Hello,
I launched Kdenlive today and discovered that position and zoom effect was not working. I can confirm it was working a few weeks ago.
It shows the effect in Preview window, but in rendered file, the effect is not applied.
Kdenlive version: 21.04.0-3 (installed/updated through Pamac-GUI)
System information:
System: Kernel: 5.10.36-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: KDE Plasma 5.21.5 Distro: Manjaro Linux
base: Arch Linux
Machine: Type: Laptop System: HP product: HP Pavilion Notebook v: Type1ProductConfigId serial: <filter>
Mobo: HP model: 8216 v: 83.18 serial: <filter> UEFI: Insyde v: F.52 date: 05/02/2019
Battery: Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 2S charge: 55% (should be ignored)
status: Discharging
CPU: Info: Dual Core model: Intel Core i7-7500U bits: 64 type: MT MCP arch: Amber/Kaby Lake note: check rev: 9 cache:
L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 23209
Speed: 700 MHz min/max: 400/3500 MHz Core speeds (MHz): 1: 700 2: 700 3: 701 4: 700
Graphics: Device-1: Intel HD Graphics 620 vendor: Hewlett-Packard driver: i915 v: kernel bus-ID: 00:02.0
Device-2: NVIDIA GM108M [GeForce 940MX] vendor: Hewlett-Packard driver: nvidia v: 460.80 bus-ID: 01:00.0
Display: x11 server: X.Org 1.20.11 driver: loaded: modesetting,nvidia resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.0.3 direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
Sound Server-1: ALSA v: k5.10.36-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.28 running: yes
Network: Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000
bus-ID: 03:00.0
Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi v: kernel port: 3000 bus-ID: 05:00.0
IF: wlo1 state: down mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
Bluetooth: Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-7:4
Drives: Local Storage: total: 3.18 TiB used: 1.1 TiB (34.8%)
ID-1: /dev/sda vendor: Seagate model: ST2000LM003 HN-M201RAD size: 1.82 TiB
ID-2: /dev/sdb vendor: Western Digital model: WDS480G2G0A-00JH30 size: 447.13 GiB
ID-3: /dev/sdc type: USB vendor: Lenovo model: USB Hard Drive size: 931.51 GiB
ID-4: /dev/sdd type: USB vendor: SanDisk model: Cruzer Blade size: 14.32 GiB
Partition: ID-1: / size: 421.94 GiB used: 121.97 GiB (28.9%) fs: ext4 dev: /dev/sdb2
ID-2: /boot/efi size: 299.4 MiB used: 296 KiB (0.1%) fs: vfat dev: /dev/sdb1
Swap: ID-1: swap-1 type: partition size: 17.08 GiB used: 0 KiB (0.0%) dev: /dev/sdb3
Sensors: System Temperatures: cpu: 47.0 C mobo: N/A
Info: Processes: 228 Uptime: 34m Memory: 15.52 GiB used: 2.65 GiB (17.0%) Init: systemd Compilers: gcc: 10.2.0
clang: 11.1.0 Packages: 1538 Shell: Zsh v: 5.8 inxi: 3.3.04
