I tried this: [root tip] [How To] Mitigate and prevent GPGME error when syncing your system
and it did not work. I refreshed the keys, deleted cache, changed mirrors
did you modify pacman.conf as laid out?
Yes I did it and then changed mirrors
In the past there was a signing error of the server
What is the response to above command?
zsh: no matches found: /var/lib/pacman/sync/*.db.sig
First - the reference to the signing issue is several months ago.
Second - if if was a general issues - a lot more members would be having same issue - as of now you are the lonely swallow.
This points towards a local issue - and if you have tried everything - I have no extra info or clues.
oberon
9
see the respective issue:
