KDE : problem suspend/resume
Hello everybody,
For 10 days now, my laptop has problem to suspend and to resume.
Autologin is enable.
So, i start the computer, everything is ok, plasma starts and i can work normally.
If i press the “suspend” button or if i write in a console “systemctl suspend”, screen hangs and i only have the white arrow cursor which is still moving. After 2 mins, session is suspended.
When i hit the power button to resume, i still have the freezed screen with the cursor.
If i start the laptop, log out from plasma and press the “suspend button” from the sddm screen, suspend/resume works !!!
I reinstalled Manjaro. Suspend/resume worked. I updated and rebooted, and suspend/resume stopped to work.
I think it’s a plasma related problem, so, how can i fix it ?
inxi --full --admin --filter --width        
  Kernel: 6.9.12-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.9-x86_64
    root=UUID=f226db87-3fc9-4c89-bd63-4be26a7528a3 rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.4.0
  Type: Laptop System: HP product: HP EliteBook Folio 1040 G3 v: N/A
  Mobo: HP model: 80FA v: KBC Version 01.74 serial: <superuser required>
    part-nu: M5R96AV uuid: <superuser required> UEFI: HP v: N83 Ver. 01.59
    date: 12/15/2022
  ID-1: BAT0 charge: 32.7 Wh (87.9%) condition: 37.2/45.8 Wh (81.1%)
    volts: 11.7 min: 11.4 model: Hewlett-Packard Primary type: Li-ion
    serial: <filter> status: discharging cycles: 227
  Info: model: Intel Core i5-6200U bits: 64 type: MT MCP arch: Skylake
    gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
    model-id: 0x4E (78) stepping: 3 microcode: 0xF0
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 800 min/max: 400/2800 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 19204
  Type: gather_data_sampling status: Vulnerable: No microcode
    vulnerable
  Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Hewlett-Packard
    driver: i915 v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports:
    active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
    chip-ID: 8086:1916 class-ID: 0300
  Device-2: Cheng Uei Precision Industry (Foxlink) HP HD Camera
    driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
    bus-ID: 1-9:4 chip-ID: 05c8:0386 class-ID: 0e02 serial: <filter>
  Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.1
    compositor: kwin_wayland driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: 0
  Monitor-1: eDP-1 res: 2560x1440 size: N/A modes: N/A
    drv: iris x11: drv: iris
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.1.5-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 520 (SKL GT2)
    device-ID: 8086:1916 memory: 3.73 GiB unified: yes display-ID: :1.0
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
    driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_soc_avs
    bus-ID: 00:1f.3 chip-ID: 8086:9d70 class-ID: 0403
  API: ALSA v: k6.9.12-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.2 status: active with: 1: pipewire-pulse
  Device-1: Intel Ethernet I219-V vendor: Hewlett-Packard driver: e1000e
    v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:1570 class-ID: 0200
  IF: enp0s31f6 state: down mac: <filter>
  Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:24f3 class-ID: 0280
  Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:2 chip-ID: 8087:0a2b
    class-ID: e001
  Local Storage: total: 238.47 GiB used: 11.73 GiB (4.9%)
  ID-1: /dev/sda maj-min: 8:0 vendor: LITE-ON model: CV5-8Q256-HP
    size: 238.47 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: V581 scheme: GPT
  ID-1: / raw-size: 238.17 GiB size: 233.38 GiB (97.99%) used: 11.73 GiB (5.0%)
    fs: ext4 dev: /dev/sda2 maj-min: 8:2
    used: 296 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  System Temperatures: cpu: 41.0 C pch: 32.5 C mobo: N/A
  Fan Speeds (rpm): N/A
  Memory: total: 8 GiB available: 7.64 GiB used: 2.39 GiB (31.3%)
  Processes: 221 Power: uptime: 0m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 3.04 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Packages: pm: pacman pkgs: 1222 libs: 353 tools: pamac,yay pm: flatpak
    pkgs: 0 Compilers: gcc: 14.1.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.26
    running-in: konsole inxi: 3.3.35
journalctl -b -1 -g suspend        
août 08 06:28:21 jejelitebook sddm[520]: Message received from greeter: Suspend
août 08 06:28:21 jejelitebook systemd-logind[457]: The system will suspend now!
août 08 06:28:21 jejelitebook ModemManager[494]: <msg> [sleep-monitor-systemd] system is about to suspend
août 08 06:28:21 jejelitebook systemd[1]: Starting System Suspend...
