Hello everyone!
I’ve been working on setting up fingerprint authentication on Manjaro KDE, and I’ve made some progress. However, I’m encountering an issue where fingerprint authentication does not work on the login screen or other areas. I have successfully registered my fingerprint using the following steps:
- Installed the required packages:
sudo pacman -S fprintd libfprint
- Started and enabled the
fprintd
service:
sudo systemctl start fprintd.service
sudo systemctl enable fprintd.service
- Fixed an issue during enablement:
- Edited the
fprintd.service
file:
sudo systemctl edit --full --force fprintd.service
- Added the following lines under the
[Install]
section:
[Install]
WantedBy=multi-user.target
- Reloaded the systemd configuration:
sudo systemctl daemon-reload
- Verified the status of the
fprintd
service:
sudo systemctl status fprintd.service
- Enrolled my fingerprint:
fprintd-enroll
- Enabled the
fprintd
service:
- Edited the
/etc/sddm.conf
file:
sudo nano /etc/sddm.conf
- Added the following configuration under the
[General]
section:
[General]
EnablePAM=true
- Edited the
/etc/pam.d/sddm
file:
sudo nano /etc/pam.d/sddm
- Added the following line:
auth sufficient pam_fprintd.so
After following these steps, fingerprint authentication worked as expected. However, when I restarted the system, fingerprint authentication still did not function on the login screen. I had to manually log in using another authentication method.
To enhance the functionality and usability of fingerprint authentication on Manjaro KDE, I kindly request the following feature:
Feature Request:
- Enable seamless fingerprint authentication on the login screen.
I greatly appreciate the work of the community in developing and maintaining the fingerprint authentication features. Your efforts have made Manjaro KDE an outstanding distribution. I kindly request assistance from the community to resolve the issue of fingerprint authentication not working on the login screen.
Thank you all for your contributions and support!
