KDE/Plasma on Wayland does not respect screen priority after latest update (05.02.2025)
Hey
I have 2 GPUs with 5 screens and up until the latest update my central screen was set as primary and respected. Since last update some windows (and games) are started on the screen on the left.
Has anyone encounter similar behaviour / know about how to fix this?
Thanks
Setup:
Output: 1 DP-2
enabled, connected, priority 3, DisplayPort, Modes: 2560x1440@60, Geometry: 5120,1080 2560x1440, Scale: 1, Rotation: 1
Output: 2 DP-1
enabled, connected, priority 1, DisplayPort, Modes:  2560x1440@85, Geometry: 2560,1080 2560x1440, Scale: 1, Rotation: 1
Output: 3 DP-3
enabled, connected, priority 2, DisplayPort, Modes:2560x1440@70, Geometry: 0,1080 2560x1440, Scale: 1, Rotation: 1
Output: 4 HDMI-A-1
enabled, connected, priority 4, HDMI, Modes: 1920x1080@75, Geometry: 3200,0 1920x1080, Scale: 1, Rotation: 1
Output: 5 HDMI-A-2
enabled, connected, priority 5, HDMI, Modes:1920x1080@75, Geometry: 5120,0 1920x1080, Scale: 1, Rotation: 1
inxi -Farz
  Kernel: 6.6.74-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=63bb6c38-57a7-4853-94f3-d187e879faca rw udev.log_priority=3
  Desktop: KDE Plasma v: 6.2.5 tk: Qt v: N/A wm: kwin_wayland with: krunner
    tools: avail: xfce4-screensaver dm: SDDM Distro: Manjaro base: Arch Linux
  Type: Desktop Mobo: Micro-Star model: MEG X570 ACE (MS-7C35) v: 1.0
    serial: <filter> uuid: 9bb58aad-e88c-5416-a59d-00d861a803e6
    UEFI: American Megatrends v: 1.C0 date: 10/29/2020
  Info: model: AMD Ryzen 9 3900X socket: AM4 bits: 64 type: MT MCP arch: Zen 2
    gen: 2 level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
    family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701034
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 12 threads: 24 tpc: 2
    smt: enabled cache: L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB
    desc: 12x512 KiB L3: 64 MiB desc: 4x16 MiB
  Speed (MHz): avg: 3800 min/max: 2200/4672 boost: enabled
    base/boost: 3800/4650 scaling: driver: acpi-cpufreq governor: performance
    volts: 1.1 V ext-clock: 100 MHz cores: 1: 3800 2: 3800 3: 3800 4: 3800
    5: 3800 6: 3800 7: 3800 8: 3800 9: 3800 10: 3800 11: 3800 12: 3800
    13: 3800 14: 3800 15: 3800 16: 3800 17: 3800 18: 3800 19: 3800 20: 3800
    21: 3800 22: 3800 23: 3800 24: 3800 bogomips: 182494
  Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
    protection
    always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 22 [Radeon RX 6700/6700
    XT/6750 XT / 6800M/6850M XT] vendor: Micro-Star MSI driver: amdgpu
    v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm) built: 2020-22
    pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1, DP-2, DP-3,
    HDMI-A-1 empty: none bus-ID: 2f:00.0 chip-ID: 1002:73df class-ID: 0300
  Device-2: Advanced Micro Devices [AMD/ATI] Lexa PRO [Radeon
    540/540X/550/550X / RX 540X/550/550X] driver: amdgpu v: kernel arch: GCN-4
    code: Arctic Islands process: GF 14nm built: 2016-20 pcie: gen: 3
    speed: 8 GT/s lanes: 8 ports: active: HDMI-A-2 empty: DP-4,DVI-D-1
    bus-ID: 30:00.0 chip-ID: 1002:699f class-ID: 0300 temp: 37.0 C
  Device-3: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1.2:5
    chip-ID: 046d:082d class-ID: 0102 serial: <filter>
  Device-4: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1.3:7
    chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
  Display: unspecified server: X.Org v: 24.1.4 with: Xwayland v: 24.1.4
    compositor: kwin_wayland driver: X: loaded: amdgpu
    gpu: amdgpu display-ID: :1 screens: 1
