Hi,
for a few months now (can’t pinpoint the exact date) my up-to-date Manjaro with KDE plasma crashes randomly on harmless everyday actions: the screen goes black for a few seconds and I am presented the login screen.
This happens without any observable pattern, it can happen when simply double-clicking an image file, opening Dolphin, opening a YT video in a new Firefox tab or launching a game from Steam. It works n out of n+1 times, but then it doesn’t.
I have an Nvidia GPU installed, so after some googling I have tested adding (and removing) the flag “nvidia_drm.modeset=1” to the grub cmd without any noticeable effect.
AS suggested in other threads I have attached the output of " inxi -zav7
" and “journalctl --no-pager -p4 -b-0” (truncated at the beginning to not exceed the character limit).
Kernel: 6.6.54-2
KDE 6.6.0
Plasma: 6.1.5
Nvidia: 550.120
The most obvious error is
kernel: [drm:drm_new_set_master] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
Do you have any idea on how to prevent the crashes?
Inxi output:
Kernel: 6.6.54-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=915e20e5-3c7d-4fdd-89e4-898400ef1a1c rw nvidia_drm.modeset=1
resume=UUID=e00e0ab6-6611-48d8-aa55-02fc48975561 udev.log_priority=3
Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.6.0
Type: Desktop System: Gigabyte product: Z690 UD DDR4 v: N/A
serial: <superuser required>
Mobo: Gigabyte model: Z690 UD DDR4 v: x.x serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: F28
date: 12/14/2023
ID-1: hidpp_battery_0 charge: 100% condition: N/A volts: 4.2 min: N/A
model: Logitech G703 LIGHTSPEED Wireless Gaming Mouse w/ HERO type: N/A
serial: <filter> status: full
System RAM: total: 64 GiB available: 62.56 GiB used: 3.83 GiB (6.1%)
Device-1: DDR4-A1 type: no module installed
Device-2: DDR4-A2 type: DDR4 detail: synchronous size: 32 GiB speed:
spec: 2133 MT/s actual: 3200 MT/s volts: curr: 1.35 min: 1.35 max: 1.35
width (bits): data: 64 total: 64 manufacturer: Corsair
part-no: CMK64GX4M2E3200C16 serial: N/A
Device-3: DDR4-B1 type: no module installed
Device-4: DDR4-B2 type: DDR4 detail: synchronous size: 32 GiB speed:
Info: model: 12th Gen Intel Core i7-12700K bits: 64 type: MST AMCP
arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x97 (151) stepping: 2
microcode: 0x36
Topology: cpus: 1x dies: 1 clusters: 9 cores: 12 threads: 20 mt: 8 tpc: 2
st: 4 smt: enabled cache: L1: 1024 KiB desc: d-4x32 KiB, 8x48 KiB; i-8x32
KiB, 4x64 KiB L2: 12 MiB desc: 8x1.2 MiB, 1x2 MiB L3: 25 MiB
desc: 1x25 MiB
Speed (MHz): avg: 800 min/max: 800/4900:5000:3800 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 800
5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800
15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 bogomips: 144440
de ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c flexpriority
hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pclmulqdq pconfig pdcm
rdtscp rep_good sdbg sep serialize sha_ni smap smep smx split_lock_detect
ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tme tpr_shadow
tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip user_shstk vaes vme
vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec xsaveopt
xsaves xtopology xtpr
conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
Device-1: Intel AlderLake-S GT1 vendor: Gigabyte driver: i915 v: kernel
arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports: active: none
empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:4680
class-ID: 0380
Device-2: NVIDIA GA104 [GeForce RTX 3060] driver: nvidia v: 550.120
alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current (as of
2024-09; EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
built: 2020-2023 pcie: gen: 2 speed: 5 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s ports: active: none off: DP-3,DP-4,HDMI-A-3 empty: DP-2
bus-ID: 01:00.0 chip-ID: 10de:2487 class-ID: 0300
Device-3: Logitech C920 PRO HD Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6.2.2:11
chip-ID: 046d:08e5 class-ID: 0102
Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
display-ID: :0 screens: 1
Screen-1: 0 s-res: 5760x2160 s-dpi: 140 s-size: 1045x392mm (41.14x15.43")
s-diag: 1116mm (43.94")
Monitor-1: DP-3 mapped: DP-2 note: disabled pos: right
model: Idek Iiyama PL2492H serial: <filter> built: 2016 res: 1920x1080
hz: 60 dpi: 93 gamma: 1.2 size: 527x296mm (20.75x11.65")
diag: 604mm (23.8") ratio: 16:9 modes: max: 1920x1080 min: 640x480
Monitor-2: DP-4 note: disabled pos: primary,left
model: Idek Iiyama PL3288UH serial: <filter> built: 2020 res: 3840x2160
hz: 60 dpi: 140 gamma: 1.2 size: 698x393mm (27.48x15.47")
diag: 801mm (31.5") ratio: 16:9 modes: max: 3840x2160 min: 640x480
Monitor-3: HDMI-A-3 mapped: HDMI-0 note: disabled model: Samsung
serial: <filter> built: 2017 res: 3840x2160 dpi: 81 gamma: 1.2
size: 1872x1053mm (73.7x41.46") diag: 1388mm (54.6") ratio: 16:9 modes:
drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: iris
surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.120
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2
memory: 11.72 GiB
API: Vulkan v: 1.3.295 layers: 5 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 driver: nvidia v: 550.120 device-ID: 10de:2487
surfaces: xcb,xlib
Device-1: Intel Alder Lake-S HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:7ad0 class-ID: 0403
Device-2: NVIDIA GA104 High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:228b class-ID: 0403
API: ALSA v: k6.6.54-2-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.2.5 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 06:00.0
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: TP-Link UB500 Adapter driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6.2.4:13 chip-ID: 2357:0604
Local Storage: total: 10.35 TiB used: 3.19 TiB (30.8%)
ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Samsung model: SSD 990 EVO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 0B2QKXJ7 temp: 46.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 44.9 C
scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 1TB
tech: SSD serial: <filter> fw-rev: 2B6Q scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 PRO 256GB
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 4B6Q scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST6000DM003-2CY186
size: 5.46 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 5425 serial: <filter> fw-rev: 0001 scheme: GPT
ID-6: /dev/sdd maj-min: 8:48 vendor: Samsung model: SSD 840 Series
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 9B0Q scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GH24NSD5 rev: LV00
dev-links: cdrom
Features: speed: 12 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 73.24 GiB size: 71.54 GiB (97.68%) used: 33.13 GiB (46.3%)
fs: ext4 dev: /dev/nvme1n1p3 maj-min: 259:3 label: /
uuid: 915e20e5-3c7d-4fdd-89e4-898400ef1a1c
ID-2: /boot/efi raw-size: 1024 MiB size: 1022 MiB (99.80%)
used: 300 KiB (0.0%) fs: vfat dev: /dev/nvme1n1p2 maj-min: 259:2 label: BOOT
uuid: EB6E-F9EC
ID-3: /data raw-size: 1.91 TiB size: 1.91 TiB (100.00%)
used: 1007.7 GiB (51.6%) fs: ntfs dev: /dev/sdc2 maj-min: 8:34 label: /data
uuid: 211AF22C1F6B486A
ID-4: /devel raw-size: 1.64 TiB size: 1.64 TiB (100.00%)
used: 492.31 GiB (29.3%) fs: ntfs dev: /dev/sdc3 maj-min: 8:35 label: /devel
uuid: 2A3686667D7AB1C6
ID-5: /home raw-size: 1.74 TiB size: 1.71 TiB (98.37%)
used: 562.17 GiB (32.0%) fs: ext4 dev: /dev/nvme1n1p4 maj-min: 259:4
label: /home uuid: 99f614aa-420c-456f-8ed8-a24bdfb51142
ID-6: /opt raw-size: 1.91 TiB size: 1.88 TiB (98.38%)
used: 562.75 GiB (29.3%) fs: ext4 dev: /dev/sdc1 maj-min: 8:33 label: /opt
uuid: 71217bea-4f44-462f-9329-428cce46b38f
