How do I make it white to match all others in sys tray? I don’t want to change my theme, just for 1 icon.
Which theme are you using? Maybe it hasn’t been maintained or upgraded to support the latest Plasma version?
I’ve had to switch recently due to compatibility issues.
I moved this to Support. I hope this is appropriate.
Perhaps ePapirus is no longer as compatible with Plasma as it once was – the volume icon looks the same for me.
However, the Papirus and Papirus-Dark icon themes seem to work as expected, and they are basically the same as ePapirus; I keep these in case I ever feel like a change; usually I just use Breeze Dark.
epapirus
was never compatible as it is for use with elementary.
Use just about any other version of papirus.
Using the Icons section of settings, you’ll find results which appear to be limited to Plasma 6 compatible themes.
Even a direct search doesn’t come up with much for you:
https://www.pling.com/find?search=epapirus
Your icon theme is dead, Jim…
Just adding to @cscs,
Papirus icon theme is available in five variants:
- Papirus
- Papirus Dark
- Papirus Light
- ePapirus (for elementary OS and Pantheon Desktop only)
- ePapirus Dark (for elementary OS and Pantheon Desktop only)
https://github.com/PapirusDevelopmentTeam/papirus-icon-theme
With all variants conveniently provided in the same package; this made it easy to quickly confirm the OP’s gripe.
This is a good reminder that what’s most convenient or easier for the developer isn’t always good for the user.
Ended up with Breeze nior white, I think that’s it. Is there a way to dowload that as a file to the drive?
If you ‘ended up’ with them, that means they are already downloaded and installed on your drive in one of the icon folders…
Maybe ~/.icons or ~/.local/share/icons
Thanks, I thought it went into a icon database & the single file wasn’t there.
