Hi Community
when monitoring the project the pictures play correctly with transactions but there is no sound … Why?
-on the timeline Audio is on
- All the levels are OK (signal level play)
- the clips (MP3 lime) well render with Mplayer
Who is the mistake ???
Thanks
[philline0@philline0-hplx ~]$ inxi -Fxxxz
System: Kernel: 5.4.80-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2
wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Laptop System: Hewlett-Packard product: HP Pavilion dv7 Notebook PC v: 058A110000242B10010020100
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: Hewlett-Packard model: 1449 v: 65.38 serial: <filter> BIOS: Hewlett-Packard v: F.29 date: 11/07/2011
Battery: ID-1: BAT0 charge: 23.8 Wh condition: 23.8/23.8 Wh (100%) volts: 12.4/10.8 model: Hewlett-Packard Primary
type: Li-ion serial: N/A status: Full
CPU: Info: Quad Core model: Intel Core i7 Q 720 bits: 64 type: MT MCP arch: Nehalem rev: 5 L2 cache: 6144 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 25548
Speed: 931 MHz min/max: 933/1600 MHz boost: enabled Core speeds (MHz): 1: 931 2: 932 3: 931 4: 931 5: 931 6: 931
7: 931 8: 931
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Madison [Mobility Radeon HD 5650/5750 / 6530M/6550M]
vendor: Hewlett-Packard driver: radeon v: kernel bus ID: 01:00.0 chip ID: 1002:68c1
Device-2: Quanta HP Webcam type: USB driver: uvcvideo bus ID: 2-1.5:5 chip ID: 0408:03b2
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: ati,radeon unloaded: modesetting
alternate: fbdev,vesa resolution: 1600x900~60Hz s-dpi: 96
OpenGL: renderer: AMD REDWOOD (DRM 2.50.0 / 5.4.80-2-MANJARO LLVM 11.0.0) v: 3.3 Mesa 20.2.3 compat-v: 3.1
direct render: Yes
Audio: Device-1: Intel 5 Series/3400 Series High Definition Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus ID: 00:1b.0 chip ID: 8086:3b56
Device-2: Advanced Micro Devices [AMD/ATI] Redwood HDMI Audio [Radeon HD 5000 Series] vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 1002:aa60
Sound Server: ALSA v: k5.4.80-2-MANJARO
Network: Device-1: Ralink RT3090 Wireless 802.11n 1T/1R PCIe vendor: Hewlett-Packard driver: rt2800pci v: 2.3.0 port: 4000
bus ID: 02:00.0 chip ID: 1814:3090
IF: wlo1 state: down mac: <filter>
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard driver: r8169 v: kernel
port: 2000 bus ID: 03:00.0 chip ID: 10ec:8168
Device-3: Ralink Motorola BC4 Bluetooth 3.0+HS Adapter type: USB driver: btusb bus ID: 1-1.3:4 chip ID: 148f:1000
Device-4: TP-Link Archer T3U [Realtek RTL8812BU] type: USB driver: rtl88x2bu bus ID: 2-1.1:3 chip ID: 2357:012d
serial: <filter>
IF: wlp0s29u1u1 state: up mac: <filter>
Drives: Local Storage: total: 238.47 GiB used: 49.36 GiB (20.7%)
ID-1: /dev/sda vendor: GOODRAM model: SSDPR-CX400-256 size: 238.47 GiB speed: 3.0 Gb/s serial: <filter> rev: 61.2
scheme: MBR
Partition: ID-1: / size: 225.54 GiB used: 49.36 GiB (21.9%) fs: ext4 dev: /dev/sda1
Swap: ID-1: swap-1 type: partition size: 8.32 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda2
Sensors: System Temperatures: cpu: 61.0 C mobo: N/A gpu: radeon temp: 65.0 C
Info: Processes: 206 Uptime: 13m Memory: 3.78 GiB used: 1.41 GiB (37.2%) Init: systemd v: 246 Compilers: gcc: 10.2.0
Packages: 1395 pacman: 1390 flatpak: 5 Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.08
mod. edited for reasons of better readability
only turn ON the sound in Plasma - Audio - Volume parameters - Application / Kdenlive. (from taskbar)
