Hi Manjaro, spectacle does not work nicely when I’ve the “default” application style breeze. It works ok with another application style, like oxygen or even kvantum. This is what I experience:
- run spectacle
- select a region
- if in the newly opened window containig the screenshot, you click on “new screenshot” no pulldown menu appear. If I change the application style (in kde/system setting) the pulldown menu appears
If I look into journalctl -b at the bottom I see a lot of messages like:
Aug 03 18:42:57 manjaro-imac kwin_wayland_wrapper[871]: radeon: The kernel rejected CS, see dmesg for more information (-22).
Aug 03 18:42:57 manjaro-imac kernel: radeon 0000:01:00.0: evergreen_surface_check_linear_aligned:216 texture pitch 312 invalid must be aligned with 64
Aug 03 18:42:57 manjaro-imac kernel: radeon 0000:01:00.0: evergreen_cs_track_validate_texture:831 texture invalid 0x04dc0981 0x1000007f 0x060a0000 0x00000000 0x00000000 0x80>
ifI look into dmesg I get the same 2nd and 3rd lines above
inxi:
Kernel: 6.18.39-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.1.1
parameters: root=UUID=dcd2885d-ae78-4f92-b3e7-c8507caef8a3 rw quiet
splash udev.log_priority=3 initrd=boot\initramfs-6.18-x86_64.img
Desktop: KDE Plasma v: 6.7.3 tk: Qt v: N/A info: frameworks v: 6.28.0
wm: kwin_wayland vt: 2 dm: N/A Distro: Manjaro base: Arch Linux
Type: Desktop System: Apple product: iMac12,1 v: 1.0
serial: <superuser required> Chassis: type: 13 v: Mac-942B5BF58194151B
Mobo: Apple model: Mac-942B5BF58194151B serial: <superuser required>
uuid: <superuser required> Firmware: UEFI vendor: Apple v: 87.0.0.0.0
date: 06/14/2019
System RAM: total: 12 GiB available: 11.65 GiB used: 3.71 GiB (31.8%)
Array-1: capacity: 16 GiB slots: 4 modules: 4 EC: None
max-module-size: 4 GiB note: est.
Device-1: DIMM0 type: DDR3 detail: synchronous size: 2 GiB
speed: 1333 MT/s volts: N/A width: N/A manufacturer: 0x02FE
part-no: 0x45424A3231554538424655302D444A2D4620 serial: <filter>
Device-2: DIMM0 type: DDR3 detail: synchronous size: 2 GiB
Device-3: DIMM1 type: DDR3 detail: synchronous size: 4 GiB
speed: 1333 MT/s volts: N/A width: N/A manufacturer: 0x80CE
part-no: 0x4D34373142353237334348302D4348392020 serial: <filter>
Device-4: DIMM1 type: DDR3 detail: synchronous size: 4 GiB
Info: model: Intel Core i5-2400S bits: 64 type: MCP arch: Sandy Bridge
gen: core 2 level: v2 built: 2010-12 process: Intel 32nm family: 6
model-id: 0x2A (42) stepping: 7 microcode: 0x2F
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 smt: <unsupported> cache:
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1600 min/max: 1600/3300 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 1600 2: 1600 3: 1600 4: 1600 bogomips: 20000
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts ept est
flexpriority flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce
md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdtscp rep_good
sep smx ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology
xtpr
disabled
STIBP: disabled; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
affected
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
driver: i915 v: kernel arch: Gen-6 code: Sandybridge process: Intel 32nm
built: 2011 ports: active: none empty: VGA-1 bus-ID: 00:02.0
chip-ID: 8086:0102 class-ID: 0380
Device-2: Advanced Micro Devices [AMD/ATI] Whistler [Radeon HD
6630M/6650M/6750M/7670M/7690M] vendor: Apple driver: radeon v: kernel
alternate: amdgpu arch: TeraScale-2 code: Evergreen process: TSMC 32-40nm
built: 2009-15 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 ports: active: eDP-1
empty: DP-1, DP-2, DP-3, VGA-2 bus-ID: 01:00.0 chip-ID: 1002:6741
class-ID: 0300
