Hi
After recent update I got yesterday 09/30/2022 I have this issue when running my laptop standalone, everything launches fine, but after connecting it to the dock with two other monitors, I’m getting stuck on the splash screen of Plasma. I have just the logo with the spinning gear icon. The gear is very laggy followed by my laptop fan turning at almost max speed.
If I switch to tty, I can run startx and I can get to the desktop, but that’s rather annoying and also if I try to restart the system, it puts me into an empty prompt on a screen, then it just hangs there.
If I boot the laptop with the laptop screen first and then connect the dock, everything also works as expected, the only thing this happens is when I’m trying to boot directly with the dock in.
I will provide any additional info if needed, since I can get in the DE, but I’d like to fix this somehow, so I don’t have to run startx every time.
brahma
30 September 2022 06:47
2
provide system info:
inxi -Faz
use formatting, click this icon in editor: </> and copy the output there
Kernel: 5.19.7-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.19-x86_64
root=UUID=d40f3104-bcff-40b6-bb35-abc247231d4f rw quiet apparmor=1
Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1
Type: Laptop System: HP product: HP ProBook 455 G7 v: N/A
Mobo: HP model: 8730 v: KBC Version 13.26.00 serial: <superuser required>
UEFI: HP v: S79 Ver. 01.08.20 date: 03/15/2022
ID-1: BAT0 charge: 35.9 Wh (99.4%) condition: 36.1/45.0 Wh (80.2%)
volts: 12.0 min: 11.4 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: not charging cycles: 9
Info: model: AMD Ryzen 5 4500U with Radeon Graphics bits: 64 type: MCP
arch: Zen 2 gen: 3 level: v3 built: 2020-22 process: TSMC n7 (7nm)
family: 0x17 (23) model-id: 0x60 (96) stepping: 1 microcode: 0x8600106
Topology: cpus: 1x cores: 6 smt: <unsupported> cache: L1: 384 KiB
desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1404 high: 1435 min/max: 1400/2375 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1403 2: 1397
3: 1435 4: 1397 5: 1397 6: 1400 bogomips: 28454
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Renoir vendor: Hewlett-Packard driver: amdgpu v: kernel
arch: GCN-5.1 code: Vega-2 process: TSMC n7 (7nm) built: 2018-21 pcie:
gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
active: DP-3,DP-4 off: eDP-1 empty: DP-1, DP-2, DP-5, HDMI-A-1
bus-ID: 05:00.0 chip-ID: 1002:1636 class-ID: 0300
Device-2: Lite-On HP HD Camera type: USB driver: uvcvideo bus-ID: 3-4:3
chip-ID: 04ca:7095 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
alternate: fbdev,vesa gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1167 s-dpi: 96 s-size: 1013x307mm (39.88x12.09")
s-diag: 1058mm (41.67")
Monitor-1: DP-3 mapped: DisplayPort-2 pos: bottom-l model: HP 23xi
serial: <filter> built: 2014 res: 1920x1080 hz: 60 dpi: 96 gamma: 1.2
size: 509x286mm (20.04x11.26") diag: 584mm (23") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
Monitor-2: DP-4 mapped: DisplayPort-3 pos: primary,top-right model: HP
P24h G4 serial: <filter> built: 2019 res: 1920x1080 dpi: 93 gamma: 1.2
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9 modes:
Monitor-3: eDP-1 mapped: eDP note: disabled model: LG Display 0x062e
built: 2019 res: 1920x1080 dpi: 142 gamma: 1.2
size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
OpenGL: renderer: AMD RENOIR (LLVM 14.0.6 DRM 3.47 5.19.7-1-MANJARO) v: 4.6
Mesa 22.1.7 direct render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 1-1.5:20 chip-ID: 0bda:4014 pcie:
class-ID: 0102 gen: 3 serial: <filter> speed: 8 GT/s lanes: 16 link-max:
gen: 4 speed: 16 GT/s bus-ID: 05:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Hewlett-Packard
driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x,
snd_pci_acp6x, snd_acp_pci, snd_sof_amd_renoir pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3
class-ID: 0403
Device-4: Realtek USB Audio type: USB driver: snd-usb-audio
Device-5: Focusrite-Novation Scarlett Solo USB type: USB
driver: snd-usb-audio bus-ID: 1-1.7:23 chip-ID: 1235:8205 class-ID: 0102
Device-6: Samson C01U Pro condenser microphone type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-3:2 chip-ID: 17a0:0303
class-ID: 0300
Sound Server-1: ALSA v: k5.19.7-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.57 running: yes
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp1s0 state: down mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:2723 class-ID: 0280
Device-3: Realtek RTL8153 Gigabit Ethernet Adapter type: USB
driver: r8152 bus-ID: 2-1.2:7 chip-ID: 0bda:8153 class-ID: 0000
serial: <filter>
IF: enp5s0f3u1u2 state: down mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-3:2 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 476.94 GiB used: 331.96 GiB (69.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba
model: KBG40ZNV512G KIOXIA size: 476.94 GiB block-size: physical: 512 B
rev: HP00AE00 temp: 56.9 C scheme: GPT
ID-1: / raw-size: 379.89 GiB size: 372.86 GiB (98.15%) used: 243.81 GiB
(65.4%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 44.7 MiB
(14.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 61.6 C mobo: N/A gpu: amdgpu temp: 46.0 C
Processes: 325 Uptime: 2h 38m wakeups: 2 Memory: 15.03 GiB used: 8.55 GiB
(56.9%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 alt: 11 clang: 14.0.6 Packages: 2125 pm: dpkg
pkgs: 0 pm: pacman pkgs: 2110 libs: 476 tools: pamac,yay pm: flatpak
pkgs: 6 pm: snap pkgs: 9 Shell: Zsh v: 5.9 default: Bash v: 5.1.16
running-in: yakuake inxi: 3.3.21
brahma
30 September 2022 06:51
4
did you try with different kernel, for example the 5.15 lts?
Can confirm this issue doesn’t occur with kernel 5.18.19-3-MANJARO I had previously. The system starts as expected while booting with this kernel
brahma
30 September 2022 07:00
6
so could be a kernel thing … however the 5.18 is going to be no longer supported - end of life… you could create a new test user, reboot select the 5.19 and login with the test user, to rule out that some plasma config is messing the things up with the 5.19
Now after a reboot, I can’t even run the system with the old kernel, nor I can create another account. The system always starts with my primary one and when I want to log out, or change user, it doesn’t show me anything at all. I might try to clear the plasma config to be sure it’s not just that.
brahma
30 September 2022 07:33
8
but you can boot with the 5.19 kernel, without the dock?
I’ve managed to boot without the dock, change the default user to log in to the testing account and it booted without an issue, so I suppose this might be caused by some messy config
brahma
30 September 2022 07:46
10
so if you booted with the dock normally with the test user, try resetting your plasma - go to system settings/global theme, click defaults, check desktop layout, click apply, then clear your cache:
rm -rf ~/.cache/*
reboot - you do this in your main user - and test if it helped …
if not, rename the .config folder to .config.bak, reboot and see if that helped - of course you do this on the main user
Thanks!
This ^ and also mv ~/.config/plasma-org.kde.plasma.desktop-appletsrc ~/.config/plasma-org.kde.plasma.desktop-appletsrc-old
Made the desktop functioning again. I need to readjust the panels, but that’s not that much work.
system
Closed
2 October 2022 22:01
12
