Hey there,
I have just recently installed Manjaro KDE and everything except one single thing has been working. Sadly that thing is not that small of an issue. Every time I lock my system, I get thrown to the old Login screen which is not the SDDM installed one.
I cannot login from that login screen, it just says: Unlocking failed. Maybe that is because I have no password, however I feel like that would not change the following.
Because I cannot login I press ¨Switch User". I now am redirected to my SDDM Login Screen. The Bug occurs right here:
I cannot type with my keyboard
If I can, I can login with no password (because I don´t have one), however as soon as I get past the Login Screen, the Screen is fully black. Nothing works. My Hz Rate on my main monitor is also downplayed to 60hz.
I suspect KDE is having an issue loading itself up or is caught on the old Login Screen. I really would appreciate the help, it ruins productivity, is frustrating and I also have to hard reset my machine every time this happens by pressing the power button. I cannot find a solution online.
