Hey all, I am having this obnoxious problem with Plasma 6.1 Wayland. Ever since updating to it via Manjaro Unstable last week, screen sharing to any chromium application via xdg-desktop-portal has this horrendous input frame rate of 1-5 FPS. This ONLY happens in Chromium/Electron apps using WebRTC. obs and Firefox have 0 issues.
Weirdly, moving the mouse over the window I am sharing, or screen, the frame rate will temporarily increase until I stop moving it. However, the video flickers, and I have to keep moving it.
I had no problems until plasma 6.1, 6.0 was fine.
GNOME wayland does not have this issue, nor does Plasma 6.1 X11.
mhwd
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-linux 2024.05.06 true PCI
> 0000:26:00.0 (0300:8086:56a1) Display controller Intel Corporation:
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> 0000:2f:00.0 (0300:1002:73df) Display controller ATI Technologies Inc:
inxi info
Kernel: 6.6.36-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
clocksource: tsc avail: hpet,acpi_pm parameters: BOOT_IMAGE=/boot/vmlinuz-
root=UUID=0765f152-d13d-4074-881e-6c1a42c71dd2 rw clearcpuid=514
udev.log_priority=3 nowatchdogs splash
Desktop: KDE Plasma v: 6.1.1 tk: Qt v: N/A info: frameworks v: 6.3.0
wm: kwin_wayland tools: avail: i3lock vt: 1 dm: SDDM Distro: Manjaro
base: Arch Linux
Type: Desktop Mobo: Micro-Star model: MAG X570S TOMAHAWK MAX WIFI (MS-7D54)
v: 1.0 serial: <superuser required> uuid: <superuser required> UEFI: American
Megatrends LLC. v: 1.80 date: 10/12/2023
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 2 microcode: 0xA20120E
Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 smt: enabled cache:
L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB desc: 12x512 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 4014 high: 4277 min/max: 2200/5719 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 4275 2: 4273
3: 4273 4: 4277 5: 2200 6: 4273 7: 4274 8: 4275 9: 4275 10: 4275 11: 4274
12: 4274 13: 4265 14: 2200 15: 4273 16: 4272 17: 4275 18: 2200 19: 4272
20: 4273 21: 4273 22: 4274 23: 4275 24: 4272 bogomips: 205294
affected
Device-1: Intel DG2 [Arc A750] driver: i915 v: kernel arch: Gen-12.7
code: Alchemist process: TSMC n6 (7nm) built: 2022+ pcie: gen: 1
speed: 2.5 GT/s lanes: 1 ports: active: DP-3,DP-4 empty: DP-1, DP-2,
HDMI-A-1, HDMI-A-2, HDMI-A-3 bus-ID: 26:00.0 chip-ID: 8086:56a1
class-ID: 0300
Device-2: AMD Navi 22 [Radeon RX 6700/6700 XT/6750 XT / 6800M/6850M XT]
vendor: ASRock driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: none empty: DP-5, DP-6, DP-7, HDMI-A-4 bus-ID: 2f:00.0
chip-ID: 1002:73df class-ID: 0300
Device-3: MACROSILICON USB3.0 UHD
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo type: USB rev: 3.2
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-1:2 chip-ID: 345f:2130
class-ID: 0300 serial: <filter>
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.0
compositor: kwin_wayland driver: X: loaded: amdgpu,modesetting
unloaded: radeon alternate: fbdev,vesa dri: iris,radeonsi gpu: i915,amdgpu
d-rect: 3840x1080 display-ID: 0
Monitor-1: DP-3 pos: primary,left res: 1920x1080 size: N/A modes: N/A
Monitor-2: DP-4 pos: right res: 1920x1080 size: N/A modes: N/A
API: EGL v: 1.5 hw: drv: intel iris drv: amd radeonsi platforms: device: 0
drv: iris device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: radeonsi
surfaceless: drv: iris wayland: drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.1.2-arch10.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Arc A750 Graphics (DG2)
device-ID: 8086:56a1 memory: 7.75 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 8 device: 0 type: discrete-gpu name: Intel
Arc A750 Graphics (DG2) driver: mesa intel v: 24.1.2-arch10.1
device-ID: 8086:56a1 surfaces: xcb,xlib,wayland device: 1
type: discrete-gpu name: AMD Radeon RX 6700 XT (RADV NAVI22)