ID-7: /ssd_opt raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
used: 142.37 GiB (7.8%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:6
label: /ssd_opt uuid: dfa8d35b-f496-473a-836f-08688beb6237
ID-8: /windows raw-size: 292.34 GiB size: 292.34 GiB (100.00%)
used: 147.89 GiB (50.6%) fs: ntfs dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 8AE0B453E0B446EB
ID-9: /windows_opt raw-size: 638.54 GiB size: 638.54 GiB (100.00%)
used: 238.87 GiB (37.4%) fs: ntfs dev: /dev/sda5 maj-min: 8:5
label: /windows_opt uuid: 302EC2912EC25010
ID-10: /windows_ssd2 raw-size: 238.47 GiB size: 238.47 GiB (100.00%)
used: 16.73 GiB (7.0%) fs: ntfs dev: /dev/sdb1 maj-min: 8:17
label: /windows_ssd2 uuid: 1DA6E41338F4C35E
ID-11: /windows_ssd_128GB raw-size: 111.79 GiB size: 111.79 GiB (100.00%)
used: 63.24 GiB (56.6%) fs: ntfs dev: /dev/sdd1 maj-min: 8:49
label: /windows_ssd_128GB uuid: F6E0FA0FE0F9D5B9
ID-1: swap-1 type: partition size: 4 GiB used: 256 KiB (0.0%) priority: -2
dev: /dev/nvme1n1p1 maj-min: 259:1 label: N/A
uuid: e00e0ab6-6611-48d8-aa55-02fc48975561
ID-1: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: vfat label: N/A
uuid: EAA6-1684
ID-2: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/sda4 maj-min: 8:4 size: 525 MiB fs: ntfs label: N/A
uuid: 640020E00020BAC6
Hub-2: 1-1:2 info: VIA Labs VL813 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2813
Device-1: 1-4:4 info: Canon CanoScan LIDE 25 type: <vendor specific>
driver: N/A interfaces: 1 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 500mA chip-ID: 04a9:2220 class-ID: ff00
Hub-3: 1-6:5 info: Genesys Logic Hub ports: 4 rev: 2.0
Hub-4: 1-6.2:7 info: Genesys Logic USB 2.0 Hub / D-Link DUB-H4 ports: 4
rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 100mA
chip-ID: 05e3:0606 class-ID: 0900
Device-1: 1-6.2.1:9 info: Logitech Lightspeed Receiver
type: keyboard,mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 98mA
chip-ID: 046d:c539 class-ID: 0300
Device-2: 1-6.2.2:11 info: Logitech C920 PRO HD Webcam type: video,audio
driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 2.1
Device-3: 1-6.2.3:12 info: Logitech G703 LIGHTSPEED Wireless Gaming Mouse
w/ HERO type: mouse,keyboard,HID driver: logitech-hidpp-device,usbhid
interfaces: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 500mA chip-ID: 046d:c090 class-ID: 0300 serial: <filter>
Device-4: 1-6.2.4:13 info: TP-Link UB500 Adapter type: bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 500mA chip-ID: 2357:0604 class-ID: e001 serial: <filter>
Hub-5: 1-9:6 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 1-11:8 info: Integrated Express RGB LED Controller type: HID
lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:5702 class-ID: 0300
Device-2: 1-12:10 info: Logitech G815 Mechanical Keyboard
type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
chip-ID: 046d:c33f class-ID: 0300 serial: <filter>
Hub-6: 2-0:1 info: super-speed hub ports: 9 rev: 3.1
Hub-7: 2-1:2 info: VIA Labs VL813 Hub ports: 4 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0813
System Temperatures: cpu: 45.0 C mobo: 35.0 C gpu: nvidia temp: 56 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
Processes: 389 Power: uptime: 7h 12m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 25.01 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Packages: pm: pacman pkgs: 1547 libs: 471 tools: pamac pm: flatpak pkgs: 0
Compilers: clang: 18.1.8 gcc: 14.2.1 alt: 13 Shell: Bash v: 5.2.37
running-in: konsole inxi: 3.3.36
journalctl:
Nov 06 11:59:07 computername konsole[16690]: Detected locale "LC_CTYPE=en_GB;LC_NUMERIC=de_DE.UTF-8;LC_TIME=en_GB.UTF-8;LC_COLLATE=en_GB;LC_MONETARY=de_DE.UTF-8;LC_MESSAGES=en_GB;LC_PAPER=de_DE.UTF-8;LC_NAME=de_DE.UTF-8;LC_ADDRESS=de_DE.UTF-8;LC_TELEPHONE=de_DE.UTF-8;LC_MEASUREMENT=de_DE.UTF-8;LC_IDENTIFICATION=en_GB.UTF-8" with character encoding "ISO-8859-1", which is not UTF-8.
Qt depends on a UTF-8 locale, and has switched to "en_GB.UTF-8" instead.
If this causes problems, reconfigure your locale. See the locale(1) manual
for more information.
Nov 06 11:59:10 computername konsole[16690]: qt.xkb.compose: failed to create compose table
Nov 06 11:59:24 computername plasmashell[1273]: kf.plasma.quick: Exposed with no visual parent. Window positioning broken.
Nov 06 11:59:25 computername plasmashell[1273]: kf.plasma.quick: Exposed with no visual parent. Window positioning broken.
Nov 06 11:59:26 computername xdg-desktop-portal-kde[1380]: xdp-kde-settings: Namespace "org.gnome.desktop.interface" is not supported
Nov 06 11:59:28 computername xdg-desktop-portal-kde[1380]: xdp-kde-settings: Namespace "org.gnome.desktop.interface" is not supported
Nov 06 11:59:37 computername xdg-desktop-portal-kde[1380]: xdp-kde-settings: Namespace "org.gnome.desktop.interface" is not supported
Nov 06 11:59:40 computername kwin_x11[1257]: kwin_core: Failed to focus 0x560002f (error 8)
Nov 06 12:01:27 computername kernel: x86/split lock detection: #AC: CHTTPClientThre/18278 took a split_lock trap at address: 0x565e2d1f
Nov 06 12:04:36 computername kwin_x11[1257]: kwin_core: Failed to focus 0x560007b (error 3)
Nov 06 12:04:36 computername kwin_x11[1257]: kwin_core: XCB error: 3 (BadWindow), sequence: 33638, resource id: 90177659, major code: 129 (SHAPE), minor code: 3 (Combine)
Nov 06 12:04:36 computername kwin_x11[1257]: kwin_core: XCB error: 3 (BadWindow), sequence: 33639, resource id: 90177659, major code: 129 (SHAPE), minor code: 3 (Combine)
Nov 06 12:04:36 computername kwin_x11[1257]: kwin_core: XCB error: 3 (BadWindow), sequence: 33655, resource id: 90177659, major code: 129 (SHAPE), minor code: 3 (Combine)
Nov 06 12:04:36 computername kwin_x11[1257]: kwin_core: XCB error: 3 (BadWindow), sequence: 33656, resource id: 90177659, major code: 129 (SHAPE), minor code: 3 (Combine)
Nov 06 12:08:12 computername kioworker[18903]: Detected locale "LC_CTYPE=en_GB;LC_NUMERIC=de_DE.UTF-8;LC_TIME=en_GB.UTF-8;LC_COLLATE=en_GB;LC_MONETARY=de_DE.UTF-8;LC_MESSAGES=en_GB;LC_PAPER=de_DE.UTF-8;LC_NAME=de_DE.UTF-8;LC_ADDRESS=de_DE.UTF-8;LC_TELEPHONE=de_DE.UTF-8;LC_MEASUREMENT=de_DE.UTF-8;LC_IDENTIFICATION=en_GB.UTF-8" with character encoding "ISO-8859-1", which is not UTF-8.
Nov 06 12:46:30 computername kscreenlocker_greet[19920]: Detected locale "LC_CTYPE=en_GB;LC_NUMERIC=de_DE.UTF-8;LC_TIME=en_GB.UTF-8;LC_COLLATE=en_GB;LC_MONETARY=de_DE.UTF-8;LC_MESSAGES=en_GB;LC_PAPER=de_DE.UTF-8;LC_NAME=de_DE.UTF-8;LC_ADDRESS=de_DE.UTF-8;LC_TELEPHONE=de_DE.UTF-8;LC_MEASUREMENT=de_DE.UTF-8;LC_IDENTIFICATION=en_GB.UTF-8" with character encoding "ISO-8859-1", which is not UTF-8.
Nov 06 12:46:31 computername wireplumber[1339]: wplua: [string "alsa.lua"]:182: attempt to concatenate a nil value (local 'node_name')
stack traceback:
[string "alsa.lua"]:182: in function <[string "alsa.lua"]:175>
Nov 06 12:46:32 computername kscreenlocker_greet[19920]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_GB". Search paths QList("/usr/share/qt6/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
Nov 06 12:46:47 computername wireplumber[1339]: wplua: [string "alsa.lua"]:182: attempt to concatenate a nil value (local 'node_name')
stack traceback:
Nov 06 12:47:13 computername wireplumber[1339]: wplua: [string "alsa.lua"]:182: attempt to concatenate a nil value (local 'node_name')
stack traceback:
Nov 06 13:08:33 computername kscreenlocker_greet[20592]: Detected locale "LC_CTYPE=en_GB;LC_NUMERIC=de_DE.UTF-8;LC_TIME=en_GB.UTF-8;LC_COLLATE=en_GB;LC_MONETARY=de_DE.UTF-8;LC_MESSAGES=en_GB;LC_PAPER=de_DE.UTF-8;LC_NAME=de_DE.UTF-8;LC_ADDRESS=de_DE.UTF-8;LC_TELEPHONE=de_DE.UTF-8;LC_MEASUREMENT=de_DE.UTF-8;LC_IDENTIFICATION=en_GB.UTF-8" with character encoding "ISO-8859-1", which is not UTF-8.
