Quick rundown of events:
Been using Manjaro KDE Plasma Desktop without issue for about 6 months.
Performed an update of drivers through Package Manager, after rebooting I only see a black screen.
Decide to do a fresh install using Proprietary Drivers, NVIDIA Graphics Card.
Everything appears to install fine, including using the Live USB with Proprietary Drivers, go to login to my new account and I am again greeted with a black screen with the Manjaro Hello window and mouse cursor.
Can open Firefox through the Manjaro Hello window, however no other GUI elements are visible, but can access TTY using CTRL + ALT + F3.
Reinstalled Manjaro again, this time using Open Source Drivers. Everything installs fine and I am able to login and access all GUI elements. However my entire PC is very laggy, video + audio not syncing and GUI elements freezing for several seconds.
I have attempted to manually remove and install NVIDIA drivers using the mhwd tool, essentially whenever the Proprietary Drivers are installed the GUI does not load.
Currently I have done a reinstall with Proprietary Drivers using a fresh Live USB with the Manjaro Vulcan 23.1.3 KDE Plasma Desktop ISO downloaded from here: Manjaro Downloads, and I am now using the Live USB for troubleshooting after running manjaro-chroot -a.
Please let me know if any more information would be of use.
[manjaro /]# sudo inxi --admin --verbosity=8 --filter --no-host --width --repos
Kernel: 6.6.10-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_GB keytable=gb tz=UTC
misobasedir=manjaro misolabel=MANJARO_KDE_2313 quiet systemd.show_status=1
splash driver=nonfree nouveau.modeset=0 i915.modeset=1 radeon.modeset=1
Desktop: KDE Plasma v: ERR-101 tk: Qt v: 5.15.12 wm: kwin_x11 dm: N/A
Type: Desktop Mobo: ASUSTeK model: ROG STRIX B450-F GAMING II v: Rev 1.xx
serial: <filter> UEFI: American Megatrends v: 4007 date: 12/08/2020
System RAM: total: 16 GiB available: 15.51 GiB used: 4.51 GiB (29.1%)
Device-1: DIMM_A1 type: no module installed
Device-2: DIMM_A2 type: no module installed
Device-3: DIMM_B1 type: DDR4 detail: synchronous unbuffered (unregistered)
size: 8 GiB speed: 2133 MT/s volts: curr: 1.2 min: 1.2 max: 1.2 width (bits):
data: 64 total: 64 manufacturer: Corsair part-no: CMW16GX4M2C3200C16
serial: N/A
Device-4: DIMM_B2 type: DDR4 detail: synchronous unbuffered (unregistered)
serial: N/A
Slot: 0 type: PCIe lanes: 1 status: available length: short volts: 3.3
bus-ID: 00:1f.7
Slot: 1 type: PCIe lanes: 16 status: in use length: long volts: 3.3
bus-ID: 00:03.1 children: 1: 09:00.0 class-ID: 0300 type: display 2: 09:00.1
class-ID: 0403 type: audio
Slot: 2 type: PCIe lanes: 1 status: available length: short volts: 3.3
bus-ID: 00:1f.7
Slot: 3 type: PCIe lanes: 16 status: available length: long volts: 3.3
bus-ID: 00:1f.7
Slot: 4 type: PCIe lanes: 1 status: available length: short volts: 3.3
bus-ID: 00:1f.7
Slot: 5 type: PCIe lanes: 16 status: available length: long volts: 3.3
bus-ID: 00:1f.7
Info: model: AMD Ryzen 7 2700X socket: AM4 bits: 64 type: MT MCP arch: Zen+
gen: 2 level: v3 note: check built: 2018-21 process: GF 12nm
family: 0x17 (23) model-id: 8 stepping: 2 microcode: 0x800820D
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 768 KiB desc: d-8x32 KiB; i-8x64 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB
desc: 2x8 MiB
Speed (MHz): avg: 2450 high: 3700 min/max: 2200/3700 boost: enabled