août 08 06:28:21 jejelitebook systemd-sleep[2315]: Performing sleep operation 'suspend'...
août 08 06:28:21 jejelitebook kernel: PM: suspend entry (deep)
août 08 06:28:29 jejelitebook kernel: printk: Suspending console(s) (use no_console_suspend to debug)
août 08 06:28:30 jejelitebook kernel: PM: suspend exit
août 08 06:28:29 jejelitebook systemd-sleep[2315]: System returned from sleep operation 'suspend'.
août 08 06:28:29 jejelitebook systemd[1]: systemd-suspend.service: Deactivated successfully.
août 08 06:28:29 jejelitebook systemd[1]: Finished System Suspend.
août 08 06:28:29 jejelitebook systemd[1]: Reached target Suspend.
août 08 06:28:29 jejelitebook systemd-logind[457]: Operation 'suspend' finished.
août 08 06:28:29 jejelitebook systemd[1]: Stopped target Suspend.
août 08 06:28:57 jejelitebook kded6[2491]: kscreen.kded: PowerDevil SuspendSession action not available!
août 08 06:29:10 jejelitebook systemd-logind[457]: The system will suspend now!
août 08 06:29:10 jejelitebook ModemManager[494]: <msg> [sleep-monitor-systemd] system is about to suspend
août 08 06:29:11 jejelitebook systemd[1]: Starting System Suspend...
août 08 06:30:11 jejelitebook systemd-sleep[2921]: Performing sleep operation 'suspend'...
août 08 06:30:11 jejelitebook kernel: PM: suspend entry (deep)
août 08 06:30:26 jejelitebook kernel: printk: Suspending console(s) (use no_console_suspend to debug)
août 08 06:30:27 jejelitebook kernel: PM: suspend exit
août 08 06:30:26 jejelitebook systemd-sleep[2921]: System returned from sleep operation 'suspend'.
août 08 06:30:26 jejelitebook systemd[1]: systemd-suspend.service: Deactivated successfully.
août 08 06:30:26 jejelitebook systemd[1]: Finished System Suspend.
août 08 06:30:26 jejelitebook systemd[1]: Reached target Suspend.
août 08 06:30:26 jejelitebook systemd-logind[457]: Operation 'suspend' finished.
août 08 06:30:26 jejelitebook systemd[1]: Stopped target Suspend.
A little swap is always better than none, see → Swap - Manjaro
I cannot say what causes this - but as you state
At the basic level the kernel is responsible for the power state
I suspect ther may be a glitch with the synced kernel build - I cannot say for sure - but I suspect.
The kernel you are using is EOL, it will soon be removed, within 2-4 weeks it depends.
See → [Stable Update] 2024-08-08 - Kernels, Nvidia, Mesa, AMDVLK, Firefox, Thunderbird, Pipewire, Wine - #2 by philm
My suggestion is to sync the latest 6.10 kernel
sudo mhwd-kernel -i linux610
EDIT:
For the sake of verification - I have tested a KDE on bare metal using the same software level as you do and I cannot reproduce your issue.
System used for verification is
  Host: clevo Kernel: 6.9.12-1-MANJARO arch: x86_64 bits: 64 compiler: gcc
    v: 14.1.1 clocksource: tsc
  Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A wm: kwin_x11 vt: 2 dm: SDDM
  Type: Laptop System: Notebook product: N14xWU v: N/A
    serial: <superuser required> Chassis: No Enclosure type: 10
  Mobo: Notebook model: N14xWU serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends v: 1.07.21
    date: 09/24/2019
  ID-1: BAT0 charge: 28.5 Wh (88.0%) condition: 32.4/35.3 Wh (91.6%)
    volts: 12.2 min: 11.4 model: Notebook BAT type: Li-ion serial: 0001
    status: not charging
  Info: quad core model: Intel Core i7-8550U bits: 64 type: MT MCP
    smt: enabled arch: Coffee Lake rev: A cache: L1: 256 KiB L2: 1024 KiB
    L3: 8 MiB
  Speed (MHz): avg: 899 high: 2796 min/max: 400/4000 cores: 1: 800 2: 800
    3: 400 4: 800 5: 400 6: 400 7: 800 8: 2796 bogomips: 32012
  Device-1: Intel UHD Graphics 620 vendor: CLEVO/KAPOK driver: i915 v: kernel
    arch: Gen-9.5 ports: active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2
    bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
  Device-2: Chicony USB2.0 Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 bus-ID: 1-4:2 chip-ID: 04f2:b649 class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.1
    compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: :0 screens: 1
    s-diag: 582mm (22.93") monitors: <missing: xrandr>
  Monitor-1: eDP-1 model: AU Optronics 0x403d res: 1920x1080 dpi: 158
    size: 309x173mm (12.17x6.81") diag: 354mm (13.9") modes: 1920x1080
    device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
    inactive: wayland
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 620 (KBL
    GT2) device-ID: 8086:5917
  API: Vulkan v: 1.3.279 layers: N/A surfaces: xcb,xlib device: 0
    type: integrated-gpu driver: mesa intel device-ID: 8086:5917
  Device-1: Intel Sunrise Point-LP HD Audio vendor: CLEVO/KAPOK
    driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:9d71
    class-ID: 0403
    type: oss-emulator
  Server-1: JACK v: 1.9.22 status: off
    vendor: CLEVO/KAPOK driver: r8169 v: kernel pcie: speed: 2.5 GT/s lanes: 1
    port: e000 bus-ID: 3a:00.1 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp58s0f1 state: down mac: 80:fa:5b:60:c4:53
  Device-2: Intel Wi-Fi 5 Wireless-AC 9x6x [Thunder Peak] driver: iwlwifi
    v: kernel pcie: speed: 5 GT/s lanes: 1 bus-ID: 3b:00.0 chip-ID: 8086:2526
    class-ID: 0280
  IF: wlp59s0 state: down mac: 1e:8a:2b:95:88:25
  Device-3: ASIX AX88179 Gigabit Ethernet driver: cdc_ncm type: USB rev: 3.2
    speed: 5 Gb/s lanes: 1 bus-ID: 2-1:2 chip-ID: 0b95:1790 class-ID: 0a00
    serial: 0097E316
  IF: enp0s20f0u1c2 state: up speed: 1000 Mbps duplex: half
    mac: 20:7b:d2:97:e3:16
  Device-1: Intel Wireless-AC 9260 Bluetooth Adapter driver: btusb v: 0.8
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 bus-ID: 1-5:3 chip-ID: 8087:0025
    class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 4 state: up address: see --recommends
  Local Storage: total: 2.04 TiB used: 7.43 GiB (0.4%)
  ID-1: /dev/sda vendor: OCZ model: AGILITY3 size: 223.57 GiB
    speed: 6.0 Gb/s tech: SSD serial: OCZ-0DIEL1YFNWZ3UPC2 fw-rev: 2.25
    scheme: GPT
  ID-2: /dev/sdb vendor: Samsung model: PSSD T7 Shield size: 1.82 TiB
    type: USB rev: 3.2 spd: 10 Gb/s lanes: 1 tech: SSD serial: S6YKNJ0W401770D
    scheme: GPT
  ID-1: / size: 201.93 GiB used: 7.43 GiB (3.7%) fs: ext4 dev: /dev/sda2
  ID-2: /boot/efi size: 299.4 MiB used: 296 KiB (0.1%) fs: vfat
    dev: /dev/sda1
  System Temperatures: cpu: 52.0 C pch: 43.0 C mobo: N/A
  Memory: total: 16 GiB available: 15.49 GiB used: 1.13 GiB (7.3%)
  Processes: 272 Power: uptime: 19m states: freeze,mem,disk suspend: deep
    wakeups: 3 hibernate: platform Init: systemd v: 256 default: graphical
  Packages: pm: pacman pkgs: 1088 Compilers: N/A Shell: Zsh v: 5.9
    default: Bash v: 5.2.26 running-in: konsole inxi: 3.3.35
I already updated the kernel before reinstalling : i even tried an old kernel in 5.something.
And since suspend/resume works when plasma is not started, as i already said, i think it’s plasma related.
I have tested with Plasma as well - clicking the Sleep button in the menu.
I have tested using terminal systemctl suspend and systemctl sleep where the latter only triggers what ever is available - starting with suspend - hibernate - of course - does not work as there is no swap registered.
All in all - cannot reproduce the issue.
The only thing I have not tested is using autologin.
So I suggest you try disabling autologin - restart - then see if you still can trigger the issue.
If it is plasma related - then it is local to your system - as the journal on my system also shows a similar powerdevil message → see https://0x0.st/XV3m.txt
The Archlinux wiki has some clues:
https://wiki.archlinux.org/title/Power_management/Suspend_and_hibernate
In addition, here is an old but still good article how to debug suspend issues:
Same problem with another computer
I installed Gnome on the first laptop, suspend/resume works perfectly
inxi --full --admin --filter --width         22 ✘
  Kernel: 6.10.3-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.10-x86_64
    root=UUID=098045f6-9a29-4560-a5b6-54bedb929e7a rw quiet splash
    udev.log_priority=3
  Type: Laptop System: LENOVO product: 20N8000RFR v: ThinkPad E490
  Mobo: LENOVO model: 20N8000RFR v: SDK0J40697 WIN
    serial: <superuser required> part-nu: LENOVO_MT_20N8_BU_SMB_FM_ThinkPad E490
    uuid: <superuser required> UEFI: LENOVO v: R0YET46W (1.29 )
    date: 10/09/2020
  ID-1: BAT0 charge: 31.4 Wh (82.8%) condition: 37.9/45.7 Wh (82.9%)
    power: 8.3 W volts: 11.6 min: 11.1 model: SMP 01AV447 type: Li-poly
    serial: <filter> status: discharging cycles: 264
  Info: model: Intel Core i5-8265U bits: 64 type: MT MCP
    arch: Comet/Whiskey Lake note: check gen: core 8 level: v3 note: check
    built: 2018 process: Intel 14nm family: 6 model-id: 0x8E (142)
    stepping: 0xC (12) microcode: 0xFA
    L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 578 high: 900 min/max: 400/3900 scaling:
    driver: intel_pstate governor: powersave cores: 1: 899 2: 900 3: 400 4: 400
    5: 832 6: 400 7: 400 8: 400 bogomips: 28808
  Type: retbleed mitigation: Enhanced IBRS
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
    RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
  Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Lenovo
    ports: active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
    chip-ID: 8086:3ea0 class-ID: 0300
  Device-2: Chicony Integrated Camera (1280x720@30) driver: uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3
    chip-ID: 04f2:b604 class-ID: 0e02 serial: <filter>
  Monitor-1: eDP-1 res: 1920x1080 size: N/A modes: N/A
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 620 (WHL GT2)
    device-ID: 8086:3ea0 memory: 3.65 GiB unified: yes display-ID: :1.0
  API: Vulkan v: 1.3.279 layers: N/A device: 0 type: integrated-gpu
    name: Intel UHD Graphics 620 (WHL GT2) driver: mesa intel
    v: 24.1.5-manjaro1.1 device-ID: 8086:3ea0 surfaces: xcb,xlib,wayland
  Device-1: Intel Cannon Point-LP High Definition Audio vendor: Lenovo
    driver: snd_hda_intel v: kernel alternate: snd_soc_skl, snd_soc_avs,
    snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:9dc8 class-ID: 0403
  API: ALSA v: k6.10.3-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.2 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Server-3: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
    vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 2000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp4s0 state: down mac: <filter>
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 05:00.0
    chip-ID: 8086:2526 class-ID: 0280
  IF: wlp5s0 state: up mac: <filter>
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:2
    chip-ID: 8087:0025 class-ID: e001
  Local Storage: total: 238.47 GiB used: 32 GiB (13.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN520
    SDAPMUW-256G-1001 size: 238.47 GiB block-size: physical: 512 B
    logical: 512 B speed: 15.8 Gb/s lanes: 2 tech: SSD serial: <filter>
    fw-rev: 20370001 temp: 30.9 C scheme: GPT
  ID-1: / raw-size: 238.17 GiB size: 233.38 GiB (97.99%) used: 32 GiB (13.7%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  System Temperatures: cpu: 42.0 C pch: 36.0 C mobo: N/A
  Fan Speeds (rpm): fan-1: 0 fan-2: 0
  Memory: total: 8 GiB available: 7.48 GiB used: 2.8 GiB (37.4%)
  Processes: 258 Power: uptime: 2m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 2.98 GiB services: org_kde_powerdevil,
    tool: systemctl
  Packages: pm: pacman pkgs: 1417 libs: 378 tools: pamac,yay pm: flatpak
    pkgs: 0 Compilers: clang: 18.1.8 gcc: 14.1.1 Shell: Zsh v: 5.9