Nov 06 13:08:34 computername wireplumber[1339]: wplua: [string "alsa.lua"]:182: attempt to concatenate a nil value (local 'node_name')
stack traceback:
Nov 06 13:08:38 computername kscreenlocker_greet[20592]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_GB". Search paths QList("/usr/share/qt6/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
Nov 06 13:24:20 computername kwin_x11[1257]: kwin_core: XCB error: 152 (BadDamage), sequence: 65429, resource id: 21270035, major code: 143 (DAMAGE), minor code: 2 (Destroy)
Nov 06 13:24:20 computername kwin_x11[1257]: kwin_core: XCB error: 3 (BadWindow), sequence: 65430, resource id: 18874403, major code: 129 (SHAPE), minor code: 6 (Input)
Nov 06 13:28:13 computername plasmashell[1273]: QUnifiedTimer::stopAnimationDriver: driver is not running
Nov 06 13:50:16 computername kscreenlocker_greet[22446]: Detected locale "LC_CTYPE=en_GB;LC_NUMERIC=de_DE.UTF-8;LC_TIME=en_GB.UTF-8;LC_COLLATE=en_GB;LC_MONETARY=de_DE.UTF-8;LC_MESSAGES=en_GB;LC_PAPER=de_DE.UTF-8;LC_NAME=de_DE.UTF-8;LC_ADDRESS=de_DE.UTF-8;LC_TELEPHONE=de_DE.UTF-8;LC_MEASUREMENT=de_DE.UTF-8;LC_IDENTIFICATION=en_GB.UTF-8" with character encoding "ISO-8859-1", which is not UTF-8.
Nov 06 13:50:16 computername wireplumber[1339]: wplua: [string "alsa.lua"]:182: attempt to concatenate a nil value (local 'node_name')
stack traceback:
Nov 06 13:50:21 computername kscreenlocker_greet[22446]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_GB". Search paths QList("/usr/share/qt6/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
Nov 06 14:36:11 computername kscreenlocker_greet[23999]: Detected locale "LC_CTYPE=en_GB;LC_NUMERIC=de_DE.UTF-8;LC_TIME=en_GB.UTF-8;LC_COLLATE=en_GB;LC_MONETARY=de_DE.UTF-8;LC_MESSAGES=en_GB;LC_PAPER=de_DE.UTF-8;LC_NAME=de_DE.UTF-8;LC_ADDRESS=de_DE.UTF-8;LC_TELEPHONE=de_DE.UTF-8;LC_MEASUREMENT=de_DE.UTF-8;LC_IDENTIFICATION=en_GB.UTF-8" with character encoding "ISO-8859-1", which is not UTF-8.
Nov 06 14:36:12 computername wireplumber[1339]: wplua: [string "alsa.lua"]:182: attempt to concatenate a nil value (local 'node_name')
stack traceback:
Nov 06 14:36:15 computername kscreenlocker_greet[23999]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_GB". Search paths QList("/usr/share/qt6/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
Nov 06 15:07:09 computername kscreenlocker_greet[25092]: Detected locale "LC_CTYPE=en_GB;LC_NUMERIC=de_DE.UTF-8;LC_TIME=en_GB.UTF-8;LC_COLLATE=en_GB;LC_MONETARY=de_DE.UTF-8;LC_MESSAGES=en_GB;LC_PAPER=de_DE.UTF-8;LC_NAME=de_DE.UTF-8;LC_ADDRESS=de_DE.UTF-8;LC_TELEPHONE=de_DE.UTF-8;LC_MEASUREMENT=de_DE.UTF-8;LC_IDENTIFICATION=en_GB.UTF-8" with character encoding "ISO-8859-1", which is not UTF-8.
Nov 06 15:07:10 computername wireplumber[1339]: wplua: [string "alsa.lua"]:182: attempt to concatenate a nil value (local 'node_name')
stack traceback:
Nov 06 15:07:14 computername kscreenlocker_greet[25092]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_GB". Search paths QList("/usr/share/qt6/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
Nov 06 15:16:47 computername wireplumber[1339]: m-lua-scripting: Got invalid index when switching profile
Nov 06 15:17:32 computername wireplumber[1339]: m-lua-scripting: Got invalid index when switching profile
Nov 06 15:17:33 computername wireplumber[1339]: m-lua-scripting: Got invalid index when switching profile
Nov 06 15:17:34 computername gameoverlayui[26809]: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Nov 06 15:22:03 computername gameoverlayui[26926]: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Nov 06 15:34:54 computername kscreenlocker_greet[27658]: Detected locale "LC_CTYPE=en_GB;LC_NUMERIC=de_DE.UTF-8;LC_TIME=en_GB.UTF-8;LC_COLLATE=en_GB;LC_MONETARY=de_DE.UTF-8;LC_MESSAGES=en_GB;LC_PAPER=de_DE.UTF-8;LC_NAME=de_DE.UTF-8;LC_ADDRESS=de_DE.UTF-8;LC_TELEPHONE=de_DE.UTF-8;LC_MEASUREMENT=de_DE.UTF-8;LC_IDENTIFICATION=en_GB.UTF-8" with character encoding "ISO-8859-1", which is not UTF-8.
Nov 06 15:34:54 computername wireplumber[1339]: wplua: [string "alsa.lua"]:182: attempt to concatenate a nil value (local 'node_name')
stack traceback:
Nov 06 15:34:56 computername kscreenlocker_greet[27658]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_GB". Search paths QList("/usr/share/qt6/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
Nov 06 15:52:17 computername wireplumber[1339]: wplua: [string "alsa.lua"]:182: attempt to concatenate a nil value (local 'node_name')
stack traceback:
Nov 06 15:52:17 computername kded6[1256]: org.kde.pulseaudio: No object for name "alsa_output.pci-0000_00_1f.3.analog-stereo"
Nov 06 15:52:17 computername kded6[1256]: org.kde.pulseaudio: No object for name "alsa_input.usb-046d_HD_Pro_Webcam_C920-02.analog-stereo"
Nov 06 15:52:17 computername plasmashell[1273]: org.kde.pulseaudio: No object for name "alsa_output.pci-0000_00_1f.3.analog-stereo"
Nov 06 15:52:17 computername kded6[1256]: org.kde.pulseaudio: No object for name "@DEFAULT_SINK@"
Nov 06 15:52:17 computername kded6[1256]: org.kde.pulseaudio: No object for name "@DEFAULT_SOURCE@"
Nov 06 15:52:17 computername plasmashell[1273]: org.kde.pulseaudio: No object for name "alsa_input.usb-046d_HD_Pro_Webcam_C920-02.analog-stereo"
Nov 06 15:52:17 computername plasmashell[1273]: org.kde.pulseaudio: No object for name "@DEFAULT_SINK@"
Nov 06 15:52:17 computername plasmashell[1273]: org.kde.pulseaudio: No object for name "@DEFAULT_SOURCE@"
Nov 06 15:52:17 computername kded6[1256]: org.kde.pulseaudio: No object for name "auto_null.monitor"
Nov 06 15:52:17 computername plasmashell[1273]: org.kde.pulseaudio: No object for name "auto_null.monitor"
Nov 06 15:52:17 computername systemd-coredump[28421]: Process 1082 (Xorg) of user 0 dumped core.
Stack trace of thread 1082:
#0 0x00007f65abb3e3f4 n/a (libc.so.6 + 0x963f4)
#1 0x00007f65abae5120 raise (libc.so.6 + 0x3d120)
#2 0x00007f65abacc4c3 abort (libc.so.6 + 0x244c3)
#3 0x000055bd623d847e OsAbort (Xorg + 0x15147e)
#4 0x000055bd623d9977 FatalError (Xorg + 0x152977)
#5 0x000055bd623e07f8 n/a (Xorg + 0x1597f8)
#6 0x00007f65abae51d0 n/a (libc.so.6 + 0x3d1d0)
#7 0x00007f65aacb0b35 n/a (nvidia_drv.so + 0x4b0b35)
Nov 06 15:52:17 computername gmenudbusmenuproxy[1375]: The X11 connection broke (error 1). Did the X11 server die?
Nov 06 15:52:17 computername pamac-tray-plasma[1555]: The X11 connection broke (error 1). Did the X11 server die?
Nov 06 15:52:17 computername org_kde_powerdevil[1377]: The X11 connection broke (error 1). Did the X11 server die?
Nov 06 15:52:17 computername kded6[1256]: The X11 connection broke: I/O error (code 1)
Nov 06 15:52:17 computername ksmserver[1254]: qt.qpa.xcb: atomName: bad atom 450
Nov 06 15:52:17 computername kwalletd6[1180]: The X11 connection broke (error 1). Did the X11 server die?
Nov 06 15:52:17 computername kaccess[1552]: The X11 connection broke (error 1). Did the X11 server die?
Nov 06 15:52:17 computername kdeconnectd[1532]: 2024-11-06T15:52:17 default: The X11 connection broke (error 1). Did the X11 server die?
Nov 06 15:52:17 computername kscreen_backend_launcher[1365]: The X11 connection broke (error 1). Did the X11 server die?
Nov 06 15:52:17 computername xembedsniproxy[1382]: The X11 connection broke (error 1). Did the X11 server die?
Nov 06 15:52:17 computername ksmserver[1254]: failed to get the primary output of the screen
Nov 06 15:52:17 computername kactivitymanagerd[1369]: The X11 connection broke (error 1). Did the X11 server die?
Nov 06 15:52:17 computername plasmashell[1273]: The X11 connection broke (error 1). Did the X11 server die?
Nov 06 15:52:17 computername xdg-desktop-portal-kde[1380]: The X11 connection broke (error 1). Did the X11 server die?
Nov 06 15:52:17 computername msm_kde_notifier[1571]: The X11 connection broke (error 1). Did the X11 server die?
