I cannot use kdenlive… always I got Segmentation fault. I tried remove and install by pacman, by pamac and by GUI, but It dont starts.
Linux lud-txu 5.15.173-1-MANJARO #1 SMP PREEMPT Sun Nov 17 21:30:08 UTC 2024 x86_64 GNU/Linux
How fix it?
How fix it?
What branch are you on? If not testing, I would change it to testing at it carries already a fresher version.
As the package is in Manjaro’s repos, pacman
is sufficient to update it.
I have 24.08.3-1
sudo pacman -S kdenlive
How can I change to testing?
sudo pacman-mirrors -a -B testing && sudo pacman-mirrors -f && sudo pacman -Syyu
Be sure to let it finish and do not interrupt the process.
