Hello everyone.
I want to install Kdenlive, but i can’t because there is a dependency problem.
The error is this:
:: installing poppler (20.12.1-1) breaks dependency ‘poppler=20.10.0’ required by poppler-glib
==> Restart building kdenlive-git ? [y/N]
==> % ➜ ~ yaourt -S poppler
resolving dependencies…
➜ ~ yaourt -Rns sane
checking dependencies…
:: removing sane breaks dependency ‘sane’ required by colord-sane
I still don’t know how to solve these cases when there is a problem with packages that use other packages that are installed, and it is not easy to see the entire dependency tree.
Thanks
This is the error:
➜ ~ sudo pacman -S kdenlive poppler
I tried to install latte-dock yesterday, and it gave me that dependency error. And it gave me that poppler error. I thought it would only be for that package, but then I couldn’t install Kdenlive.
If the problem has been solved ─ and for future reference ─ could you then please mark the post that solved it as the solution? This will add a summary of said post to your opening post, so that people with the same problem can more easily find out how to fix it.
Well, the versions in the AUR are generally newer, because AUR is on par with Arch Stable, which in turn is on par with Manjaro Unstable. So I figured that allowing pacman to downgrade the packages was the way to go. The double uu allows for downgrading.