base/boost: 3700/4350 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.2 V ext-clock: 100 MHz cores: 1: 2200 2: 2200 3: 3700 4: 2200
5: 2200 6: 2200 7: 2200 8: 2200 9: 3200 10: 2200 11: 2200 12: 2200 13: 3700
14: 2200 15: 2200 16: 2200 bogomips: 118215
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2
sse4a ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate]
vendor: Micro-Star MSI driver: nvidia v: 545.29.06 alternate: nouveau
non-free: 545.xx+ status: current (as of 2023-11; EOL~2026-12-xx)
arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-2023 pcie:
gen: 3 speed: 8 GT/s lanes: 4 link-max: gen: 4 speed: 16 GT/s lanes: 16
bus-ID: 09:00.0 chip-ID: 10de:2504 class-ID: 0300
Display: server: X.org v: 1.21.1.10 with: Xwayland v: 23.2.3
compositor: kwin_x11 driver: X: loaded: N/A failed: nvidia gpu: nvidia
display-ID: :0
Monitor-1: Unknown-1 size-res: N/A modes: 1024x768
API: EGL v: 1.5 platforms: device: 1 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: swrast inactive: wayland,x11,device-0
API: OpenGL v: 4.5 vendor: mesa v: 23.3.3-manjaro1.1 note: incomplete (EGL
sourced) renderer: llvmpipe (LLVM 16.0.6 256 bits)
Device-1: NVIDIA GA106 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 4 link-max:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 09:00.1 chip-ID: 10de:228e
class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0e:00.3
chip-ID: 1022:1457 class-ID: 0403
Device-3: Texas Instruments PCM2902 Audio Codec
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-2:2 chip-ID: 08bb:2902 class-ID: 0300
API: ALSA v: k6.6.10-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.0 status: n/a (root, process) with:
Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 03:00.0
Local Storage: total: 6.4 TiB used: 9.38 GiB (0.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
family: BarraCuda 3.5 (SMR) size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: HDD rpm: 7200
serial: <filter> fw-rev: 0001 temp: 36 C
SMART: yes state: enabled health: PASSED on: 21622h+28m+21.216s
cycles: 2015 read: 8.13 TiB written: 10.47 TiB Pre-Fail: end-to-end: 49
threshold: 99 alert: FAILING_NOW attribute: Spin_Retry_Count value: 100
worst: 100 threshold: 97
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WDS100T2B0B-00YS70 family: WD Blue / Red / Green SSDs size: 931.51 GiB
block-size: physical: 512 B logical: 512 B sata: 3.3 speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 00WD temp: 33 C
SMART: yes state: enabled health: PASSED on: 2y 171d 0h cycles: 1980
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD40NDZW-11MR8S1 family: Elements / My Passport (USB, AF)
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 sata: 3.1 speed: 6.0 Gb/s
tech: HDD rpm: 5400 serial: <filter> fw-rev: 4008 drive-rev: 02.01A02
temp: 28 C
SMART: yes state: enabled health: PASSED on: 144d 21h cycles: 25
ID-4: /dev/sdd maj-min: 8:48 vendor: SanDisk model: USB 3.2Gen1
size: 28.64 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 3.0
spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: 1.00
ID-1: / raw-size: 922.42 GiB size: 906.86 GiB (98.31%) used: 9.38 GiB (1.0%)
fs: ext4 block-size: 4096 B dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: 7e3f72b5-6fc3-4cef-934e-d8ebcb6b2c53
used: 296 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sdb1 maj-min: 8:17
label: N/A uuid: 8074-C4E6
ID-1: /dev/sdb3 maj-min: 8:19 size: 8.8 GiB fs: swap label: swap
uuid: acae7072-dd1d-49bf-a459-1a9f28235522
