KDE Plasma freezing constantly
Provide your system information, whenever relevant or when in doubt.
  • Latest manjaro stable (just ran pamac update and pacman -Syu)
  • Ryzen 7 3800x
  • Nvidia RTX 3070
  • gpu driver video-linux
Provide text information as formatted text
I’m having an issue with plasmashell on manjaro.
a quick breakdown is that plasmashell freezes and wont respond to anything (the clock in my taskbar is frozen at whatever time the freeze happens).
I’ve tried using plasmashell --replace as mentioned on a lot of reddit posts but this doesn’t work (also tried using kill/killall).
Any apps that are open at the time of the freeze remain functional and i can use them, move and resize the windows etc, and alt tab still works to switch between them. But clicking anything in the shell (app launcher, icons in taskbar etc) does nothing.
command output and file content as formatted text
kf.dbusaddons: Failed to register name 'org.kde.plasmashell' with DBUS - does this process have permission to use the name, and do no other processes own it already?
The journal is FLOODED with Unknown key Qt::Key_Alt but i think that may be a red herring.
journalctl -b -r _COMM=plasmashell
Oct 11 12:39:52 manjaro-desktop plasmashell[1088]: org.kde.plasma.keyboardindicator: Unknown key Qt::Key_Alt
Oct 11 12:36:49 manjaro-desktop plasmashell[1088]: qt.svg: <input>:303:2221: Could not add child element to parent element because the types are incorrect.
Oct 11 12:36:49 manjaro-desktop plasmashell[1088]: qt.svg: <input>:303:1978: Could not add child element to parent element because the types are incorrect.
Oct 11 12:36:49 manjaro-desktop plasmashell[1088]: qt.svg: <input>:303:1737: Could not add child element to parent element because the types are incorrect.
Oct 11 12:36:49 manjaro-desktop plasmashell[1088]: qt.svg: <input>:303:1629: Could not add child element to parent element because the types are incorrect.
Oct 11 12:36:49 manjaro-desktop plasmashell[1088]: qt.svg: <input>:303:1451: Could not add child element to parent element because the types are incorrect.
Oct 11 12:36:49 manjaro-desktop plasmashell[1088]: qt.svg: <input>:303:1249: Could not add child element to parent element because the types are incorrect.
Oct 11 12:36:49 manjaro-desktop plasmashell[1088]: qt.svg: <input>:303:1047: Could not add child element to parent element because the types are incorrect.
Oct 11 12:36:49 manjaro-desktop plasmashell[1088]: qt.svg: <input>:303:911: Could not add child element to parent element because the types are incorrect.
Oct 11 12:36:49 manjaro-desktop plasmashell[1088]: qt.svg: <input>:303:657: Could not add child element to parent element because the types are incorrect.
Oct 11 12:36:49 manjaro-desktop plasmashell[1088]: qt.svg: <input>:303:461: Could not add child element to parent element because the types are incorrect.
Oct 11 12:36:49 manjaro-desktop plasmashell[1088]: qt.svg: <input>:303:256: Could not add child element to parent element because the types are incorrect.
Oct 11 12:28:57 manjaro-desktop plasmashell[1088]: org.kde.plasma.keyboardindicator: Unknown key Qt::Key_Alt
Oct 11 12:28:56 manjaro-desktop plasmashell[1088]: org.kde.plasma.keyboardindicator: Unknown key Qt::Key_Alt
Oct 11 12:28:55 manjaro-desktop plasmashell[1088]: org.kde.plasma.keyboardindicator: Unknown key Qt::Key_Alt
Oct 11 12:28:35 manjaro-desktop plasmashell[1088]: org.kde.plasma.keyboardindicator: Unknown key Qt::Key_Alt
Oct 11 12:28:30 manjaro-desktop plasmashell[1088]: org.kde.plasma.keyboardindicator: Unknown key Qt::Key_Alt
Oct 11 12:28:29 manjaro-desktop plasmashell[1088]: org.kde.plasma.keyboardindicator: Unknown key Qt::Key_Alt
Oct 11 12:28:28 manjaro-desktop plasmashell[1088]: org.kde.plasma.keyboardindicator: Unknown key Qt::Key_Alt
Oct 11 12:28:27 manjaro-desktop plasmashell[1088]: org.kde.plasma.keyboardindicator: Unknown key Qt::Key_Alt
Oct 11 12:28:25 manjaro-desktop plasmashell[1088]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Oct 11 12:28:24 manjaro-desktop plasmashell[1088]: The cached device pixel ratio value was stale on window update.  Please file a QTBUG which explains how to reproduce.
Oct 11 12:28:24 manjaro-desktop plasmashell[1088]: qt.svg: <input>:303:2221: Could not add child element to parent element because the types are incorrect.
Oct 11 12:28:24 manjaro-desktop plasmashell[1088]: qt.svg: <input>:303:1978: Could not add child element to parent element because the types are incorrect.
Oct 11 12:28:24 manjaro-desktop plasmashell[1088]: qt.svg: <input>:303:1737: Could not add child element to parent element because the types are incorrect.
Oct 11 12:28:24 manjaro-desktop plasmashell[1088]: qt.svg: <input>:303:1629: Could not add child element to parent element because the types are incorrect.
Oct 11 12:28:24 manjaro-desktop plasmashell[1088]: qt.svg: <input>:303:1451: Could not add child element to parent element because the types are incorrect.
Oct 11 12:28:24 manjaro-desktop plasmashell[1088]: qt.svg: <input>:303:1249: Could not add child element to parent element because the types are incorrect.
Oct 11 12:28:24 manjaro-desktop plasmashell[1088]: qt.svg: <input>:303:1047: Could not add child element to parent element because the types are incorrect.
Oct 11 12:28:24 manjaro-desktop plasmashell[1088]: qt.svg: <input>:303:911: Could not add child element to parent element because the types are incorrect.
Oct 11 12:28:24 manjaro-desktop plasmashell[1088]: qt.svg: <input>:303:657: Could not add child element to parent element because the types are incorrect.
Oct 11 12:28:24 manjaro-desktop plasmashell[1088]: qt.svg: <input>:303:461: Could not add child element to parent element because the types are incorrect.
Oct 11 12:28:24 manjaro-desktop plasmashell[1088]: qt.svg: <input>:303:256: Could not add child element to parent element because the types are incorrect.
Oct 11 12:28:23 manjaro-desktop plasmashell[1088]: qt.svg: <input>:303:2221: Could not add child element to parent element because the types are incorrect.
Oct 11 12:28:23 manjaro-desktop plasmashell[1088]: qt.svg: <input>:303:1978: Could not add child element to parent element because the types are incorrect.
Oct 11 12:28:23 manjaro-desktop plasmashell[1088]: qt.svg: <input>:303:1737: Could not add child element to parent element because the types are incorrect.
Oct 11 12:28:23 manjaro-desktop plasmashell[1088]: qt.svg: <input>:303:1629: Could not add child element to parent element because the types are incorrect.
Oct 11 12:28:23 manjaro-desktop plasmashell[1088]: qt.svg: <input>:303:1451: Could not add child element to parent element because the types are incorrect.
Oct 11 12:28:23 manjaro-desktop plasmashell[1088]: qt.svg: <input>:303:1249: Could not add child element to parent element because the types are incorrect.
Oct 11 12:28:23 manjaro-desktop plasmashell[1088]: qt.svg: <input>:303:1047: Could not add child element to parent element because the types are incorrect.
Oct 11 12:28:23 manjaro-desktop plasmashell[1088]: qt.svg: <input>:303:911: Could not add child element to parent element because the types are incorrect.
Oct 11 12:28:23 manjaro-desktop plasmashell[1088]: qt.svg: <input>:303:657: Could not add child element to parent element because the types are incorrect.
Oct 11 12:28:23 manjaro-desktop plasmashell[1088]: qt.svg: <input>:303:461: Could not add child element to parent element because the types are incorrect.
Oct 11 12:28:23 manjaro-desktop plasmashell[1088]: qt.svg: <input>:303:256: Could not add child element to parent element because the types are incorrect.
Oct 11 12:28:23 manjaro-desktop plasmashell[1088]: Toolbox not loading, toolbox package is either invalid or disabled.
Oct 11 12:28:23 manjaro-desktop plasmashell[1088]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:195:25: QML FolderViewDropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
Oct 11 12:28:23 manjaro-desktop plasmashell[1088]: kf.plasma.quick: Applet preload policy set to 1
Oct 11 12:28:23 manjaro-desktop plasmashell[1088]: kde.plasmashell: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Oct 11 12:28:23 manjaro-desktop plasmashell[1088]: kde.plasmashell: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
EDITS
  1. I just checked htop… a plasmashell process is eating 100% of a single core it seems
mod. edit: Nvidia added
It’s still happening after this but way less often
quick update if anyone is looking at this in the future:
  • I installed the proprietary nvidia drivers (550.120 at the time of writing)
  • I ran into issues with wayland (black screen w/ cursor and nothing else)
  • switched to x11, used sudo nvidia-settings and set my display resolutions and refresh rates in there
  • leaving it this way for now. I was only using wayland for the fractional scaling anyway, so this works okay.
