /home raw-size: 200 GiB size: 195.8 GiB (97.90%) used: 40.85 GiB (20.9%) fs: ext4
dev: /dev/nvme0n1p8 maj-min: 259:8
ID-5: /var raw-size: 159.64 GiB size: 156.08 GiB (97.77%) used: 375 MiB (0.2%) fs: ext4
dev: /dev/nvme0n1p9 maj-min: 259:9
Swap: Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p6
maj-min: 259:6
Sensors: System Temperatures: cpu: 50.4 C mobo: 49.0 C gpu: amdgpu temp: 36.0 C
Info: Processes: 302 Uptime: 3m wakeups: 997 Memory: 14.98 GiB used: 2.13 GiB (14.2%) Init: systemd v: 249
tool: systemctl Compilers: gcc: N/A Packages: pacman: 1210 lib: 331 flatpak: 0 Shell: Zsh v: 5.8
default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.08```
. You installed through the system settings , right ??
