When I open system settings and click on Kernel system settings crashes and when I say crashes it disappears from the screen.
Hi @MAYBL8,
Please open it from a terminal with the command:
systemsettings
…and provide any output it provides when you do that and this happens.
Hope you manage!
[demo@manjaro ~]$ systemsettings
(process:3705): GLib-GObject-WARNING **: 10:28:09.248: cannot register existing type 'PamacSnapPlugin'
(process:3705): GLib-GObject-CRITICAL **: 10:28:09.248: g_type_interface_add_prerequisite: assertion 'G_TYPE_IS_INTERFACE (interface_type)' failed
(process:3705): GLib-CRITICAL **: 10:28:09.248: g_once_init_leave: assertion 'result != 0' failed
(process:3705): GLib-GObject-CRITICAL **: 10:28:09.248: g_type_add_interface_static: assertion 'g_type_parent (interface_type) == G_TYPE_INTERFACE' failed
(process:3705): GLib-GObject-WARNING **: 10:28:09.255: cannot register existing type 'PamacFlatpakPlugin'
(process:3705): GLib-GObject-CRITICAL **: 10:28:09.255: g_type_interface_add_prerequisite: assertion 'G_TYPE_IS_INTERFACE (interface_type)' failed
(process:3705): GLib-CRITICAL **: 10:28:09.255: g_once_init_leave: assertion 'result != 0' failed
(process:3705): GLib-GObject-CRITICAL **: 10:28:09.255: g_type_add_interface_static: assertion 'g_type_parent (interface_type) == G_TYPE_INTERFACE' failed
Segmentation fault (core dumped)
Thank you! Now let’s hope the smart people sees it, because I see it and I’m completely lost…
Here is my system info if that helps:
[demo@manjaro ~]$ inxi --admin --verbosity=7 --filter --width
Kernel: 6.0.6-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-6.0-x86_64
root=UUID=45ca132d-4a37-4dc3-afa0-be2e80d6a4a2 rw quiet pci=nocrs
acpi=force "acpi_osi=Windows 2022" ibt=off
Desktop: KDE Plasma v: 5.26.2 tk: Qt v: 5.15.7 info: latte-dock
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Convertible System: HP product: HP Spectre x360 Convertible 15-df1xxx
v: N/A serial: <superuser required> Chassis: type: 31
Mobo: HP model: 863F v: 54.24 serial: <superuser required> UEFI: AMI
v: F.28 date: 07/14/2022
ID-1: BAT0 charge: 69.4 Wh (100.0%) condition: 69.4/69.4 Wh (100.0%)
volts: 13.0 min: 11.6 model: HP Primary type: Li-ion serial: <filter>
status: full cycles: 178
Device-1: hid-0018:04F3:2992.0003-battery model: ELAN2514:00 04F3:2992
serial: N/A charge: N/A status: N/A
RAM: total: 15.26 GiB used: 4.83 GiB (31.6%)
Info: model: Intel Core i7-10510U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check gen: core 10 level: v3 note: check
built: 2018 process: Intel 14nm family: 6 model-id: 0x8E (142)
stepping: 0xC (12) microcode: 0xF0
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 2892 high: 3100 min/max: 400/4900 scaling:
driver: intel_pstate governor: powersave cores: 1: 3009 2: 3037 3: 3093
4: 2514 5: 3000 6: 3100 7: 3086 8: 2300 bogomips: 36812
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand
rdseed rdtscp rep_good sdbg sep sgx smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: retbleed mitigation: Enhanced IBRS
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Hewlett-Packard
ports: active: eDP-1 empty: DP-1,DP-2 bus-ID: 00:02.0 chip-ID: 8086:9b41
class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX250] vendor: Hewlett-Packard
driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 520.xx+
status: current (as of 2022-10) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 4 bus-ID: 3b:00.0
