KDE Plasma Wayland Notifications/Startmenu/Tooltips wrong position after update
Hello, after today’s update, under KDE Plasma Wayland all notifications appear in the upper left corner of the main screen (I have a 2 monitors setup) although they are set to lower right. The menu X and application launcher (start menu) also appear in the upper left corner of the main screen also the start menu of the 2nd screen appears there. All tolltips from the systremtray icons appear at the top of the screen(see screenshots).
This was not the case before today’s update.
  Host: Manjaro Kernel: 5.18.14-1-MANJARO arch: x86_64 bits: 64
    Desktop: KDE Plasma v: 5.24.6 Distro: Manjaro Linux
  Type: Desktop Mobo: Micro-Star model: MPG X570 GAMING PLUS (MS-7C37) v: 2.0
    serial: <superuser required> UEFI: American Megatrends LLC. v: A.H0
    date: 05/19/2022
  Info: 8-core model: AMD Ryzen 7 3700X bits: 64 type: MT MCP cache:
    L2: 4 MiB
  Speed (MHz): avg: 2875 min/max: 2200/4426 cores: 1: 3119 2: 2967 3: 2069
    4: 2491 5: 2857 6: 4106 7: 2121 8: 3420 9: 3054 10: 2122 11: 2096 12: 3482
    13: 2346 14: 4156 15: 2108 16: 3501
  Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
    driver: amdgpu v: kernel
  Display: wayland server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3
    compositor: kwin_wayland driver: X: loaded: amdgpu
    unloaded: modesetting,radeon gpu: amdgpu resolution: 1: 2560x1440
    2: 1920x1080
  OpenGL: renderer: AMD Radeon RX 5700 XT (navi10 LLVM 14.0.6 DRM 3.46
    5.18.14-1-MANJARO) v: 4.6 Mesa 22.1.4
  Device-1: Creative Labs Sound Core3D [Sound Blaster Recon3D / Z-Series]
    driver: snd_hda_intel
  Device-2: AMD Navi 10 HDMI Audio driver: snd_hda_intel
  Device-3: AMD Starship/Matisse HD Audio driver: snd_hda_intel
  Device-4: DCMT USB Condenser Microphone type: USB
    driver: hid-generic,snd-usb-audio,usbhid
  Device-5: Kingston HyperX 7.1 Audio type: USB
  Sound Server-1: ALSA v: k5.18.14-1-MANJARO running: yes
  Sound Server-3: PipeWire v: 0.3.56 running: yes
    driver: r8168
  IF: enp39s0 state: up speed: 1000 Mbps duplex: full
    mac: xxx
    driver: btusb
  Local Storage: total: 7.5 TiB used: 2.37 TiB (31.6%)
  ID-1: /dev/sda vendor: Samsung model: SSD 840 EVO 250GB size: 232.89 GiB
  ID-2: /dev/sdb vendor: Samsung model: SSD 860 EVO 1TB size: 931.51 GiB
  ID-3: /dev/sdc vendor: Seagate model: ST2000LX001-1RG174 size: 1.82 TiB
  ID-4: /dev/sdd vendor: Western Digital model: WD40EZRZ-00GXCB0
  ID-5: /dev/sde vendor: Samsung model: HD103UJ size: 931.51 GiB
  ID-1: / size: 491.08 GiB used: 118.19 GiB (24.1%) fs: ext4 dev: /dev/sdb1
  ID-2: /boot/efi size: 96 MiB used: 25.9 MiB (27.0%) fs: vfat
    dev: /dev/sda1
  ID-3: /home size: 1.92 TiB used: 1.56 TiB (81.2%) fs: ext4 dev: /dev/sdd3
  System Temperatures: cpu: 37.0 C mobo: 32.0 C gpu: amdgpu temp: 51.0 C
  Fan Speeds (RPM): fan-1: 746 fan-2: 1685 fan-3: 670 fan-4: 0 fan-5: 444
    fan-6: 466 fan-7: 0 gpu: amdgpu fan: 1006
  Processes: 404 Uptime: 9m Memory: 31.27 GiB used: 5.26 GiB (16.8%)
  Shell: fish inxi: 3.3.20
Same here. I have 2 monitors, menu and taskbar on right monitor (my main monitor), but both appears on left corner of left monitor. Except this visual change, everything works correctly.
Same problem here. I’m also on Wayland.
I have 2 monitors and my task bar is vertical on the left side of the left (main) monitor.
Since this morning, the last update seem to work perfectly except for the position on the monitor of the menu and the notification. They appear on the top left. of my second monitor.
No idea how to fix it.
Thx
There is some discussion in the stable update thread saying this is due to Wayland.
KDE, Wayland. One monitor 1920x1080, menu and all notifications show up on the top-left corner of my screen. need a solution, please.
I found a workaround, shared it in the update thread.
Hello,
I’m facing issue here after update, KDE Plasma Menu is now placed wrongly in the middle of desktop.
  Kernel: 5.18.14-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.18-x86_64
    root=UUID=69678a39-1940-48ee-8d02-88e765985137 rw rootflags=subvol=@ quiet
    apparmor=1 security=apparmor
    resume=UUID=b136d668-4460-4cf7-9211-93b9a5283ab3 udev.log_priority=3
  Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_wayland vt: 2
  Type: Desktop Mobo: N/A model: X99 serial: <superuser required>
    UEFI: American Megatrends v: 5.11 date: 07/30/2021
  RAM: total: 15.53 GiB used: 2.07 GiB (13.4%)
  RAM Report: permissions: Unable to run dmidecode. Root privileges
    required.
  Info: model: Intel Xeon E5-2640 v3 bits: 64 type: MT MCP arch: Haswell
    built: 2013-15 process: Intel 22nm family: 6 model-id: 0x3F (63) stepping: 2
    microcode: 0x49
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB desc: 8x256 KiB
    L3: 20 MiB desc: 1x20 MiB
  Speed (MHz): avg: 1388 high: 2743 min/max: 1200/3400 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 1412 2: 1198 3: 1197
    4: 2743 5: 1197 6: 1199 7: 1197 8: 1198 9: 1502 10: 1451 11: 1198 12: 1849
    13: 1197 14: 1198 15: 1197 16: 1287 bogomips: 83046
  Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
    bts clflush cmov constant_tsc cpuid cpuid_fault cqm cqm_llc cqm_occup_llc
    cx16 cx8 dca de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c
    flexpriority flush_l1d fma fpu fsgsbase fxsr ht ibpb ibrs ida intel_ppin
    invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe msr
    pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good sdbg sep smep smx
    ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
    tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt
    xtopology xtpr
    vulnerable
  Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
    vendor: Micro-Star MSI driver: amdgpu v: kernel arch: GCN-4
    code: Arctic Islands process: GF 14nm built: 2016-20 pcie: gen: 3
    speed: 8 GT/s lanes: 16 ports: active: DVI-D-1 empty: DP-1, DP-2, DP-3,
    HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:67df class-ID: 0300
    alternate: fbdev,vesa gpu: amdgpu display-ID: 0
  Monitor-1: DVI-D-1 res: 1920x1080 size: N/A modes: N/A
  OpenGL: renderer: AMD Radeon RX 570 Series (polaris10 LLVM 14.0.6 DRM 3.46
    5.18.14-1-MANJARO) v: 4.6 Mesa 22.1.4 direct render: Yes
  Device-1: Intel 8 Series/C220 Series High Definition Audio
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
    class-ID: 0403
  Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
    vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:aaf0 class-ID: 0403
  Sound Server-4: PipeWire v: 0.3.56 running: yes
    driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
    bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: virbr0 state: down mac: <filter>
  Local Storage: total: 2.73 TiB used: 1.74 TiB (63.8%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD Blue
    SN570 500GB size: 465.76 GiB block-size: physical: 512 B logical: 512 B
    speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 234100WD
    temp: 32.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Western Digital
    model: WDS500G2B0C-00PXH0 size: 465.76 GiB block-size: physical: 512 B
    rev: 233010WD temp: 30.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Western Digital
    model: WD20PURZ-85GU6Y0 size: 1.82 TiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
    rev: 0A80 scheme: MBR
  ID-1: / raw-size: 448.38 GiB size: 448.38 GiB (100.00%) used: 209.92 GiB
    (46.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2 label: LINUX
    uuid: 69678a39-1940-48ee-8d02-88e765985137
  ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 568 KiB
    (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: NO_LABEL
    uuid: CDC5-157E
  ID-3: /home raw-size: 448.38 GiB size: 448.38 GiB (100.00%) used: 209.92
    GiB (46.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2 label: LINUX
  ID-4: /home/<filter>/GAMES raw-size: 465.76 GiB size: 457.38 GiB (98.20%)
    used: 38.02 GiB (8.3%) fs: ext4 dev: /dev/nvme1n1p1 maj-min: 259:5
    label: GAMES uuid: 9467047a-a0d0-46ff-859d-67a1bfff2456
  ID-5: /home/<filter>/HDD-2TB raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
    used: 1.5 TiB (83.8%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: 2TB-EXT4
    uuid: b9d4d0f9-d1ce-425d-8fe4-e2f830005289
  ID-6: /var/cache raw-size: 448.38 GiB size: 448.38 GiB (100.00%)
    used: 209.92 GiB (46.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    label: LINUX uuid: 69678a39-1940-48ee-8d02-88e765985137
  ID-7: /var/log raw-size: 448.38 GiB size: 448.38 GiB (100.00%) used: 209.92
  ID-1: swap-1 type: partition size: 17.09 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
    uuid: b136d668-4460-4cf7-9211-93b9a5283ab3
  Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
    speed: 480 Mb/s chip-ID: 8087:8008 class-ID: 0900
  Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
    speed: 480 Mb/s chip-ID: 8087:8000 class-ID: 0900
  Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-7:2 info: Pixart Imaging Optical Mouse type: Mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
    power: 100mA chip-ID: 093a:2521 class-ID: 0301
  Device-2: 3-8:3 info: SINO WEALTH USB KEYBOARD type: Keyboard,HID
    power: 100mA chip-ID: 258a:0001 class-ID: 0300
  Hub-6: 4-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 26.0 C mobo: N/A gpu: amdgpu temp: 51.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 185
  Processes: 379 Uptime: 4m wakeups: 0 Init: systemd v: 251 default: graphical
  tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6 Packages: 1525
  pacman: 1503 lib: 418 flatpak: 22 Shell: Zsh v: 5.9 default: Bash v: 5.1.16
  running-in: konsole inxi: 3.3.20
Try to delete KDE menu, then add the same KDE menu.
An update to qt5-wayland has landed that fixes the issue. Update your Manjaro and no workaround is needed.
Thank, mine was fixed with the updated.
Fixed for me after the minor update of Qt5
thx