Device-3: Apple FaceTime HD Camera (Built-in) driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:3 chip-ID: 05ac:850b
Display: wayland server: X.org v: 1.21.1.24 with: Xwayland v: 24.1.13
compositor: kwin_wayland driver: X: loaded: modesetting,radeon
alternate: fbdev,vesa dri: r600,crocus gpu: radeon display-ID: 0
Monitor-1: eDP-1 model: Apple iMac built: 2010 res: mode: 1920x1080 hz: 60
scale: 100% (1) dpi: 103 gamma: 1.2 chroma: red: x: 0.655 y: 0.333 green:
x: 0.298 y: 0.620 blue: x: 0.145 y: 0.047 white: x: 0.314 y: 0.329
size: 475x267mm (18.7x10.51") diag: 545mm (21.5") ratio: 16:9
modes: 1920x1080
API: EGL v: 1.5 hw: drv: intel crocus drv: amd r600 platforms: device: 0
drv: r600 device: 1 drv: crocus device: 2 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: r600 wayland: drv: r600 x11: drv: r600
API: OpenGL v: 4.6 compat-v: 3.3 vendor: mesa v: 26.1.5-arch1.1 glx-v: 1.4
direct-render: yes renderer: AMD TURKS (DRM 2.51.0 / 6.18.39-1-MANJARO)
device-ID: 1002:6741 memory: 500 MiB unified: no display-ID: :0.0
de: kscreen-console,kscreen-doctor gpu: radeontop wl: wayland-info
x11: xdpyinfo, xprop, xrandr
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1c20
class-ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] Turks HDMI Audio [Radeon HD
6500/6600 / 6700M Series] vendor: Apple driver: snd_hda_intel v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aa90
class-ID: 0403
API: ALSA v: k6.18.39-1-MANJARO status: kernel-api tools: N/A
Server-3: PipeWire v: 1.6.8 status: active with: 1: pipewire-pulse
Device-1: Broadcom NetXtreme BCM57765 Gigabit Ethernet PCIe driver: tg3
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 02:00.0
chip-ID: 14e4:16b4 class-ID: 0200
IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Qualcomm Atheros AR93xx Wireless Network Adapter
vendor: Apple AirPort Extreme driver: ath9k v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:0030 class-ID: 0280
IF: wlp3s0 state: down mac: <filter>
IF-ID-1: wg0-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
IP v4: <filter> scope: global
Device-1: Apple Built-in Bluetooth 2.0+EDR HCI driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1.1.1:6
chip-ID: 05ac:8215 class-ID: fe01 serial: <filter>
Device-1: luks_home maj-min: 253:0 type: LUKS dm: dm-0 size: 273.36 GiB
Components:
p-1: sda8 maj-min: 8:8 size: 273.37 GiB
Device-2: luks2_Media maj-min: 253:1 type: LUKS dm: dm-1 size: 1.3 TiB
Components:
p-1: sdb1 maj-min: 8:17 size: 1.3 TiB
Local Storage: total: 2.27 TiB used: 988.12 GiB (42.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST3500418AS
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: AP2A scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: ST2000LM003 HN-M201RAD
size: 1.82 TiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: HDD rpm: 5400
serial: <filter> fw-rev: 1153 scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRW GA32N rev: KE06
dev-links: cdrom
rw: cd-r,cd-rw,dvd-r state: running
ID-1: / raw-size: 48.83 GiB size: 47.76 GiB (97.81%) used: 28.29 GiB (59.2%)
fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: Manjaro
uuid: dcd2885d-ae78-4f92-b3e7-c8507caef8a3
ID-2: /boot/efi raw-size: 200 MiB size: 196.9 MiB (98.44%)
used: 34.6 MiB (17.6%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: EFI
uuid: 2860-11F4
ID-3: /home raw-size: 273.36 GiB size: 268.89 GiB (98.36%)
used: 145.37 GiB (54.1%) fs: ext4 dev: /dev/dm-0 maj-min: 253:0
mapped: luks_home label: N/A uuid: N/A
ID-4: /run/media/redmanjaro/Media raw-size: 1.3 TiB
size: 1.27 TiB (98.35%) used: 814.42 GiB (62.4%) fs: ext4 dev: /dev/dm-1
maj-min: 253:1 mapped: luks2_Media label: N/A uuid: N/A
ID-1: /dev/sda2 maj-min: 8:2 size: 93.94 GiB fs: cs_fvault2 label: N/A