Nov 06 15:52:17 computername kglobalacceld[1208]: The X11 connection broke (error 1). Did the X11 server die?
Nov 06 15:52:17 computername polkit-kde-authentication-agent-1[1376]: The X11 connection broke (error 1). Did the X11 server die?
Nov 06 15:52:17 computername systemd[1164]: dbus-:1.53-org.a11y.atspi.Registry@0.service: Failed with result 'exit-code'.
Nov 06 15:52:18 computername kded6[1256]: org.kde.pulseaudio: No object for name "auto_null"
Nov 06 15:52:18 computername kded6[1256]: org.kde.pulseaudio: No object for name "auto_null.monitor"
Nov 06 15:52:18 computername systemd[1164]: plasma-xembedsniproxy.service: Failed with result 'exit-code'.
Nov 06 15:52:18 computername kwin_x11[1257]: The X11 connection broke: I/O error (code 1)
Nov 06 15:52:18 computername kglobalacceld[1208]: The X11 connection broke: I/O error (code 1)
Nov 06 15:52:18 computername systemd[1164]: app-msm_kde_notifier_settings@6f9ca3dd9ec44bc7bd49f8f196e333c9.service: Failed with result 'exit-code'.
Nov 06 15:52:18 computername plasmashell[1273]: org.kde.pulseaudio: No object for name "auto_null"
Nov 06 15:52:18 computername plasmashell[1273]: org.kde.pulseaudio: No object for name "auto_null.monitor"
Nov 06 15:52:18 computername systemd[1164]: app-kaccess@autostart.service: Failed with result 'exit-code'.
Nov 06 15:52:18 computername systemd[1164]: plasma-gmenudbusmenuproxy.service: Failed with result 'exit-code'.
Nov 06 15:52:18 computername systemd[1164]: app-org.kde.kdeconnect.daemon@autostart.service: Failed with result 'exit-code'.
Nov 06 15:52:18 computername systemd[1164]: app-pamac\x2dtray\x2dplasma@autostart.service: Failed with result 'exit-code'.
Nov 06 15:52:18 computername systemd[1164]: plasma-kded6.service: Failed with result 'exit-code'.
Nov 06 15:52:18 computername systemd[1164]: app-firefox@dda60a451f3140d89ae93c260e9bc1ff.service: Failed with result 'exit-code'.
Nov 06 15:52:18 computername systemd-coredump[28465]: Process 1254 (ksmserver) of user 1000 dumped core.
Stack trace of thread 1254:
#0 0x00007f39439c052b _ZN10QXcbScreen23updateColorSpaceAndEdidEv (libQt6XcbQpa.so.6 + 0x6152b)
#1 0x00007f394399aaa3 _ZN14QXcbConnection20createScreen_monitorEP18QXcbVirtualDesktopP24xcb_randr_monitor_info_tj (libQt6XcbQpa.so.6 + 0x3baa3)
#2 0x00007f394399b4bf _ZN14QXcbConnection28initializeScreensFromMonitorEP21xcb_screen_iterator_tiPP10QXcbScreenb (libQt6XcbQpa.so.6 + 0x3c4bf)
#3 0x00007f394399bcd7 _ZN14QXcbConnection17initializeScreensEb (libQt6XcbQpa.so.6 + 0x3ccd7)
#4 0x00007f394398fd1d _ZN14QXcbConnection14handleXcbEventEP19xcb_generic_event_t (libQt6XcbQpa.so.6 + 0x30d1d)
#5 0x00007f3943996c32 _ZN14QXcbConnection16processXcbEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6XcbQpa.so.6 + 0x37c32)
#6 0x00007f39439b0b7f n/a (libQt6XcbQpa.so.6 + 0x51b7f)
#7 0x00007f3948fd0299 n/a (libglib-2.0.so.0 + 0x5d299)
#8 0x00007f3949032ec7 n/a (libglib-2.0.so.0 + 0xbfec7)
#9 0x00007f3948fcf795 g_main_context_iteration (libglib-2.0.so.0 + 0x5c795)
#10 0x00007f3949da82bd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3a82bd)
#11 0x00007f3949b4ff66 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x14ff66)
#12 0x00007f3949b4a11d _ZN16QCoreApplication4execEv (libQt6Core.so.6 + 0x14a11d)
#13 0x0000561c7f54739e n/a (ksmserver + 0xb39e)
#14 0x00007f394a034e08 n/a (libc.so.6 + 0x25e08)
#15 0x00007f394a034ecc __libc_start_main (libc.so.6 + 0x25ecc)
#16 0x0000561c7f547d25 n/a (ksmserver + 0xbd25)
Stack trace of thread 1264:
#0 0x00007f394a11a63d __poll (libc.so.6 + 0x10b63d)
#1 0x00007f3949032e0d n/a (libglib-2.0.so.0 + 0xbfe0d)
#2 0x00007f3948fcf795 g_main_context_iteration (libglib-2.0.so.0 + 0x5c795)
#3 0x00007f3949da82bd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3a82bd)
#4 0x00007f3949b4ff66 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x14ff66)
#5 0x00007f3949c3d650 _ZN7QThread4execEv (libQt6Core.so.6 + 0x23d650)
#6 0x00007f394aaa8f0e n/a (libQt6DBus.so.6 + 0x2df0e)
#7 0x00007f3949ccd237 n/a (libQt6Core.so.6 + 0x2cd237)
#8 0x00007f394a0a339d n/a (libc.so.6 + 0x9439d)
#9 0x00007f394a12849c n/a (libc.so.6 + 0x11949c)
Nov 06 15:52:18 computername startplasma-x11[1181]: org.kde.startup: "kdeinit5_shutdown" QList() exited with code 255
Nov 06 15:52:18 computername gmenudbusmenuproxy[28478]: Detected locale "LC_CTYPE=en_GB;LC_NUMERIC=de_DE.UTF-8;LC_TIME=en_GB.UTF-8;LC_COLLATE=en_GB;LC_MONETARY=de_DE.UTF-8;LC_MESSAGES=en_GB;LC_PAPER=de_DE.UTF-8;LC_NAME=de_DE.UTF-8;LC_ADDRESS=de_DE.UTF-8;LC_TELEPHONE=de_DE.UTF-8;LC_MEASUREMENT=de_DE.UTF-8;LC_IDENTIFICATION=en_GB.UTF-8" with character encoding "ISO-8859-1", which is not UTF-8.
Nov 06 15:52:18 computername xembedsniproxy[28479]: Detected locale "LC_CTYPE=en_GB;LC_NUMERIC=de_DE.UTF-8;LC_TIME=en_GB.UTF-8;LC_COLLATE=en_GB;LC_MONETARY=de_DE.UTF-8;LC_MESSAGES=en_GB;LC_PAPER=de_DE.UTF-8;LC_NAME=de_DE.UTF-8;LC_ADDRESS=de_DE.UTF-8;LC_TELEPHONE=de_DE.UTF-8;LC_MEASUREMENT=de_DE.UTF-8;LC_IDENTIFICATION=en_GB.UTF-8" with character encoding "ISO-8859-1", which is not UTF-8.
Nov 06 15:52:18 computername gmenudbusmenuproxy[28478]: qt.qpa.xcb: could not connect to display :0
Nov 06 15:52:18 computername xembedsniproxy[28479]: qt.qpa.xcb: could not connect to display :0
Nov 06 15:52:18 computername xembedsniproxy[28479]: qt.qpa.plugin: From 6.5.0, xcb-cursor0 or libxcb-cursor0 is needed to load the Qt xcb platform plugin.
Nov 06 15:52:18 computername gmenudbusmenuproxy[28478]: qt.qpa.plugin: From 6.5.0, xcb-cursor0 or libxcb-cursor0 is needed to load the Qt xcb platform plugin.
Nov 06 15:52:18 computername gmenudbusmenuproxy[28478]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: linuxfb, vnc, offscreen, xcb, minimalegl, vkkhrdisplay, minimal, wayland-egl, eglfs, wayland.
Nov 06 15:52:18 computername xembedsniproxy[28479]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Nov 06 15:52:18 computername systemd[1164]: plasma-ksmserver.service: Main process exited, code=dumped, status=11/SEGV
Nov 06 15:52:18 computername systemd[1164]: plasma-ksmserver.service: Failed with result 'core-dump'.
Nov 06 15:52:18 computername systemd-coredump[28508]: Process 28479 (xembedsniproxy) of user 1000 dumped core.
