System info
Version : 24.12.2-1
❱inxi -b
Host: greg-venusseries Kernel: 6.13.1-2-MANJARO arch: x86_64 bits: 64
Desktop: KDE Plasma v: 6.2.5 Distro: Manjaro Linux
Type: Desktop System: Micro (HK) Tech product: Venus Series v: N/A
serial:
Mobo: Shenzhen Meigao Equipment model: AHWSA serial:
UEFI: American Megatrends LLC. v: AHWSA.1.22 date: 03/12/2024
Info: 14-core (6-mt/8-st) 13th Gen Intel Core i9-13900H [MST AMCP]
speed (MHz): avg: 400 min/max: 400/5200:5400:4100
Device-1: Intel Raptor Lake-P [Iris Xe Graphics] driver: i915 v: kernel
Display: x11 server: X.Org v: 21.1.15 with: Xwayland v: 24.1.5 driver: X:
loaded: modesetting dri: iris gpu: i915 resolution: 3840x2160~60Hz
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.3.4-arch1.1
renderer: Mesa Intel Iris Xe Graphics (RPL-P)
x11: xdpyinfo, xprop, xrandr
Device-1: Intel Ethernet I226-V driver: igc
Device-2: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
driver: mt7921e
Local Storage: total: 1.84 TiB used: 269.66 GiB (14.3%)
Memory: total: 32 GiB note: est. available: 31.07 GiB used: 7.52 GiB (24.2%)
Processes: 418 Uptime: 1d 1h 7m Shell: fish inxi: 3.3.37
I’m running Kdenlive on Manjaro KDE and experiencing a recurring issue where all sound output stops after a while. Initially, everything works fine, and I can see SDL Application: Audio Stream in my desktop audio settings. However, after some time, audio cuts out, and SDL Application: Audio Stream disappears entirely. Nothing i do can get it working again except to restart kdenlive.
Running Kdenlive from the terminal gives repeated errors:
MLT: "[consumer sdl2_audio ] SDL failed to open audio"
ALSA lib pcm.c:8772:(snd_pcm_recover) underrun occurred
ERROR: ALSA: period size = 1024, periods = 2, buffer size = 2048
pos: 412 out: 624
pos: 442 out: 624
pos: 497 out: 624
pos: 530 out: 624
pos: 582 out: 624
I’ve tried different environment variables to force ALSA, PulseAudio, and JACK:
KDENLIVE_AUDIO_BACKEND=alsa SDL_AUDIODRIVER=alsa kdenlive
KDENLIVE_AUDIO_BACKEND=jack kdenlive
But the issue persists regardless of backend. Even switching to JACK (after installing jack2 and qjackctl) didn’t resolve the issue, and the errors still appear.
Things I’ve Tried:
- Increasing ALSA buffer size (
ALSA_PCM_BUFFER_SIZE=8192) - Setting PipeWire to prevent suspending (
session.suspend-timeout 0) - Giving Kdenlive real-time priority (
chrt -f 99)
Does anyone know a fix or workaround for this? Is there a way to get Kdenlive to properly hold onto the audio stream without it vanishing mid-session?
Thanks in advance!
