i put a web widget on desktop and my screen its gone
how can i remove from console?
You can edit ~/.config/plasma-org.kde.plasma.desktop-appletsrc (or remove file if you want to reset to default) but you need to know exactly what widget you added – just web widget say nothing about it.
thaks it works
$ plasmashell --replace
and that show me where to go Cuz im noob and idk exactly how to use this : `~/.config/plasma-org.kde.plasma.desktop-appletsrc
so i delete the widget and works
This topic was automatically closed 24 hours after the last reply. New replies are no longer allowed.