Stack trace of thread 28479:
#0 0x00007fa79aaa53f4 n/a (libc.so.6 + 0x963f4)
#1 0x00007fa79aa4c120 raise (libc.so.6 + 0x3d120)
#2 0x00007fa79aa334c3 abort (libc.so.6 + 0x244c3)
#3 0x00007fa79a48c663 n/a (libQt6Core.so.6 + 0x8c663)
#4 0x00007fa79a48ce07 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8ce07)
#5 0x00007fa79acdaa65 n/a (libQt6Gui.so.6 + 0xdaa65)
#6 0x00007fa79ad7c3a8 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x17c3a8)
#7 0x00007fa79a549a2d _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x149a2d)
#8 0x00007fa79ad7c43e _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x17c43e)
#9 0x00007fa79ad74fad _ZN15QGuiApplicationC2ERiPPci (libQt6Gui.so.6 + 0x174fad)
#10 0x000055d4d144a335 n/a (xembedsniproxy + 0x6335)
#11 0x00007fa79aa34e08 n/a (libc.so.6 + 0x25e08)
#12 0x00007fa79aa34ecc __libc_start_main (libc.so.6 + 0x25ecc)
#13 0x000055d4d144a735 n/a (xembedsniproxy + 0x6735)
Stack trace of thread 28491:
#0 0x00007fa79ab1a63d __poll (libc.so.6 + 0x10b63d)
#1 0x00007fa799f20e0d n/a (libglib-2.0.so.0 + 0xbfe0d)
#2 0x00007fa799ebd795 g_main_context_iteration (libglib-2.0.so.0 + 0x5c795)
#3 0x00007fa79a7a82bd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3a82bd)
#4 0x00007fa79a54ff66 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x14ff66)
#5 0x00007fa79a63d650 _ZN7QThread4execEv (libQt6Core.so.6 + 0x23d650)
#6 0x00007fa79b631f0e n/a (libQt6DBus.so.6 + 0x2df0e)
#7 0x00007fa79a6cd237 n/a (libQt6Core.so.6 + 0x2cd237)
#8 0x00007fa79aaa339d n/a (libc.so.6 + 0x9439d)
#9 0x00007fa79ab2849c n/a (libc.so.6 + 0x11949c)
Nov 06 15:52:18 computername systemd-coredump[28509]: Process 28478 (gmenudbusmenupr) of user 1000 dumped core.
Stack trace of thread 28478:
#0 0x00007ff49c6a53f4 n/a (libc.so.6 + 0x963f4)
#1 0x00007ff49c64c120 raise (libc.so.6 + 0x3d120)
#2 0x00007ff49c6334c3 abort (libc.so.6 + 0x244c3)
#3 0x00007ff49c08c663 n/a (libQt6Core.so.6 + 0x8c663)
#4 0x00007ff49c08ce07 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8ce07)
#5 0x00007ff49c8daa65 n/a (libQt6Gui.so.6 + 0xdaa65)
#6 0x00007ff49c97c3a8 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x17c3a8)
#7 0x00007ff49c149a2d _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x149a2d)
#8 0x00007ff49c97c43e _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x17c43e)
#9 0x00007ff49c974fad _ZN15QGuiApplicationC2ERiPPci (libQt6Gui.so.6 + 0x174fad)
#10 0x000055ec57760c8e n/a (gmenudbusmenuproxy + 0x9c8e)
#11 0x00007ff49c634e08 n/a (libc.so.6 + 0x25e08)
#12 0x00007ff49c634ecc __libc_start_main (libc.so.6 + 0x25ecc)
#13 0x000055ec57760f65 n/a (gmenudbusmenuproxy + 0x9f65)
Stack trace of thread 28490:
#0 0x00007ff49c71a63d __poll (libc.so.6 + 0x10b63d)
#1 0x00007ff49b974e0d n/a (libglib-2.0.so.0 + 0xbfe0d)
#2 0x00007ff49b911795 g_main_context_iteration (libglib-2.0.so.0 + 0x5c795)
#3 0x00007ff49c3a82bd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3a82bd)
#4 0x00007ff49c14ff66 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x14ff66)
#5 0x00007ff49c23d650 _ZN7QThread4execEv (libQt6Core.so.6 + 0x23d650)
#6 0x00007ff49d091f0e n/a (libQt6DBus.so.6 + 0x2df0e)
#7 0x00007ff49c2cd237 n/a (libQt6Core.so.6 + 0x2cd237)
#8 0x00007ff49c6a339d n/a (libc.so.6 + 0x9439d)
#9 0x00007ff49c72849c n/a (libc.so.6 + 0x11949c)
Nov 06 15:52:18 computername systemd[1164]: plasma-gmenudbusmenuproxy.service: Main process exited, code=dumped, status=6/ABRT
Nov 06 15:52:18 computername systemd[1164]: plasma-gmenudbusmenuproxy.service: Failed with result 'core-dump'.
Nov 06 15:52:18 computername systemd[1164]: plasma-xembedsniproxy.service: Main process exited, code=dumped, status=6/ABRT
Nov 06 15:52:18 computername systemd[1164]: plasma-xembedsniproxy.service: Failed with result 'core-dump'.
Nov 06 15:52:18 computername systemd[1164]: app-org.mozilla.Thunderbird@63fbf0e67e9c4667bb0a7986f4f3a57d.service: Failed with result 'exit-code'.
Nov 06 15:52:20 computername dbus-broker-launch[28557]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Nov 06 15:52:20 computername dbus-broker-launch[28557]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
Nov 06 15:52:20 computername dbus-broker-launch[28557]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Nov 06 15:52:20 computername sddm-greeter-qt6[28553]: KeyStatesEngine is deprecated. Use KeyState from org.kde.plasma.private.keyboardindicator instead.
Nov 06 15:52:27 computername sddm-greeter-qt6[28553]: file:///usr/share/sddm/themes/breath/Main.qml:241:17 Parameter "username" is not declared. Injection of parameters into signal handlers is deprecated. Use JavaScript functions with formal parameters instead.
Nov 06 15:52:27 computername kapplymousetheme[28617]: Detected locale "LC_CTYPE=en_GB;LC_NUMERIC=de_DE.UTF-8;LC_TIME=en_GB.UTF-8;LC_COLLATE=en_GB;LC_MONETARY=de_DE.UTF-8;LC_MESSAGES=en_GB;LC_PAPER=de_DE.UTF-8;LC_NAME=de_DE.UTF-8;LC_ADDRESS=de_DE.UTF-8;LC_TELEPHONE=de_DE.UTF-8;LC_MEASUREMENT=de_DE.UTF-8;LC_IDENTIFICATION=en_GB.UTF-8" with character encoding "ISO-8859-1", which is not UTF-8.
Nov 06 15:52:27 computername ksplashqml[28619]: Detected locale "LC_CTYPE=en_GB;LC_NUMERIC=de_DE.UTF-8;LC_TIME=en_GB.UTF-8;LC_COLLATE=en_GB;LC_MONETARY=de_DE.UTF-8;LC_MESSAGES=en_GB;LC_PAPER=de_DE.UTF-8;LC_NAME=de_DE.UTF-8;LC_ADDRESS=de_DE.UTF-8;LC_TELEPHONE=de_DE.UTF-8;LC_MEASUREMENT=de_DE.UTF-8;LC_IDENTIFICATION=en_GB.UTF-8" with character encoding "ISO-8859-1", which is not UTF-8.
Nov 06 15:52:27 computername kde-systemd-start-condition[28634]: Detected locale "LC_CTYPE=en_GB;LC_NUMERIC=de_DE.UTF-8;LC_TIME=en_GB.UTF-8;LC_COLLATE=en_GB;LC_MONETARY=de_DE.UTF-8;LC_MESSAGES=en_GB;LC_PAPER=de_DE.UTF-8;LC_NAME=de_DE.UTF-8;LC_ADDRESS=de_DE.UTF-8;LC_TELEPHONE=de_DE.UTF-8;LC_MEASUREMENT=de_DE.UTF-8;LC_IDENTIFICATION=en_GB.UTF-8" with character encoding "ISO-8859-1", which is not UTF-8.
Nov 06 15:52:27 computername kcminit_startup[28638]: Detected locale "LC_CTYPE=en_GB;LC_NUMERIC=de_DE.UTF-8;LC_TIME=en_GB.UTF-8;LC_COLLATE=en_GB;LC_MONETARY=de_DE.UTF-8;LC_MESSAGES=en_GB;LC_PAPER=de_DE.UTF-8;LC_NAME=de_DE.UTF-8;LC_ADDRESS=de_DE.UTF-8;LC_TELEPHONE=de_DE.UTF-8;LC_MEASUREMENT=de_DE.UTF-8;LC_IDENTIFICATION=en_GB.UTF-8" with character encoding "ISO-8859-1", which is not UTF-8.
Nov 06 15:52:27 computername kglobalacceld[28633]: Detected locale "LC_CTYPE=en_GB;LC_NUMERIC=de_DE.UTF-8;LC_TIME=en_GB.UTF-8;LC_COLLATE=en_GB;LC_MONETARY=de_DE.UTF-8;LC_MESSAGES=en_GB;LC_PAPER=de_DE.UTF-8;LC_NAME=de_DE.UTF-8;LC_ADDRESS=de_DE.UTF-8;LC_TELEPHONE=de_DE.UTF-8;LC_MEASUREMENT=de_DE.UTF-8;LC_IDENTIFICATION=en_GB.UTF-8" with character encoding "ISO-8859-1", which is not UTF-8.
Nov 06 15:52:27 computername kwalletd6[28606]: Detected locale "LC_CTYPE=en_GB;LC_NUMERIC=de_DE.UTF-8;LC_TIME=en_GB.UTF-8;LC_COLLATE=en_GB;LC_MONETARY=de_DE.UTF-8;LC_MESSAGES=en_GB;LC_PAPER=de_DE.UTF-8;LC_NAME=de_DE.UTF-8;LC_ADDRESS=de_DE.UTF-8;LC_TELEPHONE=de_DE.UTF-8;LC_MEASUREMENT=de_DE.UTF-8;LC_IDENTIFICATION=en_GB.UTF-8" with character encoding "ISO-8859-1", which is not UTF-8.
