Hi guys!
With my new laptop HP Victus there are tons of issues unfortunately(bluetooth not working, screen flickering, audio ). Audio is not working. Sometimes it worked but after setting volume to 0 it stopped working. Would very glad if I get some help.
Kernel: 5.15.85-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64
root=UUID=196cf2fb-fd58-43a1-b4b4-fe7f9b5b35f3 rw rootflags=subvol=@ quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: HP product: Victus by HP Laptop 16-d1xxx v: N/A
Mobo: HP model: 8A26 v: 34.55 serial: <superuser required> UEFI: AMI
v: F.07 date: 04/20/2022
ID-1: BAT0 charge: 54.4 Wh (81.7%) condition: 66.6/70.1 Wh (95.0%)
volts: 17.4 min: 15.4 model: HP Primary type: Li-ion serial: <filter>
status: charging cycles: 4
Info: model: 12th Gen Intel Core i5-12500H bits: 64 type: MST AMCP
arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 3
microcode: 0x424
Topology: cpus: 1x cores: 12 mt: 4 tpc: 2 st: 8 threads: 16 smt: enabled
cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32 KiB, 8x64 KiB L2: 9 MiB
desc: 4x1.2 MiB, 2x2 MiB L3: 18 MiB desc: 1x18 MiB
Speed (MHz): avg: 668 high: 999 min/max: 400/4500:3300 scaling:
driver: intel_pstate governor: powersave cores: 1: 999 2: 838 3: 798 4: 823
5: 679 6: 856 7: 490 8: 588 9: 617 10: 619 11: 596 12: 575 13: 594 14: 601
15: 564 16: 451 bogomips: 99568
prctl and seccomp
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel Alder Lake-P Integrated Graphics vendor: Hewlett-Packard
driver: i915 v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+
ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1
bus-ID: 00:02.0 chip-ID: 8086:46a6 class-ID: 0300
Device-2: NVIDIA GA107M [GeForce RTX 3050 Ti Mobile]
vendor: Hewlett-Packard driver: nvidia v: 525.60.11
alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:25a0 class-ID: 0300
Device-3: Quanta HP Wide Vision HD Camera type: USB driver: uvcvideo
bus-ID: 3-6:2 chip-ID: 0408:5477 class-ID: fe01 serial: <filter>
Display: x11 server: X.Org v: 21.1.6 with: Xwayland v: 22.1.7
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia
unloaded: nouveau,vesa alternate: fbdev,nv dri: iris gpu: i915
display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: BOE Display 0x0aae built: 2021 res: 1920x1080
dpi: 137 gamma: 1.2 size: 355x200mm (13.98x7.87") diag: 407mm (16")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 22.3.1 renderer: Mesa Intel Graphics (ADL GT2)
direct render: Yes
Device-1: Intel Alder Lake PCH-P High Definition Audio
vendor: Hewlett-Packard driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:51c8 class-ID: 0401
Device-2: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:2291 class-ID: 0403
Sound API: ALSA v: k5.15.85-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.63 running: yes
Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
vendor: AzureWave driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s
lanes: 1 bus-ID: 05:00.0 chip-ID: 14c3:7961 class-ID: 0280
IF: wlp5s0 state: up mac: <filter>
vendor: Hewlett-Packard driver: r8168 v: 8.050.03-NAPI modules: r8169 pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 06:00.0
Device-1: IMC Networks Wireless_Device type: USB driver: btusb v: 0.8
bus-ID: 3-7:3 chip-ID: 13d3:3567 class-ID: e001 serial: <filter>
Report: bt-adapter ID: hci0 rfk-id: 1 state: up address: N/A
Local Storage: total: 238.47 GiB used: 14.75 GiB (6.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD PC
SN810 SDCPNRY-256G-1006 size: 238.47 GiB block-size: physical: 512 B
logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter>
rev: HPS2 temp: 30.9 C scheme: GPT
ID-1: / raw-size: 238.17 GiB size: 238.17 GiB (100.00%)
used: 14.75 GiB (6.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 608 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 238.17 GiB size: 238.17 GiB (100.00%)
ID-4: /var/log raw-size: 238.17 GiB size: 238.17 GiB (100.00%)
System Temperatures: cpu: 35.0 C mobo: N/A
Processes: 375 Uptime: 24m wakeups: 2104 Memory: 15.3 GiB
used: 3.03 GiB (19.8%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman
pkgs: 1231 libs: 323 tools: pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.24
