Kdenlive doesn’t work with NVIDIA prime drivers
Nvidia’s driver’s hybrid intel - Nvidia - prime 515
OS - Linux
Distro - Manjaro
CPU - intel i5 10300h
GPU - Nvidia GTX 1650
command - prime-run kdenlive
output:
prime-run kdenlive 1 ✘
Could not detect package type, probably default? App dir is "/usr/bin"
mlt_repository_init: failed to dlopen /usr/lib/mlt-7/libmltmovit.so
(libmovit.so.8: cannot open shared object file: No such file or directory)
mlt_repository_init: failed to dlopen /usr/lib/mlt-7/libmltrtaudio.so
(librtaudio.so.6: cannot open shared object file: No such file or directory)
mlt_repository_init: failed to dlopen /usr/lib/mlt-7/libmltsox.so
(libsox.so.3: cannot open shared object file: No such file or directory)
profilePath from KdenliveSetting::mltPath: "/usr/share/mlt-7/profiles"
meltPath from KdenliveSetting::rendererPath: "/usr/bin/melt-7"
Empty metadata for "avcolour_space"
Empty metadata for "avcolor_space"
Empty metadata for "avdeinterlace"
Empty metadata for "swscale"
Empty metadata for "swresample"
Empty metadata for "audiochannels"
Empty metadata for "audioconvert"
Empty metadata for "imageconvert"
Empty metadata for "telecide"
Empty metadata for "deinterlace"
plugin not available: "avfilter.acompressor"
plugin not available: "avfilter.aecho"
plugin not available: "avfilter.agate"
plugin not available: "avfilter.atadenoise"
plugin not available: "avfilter.bwdif"
plugin not available: "avfilter.deblock"
plugin not available: "avfilter.dedot"
plugin not available: "avfilter.deflate"
plugin not available: "avfilter.derain"
plugin not available: "avfilter.doubleweave"
plugin not available: "avfilter.field"
plugin not available: "avfilter.framestep"
plugin not available: "avfilter.fspp"
plugin not available: "avfilter.graphmonitor"
plugin not available: "avfilter.hqdn3d"
plugin not available: "avfilter.inflate"
plugin not available: "avfilter.lagfun"
plugin not available: "avfilter.loudnorm"
plugin not available: "avfilter.mcdeint"
plugin not available: "avfilter.random"
plugin not available: "avfilter.removegrain"
plugin not available: "avfilter.separatefields"
plugin not available: "avfilter.shuffleplanes"
plugin not available: "avfilter.sofalizer"
plugin not available: "avfilter.sr"
plugin not available: "avfilter.tmix"
plugin not available: "avfilter.w3fdif"
plugin not available: "avfilter.weave"
plugin not available: "avfilter.yadif"
plugin not available: "frei0r.baltan"
plugin not available: "frei0r.bgsubtract0r"
plugin not available: "frei0r.delay0r"
plugin not available: "frei0r.delaygrab"
plugin not available: "frei0r.lightgraffiti"
plugin not available: "frei0r.tehRoxx0r"
plugin not available: "ladspa"
plugin not available: "movit.blur"
plugin not available: "movit.sharpen"
plugin not available: "movit.diffusion"
plugin not available: "movit.flip"
plugin not available: "movit.glow"
plugin not available: "movit.lift_gamma_gain"
plugin not available: "movit.mirror"
plugin not available: "movit.opacity"
plugin not available: "movit.rect"
plugin not available: "movit.saturation"
plugin not available: "movit.unsharp_mask"
plugin not available: "movit.vignette"
plugin not available: "movit.white_balance"
plugin not available: "sox"
plugin not available: "timewarp"
plugin not available: "region"
=== /// CANNOT ACCESS SPEECH DICTIONARIES FOLDER
QQmlEngine::setContextForObject(): Object already has a QQmlContext
:::: USING TRACK COMPOSITING: "frei0r.cairoblend"
qml: item not found
qml: item not found
// FFMPEG ARGS: ("-hide_banner", "-y", "-vaapi_device", "/dev/dri/renderD128", "-f", "lavfi", "-i", "smptebars=duration=5:size=1280x720:rate=25", "-vf", "format=nv12,hwupload", "-c:v", "h264_vaapi", "-an", "-f", "mp4", "/tmp/RTemSg.mp4")
/// ++ VAAPI FAILED ::::::
// FFMPEG ARGS: ("-hide_banner", "-y", "-hwaccel", "vaapi", "-hwaccel_output_format", "vaapi", "/dev/dri/renderD128", "-f", "lavfi", "-i", "smptebars=duration=5:size=1280x720:rate=25", "-vf", "scale_vaapi=w=640:h=-2:format=nv12,hwupload", "-c:v", "h264_vaapi", "-an", "-f", "mp4", "/tmp/RTemSg.mp4")
// FFMPEG ARGS: ("-hide_banner", "-y", "-hwaccel", "cuvid", "-f", "lavfi", "-i", "smptebars=duration=5:size=1280x720:rate=25", "-c:v", "h264_nvenc", "-an", "-f", "mp4", "/tmp/LGcqhV.mp4")
/// ++ NVENC FAILED ::::::
// FFMPEG ARGS: ("-hide_banner", "-filters")
/// ++ SCALE_NPP NOT SUPPORTED
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
