KDE plasma does not interact any more with graphics card
Since one of the recent system updates applications using the graphics card don’t find it any more.
The log says:
K-System log
04.11.26 13:41              kernel              nouveau 0000:01:00.0: gr: DATA_ERROR 00000004 INVALID_VALUE' ch 8 003f969000 Xwayland 1083 subc 0 class 9097 mthd 0804 data 03705908
(Sorry, I had to remove backslashes and brackets from this lo entry since they were interpreted as links by the forum software)
Some system information follows:
Betriebssystem: Manjaro Linux
KDE-Plasma-Version: 6.7.5
KDE-Frameworks-Version: 6.30.0
Qt-Version: 6.11.2
Kernel-Version: 6.18.55-1-MANJARO (64-bit)
Grafik-Plattform: Wayland
Prozessoren: 8 × Intel® Core™ i7-2600 CPU @ 3.40GHz
Arbeitsspeicher: 16 GiB (15.6 GiB nutzbar)
Grafikprozessor: NVCF
mhwd -li -d:
  ATTACHED:    PCI
  VERSION:     2024.05.06
  INFO:        Standard open source drivers.
  PRIORITY:    2
  FREEDRIVER:  true
  DEPENDS:     -
  CONFLICTS:   -
  CLASSIDS:    0300 0380 0302
  VENDORIDS:   1002 8086 10de
mhwd -l:
## 0000:01:00.0 (0300:10de:1245) Display controller nVidia Corporation:
##                  NAME               VERSION          FREEDRIVER           TYPE
video-nvidia-390xx            2023.03.23               false            PCI
          video-linux            2024.05.06                true            PCI
inxi -G:
 Device-1: NVIDIA GF116 [GeForce GTS 450 Rev. 2] driver: nouveau v: kernel
 Display: wayland server: X.org v: 1.21.1.24 with: Xwayland v: 24.1.13
   compositor: kwin_wayland driver: X: loaded: modesetting dri: nouveau
   gpu: nouveau resolution: 1920x1080~75Hz
 API: EGL v: 1.5 drivers: nouveau,swrast
 API: OpenGL v: 4.6 compat-v: 4.3 vendor: mesa v: 26.2.4-arch1.1
   renderer: NVCF
Thanks for helping me out.
Rudolf
Mod edit:- Please ensure that all code, commands and command output are properly formatted as per forum guidelines. As a forum member you are expected to handle this yourself.
Fixed for you, one time. No charge. :wink:
You are welcome.
Now, help out those who might wish to assist, by posting information in accordance with forum guidelines – See both “Mini-HowTo’s” (below :point_down:) to learn how code, commands and command output is required to be presented, to make it generally more readable by others.
Practice your new-found skill by providing output of the following command as pre-formatted text, in an appropriate box / code fence:
inxi -zv8
If markdown is entered correctly when creating code fences, there will typically be no warnings – warnings are part of live feedback in the Compose window while editing – they can generally be ignored when you press Reply.
inxi -zv8 (short-form)
Your privacy is respected
What is a Quark?
With regard the issue itself, I’m sure someone will help when they are able.
❯ inxi -zv8
  Kernel: 6.18.55-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.18-x86_64
    root=UUID=4a319914-09e9-4b25-9493-068b6c5032b0 rw rootflags=subvol=@
  Desktop: KDE Plasma v: 6.7.5 tk: Qt v: N/A info: frameworks v: 6.30.0
    wm: kwin_wayland vt: 2 dm: N/A Distro: Manjaro base: Arch Linux
  Type: Desktop Mobo: ASRock model: P67 Pro serial: <superuser required>
    uuid: <superuser required> Firmware: BIOS vendor: American Megatrends
    v: P1.60 date: 04/08/2011
  System RAM: total: 16 GiB available: 15.59 GiB used: 2.7 GiB (17.3%)
  Array-1: capacity: 16 GiB slots: 4 modules: 4 EC: None
    max-module-size: 4 GiB note: est.
  Device-1: A1_DIMM0 type: DDR3 detail: synchronous size: 4 GiB
    speed: 1333 MT/s volts: N/A width (bits): data: 64 total: 64
    manufacturer: Kingston part-no: 99U5471-012.A00LF serial: <filter>
  Device-2: A1_DIMM1 type: DDR3 detail: synchronous size: 4 GiB
  Device-3: A1_DIMM2 type: DDR3 detail: synchronous size: 4 GiB
  Device-4: A1_DIMM3 type: DDR3 detail: synchronous size: 4 GiB
  Info: model: Intel Core i7-2600 bits: 64 type: MT MCP arch: Sandy Bridge
    gen: core 2 level: v2 built: 2010-12 process: Intel 32nm family: 6
    model-id: 0x2A (42) stepping: 7 microcode: 0x2F
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
    desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 3800 min/max: 1600/3800 scaling: driver: intel_cpufreq
    governor: schedutil cores: 1: 3800 2: 3800 3: 3800 4: 3800 5: 3800 6: 3800
    7: 3800 8: 3800 bogomips: 54276
  Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
    constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept est
    flexpriority flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce
    md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
    pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdtscp rep_good
    sep smx ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
    tsc tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology
    xtpr
    vulnerable
    STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Device-1: NVIDIA GF116 [GeForce GTS 450 Rev. 2] vendor: ASUSTeK
    driver: nouveau v: kernel alternate: nova_core non-free: series: 390.xx+
    status: legacy (EOL~2022-11-22) last: release: 390.157 kernel: 6.0
    xorg: 1.21 arch: Fermi code: GF1xx process: 40/28nm built: 2010-2016 pcie:
    gen: 1 speed: 2.5 GT/s lanes: 16 ports: active: DVI-I-1
    empty: HDMI-A-1,VGA-1 bus-ID: 01:00.0 chip-ID: 10de:1245 class-ID: 0300
    temp: 30.0 C
    alternate: fbdev,vesa dri: nouveau gpu: nouveau display-ID: 0
  Monitor-1: DVI-I-1 model: AOC Q27P2G5 serial: <filter> built: 2021 res:
    mode: 1920x1080 hz: 75 scale: 100% (1) dpi: 109 gamma: 1.2 chroma: red:
    x: 0.647 y: 0.329 green: x: 0.322 y: 0.620 blue: x: 0.149 y: 0.051 white:
    x: 0.314 y: 0.329 size: 597x336mm (23.5x13.23") diag: 685mm (27")
    ratio: 16:9 modes: 1920x1080, 1920x1080i, 1280x1440, 1680x1050,
    1280x1024, 1440x900, 1280x960, 1280x720, 1024x768, 832x624, 800x600,
    720x576, 720x480, 640x480, 720x400
  API: EGL v: 1.5 hw: drv: nvidia nouveau platforms: device: 0 drv: nouveau
    device: 1 drv: swrast gbm: drv: nouveau surfaceless: drv: nouveau wayland:
    drv: nouveau x11: drv: nouveau
  API: OpenGL v: 4.6 compat-v: 4.3 vendor: mesa v: 26.2.4-arch1.1 glx-v: 1.4
    direct-render: yes renderer: NVCF device-ID: 10de:1245 memory: 991.2 MiB
    unified: no display-ID: :0.0
    vendor: ASRock driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
    chip-ID: 8086:1c20 class-ID: 0403
  Device-2: NVIDIA GF116 High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
    bus-ID: 01:00.1 chip-ID: 10de:0bee class-ID: 0403
  API: ALSA v: k6.18.55-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.9 status: active with: 1: pipewire-pulse
    vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Info: services: NetworkManager, smbd, systemd-timesyncd
  Local Storage: total: 1.6 TiB used: 81.29 GiB (5.0%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT256MX100SSD1
    size: 238.47 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: MU01 scheme: MBR
  ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
    model: WD10EZRX-00A8LB0 size: 931.51 GiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: N/A serial: <filter> fw-rev: 1A01
    scheme: MBR
  ID-3: /dev/sdc maj-min: 8:32 vendor: Crucial model: CT500MX500SSD1
    size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 043 scheme: MBR
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: BD-RE BH10LS38 rev: 1.00
    dev-links: cdrom
  Features: speed: 40 multisession: yes audio: yes dvd: yes
  ID-1: / raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
    used: 81.29 GiB (17.5%) fs: btrfs dev: /dev/sdc1 maj-min: 8:33 label: N/A
    uuid: 4a319914-09e9-4b25-9493-068b6c5032b0
  ID-2: /home raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
  ID-3: /var/cache raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
  ID-4: /var/log raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
  ID-1: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: ntfs label: System-reserviert
    uuid: 4A883B6D883B56A3
  ID-2: /dev/sda2 maj-min: 8:2 size: 238.37 GiB fs: ntfs label: N/A
    uuid: 166443F56443D661
  ID-3: /dev/sdb1 maj-min: 8:17 size: 500.59 GiB fs: ntfs label: N/A
