inxi -Fazy
Kernel: 5.8.11-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=497e30de-6a77-498b-b55c-0b44309797aa rw quiet udev.log_priority=3
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Desktop Mobo: Gigabyte model: AX370-Gaming K3 serial: <filter>
UEFI: American Megatrends v: F50a date: 11/27/2019
Topology: 6-Core model: AMD Ryzen 5 2600X bits: 64 type: MT MCP arch: Zen+
family: 17 (23) model-id: 8 stepping: 2 microcode: 800820D
L2 cache: 3072 KiB
bogomips: 86424
Speed: 2718 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
1: 2741 2: 3116 3: 2192 4: 2199 5: 2134 6: 2194 7: 2192 8: 2200 9: 2852
10: 3581 11: 2126 12: 2198
disabled, RSB filling
Device-1: AMD Vega 10 XL/XT [Radeon RX Vega 56/64] vendor: ASRock
driver: amdgpu v: kernel bus ID: 0a:00.0 chip ID: 1002:687f
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: amdgpu
FAILED: ati unloaded: modesetting alternate: fbdev,vesa display ID: :0
screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.0x11.2")
s-diag: 1055mm (41.5")
Monitor-1: DisplayPort-0 res: 1920x1080 dpi: 94 size: 521x293mm (20.5x11.5")
diag: 598mm (23.5")
Monitor-2: DisplayPort-1 res: 1920x1080 hz: 60 dpi: 103
size: 475x267mm (18.7x10.5") diag: 545mm (21.5")
OpenGL:
renderer: Radeon RX Vega (VEGA10 DRM 3.38.0 5.8.11-1-MANJARO LLVM 10.0.1)
v: 4.6 Mesa 20.1.8 direct render: Yes
Device-1: AMD Vega 10 HDMI Audio [Radeon Vega 56/64] driver: snd_hda_intel
v: kernel bus ID: 0a:00.1 chip ID: 1002:aaf8
Device-2: AMD Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus ID: 0c:00.3 chip ID: 1022:1457
Device-3: SteelSeries ApS type: USB driver: hid-generic,snd-usb-audio,usbhid
bus ID: 1-7.1.3:5 chip ID: 1038:1220
Sound Server: ALSA v: k5.8.11-1-MANJARO
Device-1: Qualcomm Atheros Killer E2500 Gigabit Ethernet vendor: Gigabyte
driver: alx v: kernel port: f000 bus ID: 05:00.0 chip ID: 1969:e0b1
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 1.13 TiB used: 545.93 GiB (47.3%)
ID-1: /dev/nvme0n1 vendor: Crucial model: CT500P1SSD8 size: 465.76 GiB
block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
serial: <filter> rev: P3CR013 scheme: GPT
ID-2: /dev/sda vendor: Transcend model: TS240GSSD220S size: 223.57 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
rev: 0A0 scheme: GPT
ID-3: /dev/sdb type: USB vendor: JMicron Tech model: Generic
size: 465.76 GiB block size: physical: 4096 B logical: 512 B
serial: <filter> rev: 0114 scheme: MBR
Use of uninitialized value $row{"type"} in string eq at /usr/bin/inxi line 13714.
Can't use an undefined value as an ARRAY reference at /usr/bin/inxi line 13741.
parted -l
Modell: JMicron Generic (scsi)
Festplatte /dev/sdb: 500GB
Sektorgröße (logisch/physisch): 512B/4096B
Partitionstabelle: msdos
Disk-Flags:
Nummer Anfang Ende Größe Typ Dateisystem Flags
1 32,3kB 500GB 500GB primary ntfs
fdisk -l
Festplatte /dev/sdb: 465,76 GiB, 500107862016 Bytes, 976773168 Sektoren
Festplattenmodell: Generic
Einheiten: Sektoren von 1 * 512 = 512 Bytes
Sektorgröße (logisch/physikalisch): 512 Bytes / 4096 Bytes
E/A-Größe (minimal/optimal): 4096 Bytes / 4096 Bytes
Festplattenbezeichnungstyp: dos
Festplattenbezeichner: 0x90909090
Gerät Boot Anfang Ende Sektoren Größe Kn Typ
/dev/sdb1 63 976768064 976768002 465,8G 7 HPFS/NTFS/exFAT
Partition 1 beginnt nicht an einer physikalischen Sektorgrenze.
efibootmgr -v
BootCurrent: 0001
Timeout: 1 seconds
BootOrder: 0001,0000,0009,0003,0008
Boot0000* Windows Boot Manager HD(2,GPT,a255fdc8-c084-44cf-a68e-b6c7f6aacd46,0x109000,0x32000)/File(\EFI\MICROSOFT\BOOT\BOOT
MGFW.EFI)WINDOWS.........x...B.C.D.O.B.J.E.C.T.=.{.9.d.e.a.8.6.2.c.-.5.c.d.d.-.4.e.7.0.-.a.c.c.1.-.f.3.2.b.3.4.4.d.4.7.9.5.}.
Boot0001* Manjaro HD(3,GPT,3f84d09a-0d9c-cc49-871f-a98c1fddbe4b,0x12500000,0x100000)/File(\EFI\MANJARO\GRUBX64.EFI)
Boot0003* CT500P1SSD8 BBS(HD,,0x0)..BO
Boot0008* TS240GSSD220S BBS(HD,,0x0)..BO
Boot0009* UEFI OS HD(3,GPT,3f84d09a-0d9c-cc49-871f-a98c1fddbe4b,0x12500000,0x100000)/File(\EFI\BOOT\BOOTX64.EFI)..BO
test -d /sys/firmware/efi && echo UEFI || echo BIOS
UEFI
sudo mdadm --examine /dev/sdb
Magic : a92b4efc
Version : 1.0
Feature Map : 0x1
Array UUID : aeb31056:cf827010:678701ca:3a1fe1ae
Creation Time : Mon Sep 5 19:11:09 2016
Raid Level : raid1
Raid Devices : 2
Avail Dev Size : 976767976 (465.76 GiB 500.11 GB)
Array Size : 530112 (517.69 MiB 542.83 MB)
Used Dev Size : 1060224 (517.69 MiB 542.83 MB)
Super Offset : 976767984 sectors
Unused Space : before=0 sectors, after=975707760 sectors
State : clean
Device UUID : ade56454:86d91422:2db09652:291f6b69
Internal Bitmap : 2 sectors from superblock
Update Time : Wed Oct 12 13:48:39 2016
Checksum : de984bf2 - correct
Events : 170
Device Role : Active device 0
Array State : AA ('A' == active, '.' == missing, 'R' == replacing)
RAID-Array wieder aufbauen hab ich auch über Recherche gesehen. Aber das müsste ich ja dann jedes Mal machen, wenn ich die Platte anschließe bzw. wenn ich sie an meinem Laptop (unter Linux) anschließe. Das ist ziemlich unpraktikabel.
Kann ich das nicht irgendwie anders labeln, dass es als normales NTFS auch erkannt wird wie unter Windows?
Hatte die Platte zuvor auch mit Bitlocker verschlüsselt, dies jedoch wieder rückgängig gemacht. Ggf. hat es damit auch zu tun.
Ich würde ja notfalls alles runter ziehen und noch mal neu formatieren, aber ich hab den Speicherplatz dafür nicht.
PS: ntfs-3g war bereits installiert.
OT-Frage:
Funktioniert die Firefox-Benachrichtigung hier fürs Forum nicht, wenn ich die Seite nicht offen habe?
