I just switched my DE from kde to xfce, I installed xfce4 and xfce4goodies, uninstalled all (found) kde applicatons but I have a bug. I use keepassXC and VirtualBox, both of them doesn’t shows and when I try to start them from the terminal the are just blank.
Gtk-Message: 10:57:27.000: Failed to load module "colorreload-gtk-module" Gtk-Message: 10:57:27.000: Failed to load module "window-decorations-gtk-module" Qt WARNING: QWidget::setMinimumSize: (/UIToolsView) Negative sizes (0,-1431655726) are not possible
If anyone has an idea on how to fix this, thanks in advance.
If you need more informations, I’m at your disposition
KDE Plasma install changed this file in your home directory: ~/.config/gtk-3.0/settings.ini by adding gtk-modules=colorreload-gtk-module to it, so now you have to comment it out or delete it. After that restart your session.
Ok, but that is Qt related , not GTK as the first one. That means you actually did not install the manjaro-xfce-settings and you did not copy all the content, including hidden files and folders from /etc/skel to your home directory, to have the proper xfce manjaro tweaks and settings. You still have the KDE Plasma defaults from the manjaro-kde-settings
If you install that package and create a test user, you will see that the login in that user will be more coherent. To go manually over each file, you can do that but do not expect much of holding hand, as there are quite a few files to review …
