Hi.
I’m using Manjaro KDE Plasma and Kdenlive v.22.07.70.
I have created a custom preset while creating this project with 1080x1920 resolution.
I have created a project which displays properly in Project Monitor.
However, when I’m Rendering the project with HD MP4, after rendering the video, when I play the video, the Text size reduces and Picture positions are misplaced.
IDK what to do now. I have searched online and found nothing.
Can someone please help.
Thanks.
Hello,
Why? There are already presets for HD 1080p, at different fps, but in the Video Settings will always be in that case 1920x1080 to keep the 16:9 ratio, and not 1080x1920.
When you render the project to a file you simply just chose whatever encoding you prefer. This are the recommended ones in that case:
I am creating a video for mobile phone. Thus 1080x1920. I need to make a video with this resolution.
Do you know any better way to make a video 1080x1920?
Okay finally got it.
To solve the issue, I had to create a custom Render preset.
I kept the properties as follows:
Video
- Container: mp4
- Resolution: 1080x1920
- Display aspect ratio: 16:9
- Pixel aspect ratio: 3.1604938 (256:81) [generated automatically after putting display aspect ratio]
- Codec: libx264
Audio - Channels: 2
- Codec: aac
- Sample rate: 96000
This solves the problem. However, it is better and wiser to use the Vertical HD 60 fps preset from Custom from the Project Settings.
