Hello,
after updating to KDE6 the KDE OpenVPN Modul doesn’t connect.
KDE6 OpenVPN Plugin connection failed
journalctl -b | grep vpn ✔
Mai 14 21:10:40 user NetworkManager[479]: <info> [1715713840.2865] vpn[0x55fb732c93e0,ed70a5ef-e8b5-4e64-9401-09e1a16bd197,"ovpn"]: starting openvpn
Mai 14 21:10:40 user nm-openvpn[1363]: DEPRECATED OPTION: --cipher set to 'AES-256-CBC' but missing in --data-ciphers (AES-256-GCM:AES-128-GCM:CHACHA20-POLY1305). OpenVPN ignores --cipher for cipher negotiations.
Mai 14 21:10:40 user nm-openvpn[1363]: OpenVPN 2.6.10 [git:makepkg/ba0f62fb950c56a0+] x86_64-pc-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] [DCO] built on Mar 20 2024
Mai 14 21:10:40 user nm-openvpn[1363]: library versions: OpenSSL 3.3.0 9 Apr 2024, LZO 2.10
Mai 14 21:10:40 user nm-openvpn[1363]: DCO version: N/A
Mai 14 21:10:40 user nm-openvpn[1363]: WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Mai 14 21:10:40 user nm-openvpn[1363]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Mai 14 21:10:40 user nm-openvpn[1363]: TCP/UDP: Preserving recently used remote address: [AF_INET]X.X.X.X:443
Mai 14 21:10:40 user nm-openvpn[1363]: UDPv4 link local: (not bound)
Mai 14 21:10:40 user nm-openvpn[1363]: UDPv4 link remote: [AF_INET]X.X.X.X:443
Mai 14 21:10:40 user nm-openvpn[1363]: NOTE: UID/GID downgrade will be delayed because of --client, --pull, or --up-delay
Mai 14 21:10:40 user nm-openvpn[1363]: [Fireware SSLVPN Server] Peer Connection Initiated with [AF_INET]X.X.X.X:443
Mai 14 21:10:46 user nm-openvpn[1363]: OPTIONS ERROR: failed to negotiate cipher with server. Add the server's cipher ('AES-256-CBC') to --data-ciphers (currently 'AES-256-GCM:AES-128-GCM:CHACHA20-POLY1305') if you want to connect to this server.
Mai 14 21:10:46 user nm-openvpn[1363]: ERROR: Failed to apply push options
Mai 14 21:10:46 user nm-openvpn[1363]: Failed to open tun/tap interface
Mai 14 21:10:46 user nm-openvpn[1363]: SIGUSR1[soft,process-push-msg-failed] received, process restarting
Mai 14 21:10:47 user nm-openvpn[1363]: WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Mai 14 21:10:47 user nm-openvpn[1363]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Mai 14 21:10:47 user nm-openvpn[1363]: TCP/UDP: Preserving recently used remote address: [AF_INET]X.X.X.X:443
Mai 14 21:10:47 user nm-openvpn[1363]: UDPv4 link local: (not bound)
Mai 14 21:10:47 user nm-openvpn[1363]: UDPv4 link remote: [AF_INET]X.X.X.X:443
Mai 14 21:10:48 user nm-openvpn[1363]: [Fireware SSLVPN Server] Peer Connection Initiated with [AF_INET]X.X.X.X:443
Mai 14 21:10:54 user nm-openvpn[1363]: OPTIONS ERROR: failed to negotiate cipher with server. Add the server's cipher ('AES-256-CBC') to --data-ciphers (currently 'AES-256-GCM:AES-128-GCM:CHACHA20-POLY1305') if you want to connect to this server.
Mai 14 21:10:54 user nm-openvpn[1363]: ERROR: Failed to apply push options
Mai 14 21:10:54 user nm-openvpn[1363]: Failed to open tun/tap interface
Does anyone else have problems with OpenVPN after upgrading?