Nov 06 15:52:27 computername kded6[28676]: Detected locale "LC_CTYPE=en_GB;LC_NUMERIC=de_DE.UTF-8;LC_TIME=en_GB.UTF-8;LC_COLLATE=en_GB;LC_MONETARY=de_DE.UTF-8;LC_MESSAGES=en_GB;LC_PAPER=de_DE.UTF-8;LC_NAME=de_DE.UTF-8;LC_ADDRESS=de_DE.UTF-8;LC_TELEPHONE=de_DE.UTF-8;LC_MEASUREMENT=de_DE.UTF-8;LC_IDENTIFICATION=en_GB.UTF-8" with character encoding "ISO-8859-1", which is not UTF-8.
Nov 06 15:52:27 computername ksmserver[28674]: Detected locale "LC_CTYPE=en_GB;LC_NUMERIC=de_DE.UTF-8;LC_TIME=en_GB.UTF-8;LC_COLLATE=en_GB;LC_MONETARY=de_DE.UTF-8;LC_MESSAGES=en_GB;LC_PAPER=de_DE.UTF-8;LC_NAME=de_DE.UTF-8;LC_ADDRESS=de_DE.UTF-8;LC_TELEPHONE=de_DE.UTF-8;LC_MEASUREMENT=de_DE.UTF-8;LC_IDENTIFICATION=en_GB.UTF-8" with character encoding "ISO-8859-1", which is not UTF-8.
Nov 06 15:52:27 computername kwin_x11[28677]: Detected locale "LC_CTYPE=en_GB;LC_NUMERIC=de_DE.UTF-8;LC_TIME=en_GB.UTF-8;LC_COLLATE=en_GB;LC_MONETARY=de_DE.UTF-8;LC_MESSAGES=en_GB;LC_PAPER=de_DE.UTF-8;LC_NAME=de_DE.UTF-8;LC_ADDRESS=de_DE.UTF-8;LC_TELEPHONE=de_DE.UTF-8;LC_MEASUREMENT=de_DE.UTF-8;LC_IDENTIFICATION=en_GB.UTF-8" with character encoding "ISO-8859-1", which is not UTF-8.
Nov 06 15:52:28 computername kded6[28676]: QDBusObjectPath: invalid path "/modules/plasma-session-shortcuts"
Nov 06 15:52:28 computername kded6[28676]: kf.dbusaddons: The kded module name "plasma-session-shortcuts" is invalid!
Nov 06 15:52:28 computername kded6[28676]: org.kde.libkbolt: Failed to connect to Bolt manager DBus interface:
Nov 06 15:52:28 computername qdbus[28695]: Detected locale "LC_CTYPE=en_GB;LC_NUMERIC=de_DE.UTF-8;LC_TIME=en_GB.UTF-8;LC_COLLATE=en_GB;LC_MONETARY=de_DE.UTF-8;LC_MESSAGES=en_GB;LC_PAPER=de_DE.UTF-8;LC_NAME=de_DE.UTF-8;LC_ADDRESS=de_DE.UTF-8;LC_TELEPHONE=de_DE.UTF-8;LC_MEASUREMENT=de_DE.UTF-8;LC_IDENTIFICATION=en_GB.UTF-8" with character encoding "ISO-8859-1", which is not UTF-8.
Nov 06 15:52:28 computername plasmashell[28696]: Detected locale "LC_CTYPE=en_GB;LC_NUMERIC=de_DE.UTF-8;LC_TIME=en_GB.UTF-8;LC_COLLATE=en_GB;LC_MONETARY=de_DE.UTF-8;LC_MESSAGES=en_GB;LC_PAPER=de_DE.UTF-8;LC_NAME=de_DE.UTF-8;LC_ADDRESS=de_DE.UTF-8;LC_TELEPHONE=de_DE.UTF-8;LC_MEASUREMENT=de_DE.UTF-8;LC_IDENTIFICATION=en_GB.UTF-8" with character encoding "ISO-8859-1", which is not UTF-8.
Nov 06 15:52:28 computername kwin_x11[28677]: kwin_xkbcommon: XKB: /usr/share/X11/locale/iso8859-1/Compose:39:34: string literal is not a valid UTF-8 string
Nov 06 15:52:28 computername kwin_x11[28677]: kwin_xkbcommon: XKB: /usr/share/X11/locale/iso8859-1/Compose:40:29: string literal is not a valid UTF-8 string
Nov 06 15:52:28 computername kernel: usb 1-6.2.2: current rate 16000 is different from the runtime rate 32000
Nov 06 15:52:28 computername kwin_x11[28677]: kwin_xkbcommon: XKB: /usr/share/X11/locale/iso8859-1/Compose:41:29: string literal is not a valid UTF-8 string
Nov 06 15:52:28 computername kwin_x11[28677]: kwin_xkbcommon: XKB: /usr/share/X11/locale/iso8859-1/Compose:42:29: string literal is not a valid UTF-8 string
Nov 06 15:52:28 computername kwin_x11[28677]: kwin_xkbcommon: XKB: /usr/share/X11/locale/iso8859-1/Compose:43:29: string literal is not a valid UTF-8 string
Nov 06 15:52:28 computername kwin_x11[28677]: kwin_xkbcommon: XKB: /usr/share/X11/locale/iso8859-1/Compose:44:27: string literal is not a valid UTF-8 string
Nov 06 15:52:28 computername kwin_x11[28677]: kwin_xkbcommon: XKB: /usr/share/X11/locale/iso8859-1/Compose:45:27: string literal is not a valid UTF-8 string
Nov 06 15:52:28 computername kwin_x11[28677]: kwin_xkbcommon: XKB: /usr/share/X11/locale/iso8859-1/Compose:46:27: string literal is not a valid UTF-8 string
Nov 06 15:52:28 computername kwin_x11[28677]: kwin_xkbcommon: XKB: /usr/share/X11/locale/iso8859-1/Compose:47:27: string literal is not a valid UTF-8 string
Nov 06 15:52:28 computername kwin_x11[28677]: kwin_xkbcommon: XKB: /usr/share/X11/locale/iso8859-1/Compose:48:29: string literal is not a valid UTF-8 string
Nov 06 15:52:28 computername kwin_x11[28677]: kwin_xkbcommon: XKB: /usr/share/X11/locale/iso8859-1/Compose:49:29: string literal is not a valid UTF-8 string
Nov 06 15:52:28 computername kwin_x11[28677]: kwin_xkbcommon: XKB: /usr/share/X11/locale/iso8859-1/Compose:49:29: too many errors
Nov 06 15:52:28 computername kwin_x11[28677]: kwin_xkbcommon: XKB: /usr/share/X11/locale/iso8859-1/Compose:49:29: failed to parse file
Nov 06 15:52:28 computername ksplashqml[28619]: Texture 0x559ef43acd20 () used with different accesses within the same pass, this is not allowed.
Nov 06 15:52:28 computername ksplashqml[28619]: Texture 0x7f9a103cf3c0 () used with different accesses within the same pass, this is not allowed.
Nov 06 15:52:28 computername ksplashqml[28619]: Texture 0x7f9a088514c0 () used with different accesses within the same pass, this is not allowed.
Nov 06 15:52:28 computername kactivitymanagerd[28728]: Detected locale "LC_CTYPE=en_GB;LC_NUMERIC=de_DE.UTF-8;LC_TIME=en_GB.UTF-8;LC_COLLATE=en_GB;LC_MONETARY=de_DE.UTF-8;LC_MESSAGES=en_GB;LC_PAPER=de_DE.UTF-8;LC_NAME=de_DE.UTF-8;LC_ADDRESS=de_DE.UTF-8;LC_TELEPHONE=de_DE.UTF-8;LC_MEASUREMENT=de_DE.UTF-8;LC_IDENTIFICATION=en_GB.UTF-8" with character encoding "ISO-8859-1", which is not UTF-8.
Nov 06 15:52:28 computername xembedsniproxy[28738]: Detected locale "LC_CTYPE=en_GB;LC_NUMERIC=de_DE.UTF-8;LC_TIME=en_GB.UTF-8;LC_COLLATE=en_GB;LC_MONETARY=de_DE.UTF-8;LC_MESSAGES=en_GB;LC_PAPER=de_DE.UTF-8;LC_NAME=de_DE.UTF-8;LC_ADDRESS=de_DE.UTF-8;LC_TELEPHONE=de_DE.UTF-8;LC_MEASUREMENT=de_DE.UTF-8;LC_IDENTIFICATION=en_GB.UTF-8" with character encoding "ISO-8859-1", which is not UTF-8.
Nov 06 15:52:28 computername gmenudbusmenuproxy[28732]: Detected locale "LC_CTYPE=en_GB;LC_NUMERIC=de_DE.UTF-8;LC_TIME=en_GB.UTF-8;LC_COLLATE=en_GB;LC_MONETARY=de_DE.UTF-8;LC_MESSAGES=en_GB;LC_PAPER=de_DE.UTF-8;LC_NAME=de_DE.UTF-8;LC_ADDRESS=de_DE.UTF-8;LC_TELEPHONE=de_DE.UTF-8;LC_MEASUREMENT=de_DE.UTF-8;LC_IDENTIFICATION=en_GB.UTF-8" with character encoding "ISO-8859-1", which is not UTF-8.
