KDE Plasma on wayland: issue with ultrawide screen (21:9)
The configuration was working few days ago, but now, I unable to use normal 2560x1080x75hz definition (using laptop with hybrid nvidia/intel card RTX2060)
mhwd -li
> Installed PCI configs:
video-hybrid-intel-nvidia-prime   2025.09.29               false            PCI
When searching which output is in use with xrandr
Screen 0: minimum 16 x 16, current 3840 x 1080, maximum 32767 x 32767
eDP-1 connected primary 1920x1080+1920+0 (normal left inverted right x axis y axis) 382mm x 215mm
   1920x1080    143.88*+
   1440x1080    143.90
   720x400      143.88
   640x350      143.57
HDMI-A-1 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 798mm x 334mm
   1920x1080     59.96*+
   1440x1080     59.99
and if I try to change connexion (external USB-C/HDMi interface)
   1920x1080    143.88*+
   1440x1080    143.90
   720x400      143.88
   640x350      143.57
DP-1 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 798mm x 334mm
   1920x1080     59.96*+
   1440x1080     59.99
   1400x1050     59.98
So HDMI-A-1 or DP-1 are same LG monitor with 2560x1080 capacity.
How could I troubleshoot that without AI help (or risks, it depends on my luck) ?
… does not work with Wayland. You have to use kscreen-doctor — it’s in the repository.
I should also add that, from Plasma 6.6.0, users will be able to add custom screen modes, including custom resolutions:
Plasma 6.6.0
Massively improved support for screen mirroring in the Wayland session. Now it works really well! (Xaver Hugl, bug #481222 and kscreen MR #439)
You can now use the kscreen-doctor tool to add custom screen modes, useful for supporting exotic or misbehaving screens in the Wayland session. (Xaver Hugl, bug #456697)
Russell Haley 2025-05-08 16:25:34 UTC
(In reply to Roke Julian Lockhart Beedell from comment #12)
(In reply to Russell Haley from comment #0) >
Although the original FR’s description focusses upon a custom refresh rate/frequency, would this also encompass applying a custom resolution? It appears to, based upon the example commands provided, but an explicit confirmation would be useful. (Otherwise, a pointer to the relevant FR would be even more so. :white_heart:)
Yes, see that Bug 472321 “[WISHLIST] Add custom resolution support.” was marked duplicate of this one.
@Aragorn and @scotty65 You saved my night :slightly_smiling_face:
#Tested and approved
kscreen-doctor output.DP-1.mode.2560x1080@75
#Will be tested in few hours
kscreen-doctor output.HDMI-A-1.mode.2560x1080@75
Thanks