driver: mesa radv v: 24.1.2-arch10.1 device-ID: 1002:73df
Device-1: Intel DG2 Audio driver: snd_hda_intel v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 27:00.0 chip-ID: 8086:4f90 class-ID: 0403
Device-2: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 2f:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-3: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
bus-ID: 31:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-4: MACROSILICON USB3.0 UHD
Device-5: Micro Star USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-5:2
chip-ID: 0db0:a073 class-ID: 0300
Device-6: FiiO K3 driver: snd-usb-audio type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 5-1.4:6 chip-ID: 2972:0047 class-ID: fe01
Device-7: Blue Microphones Yeti Stereo Microphone
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 5-3:3 chip-ID: b58e:9e84 class-ID: 0300
serial: <filter>
API: ALSA v: k6.6.36-1-MANJARO status: kernel-api with: aoss
Server-2: JACK v: 1.9.22 status: off tools: jack_control
Server-3: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 28:00.0
IF: enp40s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 29:00.0
chip-ID: 8086:2725 class-ID: 0280
IF: wlo1 state: down mac: <filter>
IF-ID-1: nordlynx state: unknown speed: N/A duplex: N/A mac: N/A
Device-1: TP-Link UB500 Adapter driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-4.4:8 chip-ID: 2357:0604
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.1
lmp-v: 10 status: discoverable: no pairing: no class-ID: 6c0104
Local Storage: total: 24.59 TiB used: 15.41 TiB (62.7%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Western Digital
model: WDS100T1X0E-00AFY0 size: 931.51 GiB block-size: physical: 512 B
fw-rev: 614900WD temp: 36.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 46.9 C
scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 4TB
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 2B6Q
ID-4: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT2000MX500SSD1
tech: SSD serial: <filter> fw-rev: 045 scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD40EZRZ-22GXCB0 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
fw-rev: 0A80 scheme: GPT
ID-6: /dev/sdd maj-min: 8:48 vendor: Samsung model: SSD 870 QVO 4TB
tech: SSD serial: <filter> fw-rev: 2B6Q scheme: GPT
ID-7: /dev/sde maj-min: 8:64 vendor: Samsung model: SSD 870 QVO 4TB
ID-8: /dev/sdf maj-min: 8:80 vendor: Samsung model: SSD 870 EVO 4TB
ID-9: /dev/sdg maj-min: 8:96 vendor: Samsung model: SSD 870 QVO 1TB
size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
scheme: GPT
ID-10: /dev/sdh maj-min: 8:112 vendor: Seagate model: BUP Slim BK
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: 0108 scheme: MBR
ID-11: /dev/sdi maj-min: 8:128 vendor: Kingston model: DataTraveler 3.0
size: 28.82 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 3.2
scheme: MBR
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
used: 739.81 GiB (80.8%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:4
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
System Temperatures: cpu: 43.0 C mobo: N/A gpu: amdgpu temp: 38.0 C
mem: 36.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
Memory: total: 64 GiB note: est. available: 62.72 GiB used: 9.96 GiB (15.9%)
Processes: 662 Power: uptime: 6m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 25.07 GiB services: org_kde_powerdevil,upowerd
Init: systemd v: 256 default: graphical tool: systemctl
Packages: 2112 pm: dpkg pkgs: 1 tools: apt,apt-get pm: pacman pkgs: 2030
libs: 456 tools: pamac pm: flatpak pkgs: 75 pm: snap pkgs: 6 Compilers:
clang: 17.0.6 gcc: 14.1.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.26
running-in: konsole inxi: 3.3.35
I’ve asked around, looked around and have only found one other person with this issue, so I am hoping someone here can shed some light.
