So, as the title says, I don’t hear the blooping sound unless audio is playing on some other audio source, like Spotify (but not zoom, for some reason.) In addition, pausing and playing audio leads to the audio slider ‘resetting’ depending on if the audio is playing or not.
- Go to System Settings
- Type
sound
- Ensure the Notification sounds are not muted:
(which was the issue with my system when I had what you now have…)
Thanks, this fixed it! I wish there was a way to mute all notifications EXCEPT for this.
You can. Right-click the notifications icon in your panel (use the “Show hidden icons” icon if it’s not shown), select “Configure Event Notifications and Actions” then the “Configure” button near the bottom.