    uuid: 22B25E17B25DF031
  Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:0024
  Device-1: 1-1.3:3 info: Alcor Micro AU6375 4-LUN card reader
    type: mass storage driver: usb-storage interfaces: 1 rev: 2.0
    chip-ID: 058f:6377 class-ID: 0806 serial: <filter>
  Device-2: 1-1.4:4 info: Novatek Micro Keyboard (Labtec Ultra Flat
    Keyboard) type: keyboard,HID driver: hid-generic,usbhid interfaces: 2
    rev: 1.1 speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 100mA
    chip-ID: 0603:00f2 class-ID: 0300
  Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
  Device-1: 2-1.4:3 info: Shenzhen Rapoo E9260 Wireless Multi-mode Keyboard
    type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    chip-ID: 24ae:1813 class-ID: 0301
  Device-2: 2-1.6:4 info: Shenzhen Rapoo 2.4G Wireless Device Serial
    type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    chip-ID: 24ae:2000 class-ID: 0301
  System Temperatures: cpu: 42.0 C mobo: N/A gpu: nouveau temp: 30.0 C
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1472 libs: 388 tools: pamac pm: flatpak pkgs: 0
    1: https://mirror.init7.net/manjaro/stable/$repo/$arch
    2: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
    3: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
    4: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    5: https://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
    6: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    7: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    8: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 269
  1: cpu: 22.7% command: firefox pid: 1410 mem: 491.9 MiB (3.0%)
  2: cpu: 8.9% command: pamac-manager pid: 2029 mem: 918.5 MiB (5.7%)
  3: cpu: 8.2% command: firefox pid: 1778 mem: 303.1 MiB (1.8%)
  4: cpu: 7.2% command: plasmashell pid: 1096 mem: 339.6 MiB (2.1%)
  5: cpu: 6.5% command: kwin_wayland pid: 978 mem: 195.5 MiB (1.2%)
  Memory top: 5 of 269
  1: mem: 918.5 MiB (5.7%) command: pamac-manager pid: 2029 cpu: 8.9%
  2: mem: 491.9 MiB (3.0%) command: firefox pid: 1410 cpu: 22.7%
  3: mem: 339.6 MiB (2.1%) command: plasmashell pid: 1096 cpu: 7.2%
  4: mem: 303.1 MiB (1.8%) command: firefox pid: 1778 cpu: 8.2%
  5: mem: 226.9 MiB (1.4%) command: firefox pid: 1745 cpu: 4.0%
  Processes: 269 Power: uptime: 1m states: freeze,standby,mem,disk
    suspend: deep avail: s2idle,shallow wakeups: 0 hibernate: platform
    avail: shutdown, reboot, suspend, test_resume image: 6.18 GiB
    services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd
    v: 261 default: graphical tool: systemctl
  Compilers: clang: 23.1.1 gcc: 16.2.1 Shell: Zsh v: 5.9.2
    running-in: konsole inxi: 3.3.41
I note that your computer is quite old – although what follows is not a direct fix for the stated problem, these observations might be useful:
The mainboard itself reached EOL in 2018, however there are updated BIOS firmwares available from the ASRock site ASRock P67 Pro BIOS:
2.25B (Beta) 2015/04/27 Improve VGA compatibility.
2.20 2012/06/06 1. Modify for Windows8 shut down behavior.
2. Add Dehumidifier Function.
A non-Beta BIOS update (2.20) might typically be preferable, however, the Beta BIOS (2.25B) does mention “Improve VGA compatibility” :eyes:
  • The ASRock site should have information on updating your BIOS.
  • Updating your BIOS is not without risk. Be sure to follow directions carefully.
  • There is no guarantee that updating your BIOS will solve the issue you have described.
The graphics are likewise quite old, and 390.157 (2022) was the last official Nvidia driver that supported that card – using the nouveau driver is was a wise choice.
Going forward, you might consider using AMD graphics as driver modules typically provided directly via the GNU/Linux kernel. If an AMD RX580/RX590 (I use a RX580 myself) can still be found at a reasonable price, that may be supported for some years to come.
To help (English speaking) members assist you more easily, please prefix any commands with LC_ALL=C so that the output is in English.
Example:
LC_ALL=C <your-command-here>
Hello soundofthunder
thanks for your comments and the suggestion regarding the Graphics. I had indeed been thinking along the same lines but was not sure which type/make of graphics would work well under Linux and be compatible with my hardware, i.e. the mainboard. I find that graphics with an AMD RX580 (with 8 GB) are still available, new for approx. CHF 150 and second hand for approx. CHF 60. I would consider that a very reasonable investment since it will also benefit the performance of the photo editing software I am running under Manjaro Linux.
