KDE plasma system settings blank
Hello!
I opened my system settings today and got greeted with the error message “No items matching your search”, in place of all KDEs settings, even though I have not searched anything.
Opening a setting from plasma search does not work (leads to the same screen as above) but shortcuts under “Frequently used” still work, although navigation on the left side shows the same.
The last thing I did that I believe probably could have caused this is switching branches to testing, realizing that it bricked my laptop, and restoring from a timeshift BTRFS snapshot.
Opening settings from the terminal produces the following:
e@c ~> systemsettings5        16:32
qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
I am running on wayland, but could reproduce it in xorg with no console errors.
System stuff:
Xini output:
  Kernel: 5.14.10-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.14-x86_64
  root=UUID=55b69f83-4501-4bee-bf12-cb6b55804409 rw rootflags=subvol=@ quiet
  apparmor=1 security=apparmor
  resume=UUID=eddfbad1-cabd-4bf7-91a8-ff93ff73ed06 udev.log_priority=3
  nvidia-drm.modeset=1
  Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_wayland vt: 2 dm: SDDM
  Type: Laptop System: LENOVO product: 20V3 v: Lenovo ThinkBook 15p
  serial: <filter> Chassis: type: 10 v: Lenovo ThinkBook 15p serial: <filter>
  Mobo: LENOVO model: LNVNB161216 v: SDK0J40697 WIN serial: <filter>
  UEFI: LENOVO v: F6CN18WW date: 12/21/2020
  ID-1: BAT0 charge: 51.7 Wh (100.0%) condition: 51.7/57.0 Wh (90.7%)
  volts: 12.9 min: 11.5 model: SMP L19M3PD9 type: Li-poly serial: <filter>
  status: Full cycles: 208
  RAM: total: 15.5 GiB used: 2.57 GiB (16.6%)
  Info: Quad Core model: Intel Core i5-10300H bits: 64 type: MT MCP
  arch: Comet Lake family: 6 model-id: A5 (165) stepping: 2 microcode: EA
  cache: L2: 8 MiB bogomips: 40009
  Speed: 800 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
  4: 800 5: 800 6: 799 7: 800 8: 800
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
  arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
  cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
  est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window
  hwp_epp hwp_notify ibpb ibrs ibrs_enhanced intel_pt invpcid invpcid_single
  lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl
  nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt
  pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse
  sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust
  xsaves xtopology xtpr
  Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Lenovo driver: i915
  v: kernel bus-ID: 00:02.0 chip-ID: 8086:9bc4 class-ID: 0300
  Device-2: NVIDIA TU117M vendor: Lenovo driver: nvidia v: 470.63.01
  alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1f99
  class-ID: 0300
  Device-3: IMC Networks Integrated Camera type: USB driver: uvcvideo
  bus-ID: 1-6:5 chip-ID: 13d3:56ff class-ID: 0e02
  Display: wayland server: X.Org 1.21.1.2 compositor: kwin_wayland driver:
  loaded: modesetting unloaded: nvidia alternate: fbdev,nouveau,nv,vesa
  display-ID: :1 screens: 1
  Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.0x11.2")
  s-diag: 1055mm (41.5")
  Monitor-1: XWAYLAND0 res: 1920x1080 hz: 60 dpi: 143
  size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
  Monitor-2: XWAYLAND3 res: 1920x1080 hz: 50 dpi: 96
  size: 510x290mm (20.1x11.4") diag: 587mm (23.1")
  OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.2.3
  direct render: Yes
  Device-1: Intel Comet Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
  chip-ID: 8086:06c8 class-ID: 0403
  Device-2: NVIDIA driver: snd_hda_intel v: kernel bus-ID: 01:00.1
  chip-ID: 10de:10fa class-ID: 0403
  Sound Server-1: ALSA v: k5.14.10-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.38 running: yes
  Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
  bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
  IP v6: <filter> type: noprefixroute scope: global
  vendor: Lenovo driver: r8169 v: kernel port: 3000 bus-ID: 0c:00.0
  IF: enp12s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  bus-ID: 1-14:6 chip-ID: 8087:0026 class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
  Local Storage: total: 476.94 GiB used: 90.53 GiB (19.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZALQ512HALU-000L2
  lanes: 4 type: SSD serial: <filter> rev: AL2QFXV7 temp: 26.9 C scheme: GPT
  ID-1: / raw-size: 459.59 GiB size: 459.59 GiB (100.00%)
  used: 90.53 GiB (19.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  label: N/A uuid: 55b69f83-4501-4bee-bf12-cb6b55804409
  used: 568 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  label: NO_LABEL uuid: 6C6D-4B0D
  ID-3: /home raw-size: 459.59 GiB size: 459.59 GiB (100.00%)
  ID-4: /run/timeshift/backup raw-size: 459.59 GiB size: 459.59 GiB (100.00%)
  ID-5: /var/cache raw-size: 459.59 GiB size: 459.59 GiB (100.00%)
  ID-6: /var/log raw-size: 459.59 GiB size: 459.59 GiB (100.00%)
  ID-1: swap-1 type: partition size: 17.05 GiB used: 0 KiB (0.0%) priority: -2
  dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
  uuid: eddfbad1-cabd-4bf7-91a8-ff93ff73ed06
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
  Hub-2: 1-1:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  power: 100mA chip-ID: 05e3:0610 class-ID: 0900
  Device-1: 1-1.4:4 info: Trust B.V. Optical Mouse type: Mouse
  driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
  power: 100mA chip-ID: 15d9:0a4f class-ID: 0301
  Device-2: 1-4:3 info: Elan Micro ELAN:Fingerprint type: <vendor specific>
  driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
  chip-ID: 04f3:0c57 class-ID: 0000
  Device-3: 1-6:5 info: IMC Networks Integrated Camera type: Video
  Device-4: 1-14:6 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
  interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
  class-ID: e001
  Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 44.0 C mobo: N/A
  Processes: 268 Uptime: 15m wakeups: 1 Init: systemd v: 249 tool: systemctl
  Compilers: gcc: 11.1.0 Packages: 1564 pacman: 1540 lib: 390 flatpak: 24
  Shell: fish v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.08
Journald logs (from KSystemlog):
On settings open (I had already opened it a few times before):
06.11.21 16:37	plasmashell	qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
06.11.21 16:37	plasmashell	kf.plasma.quick: Couldn't create KWindowShadow for PlasmaQuick::Dialog_QML_216(0x5589763359d0, name="popupWindow")
06.11.21 16:37	plasmashell	libpng warning: iCCP: known incorrect sRGB profile
06.11.21 16:37	plasmashell	QProcess::start: Process is already running
06.11.21 16:37	systemd	Started System Settings - System Settings.
06.11.21 16:37	xdg-desktop-portal-kde	xdp-kde-wayland-integration: Adding output:
06.11.21 16:37	xdg-desktop-portal-kde	xdp-kde-wayland-integration:     manufacturer:  "LG Display"
06.11.21 16:37	xdg-desktop-portal-kde	xdp-kde-wayland-integration:     model:  "eDP-1-unknown"
06.11.21 16:37	xdg-desktop-portal-kde	xdp-kde-wayland-integration:     resolution:  QSize(1920, 1080)
06.11.21 16:37	xdg-desktop-portal-kde	xdp-kde-wayland-integration:     manufacturer:  "AOC"
06.11.21 16:37	xdg-desktop-portal-kde	xdp-kde-wayland-integration:     model:  "2360/ACNE99A00178"
06.11.21 16:37	systemsettings5	qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
I also found something crashing on logon (may be unrelated):
06.11.21 16:25	sddm	Message received from greeter: Connect
06.11.21 16:25	sddm-greeter	Loading file:///usr/share/sddm/themes/breath2/Main.qml...
06.11.21 16:25	systemd-coredump	Process 2866 (xdg-desktop-por) of user 1000 dumped core.