  Screen-1: 0 s-res: 7680x2520 s-dpi: 96 s-size: 2032x666mm (80.00x26.22")
    s-diag: 2138mm (84.19")
  Monitor-1: DP-1 pos: primary,2-2 model: MSI MPG27CQ2 serial: <filter>
    built: 2019 res: mode: 2560x1440 hz: 85 scale: 100% (1) dpi: 109 gamma: 1.2
    size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9 modes:
    max: 2560x1440 min: 720x400
  Monitor-2: DP-2 pos: 2-4 model: Idek Iiyama PL2792UH serial: <filter>
    built: 2020 res: mode: 2560x1440 hz: 60 scale: 100% (1) dpi: 109 gamma: 1.2
    size: 596x335mm (23.46x13.19") diag: 684mm (26.9") ratio: 16:9 modes:
    max: 3840x2160 min: 720x400
  Monitor-3: DP-3 pos: 2-1 model: Idek Iiyama PL2792Q serial: <filter>
    built: 2020 res: mode: 2560x1440 hz: 70 scale: 100% (1) dpi: 109 gamma: 1.2
    max: 2560x1440 min: 640x480
  Monitor-4: HDMI-A-1 pos: 1-3 model: MSI MP242 serial: <filter> built: 2022
    res: mode: 1920x1080 hz: 75 scale: 100% (1) dpi: 93 gamma: 1.2
    size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9 modes:
    max: 1920x1080 min: 720x400
  Monitor-5: HDMI-A-2 pos: 1-4 model: MSI MP242 serial: <filter> built: 2022
    device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: radeonsi
    surfaceless: drv: radeonsi x11: drv: radeonsi inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.4-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6750 XT (radeonsi
    navi22 LLVM 19.1.7 DRM 3.54 6.6.74-1-MANJARO) device-ID: 1002:73df
    memory: 11.72 GiB unified: no
  API: Vulkan v: 1.4.303 layers: 3 device: 0 type: discrete-gpu name: AMD
    Radeon RX 6750 XT (RADV NAVI22) driver: N/A device-ID: 1002:73df
    surfaces: xcb,xlib device: 1 type: discrete-gpu name: AMD Radeon RX 550 /
    550 Series (RADV POLARIS12) driver: N/A device-ID: 1002:699f
    surfaces: xcb,xlib
  Info: Tools: api: clinfo, eglinfo, glxinfo, vulkaninfo de: kscreen-console,
    kscreen-doctor, xfce4-display-settings gpu: corectrl
    wl: way-displays,wayland-info x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio
    bus-ID: 2f:00.1 chip-ID: 1002:ab28 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Baffin HDMI/DP Audio [Radeon
    RX 550 640SP / 560/560X] driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 8 bus-ID: 30:00.1 chip-ID: 1002:aae0 class-ID: 0403
  Device-3: Advanced Micro Devices [AMD] Starship/Matisse HD Audio
    vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 32:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-4: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
  Device-5: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
  API: ALSA v: k6.6.74-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: n/a (root, process) with: wireplumber
    status: active tools: pw-cli,wpctl
  Server-3: PulseAudio v: 17.0-43-g3e2bb status: active (root, process)
    with: pulseaudio-alsa type: plugin tools: pacat,pactl
  Device-1: Intel I211 Gigabit Network vendor: Micro-Star MSI driver: igb
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 26:00.0
  IF: enp38s0 state: down mac: <filter>
  Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: c000 bus-ID: 27:00.0
  IF: enp39s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-3: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 28:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF-ID-1: tun0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
  Info: services: NetworkManager, smbd, sshd, systemd-timesyncd,
    wpa_supplicant
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:2 chip-ID: 8087:0029
