Hi everyone. I’ve been using Manjaro for the past month, and the experience is amazing. One thing that bothers me is it keeps asking me the Wi-Fi password of the alredy known SSID every boot. It’s not really an issue is the password is super memorable and easy to type, but some Wi-Fi password isn’t. Is it related to kernel issue? Recently, I upgraded the kernel to 510 because the included 59 is not supported anymore.
Here is my inxi --full --verbosity=7 --filter --no-host
System: Kernel: 5.10.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: KDE Plasma 5.20.4
tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Laptop System: Acer product: Aspire A514-52G v: V1.12 serial: <filter> Chassis: type: 10
serial: <filter>
Mobo: CML model: Sneezy_WC v: V1.12 serial: <filter> UEFI: Insyde v: 1.12 date: 03/28/2020
Battery: ID-1: BAT0 charge: 32.9 Wh condition: 44.1/48.0 Wh (92%) volts: 11.4/11.2
model: LGC KT0030G020 AP18C8K type: Li-ion serial: <filter> status: Discharging cycles: 131
Memory: RAM: total: 11.41 GiB used: 2.03 GiB (17.8%)
CPU: Info: Quad Core model: Intel Core i5-10210U bits: 64 type: MT MCP arch: Kaby Lake note: check rev: C
L2 cache: 6 MiB bogomips: 33615
Speed: 700 MHz min/max: 400/4200 MHz Core speeds (MHz): 1: 700 2: 700 3: 700 4: 701 5: 700 6: 700
7: 700 8: 700
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities arch_perfmon art avx
avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp
hwp_act_window hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid invpcid_single
lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep
smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust
tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Graphics: Device-1: Intel UHD Graphics vendor: Acer Incorporated ALI driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:9b41
Device-2: NVIDIA GP108M [GeForce MX250] vendor: Acer Incorporated ALI driver: nvidia v: 455.45.01
bus ID: 01:00.0 chip ID: 10de:1d13
Device-3: Chicony HD User Facing type: USB driver: uvcvideo bus ID: 1-7:2 chip ID: 04f2:b64f
serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: modesetting,nvidia
alternate: fbdev,intel,nouveau,nv,vesa resolution: 1366x768~60Hz s-dpi: 96
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 20.3.1 direct render: Yes
Audio: Device-1: Intel vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel bus ID: 00:1f.3
chip ID: 8086:02c8
Sound Server: ALSA v: k5.10.2-2-MANJARO
Network: Device-1: Intel Wireless-AC 9462 driver: iwlwifi v: kernel port: 5000 bus ID: 00:14.3
chip ID: 8086:02f0
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Acer Incorporated ALI
driver: r8169 v: kernel port: 3000 bus ID: 02:00.0 chip ID: 10ec:8168
RAID: Message: No RAID data was found.
Drives: Local Storage: total: 1.14 TiB used: 26.29 GiB (2.2%)
ID-1: /dev/nvme0n1 vendor: Orico model: V500 256GB size: 238.47 GiB speed: 31.6 Gb/s lanes: 4
serial: <filter> rev: S1111A0L temp: 33.9 C
ID-2: /dev/sda vendor: Western Digital model: WD10SPZX-21Z10T0 size: 931.51 GiB speed: 6.0 Gb/s
serial: <filter> rev: 1A02
Partition: ID-1: / size: 97.33 GiB used: 12.52 GiB (12.9%) fs: ext4 dev: /dev/sda4 label: N/A
uuid: 1a9154b9-9648-474f-86e3-a453620f9497
ID-2: /boot/efi size: 618.8 MiB used: 352 KiB (0.1%) fs: vfat dev: /dev/sda2 label: N/A
uuid: E4A9-4989
ID-3: /home size: 97.93 GiB used: 13.77 GiB (14.1%) fs: ext4 dev: /dev/sda3 label: N/A
uuid: 1df05ece-72f3-4d8f-ab79-5c4173225f4f
ID-4: /run/timeshift/backup raw size: 100 GiB size: <superuser required> used: <superuser required>
fs: ext4 dev: /dev/sda3 label: N/A uuid: 1df05ece-72f3-4d8f-ab79-5c4173225f4f
Swap: Alert: No Swap data was found.
Unmounted: ID-1: /dev/nvme0n1p1 size: 100 MiB fs: vfat label: N/A uuid: 3ACF-3E5C
ID-2: /dev/nvme0n1p2 size: 16 MiB fs: <superuser required> label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 size: 237.86 GiB fs: ntfs label: System uuid: 9A1ED2741ED248C1
ID-4: /dev/nvme0n1p4 size: 513 MiB fs: ntfs label: N/A uuid: 884CDAEA4CDAD254
ID-5: /dev/sda1 size: 731.51 GiB fs: ntfs label: Data uuid: B244B4D544B49E13
USB: Hub: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Device-1: 1-7:2 info: Chicony HD User Facing type: Video driver: uvcvideo interfaces: 2 rev: 2.0
speed: 480 Mb/s chip ID: 04f2:b64f serial: <filter>
Device-2: 1-10:3 info: Intel type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
chip ID: 8087:0026
Hub: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003
Sensors: System Temperatures: cpu: 54.0 C mobo: N/A
Info: Processes: 247 Uptime: 42m wakeups: 4 Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages: 1369
pacman: 1367 snap: 2 Shell: fish v: 3.1.2 running in: yakuake inxi: 3.2.01
Running sudo dmesg | grep wlp0s20f3
would produce
[ 14.910768] iwlwifi 0000:00:14.3 wlp0s20f3: renamed from wlan0
[ 229.416624] wlp0s20f3: authenticate with a6:d9:90:d2:0c:4d
[ 229.418847] wlp0s20f3: send auth to a6:d9:90:d2:0c:4d (try 1/3)
[ 229.444586] wlp0s20f3: authenticated
[ 229.448756] wlp0s20f3: associate with a6:d9:90:d2:0c:4d (try 1/3)
[ 229.453187] wlp0s20f3: RX AssocResp from a6:d9:90:d2:0c:4d (capab=0x411 status=0 aid=1)
[ 229.456586] wlp0s20f3: associated
[ 229.589462] IPv6: ADDRCONF(NETDEV_CHANGE): wlp0s20f3: link becomes ready
[ 1772.030615] wlp0s20f3: deauthenticating from a6:d9:90:d2:0c:4d by local choice (Reason: 3=DEAUTH_LEAVING)
[ 1787.098206] wlp0s20f3: authenticate with a6:d9:90:d2:0c:4d
[ 1787.100970] wlp0s20f3: send auth to a6:d9:90:d2:0c:4d (try 1/3)
[ 1787.126531] wlp0s20f3: authenticated
[ 1787.131607] wlp0s20f3: associate with a6:d9:90:d2:0c:4d (try 1/3)
[ 1787.135977] wlp0s20f3: RX AssocResp from a6:d9:90:d2:0c:4d (capab=0x411 status=0 aid=1)
[ 1787.139878] wlp0s20f3: associated
[ 1787.157132] IPv6: ADDRCONF(NETDEV_CHANGE): wlp0s20f3: link becomes ready
A6:D9:90:D2:0C:4D is the BSSID of my Wi-Fi. Any help would be so much appreciated!