Found module linux-vdso.so.1 with build-id: e816248c0af862094290c3aba368ce81d17fed89
Found module libuuid.so.1 with build-id: 832a09e0d9568cc6dbe699472218ea2f79dc0f34
Found module libxcb-util.so.1 with build-id: 4188ebc629b472b560849c5792a69c1803c3d1a4
Found module libxkbcommon-x11.so.0 with build-id: 821e1e75e92f3aaa96d19ed31fe98dbbd4d34627
Found module libICE.so.6 with build-id: af53458a64fe1e62a4d95606f7b03c210b2b098c
Found module libSM.so.6 with build-id: ac7b055fd3f16b4f29373285ab04ed52eebb632d
Found module libxcb-xinput.so.0 with build-id: 6403174c48f05f40cf7c168beb86f2886b9f09c1
Found module libxcb-xkb.so.1 with build-id: fce20d2101f3e5439923e9283c489c2cad4420c3
Found module libxcb-xinerama.so.0 with build-id: b328103ce7502d94fd3a4e2e8773978a9aa84adc
Found module libxcb-xfixes.so.0 with build-id: a6b197ace5b9b59f913f5969eb419a88d1194f47
Found module libxcb-sync.so.1 with build-id: dda14591103b01b1311906053bf1ca9e82ade35c
Found module libxcb-shape.so.0 with build-id: f1b3376c4534fab0469feb1cd19f022ff98df533
Found module libxcb-render.so.0 with build-id: a37bdb37744b508be9dd29fd9ccb9bb0170d43e5
Found module libxcb-render-util.so.0 with build-id: c64fb28ea20a320a9754273d9ea3af85f6f74b17
Found module libxcb-randr.so.0 with build-id: b6c1c7d4b28863b55ade251813db7f246b7ffe8b
Found module libxcb-shm.so.0 with build-id: fb797f299a446f559a95afcc168227482cc800d1
Found module libxcb-image.so.0 with build-id: ee7f8577926fe7c1d6972036c2f8e6f727e43b1b
Found module libxcb-icccm.so.4 with build-id: 73f1e12d76af383aa969a60279ed5ed922045f47
Found module libX11-xcb.so.1 with build-id: 0db4f94d8ae31b8dc9a83f825a9171656f1e532c
Found module libQt5XcbQpa.so.5 with build-id: 1faa9fbbd961134122bbf8a60c0bf2b1e58bb216
Found module libqxcb.so with build-id: 840fc6ab5aef9669dfcbf5bd8a034f173cc8c0a2
Found module libbrotlicommon.so.1 with build-id: f68934f94312f770550ebc6c5acfd6359b098b07
Found module libexpat.so.1 with build-id: 8850138eae6d9d4d43c5c4b2ac48393bc4279037
Found module libgmp.so.10 with build-id: e58d34ab389d1b649c24195c2d145e3ff2e58290
Found module libhogweed.so.6 with build-id: 2d70cff7b1841b4d9ca4e8e7726cd4b944c07fdc
Found module libnettle.so.8 with build-id: 9a878e513c02007598fcf1e2e286c2203f13536e
Found module libunistring.so.2 with build-id: 015ac6d6bcb60b7d8bea31a80d1941b06e8636ab
Found module libidn2.so.0 with build-id: 1ce2b50ad9f9821c2c629b521cf5a3c99593d332
Found module libp11-kit.so.0 with build-id: 5314ec746546ada6f442b6fdfae15eab9f6d3cdc
Found module libgpg-error.so.0 with build-id: ba85170c2d9343ea05eea8fa2048c212ff4ef552
Found module libbrotlidec.so.1 with build-id: f871e6f204ab8d48099915126ba01be989a8000f
Found module libxkbcommon.so.0 with build-id: 1f1bc7527e57c886c3df5803068122e1971d4724
Found module libfontconfig.so.1 with build-id: 1103a641395c7d3b42e49b793d3a9ea927c77bf6
Found module libwayland-cursor.so.0 with build-id: a8b45436314425ee9a92efaff68bd2b79f870e77
Found module libresolv.so.2 with build-id: c915c72668282861a813f7ea3c0780f37b681dc0
Found module libkeyutils.so.1 with build-id: ac405ddd17be10ce538da3211415ee50c8f8df79
Found module libkrb5support.so.0 with build-id: adf65240a4d2aba772d7a0772b4d015469934113
Found module libcom_err.so.2 with build-id: eb61ef71c8b97846db759fb89a115405cff6dd30
Found module libk5crypto.so.3 with build-id: eb8220b8f36675aac769450be4cb6bb7f97ec38a
Found module libkrb5.so.3 with build-id: 72d26767c5cb1097db75a5f5bff88860233c902b
