Alles, was nicht unbedingt benötigt wird, ist Müll.
Mich interessiert, wie hoch nachfolgend der unnötige Anteil ist!
inxi -zv8
Kernel: 6.12.39-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=fc944924-ae6d-43b3-8eb6-ad6996e9325f rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A info: frameworks v: 6.16.0
Type: Laptop System: Sony product: VPCF23A9E v: C609NWSE
Mobo: Sony model: VAIO serial: <superuser required>
uuid: <superuser required> BIOS: American Megatrends v: R2150V3
date: 07/22/2011
ID-1: BAT0 charge: 35.4 Wh (100.0%) condition: 35.4/57.2 Wh (61.9%)
volts: N/A min: 122.6 model: Sony Corp. type: Li-ion serial: N/A
status: full
Device-1: hidpp_battery_0 model: Logitech K370s/K375s Multi-Device
Wireless Keyboard serial: <filter> charge: 50% (should be ignored)
rechargeable: yes status: discharging
System RAM: total: 6 GiB available: 5.77 GiB used: 1.62 GiB (28.0%)
Array-1: capacity: N/A slots: 2 modules: 2 EC: None max-module-size: N/A
Device-1: SODIMM1 type: DDR3 detail: N/A size: 4 GiB speed: N/A volts: N/A
width (bits): data: 64 total: 64 manufacturer: N/A part-no: N/A serial: N/A
Device-2: SODIMM2 type: DDR3 detail: N/A size: 2 GiB speed: N/A volts: N/A
Info: model: Intel Core i7-2670QM bits: 64 type: MT MCP arch: Sandy Bridge
gen: core 2 level: v2 built: 2010-12 process: Intel 32nm family: 6
model-id: 0x2A (42) stepping: 7 microcode: 0x2F
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
desc: 4x256 KiB L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 3100 min/max: 800/3100 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 3100 2: 3100 3: 3100 4: 3100 5: 3100 6: 3100
7: 3100 8: 3100 bogomips: 35135
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept est
flexpriority flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce
md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdtscp rep_good
sep ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
vulnerable
STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
affected
Device-1: NVIDIA GF108M [GeForce GT 540M] vendor: Sony driver: nouveau
v: kernel non-free: series: 390.xx+ status: legacy (EOL~2022-11-22) last:
release: 390.157 kernel: 6.0 xorg: 1.21 arch: Fermi code: GF1xx
process: 40/28nm built: 2010-2016 pcie: gen: 2 speed: 5 GT/s lanes: 16
ports: active: HDMI-A-1 off: LVDS-1 empty: VGA-1 bus-ID: 01:00.0
chip-ID: 10de:0df4 class-ID: 0300 temp: 45.0 C
Device-2: Ricoh USB2.0 Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 4-1.2:3 chip-ID: 05ca:18c0
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.18 with: Xwayland v: 24.1.8
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: nouveau gpu: nouveau display-ID: :0 screens: 1
Screen-1: 0 s-res: 1400x1050 s-dpi: 96 s-size: 369x277mm (14.53x10.91")
s-diag: 461mm (18.17") monitors: <missing: xrandr>
Monitor-1: HDMI-A-1 model: LG (GoldStar) Ultra HD serial: <filter>
built: 2018 res: 3840x2160 dpi: 163 gamma: 1.2 chroma: red: x: 0.655
y: 0.333 green: x: 0.306 y: 0.639 blue: x: 0.149 y: 0.059 white: x: 0.314
y: 0.329 size: 600x340mm (23.62x13.39") diag: 690mm (27.2") ratio: 16:9
modes: 1920x1080, 1920x1080i, 1600x900, 1280x1024, 1280x800, 1152x864,
1280x720, 1024x768, 800x600, 720x480, 640x480
EDID-Warnings: 1: parse_edid: unhandled CEA mode 97 2: parse_edid:
unhandled CEA mode 96 3: parse_edid: unhandled CEA mode 93 4: parse_edid:
unhandled CEA mode 94 5: parse_edid: unhandled CEA mode 95
Monitor-2: LVDS-1 model: Chi Mei Opto 0x1600 built: 2011 res: 1920x1080
dpi: 130 gamma: 1.2 chroma: red: x: 0.565 y: 0.349 green: x: 0.341 y: 0.584
blue: x: 0.161 y: 0.122 white: x: 0.314 y: 0.329
size: 374x192mm (14.72x7.56") diag: 420mm (16.6") modes: 1920x1080,
1680x1050, 1400x1050, 1280x1024, 1280x960, 1152x864, 1024x768, 800x600,
640x480, 720x400, 640x400, 640x350
API: EGL v: 1.5 hw: drv: nvidia nouveau platforms: device: 0 drv: nouveau
device: 1 drv: swrast gbm: drv: nouveau surfaceless: drv: nouveau x11:
drv: nouveau inactive: wayland
API: OpenGL v: 4.5 compat-v: 4.3 vendor: mesa v: 25.1.6-arch1.1 glx-v: 1.4
direct-render: yes renderer: NVC1 device-ID: 10de:0df4 memory: 1.95 GiB
unified: no
vendor: Sony driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1c20 class-ID: 0403
Device-2: NVIDIA GF108 High Definition Audio vendor: Sony
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:0bea class-ID: 0403
API: ALSA v: k6.12.39-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.6 status: active with: 1: pipewire-pulse
Device-1: Qualcomm Atheros AR9485 Wireless Network Adapter
vendor: Foxconn Unex DHXA-225 driver: ath9k v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:0032 class-ID: 0280
IF: wlp2s0 state: down mac: <filter>
vendor: Sony driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 9000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 232.89 GiB used: 13.26 GiB (5.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 2B6Q scheme: MBR
Optical-1: /dev/sr0 vendor: ■■■■■■■■ model: DVD-RAM UJ8B0 rev: 1.00
dev-links: cdrom
ID-1: / raw-size: 232.88 GiB size: 232.88 GiB (100.00%)
used: 13.26 GiB (5.7%) fs: btrfs dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: fc944924-ae6d-43b3-8eb6-ad6996e9325f
ID-2: /home raw-size: 232.88 GiB size: 232.88 GiB (100.00%)
ID-3: /var/cache raw-size: 232.88 GiB size: 232.88 GiB (100.00%)
ID-4: /var/log raw-size: 232.88 GiB size: 232.88 GiB (100.00%)
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-2: 1-1:2 info: Terminus Hub ports: 4 rev: 2.0
chip-ID: 1a40:0101 class-ID: 0900
Device-1: 1-1.4:3 info: Logitech Nano Receiver type: keyboard,mouse
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
chip-ID: 046d:c534 class-ID: 0301
Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:0024
Device-1: 2-1.2:3 info: Logitech Unifying Receiver
type: keyboard,mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 98mA
chip-ID: 046d:c52b class-ID: 0300
Hub-5: 3-0:1 info: super-speed hub ports: 2 rev: 3.0
Hub-6: 4-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-7: 4-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
Device-1: 4-1.2:3 info: Ricoh USB2.0 Camera type: video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 200mA chip-ID: 05ca:18c0 class-ID: 0e02
System Temperatures: cpu: 52.0 C mobo: N/A gpu: nouveau temp: 45.0 C
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1300 libs: 362 tools: pamac pm: flatpak pkgs: 0
1: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
2: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
3: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 253
1: cpu: 18.6% command: firefox pid: 2311 mem: 492.3 MiB (8.3%)
2: cpu: 7.8% command: firefox pid: 2600 mem: 290.8 MiB (4.9%)
3: cpu: 3.3% command: kwin_x11 pid: 769 mem: 160.0 MiB (2.7%)
4: cpu: 2.8% command: Xorg pid: 606 mem: 74.2 MiB (1.2%)
5: cpu: 2.3% command: plasmashell pid: 799 mem: 361.5 MiB (6.1%)
Memory top: 5 of 253
1: mem: 492.3 MiB (8.3%) command: firefox pid: 2311 cpu: 18.6%
2: mem: 361.5 MiB (6.1%) command: plasmashell pid: 799 cpu: 2.3%
3: mem: 290.8 MiB (4.9%) command: firefox pid: 2600 cpu: 7.8%
4: mem: 219.0 MiB (3.7%) command: konsole pid: 3006 cpu: 0.5%
5: mem: 207.0 MiB (3.5%) command: firefox pid: 2489 cpu: 2.3%
Processes: 253 Power: uptime: 7m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 2.28 GiB services: org_kde_powerdevil,
tool: systemctl
Compilers: N/A Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.38