Nov 06 15:52:28 computername polkit-kde-authentication-agent-1[28735]: Detected locale "LC_CTYPE=en_GB;LC_NUMERIC=de_DE.UTF-8;LC_TIME=en_GB.UTF-8;LC_COLLATE=en_GB;LC_MONETARY=de_DE.UTF-8;LC_MESSAGES=en_GB;LC_PAPER=de_DE.UTF-8;LC_NAME=de_DE.UTF-8;LC_ADDRESS=de_DE.UTF-8;LC_TELEPHONE=de_DE.UTF-8;LC_MEASUREMENT=de_DE.UTF-8;LC_IDENTIFICATION=en_GB.UTF-8" with character encoding "ISO-8859-1", which is not UTF-8.
Nov 06 15:52:28 computername xdg-desktop-portal-kde[28737]: Detected locale "LC_CTYPE=en_GB;LC_NUMERIC=de_DE.UTF-8;LC_TIME=en_GB.UTF-8;LC_COLLATE=en_GB;LC_MONETARY=de_DE.UTF-8;LC_MESSAGES=en_GB;LC_PAPER=de_DE.UTF-8;LC_NAME=de_DE.UTF-8;LC_ADDRESS=de_DE.UTF-8;LC_TELEPHONE=de_DE.UTF-8;LC_MEASUREMENT=de_DE.UTF-8;LC_IDENTIFICATION=en_GB.UTF-8" with character encoding "ISO-8859-1", which is not UTF-8.
Nov 06 15:52:28 computername org_kde_powerdevil[28736]: Detected locale "LC_CTYPE=en_GB;LC_NUMERIC=de_DE.UTF-8;LC_TIME=en_GB.UTF-8;LC_COLLATE=en_GB;LC_MONETARY=de_DE.UTF-8;LC_MESSAGES=en_GB;LC_PAPER=de_DE.UTF-8;LC_NAME=de_DE.UTF-8;LC_ADDRESS=de_DE.UTF-8;LC_TELEPHONE=de_DE.UTF-8;LC_MEASUREMENT=de_DE.UTF-8;LC_IDENTIFICATION=en_GB.UTF-8" with character encoding "ISO-8859-1", which is not UTF-8.
Nov 06 15:52:28 computername plasmashell[28696]: kde.plasmashell: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Nov 06 15:52:28 computername plasmashell[28696]: kde.plasmashell: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Nov 06 15:52:28 computername wireplumber[1339]: spa.bluez5.midi: org.bluez.GattManager1.RegisterApplication() failed: GDBus.Error:org.bluez.Error.AlreadyExists: Already Exists
Nov 06 15:52:30 computername org_kde_powerdevil[28736]: qt.core.qobject.connect: QObject::disconnect: Unexpected nullptr parameter
Nov 06 15:52:30 computername kernel: [drm:drm_new_set_master] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
Nov 06 15:52:30 computername org_kde_powerdevil[28736]: busno=18, sleep-multiplier = 2,00. Testing for supported feature 0x10 returned Error_Info[EIO in ddc_write_read_with_retry, causes: EIO]
Nov 06 15:52:30 computername plasmashell[28696]: kde.plasmashell: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Nov 06 15:52:30 computername plasmashell[28696]: kde.plasmashell: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Nov 06 15:52:30 computername xdg-desktop-por[28640]: Choosing kwallet.portal for org.freedesktop.impl.portal.Secret via the deprecated UseIn key
Nov 06 15:52:30 computername xdg-desktop-por[28640]: The preferred method to match portal implementations to desktop environments is to use the portals.conf(5) configuration file
Nov 06 15:52:30 computername kconf_update[28822]: Detected locale "LC_CTYPE=en_GB;LC_NUMERIC=de_DE.UTF-8;LC_TIME=en_GB.UTF-8;LC_COLLATE=en_GB;LC_MONETARY=de_DE.UTF-8;LC_MESSAGES=en_GB;LC_PAPER=de_DE.UTF-8;LC_NAME=de_DE.UTF-8;LC_ADDRESS=de_DE.UTF-8;LC_TELEPHONE=de_DE.UTF-8;LC_MEASUREMENT=de_DE.UTF-8;LC_IDENTIFICATION=en_GB.UTF-8" with character encoding "ISO-8859-1", which is not UTF-8.
Nov 06 15:52:30 computername kconf_update[28822]: kf.config.kconf_update: /usr/share/kconf_update/ark.upd defined Version=5 but Version=6 was expected
Nov 06 15:52:30 computername kconf_update[28822]: kf.config.kconf_update: /usr/share/kconf_update/breath2tobreath.upd defined Version=5 but Version=6 was expected
Nov 06 15:52:30 computername kconf_update[28822]: kf.config.kconf_update: /usr/share/kconf_update/dolphin_detailsmodesettings.upd defined Version=5 but Version=6 was expected
Nov 06 15:52:30 computername kconf_update[28822]: kf.config.kconf_update: /usr/share/kconf_update/dolphin_directorysizemode.upd defined Version=5 but Version=6 was expected
Nov 06 15:52:30 computername kconf_update[28822]: kf.config.kconf_update: /usr/share/kconf_update/filepicker.upd defined Version=5 but Version=6 was expected
Nov 06 15:52:30 computername kconf_update[28822]: kf.config.kconf_update: /usr/share/kconf_update/konsole.upd defined Version=5 but Version=6 was expected
Nov 06 15:52:30 computername kconf_update[28822]: kf.config.kconf_update: /usr/share/kconf_update/okular.upd defined Version=5 but Version=6 was expected
Nov 06 15:52:30 computername org_kde_powerdevil[28736]: busno=20, Feature 0xdd should not exist but ddc_get_nontable_vcp_value() succeeds, returning mh=0x00 ml=0x64 sh=0x00 sl=0x64
Nov 06 15:52:31 computername org_kde_powerdevil[28736]: busno=20, Feature 0x41 should not exist but ddc_get_nontable_vcp_value() succeeds, returning mh=0x00 ml=0x64 sh=0x00 sl=0x64
Nov 06 15:52:31 computername kded6[28676]: kf.bluezqt: PendingCall Error: "The name is not activatable"
Nov 06 15:52:31 computername kscreen_backend_launcher[28829]: Detected locale "LC_CTYPE=en_GB;LC_NUMERIC=de_DE.UTF-8;LC_TIME=en_GB.UTF-8;LC_COLLATE=en_GB;LC_MONETARY=de_DE.UTF-8;LC_MESSAGES=en_GB;LC_PAPER=de_DE.UTF-8;LC_NAME=de_DE.UTF-8;LC_ADDRESS=de_DE.UTF-8;LC_TELEPHONE=de_DE.UTF-8;LC_MEASUREMENT=de_DE.UTF-8;LC_IDENTIFICATION=en_GB.UTF-8" with character encoding "ISO-8859-1", which is not UTF-8.
Nov 06 15:52:31 computername org_kde_powerdevil[28736]: busno=20, Feature 0x00 should not exist but ddc_get_nontable_vcp_value() succeeds, returning mh=0x00 ml=0x64 sh=0x00 sl=0x64
Nov 06 15:52:31 computername org_kde_powerdevil[28736]: busno=20, All features that should not exist detected. Monitor does not indicate unsupported
Nov 06 15:52:31 computername kded6[28676]: kscreen.kded: PowerDevil SuspendSession action not available!
Nov 06 15:52:31 computername plasmashell[28696]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:195:25: QML FolderViewDropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
Nov 06 15:52:31 computername wireplumber[1339]: wplua: [string "alsa.lua"]:182: attempt to concatenate a nil value (local 'node_name')
stack traceback:
Nov 06 15:52:31 computername kded6[28676]: org.kde.pulseaudio: No object for name "alsa_output.pci-0000_01_00.1.hdmi-stereo-extra2"
Nov 06 15:52:31 computername plasmashell[28696]: Toolbox not loading, toolbox package is either invalid or disabled.
stack traceback:
Nov 06 15:52:32 computername kwin_x11[28677]: kwin_core: XCB error: 152 (BadDamage), sequence: 2420, resource id: 20971546, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Nov 06 15:52:32 computername backlighthelper[28855]: org.kde.powerdevil: no kernel backlight interface found
Nov 06 15:52:32 computername org_kde_powerdevil[28736]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Nov 06 15:52:32 computername org_kde_powerdevil[28736]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
Nov 06 15:52:33 computername kioworker[28864]: Detected locale "LC_CTYPE=en_GB;LC_NUMERIC=de_DE.UTF-8;LC_TIME=en_GB.UTF-8;LC_COLLATE=en_GB;LC_MONETARY=de_DE.UTF-8;LC_MESSAGES=en_GB;LC_PAPER=de_DE.UTF-8;LC_NAME=de_DE.UTF-8;LC_ADDRESS=de_DE.UTF-8;LC_TELEPHONE=de_DE.UTF-8;LC_MEASUREMENT=de_DE.UTF-8;LC_IDENTIFICATION=en_GB.UTF-8" with character encoding "ISO-8859-1", which is not UTF-8.