Found module libusbmuxd-2.0.so.6 with build-id: fd9f05e7f5b0da4e15972f75b61fd9b4b9f06dbe
Found module libtasn1.so.6 with build-id: 4df18bd1f13772f0956191e137eb00d9bd6238c5
Found module libgnutls.so.30 with build-id: 8c87466eacaec0041a370df713d0fd200358c94c
Found module libogg.so.0 with build-id: ca0cae30a809f10db1f16e54a23b4e5ff7b2c54c
Found module libvorbis.so.0 with build-id: ad0a6c1af8f219b4e314090b6e8847223d424cbe
Found module libbz2.so.1.0 with build-id: 919597c477c9b2cb9cdbb7745ed6494ac0e6da60
Found module libpcre.so.1 with build-id: 845483dd0acba86de9f0313102bebbaf3ce52767
Found module libicudata.so.69 with build-id: 0ab994a49ef1848499c4af333b3266f28432a922
Found module libgcrypt.so.20 with build-id: db45f5d5e0f7af1e77324fea1885f974619ad268
Found module libcap.so.2 with build-id: c1674f9082fedd415876b9f7d9712269163259b5
Found module liblz4.so.1 with build-id: e63600ab23b2f6997f42fac2fa56e1f02ce159a1
Found module liblzma.so.5 with build-id: 8b615460aa230708c5183f16bede67aa0437d95e
Found module librt.so.1 with build-id: 75484da2d6f1515189eefa076e0a40328834cd16
Found module libgraphite2.so.3 with build-id: 47761dc11e553f519cde97ed9ee985be12ccdae2
Found module libfreetype.so.6 with build-id: 65e7f4a1e5557b0ceeaa433e5356f857fe9c669b
Found module libGLX.so.0 with build-id: 0f40ceaa036edc65147e9559b94e0219472493fc
Found module libGLdispatch.so.0 with build-id: 195b34c1bb271f3b1162c897cfbcfb859e656b93
Found module libXdmcp.so.6 with build-id: 8ca0792d23c8b8b4c0864297512349292bea5955
Found module libXau.so.6 with build-id: 1c67764663e07bec24d8951e5fd93f4d165979ff
Found module libQt5WaylandClient.so.5 with build-id: d48cf656839904c81663681d9ab030810714bff7
Found module libcrypto.so.1.1 with build-id: 6d23f0a3f354825868d044684fad31d482cc9210
Found module libssl.so.1.1 with build-id: 959cd8f1dd43fc31aeb93caac4eda87c907ef18b
Found module libgssapi_krb5.so.2 with build-id: e6e098ad51ce7bdd3dbe902d7b0f69a90f8a9e08
Found module libplist-2.0.so.3 with build-id: b4dd02ee2d5938fd2bfa34070014f4d30a21abd6
Found module libimobiledevice-1.0.so.6 with build-id: b7197d5ba7e40162e4d3f4eb92b4b589b8e5fe1e
Found module libudev.so.1 with build-id: aca8577d374861da6157b28fc1990dccf99ba5c1
Found module libKF5GlobalAccel.so.5 with build-id: 265987e75a045e1eb0c354cdb673a91ce8a3c290
Found module libXi.so.6 with build-id: 16603be937a02a7e61b0b0395d064be7efd86f49
Found module libXext.so.6 with build-id: d70f24beb4fad748d6becffdcc13e51be0a2ebfa
Found module libltdl.so.7 with build-id: 64bc54a40a0b6e4209a2c712364b4ae653c3f5b2
Found module libtdb.so.1 with build-id: bec061530310665480ee91395b4eb0a937750a03
Found module libvorbisfile.so.3 with build-id: 0010b21da05e318b42e718d90738febf58028141
Found module libQt5Svg.so.5 with build-id: 926a697e0d991ee22ee414c13c9b75c253fc1d4d
Found module libKF5Archive.so.5 with build-id: 467c6c25626c9695553f13eddb7fce72fbbcae6c
Found module ld-linux-x86-64.so.2 with build-id: 040cc3dd10461562f177df39e3be2f3704258c3c
Found module libglib-2.0.so.0 with build-id: 1fe1592d097fa28822c23e96d9f357583b48424d
Found module libzstd.so.1 with build-id: 4b10444c1560ebc574af4d5f488b7408b22d450e
Found module libpcre2-16.so.0 with build-id: 983354d71426f38a37695490499fc89d050d7cc5
Found module libdl.so.2 with build-id: 5abc547e7b0949f89f3c0e21ab0c8331a7440a8a
Found module libicuuc.so.69 with build-id: 5cf18c56e2f64efdac32cf61fb9c0c48e9bb1797
Found module libicui18n.so.69 with build-id: 9cdecde5b2e47a2bd81dc14915cbfefcade76c12
Found module libdouble-conversion.so.3 with build-id: 5bffb4317594514068e082d4b4e9acd99987ec47
Found module libsystemd.so.0 with build-id: 58c6a86edd7f38011bd682024a3b53b8a963bd30
Found module libdbus-1.so.3 with build-id: 74f2ab9c60512f3a93c932c3f627564d42e0b11e
Found module libblkid.so.1 with build-id: f03a24e92c9852272bd0049b5bcb7ed6cf0e664f
Found module libmount.so.1 with build-id: ff9a1d99d35cf640d0bfdaba294854372672c29b
Found module libacl.so.1 with build-id: 35319ea4baa70564deddffb113c0961002bc394c
Found module libKF5AuthCore.so.5 with build-id: 371c3caa7e0ebbe205bff247efc254cef7702a15
Found module libKF5DBusAddons.so.5 with build-id: c9bc9df340b4d9506b9ddb1769d0da6b62d2c298
Found module libKF5Crash.so.5 with build-id: e971aff373671fdcdddc701a87d8abc24a64f6eb
Found module libmd4c.so.0 with build-id: 2151dba72cdc9960097e6e960a58a2f03c8bb96e
Found module libharfbuzz.so.0 with build-id: f954dfb80265c0dd2484e766282305a739b8239d
Found module libz.so.1 with build-id: 81bf6e728a6d6f5b105b0f8b25f6c614ce10452a
Found module libpng16.so.16 with build-id: 2dc0bce07f199bf983c07a05fb95a6f4af83a9b3
Found module libGL.so.1 with build-id: 8b3028bab286029945569a0dfcf695f0f61d9c3b
Found module libQt5QmlModels.so.5 with build-id: 6151af051434d5c08c002bbe0609df3e4d2e7d32
Found module libgcc_s.so.1 with build-id: 7f8508bb914546ada778809b64b99d234337d835
Found module libxcb-keysyms.so.1 with build-id: 333e5eb4075795f947c924a2085f17e2e2ae7147
Found module libxcb.so.1 with build-id: 0d1ef11740a5daad2ee331e812a51aa6574af222
Found module libm.so.6 with build-id: 2b8fd1f869ecab4e0b55e92f2f151897f6818acf
Found module libKF5KIOGui.so.5 with build-id: e6babe342f0b9016dac73a792b9862354b4137e9
Found module libQt5Xml.so.5 with build-id: ec415d2e364d2b174ad5f9813ab2926098221a37
Found module libKF5ConfigGui.so.5 with build-id: 8fd1d1fd2356943cb1749239824688aebac8c308
Found module libKF5Codecs.so.5 with build-id: 28880a4154f8a74dae5c254839c91cac1537b3ea
Found module libKF5GuiAddons.so.5 with build-id: af80033ed20c6c909932a298fd4ac97529a26e67
Found module libKF5ConfigWidgets.so.5 with build-id: 58a0a318df732745a8e4fe72dcd886251fe52eda
Found module libQt5Network.so.5 with build-id: 764d42df9642f3caea52448b11932f570ba357d6
Found module libKF5Completion.so.5 with build-id: 1b2d6afda6e7d7980ac80b3702c5de4cffe3f974
Found module libKF5JobWidgets.so.5 with build-id: db7a844750e469a3f1e210ed5b1c3fbe9d7a561b
Found module libKF5Solid.so.5 with build-id: c325dd5df82b59628f2b96145ce8cb6ba69adf88
Found module libKF5XmlGui.so.5 with build-id: 229cfbb6e9439e74e33f4b8b1c38610e936a1cd7
Found module libKF5Bookmarks.so.5 with build-id: 08739160e3ce71f2b79ec47898d0363ba166ec88
Found module libpthread.so.0 with build-id: 07c8f95b4f3251d08550217ad8a1f31066229996
Found module libffi.so.7 with build-id: de60e99f39569d11d09160bbdcd486cedc87d2b6
Found module libdbusmenu-qt5.so.2 with build-id: 82cbd5bfb1d800b5991deb040afbefec7b11fc81
Found module libXtst.so.6 with build-id: 96411faea62997274e362f263e65082e601a787b
Found module libQt5X11Extras.so.5 with build-id: e41614d2e35852f913bf00633d635cfbf5a90dce
Found module libX11.so.6 with build-id: e9192497aa39fab51358826d1a1b5fb77edc5081
Found module libQt5TextToSpeech.so.5 with build-id: 99b56b543380180d6f5c8c984f01d80487672cff
Found module libcanberra.so.0 with build-id: 379ed64f9d1408a83806cd5d94dc5bb903765615
Found module libKF5IconThemes.so.5 with build-id: 39da9cfa641a96c1b7644e4f8b95dc5c3e970cbf
Found module libKF5Package.so.5 with build-id: fbeb222dc2a3f0c648c442b5ff5f27ef33f459b9
Found module libc.so.6 with build-id: 4b406737057708c0e4c642345a703c47a61c73dc
Found module libstdc++.so.6 with build-id: 8ab0e57054dd1dcba681f217016afc6a4e639783
Found module libQt5Core.so.5 with build-id: 64315bf3c7e3c2dffa4cd71f908d5f98dc29d876
Found module libQt5DBus.so.5 with build-id: eec55e409fa44577508e4ea9512ecaa9bd668b65
Found module libKF5CoreAddons.so.5 with build-id: e5541dcd552110922c3181fe43b60a337dab9758
Found module libKF5I18n.so.5 with build-id: f46b822ad5705a692eadf4a60668872925cb69fe
Found module libKF5ConfigCore.so.5 with build-id: 3dbf42485a9c9eb2cac1c444b0925318153bef52
Found module libKF5Service.so.5 with build-id: 868f8462c22120853dad55dfe7f0fd2f3772521f
Found module libKF5KIOCore.so.5 with build-id: a483791605c17ec8c8eadb7cf59b46808ee48c79
Found module libQt5Qml.so.5 with build-id: 92006af8b04f29d7af10797e88969c614f450203
Found module libQt5Gui.so.5 with build-id: 0abf1d6cd108b3ee97d0f1d0bddb918bfd083352
Found module libQt5Quick.so.5 with build-id: 69525a381a38beecc12159340d46641bc8131c5c
Found module libQt5Widgets.so.5 with build-id: 7b1df52ee680499519fbfd11fd43ca8b3e2bc212
Found module libKF5WidgetsAddons.so.5 with build-id: 6dd6940a69a4f47ff20b5b4c4d04e575aae140f5
Found module libKF5ItemViews.so.5 with build-id: 84c3e8bb9ecf21b0aa8820e068f7b0901909a925
Found module libQt5PrintSupport.so.5 with build-id: f6633d0563fe75d1df1d4edd0b9ac25cf6aea7c8
Found module libKF5WindowSystem.so.5 with build-id: 4465afe9665b61e245c8dcffff5587a9d11c535b
Found module libKF5KIOWidgets.so.5 with build-id: b747a42d4e53baa2af4690217d7f8aad8ad017b5
Found module libKF5KIOFileWidgets.so.5 with build-id: 424c9ca8f75cb9792786c3c24bd76b31252102e2
Found module libQt5QuickWidgets.so.5 with build-id: 40ef5bd18aebd12c92e079995c988e63d5225f4b
Found module libwayland-client.so.0 with build-id: 58038363d7ea1fd5e6532f6e5f90b1a3ce09388a
Found module libKF5WaylandClient.so.5 with build-id: e507c814b8f28253281208693c91d5ddba8a5d80
Found module libKF5Notifications.so.5 with build-id: b7d727f31536ededd0d5ef18115bfaacc46874ea
Found module libKF5Declarative.so.5 with build-id: a25c4aaf57592b54101b7312f54fc7f3b0fac21f
Found module xdg-desktop-portal-kde with build-id: 3b887b81b6a16ab57703e7538b8afe4f633cd8bf
Stack trace of thread 2866:
#0  0x00007f78fb7dad22 raise (libc.so.6 + 0x3cd22)
#1  0x00007f78fb7c4862 abort (libc.so.6 + 0x26862)
#2  0x00007f78fbc1094e _ZNK14QMessageLogger5fatalEPKcz (libQt5Core.so.5 + 0x9094e)
#3  0x00007f78fcacbbf5 _ZN22QGuiApplicationPrivate25createPlatformIntegrationEv (libQt5Gui.so.5 + 0x130bf5)
#4  0x00007f78fcacc0e9 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt5Gui.so.5 + 0x1310e9)
#5  0x00007f78fbe49fbb _ZN23QCoreApplicationPrivate4initEv (libQt5Core.so.5 + 0x2c9fbb)
#6  0x00007f78fcacf0a7 _ZN22QGuiApplicationPrivate4initEv (libQt5Gui.so.5 + 0x1340a7)
#7  0x00007f78fd74871e _ZN19QApplicationPrivate4initEv (libQt5Widgets.so.5 + 0x16071e)
#8  0x00005642ddc790aa n/a (xdg-desktop-portal-kde + 0x210aa)
#9  0x00007f78fb7c5b25 __libc_start_main (libc.so.6 + 0x27b25)
#10 0x00005642ddc793de n/a (xdg-desktop-portal-kde + 0x213de)
06.11.21 16:25	audit	SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@1-2882-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
06.11.21 16:25	systemd	systemd-coredump@1-2882-0.service: Deactivated successfully.
06.11.21 16:25	org.freedesktop.impl.portal.desktop.kde	Invalid MIT-MAGIC-COOKIE-1 key
06.11.21 16:25	dbus-daemon	[session uid=1000 pid=968] Activated service 'org.freedesktop.impl.portal.desktop.kde' failed: Process org.freedesktop.impl.portal.desktop.kde received signal 6
06.11.21 16:25	sddm-greeter	QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7ffdb749a4a0), parent's thread is QThread(0x55ac8eb95e90), current thread is QThread(0x55ac8eca8dc0)
06.11.21 16:25	sddm-greeter	QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Any advice on what to do?
not sure about all the things … but lets start with:
sudo pacman-mirrors -g && sudo pacman -Syyu
(post output of final transactions and/or errors)
Hello!
pacman-mirrors seemed to go smoothly save for some of the mirrors throwing errors (I guess that is expected)
pacman on the other hand has a warning:
:: Synchronising package databases...
 core        170,3 KiB   511 KiB/s 00:00 [#######################################################################################] 100%
 extra        1900,2 KiB  20,6 MiB/s 00:00 [#######################################################################################] 100%
 community        6,8 MiB  31,3 MiB/s 00:00 [#######################################################################################] 100%
 multilib        175,2 KiB  7,44 MiB/s 00:00 [#######################################################################################] 100%
warning: archlinux-keyring: local (20211028-1) is newer than core (20210902-1)
 there is nothing to do
I had a few snapshots in a short amount of time and may have restored from the wrong one. (after switching branches I believe there were two seperate updates, one for the keyring, other for everything else, and I may have restored from the one after the keyring update)
Reverting the keyring with sudo pacman -Syyuu (and a restart) removed the error but plasma settings are still blank. So that may have been unrelated
The output now is
 core                                                              170,3 KiB  1703 KiB/s 00:00 [########################################################] 100%
 extra                                                            1900,2 KiB  21,6 MiB/s 00:00 [########################################################] 100%
 community                                                           6,8 MiB  31,1 MiB/s 00:00 [########################################################] 100%
 multilib                                                          175,2 KiB  8,56 MiB/s 00:00 [########################################################] 100%
uh … maybe you need to manually select a mirror because that appears woefully wrong.
(flag for pacman-mirrors is -i … and always at least -Syyu after mirror changes)
After re-pinging all the mirrors it presents me with a GUI:
How many/what countries should I select? Is “sync” important for me?
Update
Ok, I selected 3 or so that were close to me and had a low sync time, but the -syyu response did not change. Will try a restart and see if the settings fixed themselves
…aaand it did not
I’m still learning myself, but thought I’d throw an idea out there… that may be based on some assumptions on my end.
I don’t know how differently TimeShift with BTRFS works versus RSYNC (which I use), but I do recall in my case that the default for TimeShift was to not backup the HOME directory… which of course contains a lot of saved configs, etc.
In my case, I had installed BackInTime to manage my HOME backups separate from TimeShift.
I have 2 suggestions:
  1. Try restore a HOME folder backup (last known good prior to branch switch)… or if you don’t want to try that first…
  2. Try create and log into a new user account to see how things behave there… this way you’d have a better idea if it’s an issue with the environment/apps (borked for even a new user) or an issue with your profile/HOME (because everything looks fine under the new account) that could be fixed by restoring your backup of it prior to swapping branches
I’m not 100% sure, but I’m under the impression that a proper restore/overwrite of a HOME folder may include booting from a Live USB.
Could be config/cache related: did you check if this is affects a fresh user as well?
Try cleaning plasma cache: KDE - ArchWiki
Indeed, probably an issue with configs for new Plasma (from his testing branch switch), on his current old Plasma.
Totally forgot to update!
I created a new user, moved over all my files over, and deleted the old one. That resolved my issue.
I guess an alternative would be to either for me to keep home directory snapshots/backups and restore from that (I had my important folders deja-duped so I was not that concerned about data loss, but that means I could not recover with just that), or wait for the stable branch to catch up.