uuid: 87aeccd7-cb94-4f39-98bb-942c9cfaa3c9
ID-2: /dev/sda3 maj-min: 8:3 size: 619.9 MiB fs: hfsplus
label: Recovery HD uuid: 9db3ecb9-8192-3e57-99bd-5a2711e45985
ID-3: /dev/sda5 maj-min: 8:5 size: 48.83 GiB fs: ext4 label: rootMX25
uuid: d22d3f57-0440-4190-a428-e72091abf0ca
Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 1.1
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 1d6b:0001
Hub-2: 2-0:1 info: full speed or root hub ports: 8 rev: 2.0
Hub-3: 2-1:2 info: Microchip (formerly SMSC) USB 2.0 Hub ports: 4 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 2mA
chip-ID: 0424:2514 class-ID: 0900
Device-1: 2-1.1:3 info: Apple Internal Memory Card Reader
type: mass storage driver: usb-storage interfaces: 1 rev: 2.0
chip-ID: 05ac:8403 class-ID: 0806 serial: <filter>
Device-2: 2-1.2:4 info: Apple Built-in IR Receiver type: HID
driver: appleir,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 100mA chip-ID: 05ac:8242 class-ID: 0300
Hub-4: 3-0:1 info: full speed or root hub ports: 6 rev: 2.0
Hub-5: 3-1:2 info: Microchip (formerly SMSC) USB 2.0 Hub ports: 3 rev: 2.0
Hub-6: 3-1.1:4 info: Broadcom BCM2046B1 USB 2.0 Hub (part of BCM2046
Bluetooth) ports: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
chip-ID: 0a5c:4500 class-ID: 0900
Device-1: 3-1.1.1:6 info: Apple Built-in Bluetooth 2.0+EDR HCI
type: bluetooth driver: btusb interfaces: 4 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 05ac:8215
Device-2: 3-1.2:5 info: LaCie Rugged THB USB 3.0 type: mass storage
driver: uas interfaces: 1 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 059f:1075 class-ID: 0806 serial: <filter>
Device-3: 3-1.3:7 info: Logitech Logi Bolt Receiver
type: keyboard,mouse,HID driver: hid-generic,hid-multitouch,usbhid
interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 98mA chip-ID: 046d:c548 class-ID: 0300
Device-4: 3-2:3 info: Apple FaceTime HD Camera (Built-in) type: video
driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 05ac:850b class-ID: 0e02
serial: <filter>
Hub-7: 4-0:1 info: full speed or root hub ports: 2 rev: 1.1
System Temperatures: cpu: 54.0 C mobo: N/A
Fan Speeds (rpm): cpu: 1198
Packages: 1376 pm: pacman pkgs: 1369 libs: 352 tools: octopi,pamac,yay
pm: flatpak pkgs: 7
1: https://mirror.rabisu.com/mirrors/manjaro/stable/$repo/$arch
2: https://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
3: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
4: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
5: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
6: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
7: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 261
1: cpu: 100% command: ps pid: 37157 mem: 3.70 MiB (0.0%)
2: cpu: 17.0% command: ./mullvadbrowser.real pid: 35683
mem: 464.2 MiB (3.8%)
3: cpu: 12.3% command: mullvadbrowser.real pid: 35931
mem: 296.0 MiB (2.4%)
4: cpu: 4.2% command: mullvadbrowser.real pid: 35935 mem: 327.5 MiB (2.7%)
5: cpu: 2.4% command: audiotube pid: 34124 mem: 465.1 MiB (3.8%)
Memory top: 5 of 261
1: mem: 573.1 MiB (4.8%) command: thunderbird pid: 4934 cpu: 0.1%
2: mem: 465.1 MiB (3.8%) command: audiotube pid: 34124 cpu: 2.4%
3: mem: 464.2 MiB (3.8%) command: ./mullvadbrowser.real pid: 35683
cpu: 17.0%
4: mem: 462.6 MiB (3.8%) command: plasmashell pid: 1001 cpu: 0.2%
5: mem: 327.5 MiB (2.7%) command: mullvadbrowser.real pid: 35935 cpu: 4.2%
Processes: 261 Power: uptime: 1d 20h 25m states: freeze,mem,disk
suspend: deep avail: s2idle wakeups: 2 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 4.61 GiB
services: org_kde_powerdevil,upowerd Init: systemd v: 261
Compilers: gcc: 16.1.1 Shell: Bash v: 5.3.15 default: Zsh v: 5.9.2
running-in: konsole inxi: 3.3.41