  1. Having said that and assuming that I shall have physically installed the new graphics card in my machine, what is the procedure to follow for the drivers? Will the Linux kernel (as you seem to suggest) identify automatically the new graphics and install the appropriate best driver ? Shall I need to deactivate/deinstall the current graphics drivers manually or will Linux just leave them alone once it has installed the driver for the new card?
  2. A related question is the following: My machine boots into GRUB which is located on the same disk as Manjaro Linux. On a different hard disk in the same machine I have an old Windows version (Windows 7) which I use sporadically for working with older versions of some programmes which do not run under the current Windows versions. This Windows installation I can start/access from the GRUB menu. Now, how is Windows 7 going to deal with the new graphics card? Is the graphics you suggest (RX580) within reach of the drivers contained in Windows 7 or shall I have to install the Windows graphics drivers manually from another source (say AMD)? What if Windows 7 crashes when starting with the new graphics? Any suggestions?
  3. Since your are familiar with the RX580, in the current offers for new cards I find that there are two versions of this graphics namely Product numbers VA5815RF82 and VA5815RQ82 respectively. I am unable to see a difference in the technical specs, as far as they are shown on the websites of the stores. Do you happen to know what the difference is and whether it would matter in my case.
Thanks for assisting me with this matter.
Rudolf
If you use nouveau driver now and change to AMD graphics, nothing is needed, just change hardware, it will be supported at new boot right from the start as the drivers are included in the kernel.
Hi Rudolf, I’m still a NVIDIA user, but that might change in the future, so I had a rapid look and the technical specs are indeed the same!
What changes between both cards seems to be the video outputs:
  • For the VA5815RF82, 1x HDMI, 1x DisplayPort, 1x DVI-D.
  • For the VA5815RQ82, 1x HDMI, 2x DisplayPort.
So you will have to choose regarding the kind of screens you own.
Of course, double-check by yourself with the seller before buying, that’s only the results of a quick search…
To change a GPU from NVIDIA to AMD in Windows (any versions), I would do the following if it was my PC (because it’s not so easy as when you are using the free drivers with Linux):
  • 1: Download the latest driver here: Radeon™ RX 580 Drivers and Downloads - Latest Version for Windows 7. There is a pro version which might be enough if you are only doing CAD, video editing, animation or graphic design, and a “gamer” one with all the bell and whistles (Adrenalin Edition), so again you have to choose what is the best for you.
  • 2: Download this utility here to really clean the NVIDIA driver: Download Display Driver Uninstaller (DDU) 18.1.6.2.
  • 3: Download the driver and the utility from Manjaro, and move both on your Windows 7 desktop with the file manager. So you will not have to go on the Web with an outdated web browser…
  • 4: Start Windows in safe mode. You will have to quickly tap “F8” on your keyboard after selecting it in the Grub menu. Here is a video to help in case: How To Start Windows 7 In Safe Mode [Tutorial].
  • 5: Click on the DDU utility from your desktop of Windows 7 in safe mode and select the third option “Clean and shutdown (For installing a new graphic card)”.
  • 6: Once the cleaning is done and the computer is shut down, remove the Ethernet cable! That will assure that Windows doesn’t install a generic and outdated AMD driver later…
  • 7: Touch something grounded to the floor or metallic to remove any static electricity risking to destroy your components, and replace your NVIDIA GPU with your shiny new AMD card. You can also take this occasion to clean any dust in your PC. Avoid the vacuum cleaner, a brush and a compressed air can are more than enough…
  • 8: Once everything is fixed in place, and still WITHOUT the Ethernet cable connected, start the PC and log into Windows 7. Don’t be afraid if the display is big and ugly, having uninstalled the NVIDIA drivers will made surely Windows use a standard VGA one, but that will be good enough.
  • 9: Click the AMD driver on your desktop, install it and reboot. Connect back the Ethernet cable and you should be able to enjoy your new AMD GPU in Windows 7 too!
All least, that what is supposed to happen, and even if it always has for me, I’m not taking any responsability if it doesn’t, we are talking about Windows, after all :wink:
As said in the previous message, it won’t be as complicated with Linux, as long as you are using the Nouveau driver for your actual NVIDIA card. On your next boot to Manjaro, your AMD card should be working “out-of-the-box”!
Hope this help, and good luck if you decide to do this GPU swap!
Thanks to all of you for these very exhaustive and precise suggestions.
Once I am done I’ll let you know how it went.
Rudolf