chip-ID: 10de:1d13 class-ID: 0302
Device-3: Chicony HP Wide Vision FHD Camera type: USB driver: uvcvideo
bus-ID: 1-5:3 chip-ID: 04f2:b67b class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1016x571mm (40.00x22.48")
s-diag: 1165mm (45.88")
Monitor-1: eDP-1 mapped: eDP-1-1 model: AU Optronics 0x30eb built: 2017
res: 3840x2160 hz: 60 dpi: 284 gamma: 1.2 size: 344x193mm (13.54x7.6")
diag: 394mm (15.5") ratio: 16:9 modes: 3840x2160
API: OpenGL v: 4.6.0 NVIDIA 520.56.06 renderer: NVIDIA GeForce
MX250/PCIe/SSE2 direct render: Yes
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Hewlett-Packard
driver: sof-audio-pci-intel-cnl
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
chip-ID: 8086:02c8 class-ID: 0401
Sound API: ALSA v: k6.0.6-2-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.59 running: yes
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
Local Storage: total: 931.51 GiB used: 261.75 GiB (28.1%)
model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
rev: 2B2QEXM7 temp: 40.9 C scheme: GPT
ID-1: / raw-size: 239 GiB size: 234.94 GiB (98.30%) used: 47.66 GiB (20.3%)
fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8 label: N/A
uuid: 45ca132d-4a37-4dc3-afa0-be2e80d6a4a2
used: 68.8 MiB (71.6%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 6865-B8CE
ID-3: /home raw-size: 415.57 GiB size: 407.98 GiB (98.17%)
used: 214.02 GiB (52.5%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
label: home uuid: 1f7a0eb8-f3e9-46ef-a88a-e3ae0ed0233d
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 529 MiB fs: ntfs label: Recovery
uuid: 28C6655CC6652AF0
ID-2: /dev/nvme0n1p11 maj-min: 259:9 size: 16 GiB fs: swap label: N/A
uuid: 1b9cd8e2-756a-4a24-9641-d3cdd3bed29a
ID-3: /dev/nvme0n1p12 maj-min: 259:10 size: 3 MiB fs: ufs label: N/A
uuid: 6354a81a1b0b8929
ID-4: /dev/nvme0n1p3 maj-min: 259:3 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-5: /dev/nvme0n1p4 maj-min: 259:4 size: 219.37 GiB fs: ntfs label: N/A
uuid: EAEA681CEA67E375
ID-6: /dev/nvme0n1p5 maj-min: 259:5 size: 961 MiB fs: ntfs label: N/A
uuid: 863E127D3E126709
ID-7: /dev/nvme0n1p6 maj-min: 259:6 size: 40 GiB fs: ext4 label: rootMX21
uuid: ae691757-a5f4-43d3-9580-0da970b5827f
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-1:2 info: Elan Micro Wireless Keyboard type: Keyboard,Mouse
power: 100mA chip-ID: 04f3:01a4 class-ID: 0301
Device-2: 1-5:3 info: Chicony HP Wide Vision FHD Camera type: Video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA
Device-3: 1-9:4 info: Synaptics type: <vendor specific> driver: N/A
interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 06cb:00bb
class-ID: ff00 serial: <filter>
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 48.0 C pch: 45.0 C mobo: N/A gpu: nvidia temp: 55 C
Processes: 250 Uptime: 48m wakeups: 772 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: 1714 pm: pacman pkgs: 1708 libs: 490 tools: pamac,pikaur,yay
pm: flatpak pkgs: 6 pm: snap pkgs: 0 Shell: Bash v: 5.1.16
running-in: konsole inxi: 3.3.23
you again… your system is messed up…
and what is this parameter?:
it should be like this:
acpi_osi='Windows 2022'
In trying to get bluetooth working on this laptop I was instructed on this site to use that statement.
I updated from what I was told to match the current version of Windows that is on this system.
Okay I might have read it wrong.
Let me fix it.