ID-2: /dev/sdc1 maj-min: 8:33 size: 3.64 TiB fs: ext4 label: Backup
uuid: f5ac904f-6b30-466c-b865-1158d125efc3
ID-3: /dev/sdd1 maj-min: 8:49 size: 3.65 GiB fs: N/A label: N/A uuid: N/A
ID-4: /dev/sdd2 maj-min: 8:50 size: 4 MiB fs: N/A label: MISO_EFI
uuid: B5B6-A7FC
Hub-2: 1-2:2 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2815
Device-1: 1-2.2:4 info: Corsair Gaming SCIMITAR PRO RGB Mouse
type: mouse,HID driver: corsair,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 300mA
chip-ID: 1b1c:1b3e class-ID: 0300 serial: <filter>
Hub-3: 1-2.3:5 info: Corsair Gaming USB2.0 Smart Port ports: 2 rev: 2.0
chip-ID: 1b1c:1b2c class-ID: 0900
Device-1: 1-2.3.1:7 info: Corsair Gaming MM800 RGB POLARIS type: HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1b1c:1b3b class-ID: 0300
serial: <filter>
Device-2: 1-2.4:6 info: Corsair K70 RGB MK.2 Mechanical Gaming Keyboard
type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
chip-ID: 1b1c:1b49 class-ID: 0300 serial: <filter>
Device-3: 1-8:3 info: ASUSTek AURA MOTHERBOARD type: HID
lanes: 1 mode: 1.1 power: 100mA chip-ID: 0b05:18a3 class-ID: 0300
serial: <filter>
Hub-4: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-5: 2-2:2 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0815
Device-1: 2-3:3 info: Western Digital My Passport 2627 type: mass storage
driver: usb-storage interfaces: 1 rev: 3.1 speed: 5 Gb/s (596.0 MiB/s)
lanes: 1 mode: 3.2 gen-1x1 power: 896mA chip-ID: 1058:2627 class-ID: 0806
serial: <filter>
Device-2: 2-4:4 info: SanDisk Ultra type: mass storage driver: usb-storage
interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1
power: 896mA chip-ID: 0781:5581 class-ID: 0806 serial: <filter>
Hub-6: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-2:2 info: Texas Instruments PCM2902 Audio Codec type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
Hub-7: 4-0:1 info: super-speed hub ports: 4 rev: 3.0
System Temperatures: cpu: 43.0 C mobo: 34.0 C
Fan Speeds (rpm): cpu: 4500 case-1: 0 case-2: 0 case-3: 0
Power: 12v: 10.14 5v: N/A 3.3v: N/A vbat: 3.21
Packages: pm: pacman pkgs: 1120 libs: 318 tools: pamac pm: flatpak pkgs: 0
1: https://mirrors2.manjaro.org/stable/$repo/$arch
2: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
3: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 355
1: cpu: 100% command: ps pid: 35372 mem: 4.00 MiB (0.0%)
2: cpu: 9.7% command: firefox pid: 33276 mem: 716.4 MiB (4.5%)
3: cpu: 2.9% command: xorg pid: 32686 mem: 109.2 MiB (0.6%)
4: cpu: 2.0% command: plasmashell pid: 32842 mem: 547.8 MiB (3.4%)
5: cpu: 2.0% command: firefox pid: 33544 mem: 253.2 MiB (1.5%)
Memory top: 5 of 355
1: mem: 716.4 MiB (4.5%) command: firefox pid: 33276 cpu: 9.7%
2: mem: 547.8 MiB (3.4%) command: plasmashell pid: 32842 cpu: 2.0%
3: mem: 253.2 MiB (1.5%) command: firefox pid: 33544 cpu: 2.0%
4: mem: 235.6 MiB (1.4%) command: kwin_x11 pid: 32803 cpu: 1.8%
5: mem: 196.9 MiB (1.2%) command: firefox pid: 34959 cpu: 0.4%
Processes: 355 Uptime: 16m wakeups: 0 Init: systemd v: 255 default: graphical
tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6 Shell: N/A (sudo)
running-in: pty pts/0 inxi: 3.3.31
[manjaro /]# mhwd
> 0000:09:00.0 (0300:10de:2504) Display controller nVidia Corporation:
NAME VERSION FREEDRIVER TYPE
video-nvidia 2023.03.23 false PCI
video-nvidia-470xx 2023.03.23 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
[manjaro /]# mhwd -li
> Installed PCI configs:
