KDE Plasma Task switcher not showing window previews
Hi Y’all!
This is just a minor annoyance, not actually a problem.
Since switching to Wayland, everything worked just fine on x11, since switching my Task Switcher (Alt + Tab) becomes broken. In the sense that just after login it’s working perfectly, but as the session goes on the Task Switcher loses its window previews. This happens:
https://i.imgur.com/lB1ZrDk.png
And it happens with all the switchers,that supports the window previews, not just “Cover Switch”:
https://i.imgur.com/IpVYE04.png
This is obviously not a deal-breaker, but it is something I’d like to get sorted out. Does anybody have any ideas how to fix it, or what causes it, or something in that regard.
I’m afraid I cannot reproduce it. It works fine here. :man_shrugging:
Lucky you! So then I guess it’s something local to me. But what it could be, I have no idea.
Have you tried logging out and back in?
Not specifically for this, but even rebooting. It’s always the same, just tested again:
upon re-login, everything works hunky-dory:
https://i.imgur.com/s06Tsre.png
But then, either after some time has passed, or after I’ve done something unknown to me, the above happens.
That sounds like a process that has crashed. But it’s not kwin, because you still have task switching. :thinking:
Yeah. It’s confusing as heck!
I can’t reproduce it either. No that I use ALT + Tab as a rule, but I’ve not notice any degradation of Previews.
I’m not saying it’s related, but your profile shows that you’re using an Nvidia GPU with the proprietary driver. :thinking:
Yup. I think I want to get an Intel Arc or AMD, but this is what my wife bought when I still used Windows and getting Nvidia was a no-brainer.
I’ve come to my senses since, thank goodness.
Yeah, I realize this is local, but I don’t know where to look or which files top inspect/delete. I’m still looking.
I’m starting to suspect it only happens when I save/saved a setting, because I’ve gone through not one, but two suspend-resume cycles and it still works.
Edit:
Just tested by changing settings, even window behavior settings, and nope. 'is still hanging in there.
Edit #2:
Just tested all the Switchers installed, and all working perfectly!
Conclusion: gremlins in deh circuitry.
Edit #3:
The final one.
Welp, it’s been roughly a day or more since I last played with the Task Switcher, and I’ve had 0 (zero) problems since. Confirming that it was something local, leading me to one of two explanations:
  1. When I changes the Switcher to a different one and back it “reset” the configuration. I don’t know if this is something that could’ve been influenced by the upgrade from Plasma 5 to 6, but it seems likely.
  2. Gremlins with mischievous magic.
So far I’m putting my money on #2.