This is what it shows without me changing anything
GRUB_CMDLINE_LINUX_DEFAULT="quiet pci=nocrs acpi=force acpi_osi='Windows 2022' ibt=off"
this looks ok, you can save it, and update grub:
sudo update-grub
did that
Rebooted
Still same issue
(process:1896): GLib-GObject-WARNING **: 14:37:40.924: cannot register existing type 'PamacSnapPlugin'
(process:1896): GLib-GObject-CRITICAL **: 14:37:40.924: g_type_interface_add_prerequisite: assertion 'G_TYPE_IS_INTERFACE (interface_type)' failed
(process:1896): GLib-CRITICAL **: 14:37:40.924: g_once_init_leave: assertion 'result != 0' failed
(process:1896): GLib-GObject-CRITICAL **: 14:37:40.924: g_type_add_interface_static: assertion 'g_type_parent (interface_type) == G_TYPE_INTERFACE' failed
(process:1896): GLib-GObject-WARNING **: 14:37:40.931: cannot register existing type 'PamacFlatpakPlugin'
(process:1896): GLib-GObject-CRITICAL **: 14:37:40.931: g_type_interface_add_prerequisite: assertion 'G_TYPE_IS_INTERFACE (interface_type)' failed
(process:1896): GLib-CRITICAL **: 14:37:40.931: g_once_init_leave: assertion 'result != 0' failed
(process:1896): GLib-GObject-CRITICAL **: 14:37:40.931: g_type_add_interface_static: assertion 'g_type_parent (interface_type) == G_TYPE_INTERFACE' failed
that parameter is not likely related to this issue, i just noticed it…
just to check, post output from:
grep CMDLINE /etc/default/grub
and with the system settings, i told you in the another thread with the python issues that your system is messed up…
do you have installed these plugins?
[demo@manjaro ~]$ grep CMDLINE /etc/default/grub
#GRUB_CMDLINE_LINUX="cryptdevice=UUID=0bfed5f2-15d2-4371-8c86-968ce79f3f57:cryptroot"
I browsed with pacman gui but it didn’t show those packages
How do I check for plugins?
And I’m sure my system was messed up but I thought with the steps we took before we fixed things.
I know I didn’t reinstall everything but I haven’t ran every application and every option in every application.
Please don’t give up on me.
I am trying to do the right thing.
check with:
pacman -Qs 'libpamac-flatpak-plugin|libpamac-snap-plugin'
no, we didnt fixed it, as you can see… but i dont think that now even the reinstall would help haha
[demo@manjaro ~]$ pamac -Qs 'libpamac-flatpak-plugin|libpamac-snap-plugin'
Available actions:
pamac --version
pamac --help, -h [action]
pamac search [options] <package(s)>
pamac list [options] <package(s)>
pamac info [options] <package(s)>
pamac install [options] <package(s)>
pamac reinstall [options] <package(s)>
pamac remove [options] [package(s)]
pamac checkupdates [options]
pamac update,upgrade [options]
pamac clone [options] <package(s)>
pamac build [options] [package(s)]
pamac clean [options]
sorry, wrong command:
and the crash happens only when you click on the kernel option?
[demo@manjaro ~]$ pacman -Qs 'libpamac-flatpak-plugin|libpamac-snap-plugin'
local/libpamac-flatpak-plugin 11.4.1-1
Flatpak plugin for Pamac
local/libpamac-snap-plugin 11.4.1-1
Snap plugin for Pamac
I haven’t clicked every option but that one for sure.
so check the options… but it looks like the system settings are not the issue, but pamac is…
reinstall them and see if there are any errors:
sudo pacman -S libpamac-flatpak-plugin libpamac-snap-plugin
With those plugins installed it causes the issue.
I removed both of those and it is working correctly.
To my knowledge I don’t use flatpaks or snaps.
I might have played around with some snaps in the past but nothing as of now that I know of.
So you got me curious and I clicked on Hardware configuration and it just displayed a black screen
Never mind clicked on it a second time and it worked.