    class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 0 state: down bt-service: enabled,running
    rfk-block: hardware: no software: yes address: <filter> bt-v: 5.2 lmp-v: 11
    status: discoverable: no pairing: no
  Local Storage: total: 5.46 TiB used: 2.33 TiB (42.8%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Corsair model: Force MP600
    lanes: 4 tech: SSD serial: <filter> fw-rev: EGFM11.3 temp: 50.9 C
    scheme: GPT
  SMART: yes health: PASSED on: 4y 80d 16h cycles: 270
    read-units: 21,490,573 [11.0 TB] written-units: 47,786,482 [24.4 TB]
  ID-2: /dev/nvme1n1 maj-min: 259:8 vendor: Crucial model: CT2000P3SSD8
    size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR30A temp: 42.9 C
    scheme: GPT
  SMART: yes health: PASSED on: 1y 131d 18h cycles: 18
    read-units: 12,855,896 [6.58 TB] written-units: 13,409,934 [6.86 TB]
  ID-3: /dev/nvme2n1 maj-min: 259:1 vendor: Sabrent model: Rocket 4.0 1TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: RKT401.2 temp: 33.9 C
    scheme: GPT
  SMART: yes health: PASSED on: 4y 80d 15h cycles: 270
    read-units: 17,215,748 [8.81 TB] written-units: 17,647,989 [9.03 TB]
  ID-4: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 500GB
    family: based SSDs size: 465.76 GiB block-size: physical: 512 B
    logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: SSD serial: <filter>
    fw-rev: 3B6Q temp: 32 C scheme: MBR
  SMART: yes state: enabled health: PASSED on: 4y 115d 0h cycles: 278
    written: 1.86 TiB
  ID-5: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SSD PLUS 1000GB
    family: Marvell based SSDs size: 931.52 GiB block-size: physical: 512 B
    logical: 512 B sata: 3.2 speed: 6.0 Gb/s tech: SSD serial: <filter>
    fw-rev: 00RL temp: 28 C scheme: MBR
  SMART: yes state: enabled health: PASSED on: 1y 213d 13h cycles: 289
  ID-6: /dev/sdc maj-min: 8:32 vendor: SanDisk model: USB 3.2Gen1
    size: 232.88 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
    fw-rev: 1.00 scheme: MBR
  ID-7: /dev/sdd maj-min: 8:48 vendor: SanDisk model: USB 3.2Gen1
  ID-1: / raw-size: 220.22 GiB size: 215.7 GiB (97.95%)
    used: 59.37 GiB (27.5%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p8
    maj-min: 259:7
  ID-2: /boot/efi raw-size: 2 GiB size: 2 GiB (99.80%) used: 41.2 MiB (2.0%)
    fs: vfat block-size: 512 B dev: /dev/nvme0n1p3 maj-min: 259:5
  ID-3: /home raw-size: 429 GiB size: 421.2 GiB (98.18%)
    used: 329.07 GiB (78.1%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p4
    maj-min: 259:6
  System Temperatures: cpu: 40.0 C mobo: 37.0 C
  Fan Speeds (rpm): fan-1: 2149 fan-2: 745 fan-3: 0 fan-4: 1584 fan-5: 0
    fan-6: 0 fan-7: 1755
  GPU: device: amdgpu temp: 51.0 C mem: 54.0 C fan: 825 watts: 37.00
    device: amdgpu temp: 37.0 C watts: 3.23
  Packages: pm: dpkg pkgs: 0 pm: pacman pkgs: 2136 libs: 557 tools: pamac,yay
    pm: flatpak pkgs: 0
    1: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
  Memory: total: 32 GiB available: 31.26 GiB used: 14.67 GiB (46.9%)
  Processes: 591 Power: uptime: 5d 13h 33m states: freeze,mem,disk
    suspend: deep avail: s2idle wakeups: 0 hibernate: platform avail: shutdown,
    reboot, suspend, test_resume image: 12.49 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Bash (sudo) v: 5.2.37
    running-in: terminator inxi: 3.3.37
mhwd -li -l
> Installed PCI configs:
           video-linux            2024.05.06                true            PCI
> 0000:2f:00.0 (0300:1002:73df) Display controller ATI Technologies Inc:
> 0000:30:00.0 (0300:1002:699f) Display controller ATI Technologies Inc:
