Hallo, der Ton funktioniert bei mir nicht mehr seit dem letzten Update. Falls zusätzliche Informationen benötigt werden, bitte einfach schreiben (bin Anfänger).
Vielen Dank im Voraus.
Poste doch bitte mal die Ausgabe von
inxi -Fz
pulseaudio-ctl
> System: Kernel: 5.4.124-1-MANJARO x86_64 bits: 64 Desktop: KDE Plasma 5.21.5 Distro: Manjaro Linux
> Machine: Type: Laptop System: CLEVO product: W25xHPx v: N/A serial: <filter>
> Mobo: CLEVO model: W25xHPx serial: <filter> BIOS: American Megatrends v: 4.6.4 date: 08/12/2011
> Battery: ID-1: BAT charge: 45.0 Wh (100.0%) condition: 45.0/48.8 Wh (92.2%)
> CPU: Info: Dual Core model: Intel Core i3-2330M bits: 64 type: MT MCP cache: L2: 3 MiB
> Speed: 798 MHz min/max: 800/2200 MHz Core speeds (MHz): 1: 798 2: 798 3: 798 4: 798
> Graphics: Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics driver: i915 v: kernel
> Device-2: NVIDIA GF108M [GeForce GT 520M] driver: nouveau v: kernel
> Display: x11 server: X.Org 1.20.11 driver: loaded: intel,nouveau unloaded: modesetting
> resolution: 1366x768~60Hz
> OpenGL: renderer: Mesa DRI Intel HD Graphics 3000 (SNB GT2) v: 3.3 Mesa 21.1.2
> Audio: Device-1: Intel 6 Series/C200 Series Family High Definition Audio driver: snd_hda_intel
> Device-2: NVIDIA GF108 High Definition Audio driver: snd_hda_intel
> Sound Server-1: ALSA v: k5.4.124-1-MANJARO running: yes
> Sound Server-2: PulseAudio v: 14.2 running: yes
> Network: Device-1: Intel Centrino Wireless-N 1030 [Rainbow Peak] driver: iwlwifi
> IF: wlp4s0 state: up mac: <filter>
> Device-2: JMicron JMC250 PCI Express Gigabit Ethernet driver: jme
> IF: enp5s0f0 state: down mac: <filter>
> Drives: Local Storage: total: 931.51 GiB used: 17.7 GiB (1.9%)
> ID-1: /dev/sda vendor: Samsung model: HN-M101MBB size: 931.51 GiB
> Partition: ID-1: / size: 901.96 GiB used: 17.7 GiB (2.0%) fs: ext4 dev: /dev/sda1
> Swap: Alert: No swap data was found.
> Sensors: System Temperatures: cpu: 57.0 C mobo: N/A gpu: nouveau temp: 46.0 C
> Fan Speeds (RPM): N/A
> Info: Processes: 163 Uptime: 6m Memory: 3.75 GiB used: 1.47 GiB (39.1%) Shell: Bash inxi: 3.3.04
und
> No config file found so creating a fresh one in:
> /home/timk/.config/pulseaudio-ctl/config
> Edit this file if desired.
> pulseaudio-ctl v1.67
> /usr/bin/pulseaudio-ctl {up,down,mute,mute-input,set,atmost,full-status} [n]
> Where up and down adjust volume in ±5 % increments
> Where up and down [n] adjust volume in ±n % increments
> Where mute toggles the mute status on/off
> Where mute-input toggles the input status on/off
> Where set set the volume to [n] %
> Where atmost only takes effect if current volume is higher than [n]
> Where full-status prints volume level, sink and source mute state to stdout
> Optionally, redefine an upper threshold in /home/timk/.config/pulseaudio-ctl/config
> Volume level : 17 %
> Is sink muted : no
> Is source muted : no
> Detected sink : 0
> Detected source : 0
Schau mal mit dem Befehl alsamixer nach, ob evtl. noch andere Channels gemutet sind und unmute diese. Einen gemuteten Channel erkennst du an zwei MM die nebeneinander stehen:
EInfach mit den Cursortasten den Channel auswählen und dann mit der Taste M umschalten. Am besten parallel dazu ein Lied oder Video mit Ton abspielen, damit du gleich hörst wenn sich was ändert. Ggf. mit F6 auch mal eine andere Soundkarte auswählen.
Bei dürfte es sein wie bei mir, d.h. die Soundkarte Default ist Pulseaudio (der Soundserver, der auf Alsa aufsetzt) und HDA Intel PCH, was dann der onboard Soundkarte entspricht. Bei Pulseaudio dürfen keine Channels gemutet sein, bei der Intel-Karte sollten zumindest mal Master und PCM nicht gemutet sein. Je nach genauer Konfiguration bei dir, einfach mal n bissl rumspielen.
Ansonsten kannst du auch mal mit alsactl init versuchen, den Treiber zu resetten.
Moin Tigaente,
ich habe es ausprobiert und der Ton funktioniert wieder. Bei der Intel-Karte war der Kopfhörer Kanal gemutet. Vielen Dank!
