I’m running three monitors on my setup, one main 144hz 27in. as my primary monitor, one 60hz 24in. as my second monitor, and a 50 inch Sony TV as my third monitor. I’ve been having an issue with KDE scaling the UI elements and applications on my regular monitors to the size of my TV with applications launching with the taskbar covering window headers and even the tabs selector on firefox (I keep my taskbar on the top of the screen, I’ve been working around that particular issue by moving it to the bottom temporarily).
I have tried changed global scaling in display and monitor settings, booted with the TV unplugged, gone through everything I can think of in nvidia settings, reinstalled nvidia drivers and tried open source drivers, disabling KScreen, and even tried an obscure reddit comment’s suggestion of adding “PLASMA_USE_QT_SCALING=1” to my etc/environment file. Still despite this nothing changes with my desktop scaling and it keeps all of my monitors at a scaling as if it was a TV while the resolutions and aspect ratios are the settings native to each monitor.
It is worth mentioning that this issue started when KScreen stopped detecting my primary monitor after login randomly after a PC restart the other day, I fixed the detection issue by deleting the KScreen folder in the /.local directory and rebooting to recreate those files, though the scaling issue stayed after fixing the detection issue.
Does anyone have any idea how to fix this issue or what could be causing it?
Kernel: 6.9.2-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.9-x86_64
root=UUID=5737cc19-fddb-4acf-ae99-2dc4f774da33 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.2.0
Type: Desktop Mobo: ASUSTeK model: ROG STRIX B350-F GAMING v: Rev X.0x
UEFI: American Megatrends v: 5603 date: 07/28/2020
Info: model: AMD Ryzen 7 1700X bits: 64 type: MT MCP arch: Zen level: v3
note: check built: 2017-19 process: GF 14nm family: 0x17 (23) model-id: 1
stepping: 1 microcode: 0x8001138
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 768 KiB desc: d-8x32 KiB; i-8x64 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB
desc: 2x8 MiB
Speed (MHz): avg: 2235 high: 3493 min/max: 2200/3400 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1930 2: 2200
3: 1996 4: 3493 5: 2790 6: 1975 7: 1878 8: 2200 9: 1857 10: 2234 11: 1996
12: 2803 13: 2200 14: 2200 15: 2110 16: 1906 bogomips: 108624
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Device-1: NVIDIA TU116 [GeForce GTX 1660] vendor: Micro-Star MSI
driver: nvidia v: 550.78 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-04; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: none off: DP-2,DP-3,HDMI-A-1 empty: DP-1 bus-ID: 08:00.0
chip-ID: 10de:2184 class-ID: 0300
Device-2: Logitech C922 Pro Stream Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3
chip-ID: 046d:085c class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0
compositor: kwin_x11 driver: X: loaded: N/A failed: nvidia
gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 5760x1493 s-dpi: 91 s-size: 1605x416mm (63.19x16.38")
s-diag: 1658mm (65.28")
Monitor-1: DP-3 pos: top-right res: 1920x1080 hz: 60 dpi: 37
size: 1328x747mm (52.28x29.41") diag: 1524mm (59.99") modes: N/A
Monitor-2: DP-4 pos: primary,bottom-l res: 1920x1080 dpi: 92
size: 531x298mm (20.91x11.73") diag: 609mm (23.97") modes: N/A
Monitor-3: HDMI-0 pos: bottom-c res: 1920x1080 hz: 60 dpi: 102
size: 480x270mm (18.9x10.63") diag: 551mm (21.68") modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.78 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce GTX 1660/PCIe/SSE2
memory: 5.86 GiB
API: Vulkan v: 1.3.279 layers: 10 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 1660 driver: nvidia v: 550.78 device-ID: 10de:2184
surfaces: xcb,xlib
Device-1: NVIDIA TU116 High Definition Audio vendor: Micro-Star MSI
bus-ID: 08:00.1 chip-ID: 10de:1aeb class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0a:00.3
chip-ID: 1022:1457 class-ID: 0403
Device-3: Logitech C922 Pro Stream Webcam driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.9.2-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse
Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 03:00.0
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 07:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp7s0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:4 chip-ID: 8087:0029
class-ID: e001
Local Storage: total: 1.36 TiB used: 436.69 GiB (31.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WDBNCE5000PNC
tech: SSD serial: <filter> fw-rev: 20RL scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WDS100T2B0A-00SM50 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 20WD
scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
used: 436.69 GiB (47.7%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18
used: 296 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-1: swap-1 type: partition size: 546 MiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 34.8 C mobo: N/A gpu: nvidia temp: 37 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 45%
Memory: total: 28 GiB available: 27.34 GiB used: 3.74 GiB (13.7%)
Processes: 378 Power: uptime: 26m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 10.91 GiB services: org_kde_powerdevil,
tool: systemctl
Packages: 1585 pm: pacman pkgs: 1574 libs: 493 tools: pamac pm: flatpak
pkgs: 11 Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.26 running-in: konsole inxi: 3.3.34