Nov 06 15:52:33 computername org_kde_powerdevil[28736]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Nov 06 15:52:33 computername qdbus[28910]: Detected locale "LC_CTYPE=en_GB;LC_NUMERIC=de_DE.UTF-8;LC_TIME=en_GB.UTF-8;LC_COLLATE=en_GB;LC_MONETARY=de_DE.UTF-8;LC_MESSAGES=en_GB;LC_PAPER=de_DE.UTF-8;LC_NAME=de_DE.UTF-8;LC_ADDRESS=de_DE.UTF-8;LC_TELEPHONE=de_DE.UTF-8;LC_MEASUREMENT=de_DE.UTF-8;LC_IDENTIFICATION=en_GB.UTF-8" with character encoding "ISO-8859-1", which is not UTF-8.
Nov 06 15:52:33 computername qdbus[28913]: Detected locale "LC_CTYPE=en_GB;LC_NUMERIC=de_DE.UTF-8;LC_TIME=en_GB.UTF-8;LC_COLLATE=en_GB;LC_MONETARY=de_DE.UTF-8;LC_MESSAGES=en_GB;LC_PAPER=de_DE.UTF-8;LC_NAME=de_DE.UTF-8;LC_ADDRESS=de_DE.UTF-8;LC_TELEPHONE=de_DE.UTF-8;LC_MEASUREMENT=de_DE.UTF-8;LC_IDENTIFICATION=en_GB.UTF-8" with character encoding "ISO-8859-1", which is not UTF-8.
Nov 06 15:52:33 computername org_kde_powerdevil[28736]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Nov 06 15:52:33 computername kdeconnectd[28895]: Detected locale "LC_CTYPE=en_GB;LC_NUMERIC=de_DE.UTF-8;LC_TIME=en_GB.UTF-8;LC_COLLATE=en_GB;LC_MONETARY=de_DE.UTF-8;LC_MESSAGES=en_GB;LC_PAPER=de_DE.UTF-8;LC_NAME=de_DE.UTF-8;LC_ADDRESS=de_DE.UTF-8;LC_TELEPHONE=de_DE.UTF-8;LC_MEASUREMENT=de_DE.UTF-8;LC_IDENTIFICATION=en_GB.UTF-8" with character encoding "ISO-8859-1", which is not UTF-8.
Nov 06 15:52:33 computername kwin_x11[28677]: kf.config.core: "\"fsrestore1\" - conversion of \"0,0,0,0\" to QRect failed"
Nov 06 15:52:33 computername kwin_x11[28677]: kf.config.core: "\"fsrestore2\" - conversion of \"0,0,0,0\" to QRect failed"
Nov 06 15:52:33 computername kwin_x11[28677]: kf.config.core: "\"fsrestore3\" - conversion of \"0,0,0,0\" to QRect failed"
Nov 06 15:52:33 computername kaccess[28920]: Detected locale "LC_CTYPE=en_GB;LC_NUMERIC=de_DE.UTF-8;LC_TIME=en_GB.UTF-8;LC_COLLATE=en_GB;LC_MONETARY=de_DE.UTF-8;LC_MESSAGES=en_GB;LC_PAPER=de_DE.UTF-8;LC_NAME=de_DE.UTF-8;LC_ADDRESS=de_DE.UTF-8;LC_TELEPHONE=de_DE.UTF-8;LC_MEASUREMENT=de_DE.UTF-8;LC_IDENTIFICATION=en_GB.UTF-8" with character encoding "ISO-8859-1", which is not UTF-8.
Nov 06 15:52:33 computername plasma-fallback-session-restore[28922]: Detected locale "LC_CTYPE=en_GB;LC_NUMERIC=de_DE.UTF-8;LC_TIME=en_GB.UTF-8;LC_COLLATE=en_GB;LC_MONETARY=de_DE.UTF-8;LC_MESSAGES=en_GB;LC_PAPER=de_DE.UTF-8;LC_NAME=de_DE.UTF-8;LC_ADDRESS=de_DE.UTF-8;LC_TELEPHONE=de_DE.UTF-8;LC_MEASUREMENT=de_DE.UTF-8;LC_IDENTIFICATION=en_GB.UTF-8" with character encoding "ISO-8859-1", which is not UTF-8.
Nov 06 15:52:33 computername pamac-tray-plasma[28927]: Detected locale "LC_CTYPE=en_GB;LC_NUMERIC=de_DE.UTF-8;LC_TIME=en_GB.UTF-8;LC_COLLATE=en_GB;LC_MONETARY=de_DE.UTF-8;LC_MESSAGES=en_GB;LC_PAPER=de_DE.UTF-8;LC_NAME=de_DE.UTF-8;LC_ADDRESS=de_DE.UTF-8;LC_TELEPHONE=de_DE.UTF-8;LC_MEASUREMENT=de_DE.UTF-8;LC_IDENTIFICATION=en_GB.UTF-8" with character encoding "ISO-8859-1", which is not UTF-8.
Nov 06 15:52:33 computername plasmashell[28696]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/main.qml:162:21: QML KSortFilterProxyModel: Binding loop detected for property "sourceModel"
Nov 06 15:52:33 computername kdeconnectd[28955]: Detected locale "LC_CTYPE=en_GB;LC_NUMERIC=de_DE.UTF-8;LC_TIME=en_GB.UTF-8;LC_COLLATE=en_GB;LC_MONETARY=de_DE.UTF-8;LC_MESSAGES=en_GB;LC_PAPER=de_DE.UTF-8;LC_NAME=de_DE.UTF-8;LC_ADDRESS=de_DE.UTF-8;LC_TELEPHONE=de_DE.UTF-8;LC_MEASUREMENT=de_DE.UTF-8;LC_IDENTIFICATION=en_GB.UTF-8" with character encoding "ISO-8859-1", which is not UTF-8.
Nov 06 15:52:34 computername plasmashell[28696]: qt.core.qobject.connect: QObject::connect: No such signal Solid::Backends::Fstab::FstabStorageAccess::repairRequested(QString)
Nov 06 15:52:34 computername plasmashell[28696]: qt.core.qobject.connect: QObject::connect: No such signal Solid::Backends::Fstab::FstabStorageAccess::repairDone(Solid::ErrorType, QVariant, QString)
Nov 06 15:52:34 computername plasmashell[28696]: qt.dbus.integration: Could not connect "org.cups.cupsd.Notifier" to PrinterFinishingsChanged(QString, QString, QString, uint, QString, bool) :
Nov 06 15:52:34 computername plasmashell[28696]: qml: SystemTray ItemLoader: Invalid state, cannot determine source!
Nov 06 15:52:35 computername kioworker[28998]: Detected locale "LC_CTYPE=en_GB;LC_NUMERIC=de_DE.UTF-8;LC_TIME=en_GB.UTF-8;LC_COLLATE=en_GB;LC_MONETARY=de_DE.UTF-8;LC_MESSAGES=en_GB;LC_PAPER=de_DE.UTF-8;LC_NAME=de_DE.UTF-8;LC_ADDRESS=de_DE.UTF-8;LC_TELEPHONE=de_DE.UTF-8;LC_MEASUREMENT=de_DE.UTF-8;LC_IDENTIFICATION=en_GB.UTF-8" with character encoding "ISO-8859-1", which is not UTF-8.
Nov 06 15:52:35 computername plasmashell[28696]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Nov 06 15:52:37 computername kioworker[29010]: Detected locale "LC_CTYPE=en_GB;LC_NUMERIC=de_DE.UTF-8;LC_TIME=en_GB.UTF-8;LC_COLLATE=en_GB;LC_MONETARY=de_DE.UTF-8;LC_MESSAGES=en_GB;LC_PAPER=de_DE.UTF-8;LC_NAME=de_DE.UTF-8;LC_ADDRESS=de_DE.UTF-8;LC_TELEPHONE=de_DE.UTF-8;LC_MEASUREMENT=de_DE.UTF-8;LC_IDENTIFICATION=en_GB.UTF-8" with character encoding "ISO-8859-1", which is not UTF-8.
Nov 06 15:52:39 computername konsole[29032]: Detected locale "LC_CTYPE=en_GB;LC_NUMERIC=de_DE.UTF-8;LC_TIME=en_GB.UTF-8;LC_COLLATE=en_GB;LC_MONETARY=de_DE.UTF-8;LC_MESSAGES=en_GB;LC_PAPER=de_DE.UTF-8;LC_NAME=de_DE.UTF-8;LC_ADDRESS=de_DE.UTF-8;LC_TELEPHONE=de_DE.UTF-8;LC_MEASUREMENT=de_DE.UTF-8;LC_IDENTIFICATION=en_GB.UTF-8" with character encoding "ISO-8859-1", which is not UTF-8.
Nov 06 15:52:42 computername konsole[29032]: qt.xkb.compose: failed to create compose table
Nov 06 15:52:44 computername kglobalacceld[28633]: kf.globalaccel.kglobalacceld: KKeyServer::xcbKeyPressEventToQt failed
Nov 06 15:54:59 computername kglobalacceld[28633]: kf.globalaccel.kglobalacceld: KKeyServer::xcbKeyPressEventToQt failed
